+Lee Stewart Posted August 11, 2022 Share Posted August 11, 2022 46 minutes ago, TheBF said: While looking around for some information on local variables in Forth I found this huge repository of Forth related information maintained by Anton Ertl I believe at the Technical University of Vienna: Index of /forth (tuwien.ac.at) One of the cool things an archive of Forth Dimensions magazines and there is a quicksort done as one definition. Index of /forth/forth-dimensions (tuwien.ac.at) I slightly modified it for Camel99 Forth. This version sorts an array of characters. Spoiler \ FORTH DIMENSIONS jAN/FEB 1984 Vol5,No.5 QUICK SORT BY MARK PERCEL \ Ported to Camel99 Forth with small modification Brian Fox INCLUDE DSK1.TOOLS \ harness for CAMEL99 : 2OVER 3 PICK 3 PICK ; VARIABLE PIVOT \ changed from MIDDLE to PIVOT \ Replaced ROT ROT with -ROT \ Replaced NOT with 0= \ Replaced MYSELF with RECURSE : EXCHANGE ( adr adr -- ) 2DUP C@ SWAP C@ ROT C! SWAP C! ; : QSORT ( start len -- ) OVER + ( 'start 'end ) 2DUP 2DUP OVER - 2/ + C@ PIVOT ! BEGIN SWAP BEGIN DUP C@ PIVOT @ < WHILE 1+ REPEAT SWAP BEGIN DUP C@ PIVOT @ > WHILE 1- REPEAT 2DUP > 0= IF 2DUP EXCHANGE 1 -1 D+ THEN 2DUP > ( loop until partitions cross) UNTIL SWAP ROT 2OVER 2OVER - -ROT - < IF 2SWAP THEN 2DUP < IF RECURSE ELSE 2DROP THEN 2DUP < IF RECURSE ELSE 2DROP THEN ; FYI: I have used the Forth Dimensions repository on Forth.org for years. Also, do you know what the potential hit on the return stack would be by the recursion? ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 12, 2022 Author Share Posted August 12, 2022 Ah yes, I forgot they had one too. I only tested this on a 60 char string so I don't have data on the return stack depth. I just did a quick search and it was mentioned that under a worst case condition the partition might create one array of size 1 and another of n-1. That might be the worst case for recursion. I am not sure. If we think about it a bit we need two addresses for each partitioning. The number of partitions would be what... 2^n ? So R stack depth would be 2(2^n) ? A little more research and the stack depth is worst case Log2(n) best case 1. 2 Quote Link to comment Share on other sites More sharing options...
Willsy Posted August 12, 2022 Share Posted August 12, 2022 13 hours ago, TheBF said: While looking around for some information on local variables in Forth [snipped]... In case it's of interest, I did yet another implementation of locals for TF back in February or so. It's only had minimal testing so far. https://github.com/Mark-Wills/TF-MegaLocals 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 12, 2022 Author Share Posted August 12, 2022 5 hours ago, Willsy said: In case it's of interest, I did yet another implementation of locals for TF back in February or so. It's only had minimal testing so far. https://github.com/Mark-Wills/TF-MegaLocals This is very neat. Did you have a chance to benchmark it against stack operators? 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 12, 2022 Share Posted August 12, 2022 Interesting Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 12, 2022 Author Share Posted August 12, 2022 While looking over the old Forth Dimensions magazines I found the original writeup by Dr. Eaker and his CASE statement for the CASE statement contest. He suggested that a code word called (OF) be created to optimize his case statement because OF in Forth compiles four words for each use of OF. ( OVER = IF DROP ) His assembler for 6809 was a bit hard for me to translate so I just made OVER= as a code word. With OVER= the case statement is 27% faster if you hit each case sequentially in a loop. It is 42% faster accessing the last case in a CASE statement! We save 2 bytes per OF as well. A pretty big win for little effort. It's probably not worth the effort to completely re-write (OF) as CODE. Spoiler \ ANS-Forth CASE statement \ Original by Chuck E. Eaker \ 9/80 FORTH DIMENSIONS II/3 PG 37 \ Ported to CAMEL99 Mar 7 2017 \ Added OVER= 27%..42% speedup, saves 2 bytes per OF use. HEX CODE OVER= ( n1 n2 -- ?) 8116 , \ *SP TOS CMP, 04C4 , \ TOS CLR, 1601 , 0704 , \ EQ IF, TOS SETO, ENDIF, NEXT, ENDCODE HERE : CASE ( -- 0 ) 0 ; IMMEDIATE : OF ( n -- ) POSTPONE OVER= POSTPONE IF POSTPONE DROP ; IMMEDIATE : ?OF ( flag -- ) POSTPONE OVER POSTPONE IF POSTPONE DROP ; IMMEDIATE : ENDOF ( -- ) POSTPONE ELSE ; IMMEDIATE : ENDCASE ( -- ) POSTPONE DROP BEGIN ?DUP WHILE POSTPONE THEN REPEAT ; IMMEDIATE SPACE HERE SWAP - DECIMAL . .( bytes) 4 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 12, 2022 Share Posted August 12, 2022 (edited) I thought I've seen OF in TF? Or somewhere..hmmm...I could of sworn.. maybe it was in bill's Forth, is that GForth? But I know I've seen it..oh come on... where did I see that... Edited August 12, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 12, 2022 Author Share Posted August 12, 2022 CASE 1 OF ." #1" ENDOF 2 OF ." #2" ENDOF 3 OF ." #3" ENDOF ." HUH?" ENDCASE 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 12, 2022 Author Share Posted August 12, 2022 So of course I could not resist trying to make it smaller and faster. It took me some trial and error to get the stack dropping correct for the CODE word (OF). TOS POP, is just a DROP in my system. CODE (OF) *SP TOS CMP, NE IF, TOS POP, *IP IP ADD, \ do Forth branch NEXT, ENDIF, TOS POP, TOS POP, *IP INCT, \ no branch. Advance IP NEXT, ENDCODE (OF) is just special version of ?BRANCH and so we need to use AHEAD to record the memory address and put a place holder in the code for the jump offset. The jump offset is filled in later by ENDOF which is just an alias for ELSE This makes the final definition look like this: : OF ( n -- ) POSTPONE (OF) AHEAD ; IMMEDIATE Now we are saving 6 bytes on every use of the word OF. In a 10 item case statement that is 60 bytes. In terms of performance this version is 55% faster hitting each case in a 10 selection case statement and 81% faster seeking to the last item in the 10 item case statement. And the code size to add the Eaker Case statement is 4 bytes smaller than the way I did it in hi level Forth only. I think I will take Dr. Eaker's advice on this one. 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 12, 2022 Share Posted August 12, 2022 Oh..ok .I see Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 13, 2022 Author Share Posted August 13, 2022 5 hours ago, TheBF said: So of course I could not resist trying to make it smaller and faster. It took me some trial and error to get the stack dropping correct for the CODE word (OF). TOS POP, is just a DROP in my system. Edit: Tested this on some real programs and found out that it did not work with *IP INCT, but only with *IP 2 AI, Not sure why. ? For another day. It seems reliable like this. 5 hours ago, TheBF said: CODE (OF) *SP TOS CMP, NE IF, TOS POP, *IP IP ADD, \ do Forth branch NEXT, ENDIF, *IP 2 AI, TOS POP, TOS POP, NEXT, ENDCODE \ This makes the final definition look like this: : OF ( n -- ) POSTPONE (OF) AHEAD ; IMMEDIATE (OF) is just special version of ?BRANCH and so we need to use AHEAD to record the memory address and put a place holder in the code for the jump offset. The jump offset is filled in later by ENDOF which is just an alias for ELSE. Now we are saving 6 bytes on every use of the word OF. In a 10 item case statement that is 60 bytes. In terms of performance this version is 55% faster hitting each case in a 10 selection case statement and 81% faster seeking to the last item in the 10 item case statement. And the code size to add the Eaker Case statement is 4 bytes smaller than the way I did it in hi level Forth only. I think I will take Dr. Eaker's advice on this one. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 13, 2022 Author Share Posted August 13, 2022 So many options... I now realize I was not measuring the total size of the case statement code. I was not including the CODE definition of (OF). duh!. I came back to this to stare at it and realized that I might be able to use subtraction rather than compare. This lets me refill the TOS of stack register after the subtraction and use the carry flag for the logic. I do this in ?BRANCH in the kernel. I tried it and it works. CODE (OF) *SP TOS SUB, TOS POP, \ MOV changes L> A> EQ flags, BUT does not change carry flag :-) NC IF, *IP IP ADD, \ do Forth branch NEXT, ENDIF, *IP 2 AI, \ no branch. Advance IP TOS POP, NEXT, ENDCODE This version uses 128 bytes of dictionary for the code but reduces each call to OF to 2 bytes. Then I realized with compile time address math, I could branch into the 2ND instruction of ?branch & uses what's there! HEX CODE (OF) *SP TOS SUB, ' ?BRANCH @ CELL+ @@ B, ENDCODE This version uses 120 bytes of dictionary but each call to OF is 4 bytes because DROP needs be compiled by OF This was my original thinking making a super instruction OVER= CODE OVER= ( n1 n2 -- ?) *SP TOS CMP, TOS CLR, EQ IF, TOS SETO, ENDIF, NEXT, ENDCODE 126 bytes of dictionary but calling OF consumes 6 bytes. The Forth only version uses 108 bytes of dictionary but calling OF uses up 8 bytes. That is really expensive so making that 2 bytes per call is real improvement even if speed was the same. So I think I have exhausted this and I like the reworked version at the top. I need to really beat it up now. 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 14, 2022 Author Share Posted August 14, 2022 Final Version of (OF) I used my LINKER project as a real world test because it has a 16 item case statement and is doing some fancy stuff. Sure enough it would compile and run fine with the vanilla Forth CASE statement but would fail with my various code versions. I re-worked OVER= a bit and that worked but the program size savings were not good enough for me. So I combined the working OVER= with a branch into fast RAM to run ?BRANCH and that proved to be a winner. The total implementation of the CASE statement with this addition is only 18 bytes bigger than using all Forth (126 vs 108 bytes) HEX CODE (OF) 6116 , \ *SP TOS CMP, ( OVER = ) 04C4 , \ TOS CLR, 1601 , \ EQ IF, 0704 , \ TOS SETO, \ ENDIF, 0460 , ' ?BRANCH @ , \ ' ?BRANCH @ @@ B, ENDCODE So now with all the smoke cleared I can show this table of results with a 10 item case statement tested in two scenarios SIZE Saving 1000X hit all 3000x Hit last --------------------------------------------------------------------- FORTH 0 14.3 secs 7.3 secs OVER= 20 bytes 11.2 secs 5.1 secs (OF) 40 bytes 10.5 secs 4.6 secs So if you use 5 or more items in a CASE statement you are ahead on size and speed is also improved. 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 23, 2022 Author Share Posted August 23, 2022 I noodling on what the best way to do background sounds in a video Game in Forth. I tried it first with the multi-tasker and it worked ok but I found that to make things smoother I needed to change the definition of SND!. It was: HEX : SND! ( c -- ) 8400 C! ; Going forward it is: HEX : SND! ( c -- ) PAUSE 8400 C! ; That little pause causes all the words in the sound library to behave much better when multi-tasking. I should have caught that as this is primary "rule of thumb" that came from Poly-Forth. All I/O operations should pass control to another task. I have seen PAUSE placed before the I/O operation in other systems so I am just following the example. It could work after the C! as well. Of course when you drink your own Kool-Aid be prepared for it to sometimes taste bad. I also found that my task "restarter" called RESTART was only resetting the task's return stack. This had worked in the past but if I restarted a task while it was still running it piled up new things onto it's data stack and would eventually crash. For example if I assigned a sound to a task and then triggered the task to run the sound in the background to drop a bomb and whistle. This was of those conditions that takes some time and so you could shoot again while the sound was still running. So once I debugged my system a little more it worked quite well. I put these ideas into the simple B52 program for testing. I added a 2nd task that tries (badly) to simulate fire where the bombs hit. Spoiler \ translation of SteveB52 from Extended BASIC to Forth \ Original concept on Atariage.com \ Uses Multi-tasking for background sound \ INCLUDE DSK1.TOOLS INCLUDE DSK1.MARKER \ need LOCK from this file INCLUDE DSK1.CASE INCLUDE DSK1.RANDOM INCLUDE DSK1.GRAFIX INCLUDE DSK1.DIRSPRIT INCLUDE DSK1.AUTOMOTION INCLUDE DSK1.RANDOM INCLUDE DSK1.SOUND INCLUDE DSK1.VALUES INCLUDE DSK1.MALLOC INCLUDE DSK1.MTASK99 \ some high level multi-tasker commands using primitives : NEWTASK ( -- addr) USIZE MALLOC DUP FORK ; \ create task area in LOW RAM : STOP ( -- ) MYSELF SLEEP PAUSE ; \ go to sleep and pass control \ names for the background tasks \ we will create the task when the program starts 0 VALUE BOMBER 0 VALUE FIRE \ ENDIF is easier to understand for Non-Forth speakers : ENDIF POSTPONE THEN ; IMMEDIATE \ scoreboard manager VARIABLE HITS VARIABLE MISSES : .HITS 6 0 AT-XY HITS @ U. ; \ U. prints numbers unsigned : .MISSES 28 0 AT-XY MISSES @ U. ; : .SCORE .HITS .MISSES ; \ numbered sprites like XB 0 CONSTANT #1 1 CONSTANT #2 \ name the characters for clarity DECIMAL 124 CONSTANT bomber 128 CONSTANT bomb 132 CONSTANT building 133 CONSTANT ground 134 CONSTANT crater 136 CONSTANT fire HEX CREATE flame0 01C2 , 2246 , 2434 , 7EDE , CREATE flame1 40A0 , 3018 , 083E , 2FFA , CREATE flame2 020F , 0C0C , 1038 , 79FF , CREATE flame3 0000 , 2010 , 1438 , 6ECF , DECIMAL \ animation sequence CREATE FLAMES flame0 , flame1 , flame2 , flame3 , \ choose a random flame pattern : ]FLAME ( n -- addr) CELLS FLAMES + ; : [RND]FLAME ( -- addr) 4 RND ]FLAME ; : BURNTASK 0 ( 1st flame #) BEGIN [RND]FLAME @ fire CHARDEF fire SET# DUP 9 1 COLOR 900 RND TICKS DUP 7 1 COLOR 900 RND TICKS 11 1 COLOR 600 RND TICKS AGAIN ; DECIMAL : InitGraphics S" 2810383838100000000000000000000000000000000000000000000000000000" bomb CALLCHAR ( 80 char line limit in DV80 files) S" 00000080C0E070FFFF070F1C3800000000000000000000FEFFC0000000000000" bomber CALLCHAR S" FE929292FE929292" building CALLCHAR S" FFFFFFFF00000000" ground CALLCHAR S" 8183E7FF00000000" crater CALLCHAR S" 01C2224624347EDE" fire CALLCHAR 2 MAGNIFY AUTOMOTION 2 MOVING ; : ScrInit ( fg bg -- ) DUP SCREEN \ use bg color for screen DELALL 1 17 2SWAP COLORS \ does the range of color sets 1..19 fire SET# 9 1 COLOR CLEAR ; : FlyPlane ( -- ) bomber 13 1 12 #1 SPRITE 0 16 #1 MOTION ; : DrawGround ( -- ) 0 20 ground 32 HCHAR ; : SkyScraper ( col row ) building OVER 20 SWAP - 0 MAX VCHAR ; : RNDY ( -- n) 7 RND 14 + ; : DrawCity ( -- ) DrawGround 22 8 DO I RNDY SkyScraper LOOP ; : STARTUP 16 2 ScrInit HITS OFF MISSES OFF 10 23 AT-XY ." Foxy's B52" 0 0 AT-XY ." Hits:" .HITS 20 0 AT-XY ." Misses:" InitGraphics DrawCity FlyPlane ; : VC+! ( n Vaddr -- ) TUCK VC@ + SWAP VC! ; \ add 'n' to VDP byte : DescendPlane #1 SP.X VC@ 250 > IF 1 #1 SP.X VC! \ reset sprite to left side 4 #1 SP.Y VC+! \ plane falls down 2 pixels ENDIF ; : 8/ ( n -- n' ) 3 RSHIFT ; \ divide by 8 : PIX>CHAR ( col row -- col' row') 8/ SWAP 8/ 1+ SWAP ; \ test if sprite is over a character that is not a blank (space) : COLLISION? ( spr# -- ?) POSITION PIX>CHAR GCHAR BL <> ; : DELSPRITE ( spr# -- ) DUP>R SP.Y 4 BL VFILL 0 0 R> MOTION ; \ volume fader : FADER ( speed -- ) \ fades down to -28 DB. Does not MUTE 29 0 DO I DB DUP TICKS \ MS passes to next task while it waits PAUSE LOOP DROP ; \ *************************************************************** \ background sounds \ : Whistler \ factored our as a word for testing. GEN4 MUTE ( make any previous bomb quiet) GEN1 4600 DUP HZ ( -- freq) -8 DB \ volume 400 0 \ finite # iterations with 10 HZ reduction DO ( freq) 20 - DUP HZ \ reduce freq in each loop. #2 COLLISION? IF LEAVE THEN LOOP MUTE ( freq) DROP ; : Exploder -2 NOISE 400 FADER 500 TICKS MUTE ; \ *************************************************************** : WAIT-COLLISION ( char -- ) BEGIN PAUSE #2 COLLISION? UNTIL ; : DIRECT-HIT fire VPUT HITS 1+! ; : RE-HIT BL VPUT VROW 1+! fire VPUT HITS 1+! ; : GROUND-HIT crater VPUT MISSES 1+! ; : END 2 8 ScrInit ." ** DONE ** " ; \ imitate BASIC'S END :) : DRAW-DAMAGE #2 POSITION PIX>CHAR 2DUP AT-XY \ set cursor for (EMIT) GCHAR CASE building OF DIRECT-HIT ENDOF fire OF RE-HIT ENDOF ground OF GROUND-HIT ENDOF ENDCASE ; \ This background task must end with STOP. It puts itself to sleep \ and passes control back to the console task. : DropBomb \ char colr x y spr# bomb 11 #1 POSITION 12 + #2 SPRITE \ make sprite at bomber position 24 0 #2 MOTION \ fall with automotion Whistler \ start the falling bomb sound 0 0 #2 MOTION \ stop bomb sprite when whistler collides #2 DELSPRITE Exploder \ run the explosion STOP ; HEX \ multi-tasking friendly KEY with no cursor : GKEY ( -- c | 0) BEGIN PAUSE DescendPlane KEY? ?DUP UNTIL ; DECIMAL : GameLoop DrawCity FlyPlane BEGIN GKEY BL = IF BOMBER RESTART WAIT-COLLISION DRAW-DAMAGE ENDIF PAUSE .SCORE #1 COLLISION? ?TERMINAL OR UNTIL 0 0 #1 MOTION #2 DELSPRITE ; : RUN NEWTASK TO BOMBER NEWTASK TO FIRE ['] DropBomb BOMBER ASSIGN ['] BURNTASK FIRE ASSIGN FIRE WAKE GRAPHICS \ switch VDP mode MULTI \ enable multi-tasking BEGIN STARTUP GameLoop 8 10 AT-XY ." Game Over" 12 8 AT-XY ." Play again? (Y/N)" KEY [CHAR] N = UNTIL SINGLE \ turn off multi-tasking END ; \ /\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\ Next I will re-worked some code to generate sound lists in VDP RAM and let the ISR play them. My feeling is this may be good for some situations but like Sprite automotion it may also make control harder. b52-mtask-sound.mp4 5 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted August 23, 2022 Share Posted August 23, 2022 Careful!🪂 My building has S.A.M.S..🚀 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 24, 2022 Author Share Posted August 24, 2022 While reading comp.lang.forth I found this version of ROLL published by Stephen Pelc of MPE. Looks like it would be faster than the recursive version on very deep stacks. \ ROLL.FTH from MPE posted on comp.lang.forth \ modified for Camel99 Forth DUP>R : ROLL \ nn..n0 n -- nn-1..n0 nn ; 6.2.2150 DUP>R PICK SP@ DUP CELL+ R> 1+ CELLS CMOVE> DROP ; 3 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 25, 2022 Share Posted August 25, 2022 On 8/23/2022 at 9:11 PM, TheBF said: While reading comp.lang.forth I found this version of ROLL published by Stephen Pelc of MPE. Looks like it would be faster than the recursive version on very deep stacks. \ ROLL.FTH from MPE posted on comp.lang.forth \ modified for Camel99 Forth DUP>R : ROLL \ nn..n0 n -- nn-1..n0 nn ; 6.2.2150 DUP>R PICK SP@ DUP CELL+ R> 1+ CELLS CMOVE> DROP ; That's pretty cool. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 26, 2022 Author Share Posted August 26, 2022 I just found Lee's link to the WHTECH ftp site and there I found the Wycove Forth manual. It's really enjoyable to read through the manual for tidbits. I found this code snippet: (~16 bytes without header) : (OF) OVER = IF DROP 1 ELSE 0 THEN ; Which is used to make CASE statements smaller. LOL. I guess I should have thought of that but the one I landed on is faster and a bit smaller too so no worries. 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 29, 2022 Author Share Posted August 29, 2022 (edited) OK so here's the deal. Reading the Wycove Forth manual I read about the BLOCK editor that uses the 40x24 line screen in it's natural format. I like that idea. It's what we have on the stock system. My little Forth system would benefit from a resident editor but I want to use DV80 text files. I have the monster ED99 that needs the SAMS card and all but what about something for the guy with only 32K expansion? The ANS Forth file word set alone consumes 1200 bytes! Not needed for and editor. I have an editor that lets you edit the screen like a big buffer. ( I even have one that works like the Wycove editor on BLOCKs in a DF128 file) I needed a smallish file/memory manager, to read a text file into low ram in a compressed format and save it back out. I have that now in 590 bytes. It can load the biggest source file in my system, the assembler (5217 bytes), into Low RAM in 1.2 seconds and still have 2K left over. It can seek to the last line, line 190, in .1 seconds. This is done using counted strings as a poor man's single linked list. Compact but still quite fast. It will slow down when I have to insert strings into it but the plan so far, is go VI style and only edit in the screen buffer and then update the data buffer when you commit the line of text ( or maybe the whole screen) to the data buffer. Should be acceptable. Now I have marry these two things, the editor and the 590 byte file manager. Target is to make the editor use 2K bytes. It's gonna be tight. Spoiler \ textfiles.fth minimal text file access words Aug 27 2022 Brian Fox \ The ANS Forth FILE wordset use 1200 bytes in our little TI-99. \ This minimalist system takes treats PAB addresses like handles. \ This version compiles file data as counted strings in low RAM. \ This is a fast way to seek to a line while having variable length data. NEEDS .S FROM DSK1.TOOLS NEEDS ELAPSE FROM DSK1.ELAPSE HERE \ ===[ heap management ]==== \ low RAM is file buffer HEX 2000 CONSTANT BUFFER \ base address of the heap 2000 CONSTANT 8K \ max size of the heap DECIMAL \ variable H is our memory management pointer : HALLOT ( n --) H +! ; : HEAP H @ ; : HC, ( c --) HEAP C! 1 HALLOT ; \ compile c into heap \ ===[ PAB management ]==== \ PAB: pre-computes VDP PAB address for PAB with size PSZ (300) \ The PAB is 300 bytes and has the file buffer built in after the filename. : PAB: ( n -- ) CREATE PSZ * VDPTOP SWAP - , \ runtime: set the active PAB in the ^PAB variable DOES> @ ^PAB ! ; 1 PAB: #1 2 PAB: #2 3 PAB: #3 \ DV80 (text) file access modes (FAM) HEX 10 CONSTANT R/W \ read/write 12 CONSTANT W/O \ write only 14 CONSTANT R/O \ read only 16 CONSTANT W/A \ write append DECIMAL : FSIZE ( -- n ) HEAP BUFFER - ; : ?PAB ^PAB @ VDPTOP = ABORT" File #" ; : OPEN ( addr len fam -- ) 80 SWAP ?PAB FOPEN ?FILERR ; : CLOSE ( -- ) ?PAB 1 FILEOP ?FILERR VDPTOP ^PAB ! ; \ purge sets the heap to use addr and then erases it : PURGE ( addr len -- ) OVER H ! 0 FILL LINES OFF ; : NEXT$ ( addr -- addr' ) COUNT + ALIGN ; : LEN S" C@" EVALUATE ; IMMEDIATE \ syntax sugar : V$, ( Vaddr u -- ) \ compile VDP stack string as counted string in HEAP TUCK \ tuck a copy of length under Vaddr DUP HC, \ compile the length in heap HEAP SWAP VREAD \ copy VRAM to RAM HALLOT ALIGN ; \ Allocate the heap space, align for TMS9900 : FDATA ( -- Vaddr len ) [PAB FBUFF] V@ [PAB CHARS] VC@ ; \ usage: #1 S" DSK1.MYFILE" READ-FILE : READ-FILE ( addr len -- ) BUFFER 8K PURGE R/O OPEN LINES OFF BEGIN 2 FILEOP 0= WHILE FDATA V$, LINES 1+! REPEAT CLOSE ; : NTH ( addr n -- Caddr) 0 ?DO NEXT$ LOOP ; \ seek to nth line : WRITELN ( addr len -- ior) DUP [PAB CHARS] VC! \ set the record length [PAB FBUFF] V@ SWAP VWRITE \ write addr,len to Pab file buffer 3 FILEOP ; \ hit the system \ usage: #1 S" DSK1.MYFILE" WRITE-FILE : WRITE-FILE ( addr len -- ) W/O OPEN BUFFER ( caddr ) BEGIN DUP LEN WHILE DUP COUNT WRITELN ?FILERR NEXT$ REPEAT DROP CLOSE ; DECIMAL HERE SWAP - CR . .( bytes) \ test code \ : PRINT ( $ -- ) COUNT ( C/L@ 1- MIN) CR TYPE ; \ : .HEAP ( -- ) BUFFER BEGIN DUP LEN WHILE DUP PRINT NEXT$ REPEAT ; Edited August 29, 2022 by TheBF comment removed 6 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 31, 2022 Share Posted August 31, 2022 (edited) How bout a multi cross editor that saves in both formats? I like snp with it's gradual progress in saving it's screens as dv80 or program image. I hope to get it completed one day. The snp dv80 is basically just a screenshot saved, while the complete DATA of all screens saved end up as program image saves because of the amount of data to save. But, maybe I should add an option for Saving a screenshot as DF128 as well, or maybe adding a menu and let the user pick from a selection of predefined saves / loads for the screen wanting to be saved or loaded.. I suppose I need to add "DISK DIRECTORY" ability to. Geez Edited August 31, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 31, 2022 Author Share Posted August 31, 2022 3 hours ago, GDMike said: How bout a multi cross editor that saves in both formats? I like snp with it's gradual progress in saving it's screens as dv80 or program image. I hope to get it completed one day. The snp dv80 is basically just a screenshot saved, while the complete DATA of all screens saved end up as program image saves because of the amount of data to save. But, maybe I should add an option for Saving a screenshot as DF128 as well, or maybe adding a menu and let the user pick from a selection of predefined saves / loads for the screen wanting to be saved or loaded.. I suppose I need to add "DISK DIRECTORY" ability to. Geez Could be done of course, but saving twice might slow down the user experience. Another approach would be to make a easy to use file conversion utility or offer a "save as" option with file format selector as we see on most modern programs. Yes a directory viewer is essential for these type of tools. I am going to add one to this editor as well. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 31, 2022 Author Share Posted August 31, 2022 So my "ultra-tiny" editor kind of went out the window once I started playing. I will come back to that later. I went all-in on the VI idea and have a working skeleton that lets me browse a file in "command" mode using VI keyboard mapping. I never used VI much but it is an interesting idea for a compact editor. The Forth interpreter is used for the VI command line which means numeric parameters must have a space between them and the command. Not a big compromise IMHO. At moment if you enter a bad command you bounce out to the Forth command line. I will change that if this becomes a stand alone program. The OTHER interesting idea to me is, can I use the screen as the ONLY editing buffer? I have the file contents in VDP RAM for each line. It should be possible. I need to develop some code to transfer lines of the screen to the correct place in the counted string array in memory. Not there yet. It might be tricky. We shall see. The video shows progress so far. For preliminary purposes here I am limiting the file lines to 40 chars on the screen. The full length lines are in the buffer. Here is what the VI command line commands look like once you have the "domain specific language" created. \ vi style user commands interpreted by Forth : (Q) BLK/CYAN SCREEN LINECURS ; \ Common factor : x #1 FILENAME COUNT WRITE-FILE (Q) ABORT ; : q x (Q) ABORT ; : Q q ; : q! (Q) CR S" Not saved" TYPE ABORT ; : Q! q! ; : w #1 PARSE-NAME DUP 0= IF 2DROP FILENAME COUNT ( addr len) ELSE 2DUP FILENAME PLACE THEN WRITE-FILE ; : w! w ; \ There is no overwrite protection in this version : vi #1 PARSE-NAME 2DUP FILENAME PLACE DUP 0= IF 2DROP NEW ELSE READ-FILE THEN EDIT ; : VI vi ; ( alias upper case ) : G ( n -- ) TOPLINE ! LIST ; \ 123 G *MUST HAVE SPACE AFTER NO.* : 0 TOPLINE OFF LIST ; : $ LINES @ 1- G ; VI99-SKELETON.mp4 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 1, 2022 Author Share Posted September 1, 2022 Well that was painful. Insert/overwrite/delete into a counted string array without using variables took a lot of inter-active debugging. Now that I have the functions however I can use them for a tiny editor. I took the trouble to make the source code for the editor to stay within 40 columns. The new editor can hold all 345 lines in low ram using the counted string array. There is still a bug when I tried to paste the entire file into VI99 on Classic99 so more work to do, but the concept is working. I am not sure I am a fan yet of the VI method of operation but I will give it a try. There are still a lot of functions that I have not implemented but they are just more time on task. Here is the code so far. I need a break. Spoiler \ VI99.FTH DV80 editor for TI-99 \ Aug 26 2022 Brian Fox \ VI99 concepts: \ Use VI key mappings. \ Use Forth interpreter \ Read files into low ram \ Edit text directly in VDP RAM NEEDS DUMP FROM DSK1.TOOLS NEEDS #1 FROM DSK5.TEXTFILES NEEDS CASE FROM DSK1.CASE NEEDS RKEY FROM DSK1.RKEY NEEDS -TRAILING FROM DSK1.TRAILING NEEDS NOCASE FROM DSK1.NOCASE NEEDS MOVE FROM DSK1.MOVE UCASE ( case sensitive on ) NEEDS WORDLIST FROM DSK1.WORDLISTS HERE VOCABULARY EDITOR ONLY FORTH ALSO EDITOR DEFINITIONS \ future undo buffer in VDP RAM HEX 1000 CONSTANT UNDOBUFF DECIMAL VARIABLE INSERTING VARIABLE LINESTK VARIABLE LINE# VARIABLE TOPLINE VARIABLE STOL VARIABLE CMDMODE CREATE FILENAME 16 ALLOT \ ======================== \ Helpers : BETWEEN ( n lo hi -- ?) 1+ WITHIN ; : CLIP ( n lo hi -- n) ROT MIN MAX ; : ERASE ( addr len -- ) 0 FILL ; : BLANK ( addr len -- ) BL FILL ; : VBLANK ( vaddr len -- ) BL VFILL ; : VBLANKLN ( -- ) VPOS C/L@ VBLANK ; : HLINE ( col row -- ) >VPOS C/L@ [CHAR] __ VFILL ; : GETXY ( -- x y ) VROW 2@ ; : SAVECURS S" GETXY 2>R" EVALUATE ; IMMEDIATE : RESTCURS S" 2R> AT-XY" EVALUATE ; IMMEDIATE : PROMPT ( -- ) 0 23 AT-XY VBLANKLN ; : SCRLINE ( -- Vaddr) VROW @ C/L@ * ; : VTYPE ( $ len ) VPOS SWAP VWRITE ; : HOME 0 0 AT-XY ; \ clears top 21 lines : CLS ( -- ) HOME VTOP @ [ C/SCR @ C/L@ 2* - ] LITERAL VBLANK ; : LIST ( -- ) BUFFER TOPLINE @ NTH CLS SAVECURS 22 0 DO DUP C@ 0= IF [CHAR] ~ CPUT DROP ELSE DUP COUNT 39 MIN -TRAILING VTYPE THEN CR NEXT$ LOOP DROP RESTCURS ; \ cursor movement controls : TOPLINE+! ( n --) TOPLINE @ SWAP + 0 2000 CLIP TOPLINE ! ; : MOVESCR ( n --) TOPLINE+! LIST ; : CUP VROW @ 1- 0 MAX DUP 0= IF -1 MOVESCR THEN VROW ! ; : CDOWN VROW @ 1+ 21 MIN DUP 21 = IF 1 MOVESCR THEN VROW ! ; : CRGHT VCOL @ 1+ [ C/L@ 1- ] LITERAL MIN VCOL ! ; : CLEFT VCOL @ 1- 0 MAX VCOL ! ; : NEWLINE CDOWN VCOL OFF ; : EOL C/L@ 1- VCOL ! ; HEX : LINECURS 5F CURS ! ; : BARCURS 1E CURS ! ; : BOXCURS 1F CURS ! ; DECIMAL : INS/DEL INSERTING @ -1 XOR INSERTING ! INSERTING @ IF BARCURS ELSE LINECURS THEN ; \ "right of cursor" as a stack string : ROC ( -- VDPaddr len) SCRLINE C/L@ VCOL @ /STRING ; \ "left of cursor" as a stack string : LOC ( -- VDPaddr len) SCRLINE VCOL @ ; \ ======================= \ text manipulation : DELCHAR ( -- ) PAD C/L@ 2+ BLANK ROC TUCK 1 /STRING PAD SWAP VREAD PAD VPOS ROT VWRITE ; : PUSHRIGHT ( -- ) ROC TUCK PAD SWAP VREAD BL VPUT PAD VPOS 1+ ROT 1- VWRITE ; DECIMAL : '"' [CHAR] " EMIT ; : ."FILE" ( $ -- ) COUNT DUP 0= IF 2DROP S" new file" THEN PROMPT '"' TYPE '"' SPACE LINES @ . ." lines, " FSIZE . ." chars" ; \ ===[ "INSERT" MODE primitives ]=== : V$! ( Vaddr len addr -- ) 2DUP C! 1+ SWAP VREAD ; \ line# of the cursor : ELINE# ( -- n ) TOPLINE @ VROW @ + ; \ seek to the address of the ELINE# : ELINE$ ( line# -- Caddr) BUFFER SWAP NTH ; \ -trailing for a VDP string : V-TRAILING ( V$ len -- V$ len') 1- BEGIN 2DUP + VC@ BL = WHILE 1- REPEAT 1+ ; : SCREEN$ ( -- Vaddr len) SCRLINE 39 V-TRAILING 1 MAX ; \ open space for a string of len bytes \ return the HEAP address : MAKEROOM ( len line# -- addr) ELINE$ DUP>R ( len $ ) ( r: eline$) OVER R@ + 1+ ( len $ $+len+1 ) HEAP R@ - 0 MAX ( len $ $' size ) MOVE R> ; : OVERWRITE ( len line# -- addr) ELINE$ DUP>R DUP NEXT$ SWAP 2 PICK + 1+ HEAP OVER - 0 MAX 1+ MOVE R> ; : DELETELN ( line# -- ) ELINE$ DUP NEXT$ SWAP ( $2 $1) HEAP OVER C@ - 1+ MOVE ; \ store VDP string at addr in CPU RAM : INSERTLN ( Vaddr len ELINE# --) MAKEROOM V$! ; : PLACELN ( Vaddr len ELINE# --) OVERWRITE V$! ; \ ==================================== DECIMAL : INSERT-MODE BARCURS CMDMODE OFF BEGIN VPOS VC@ [CHAR] ~ = IF BL VPOS VC! THEN RKEY DUP BL [CHAR] ~ BETWEEN IF INSERTING @ IF PUSHRIGHT THEN (EMIT) ELSE CASE 3 OF DELCHAR ENDOF 4 OF INS/DEL ENDOF 8 OF CLEFT ENDOF 13 OF SCREEN$ ELINE# PLACELN NEWLINE ENDOF 15 OF CMDMODE ON BOXCURS EXIT ENDOF ENDCASE THEN AGAIN ; : GETCMD ( -- ) SAVECURS PROMPT [CHAR] : EMIT PAD DUP C/L@ 2- ACCEPT EVALUATE FILENAME ."FILE" RESTCURS ; DECIMAL 21 CONSTANT 1SCR 11 CONSTANT 1/2SCR HEX : UPPER ( c -- c') DUP LOWER? IF 5F AND THEN ; \ ===[ VI Command Mode keys ]=== : COMMANDS ( char -- ) CASE 82 OF 1SCR NEGATE MOVESCR ENDOF \ ^B 86 OF 1SCR MOVESCR ENDOF \ ^F \ 83 OF COPYLINE ENDOF \ ^C 84 OF 1/2SCR MOVESCR ENDOF \ ^D 8C OF LIST ENDOF \ ^L 91 OF ABORT ENDOF \ ^Q 95 OF 1/2SCR NEGATE MOVESCR ENDOF \ 96 OF PASTELINE NEWLINE ENDOF \ ^V [CHAR] h OF CLEFT ENDOF [CHAR] I OF INSERT-MODE ENDOF [CHAR] j OF CUP ENDOF [CHAR] k OF CDOWN ENDOF [CHAR] l OF CRGHT ENDOF [CHAR] $ OF EOL ENDOF [CHAR] 0 OF VCOL OFF ENDOF [CHAR] D OF SAVECURS ELINE# DELETELN LIST RESTCURS ENDOF [CHAR] : OF GETCMD LIST ENDOF ENDCASE ; \ text/screen color combos HEX 17 CONSTANT BLK/CYAN E4 CONSTANT WHT/BLU 21 CONSTANT GRN/BLK DECIMAL : SCREEN ( c -- ) 7 VWTR ; : NEW CLS BUFFER 8K PURGE FILENAME OFF TOPLINE OFF ; : EDIT ( -- ) GRN/BLK SCREEN INSERTING ON CMDMODE ON BOXCURS TOPLINE OFF 0 22 HLINE FILENAME ."FILE" LIST HOME BEGIN RKEY COMMANDS AGAIN ; : GET-FILENAME ( -- addr len) PARSE-NAME TOUPPER ; : SAVE ( -- ) FILENAME COUNT #2 WRITE-FILE ; \ ===[ vi style user commands ]=== : (Q) BLK/CYAN SCREEN LINECURS ; : x SAVE (Q) ABORT ; : q x (Q) ABORT ; : Q q ; : q! (Q) CR ." Not saved" ABORT ; : Q! q! ; : w GET-FILENAME ( addr len) DUP IF FILENAME PLACE THEN SAVE ; : W w ; : w! w ; : vi GET-FILENAME 2DUP FILENAME PLACE DUP 0= IF 2DROP NEW ELSE #1 READ-FILE THEN EDIT ; : VI vi ; ( alias upper case ) \ 123 G *MUST HAVE SPACE AFTER NO.* : G ( n -- ) TOPLINE ! LIST ; : 0 TOPLINE OFF LIST ; : $ LINES @ 1- G ; HERE SWAP - DECIMAL . VI99-ALPHA.mp4 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 1, 2022 Author Share Posted September 1, 2022 I took a page out of the VIBE block editor by SAM Falvo to expand the command set of VI99. It is I nice way to code this thing. I am really liking how this is going. I am reading a VI manual to add more features. Searching should be fast since I can search the entire 8K buffer as one block. Sam's VIBE editor used command strings that were created on the fly. He took the two digits of the ASCII character and appended them to a string. The name of the strings created this way are Forth words in the program so that makes them easy to run. I simplified things because it is easier to see what VI key you are working on so I just append the ASCII letter to the end of the command string. I was not a purist and use the case statement for non-printable key commands and put the command string handler in the default line for everything else. So here are the VI99 key commands. The last letter is what you press in VI to make it do something. \ Command mode KEY commands \ Ideas from VIBE by Sam Falvo \ Word name key: $$ _ - _ \ | | \ c = command mode --+ | \ i = ins/repl mode | \ | \ ASCII code ------+ \ \ Define formated command words DECIMAL : $$c-d \ delete line KEY [CHAR] d <> IF EXIT THEN SAVECURS ELINE# DELETELN LIST RESTCURS ; : $$c-h \ Cleft VCOL @ 1- 0 MAX VCOL ! ; : $$c-j \ CUP VROW @ 1- 0 MAX DUP 0= IF -1 MOVESCR THEN VROW ! ; : $$c-k \ CDOWN VROW @ 1+ 21 MIN DUP 21 = IF 1 MOVESCR THEN VROW ! ; : NEWLINE $$c-k VCOL OFF ; : $$c-l \ CRGHT VCOL @ 1+ [ C/L@ 1- ] LITERAL MIN VCOL ! ; : $$c-$ C/L@ 1- VCOL ! ; : $$c-0 VCOL OFF ; : $$c-x \ delchar at cursor DELCHAR UPDATELN ; : $$c-: SAVECURS PROMPT [CHAR] : EMIT PAD DUP C/L@ 2- ACCEPT EVALUATE FILENAME ."FILE" RESTCURS LIST ; : $$c-i INSERTING ON VCOL @ PUSHRIGHT EDIT-AT ; : $$c-I INSERTING ON 0 EDIT-AT ; : $$c-a INSERTING OFF \ append @ curs VCOL @ 1+ EDIT-AT ; : $$c-A INSERTING OFF \ append line SCRLINE C/L@ V-TRAILING NIP EDIT-AT ; : $$c-r INSERTING OFF LINECURS GETKEY ; The command interpreter then becomes this, where k is the ascii key parameter. \ =================== \ command interpreter \ =================== : HANDLER ( k -- ) CMD! CMD$ FIND 0= IF DROP BEEP EXIT THEN EXECUTE ; The primary case statement is then simplified to: \ ===[ VI Command Mode keys ]=== : COMMANDS ( char -- ) CASE \ control keys ^ F OF 1SCR MOVESCR ENDOF ^ B OF 1SCR NEGATE MOVESCR ENDOF ^ D OF 1/2SCR MOVESCR ENDOF ^ U OF 1/2SCR NEGATE MOVESCR ENDOF ^ L OF LIST ENDOF ^ Q OF ABORT ENDOF ^M OF NEWLINE ENDOF \ otherwise interpret the key command DUP ( ascii ) HANDLER ENDCASE ; ( Created ^ to make it easier to used control key values) HEX : ^ ( c -- ) \ compile ctrl char ?COMP CHAR 1F AND POSTPONE LITERAL ; IMMEDIATE 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 6, 2022 Author Share Posted September 6, 2022 The stuff people do with Forth still amazes me. Over on Reddit an OP put up an alternative way to make CONSTANT and VARIABLE. : CONSTANT ( x "name" -- ) >R : R> POSTPONE LITERAL POSTPONE ; ; : VARIABLE ( "name" -- ) ALIGN HERE 0 , CONSTANT ; It needs a few mods for FIG-Forth but I think it would work with POSTPONE -> [COMPILE] and ALIGN -> EVEN 2 Quote Link to comment Share on other sites More sharing options...
