+TheBF Posted September 25, 2022 Author Share Posted September 25, 2022 (edited) Over in Optical Illusions @sometimes99er posted one of his signature tiny programs that do a lot of stuff. I am usually a bit jealous of just how concise BASIC can be. 🤢 The version I threw together used raw coordinates to place the sprites so I wondered what it would take to compute the circle in Forth. After all I have a fancy TRIG table in a library file. Truth be told I had never used it. I tried translating the BASIC code literally but guess what? It didn't work because TI BASIC takes the angle in RADIANS. I never noticed that before. Only took me 40 years. I also decided I should at least format the program in a Forth appropriate style, so I used many constants for clarity and factored sections of the program as words. Anyway, here is a Forth version that computes the circle using only integers. (Anybody could do it with floating point) \ translation to camel99 Forth NEEDS SIN FROM DSK1.TRIG NEEDS SPRITE FROM DSK1.DIRSPRIT DECIMAL 01 CONSTANT invisible 14 CONSTANT magenta 15 CONSTANT gray 92 CONSTANT Xbias 122 CONSTANT Ybias 130 CONSTANT Scale 128 CONSTANT BALL : SIN(X) ( n -- x) 30 * SIN Scale / Xbias + ; : COS(Y) ( n -- y) 30 * COS Scale / Ybias + ; : CIRCLE 12 0 DO BALL magenta I COS(Y) I SIN(X) I SPRITE LOOP ; : BLINKER 12 0 DO invisible I SP.COLOR 120 MS magenta I SP.COLOR LOOP ; : RUN CLEAR gray SCREEN 2 MAGNIFY 16 12 AT-XY ." +" S" 00071F3F3F7F7F7F7F7F3F3F1F07000000E0F8FCFCFEFEFEFEFEFCFCF8E00000" BALL CALLCHAR CIRCLE BEGIN BLINKER ?TERMINAL UNTIL ; Edited September 25, 2022 by TheBF fixed comment 3 Quote Link to comment Share on other sites More sharing options...
D-Type Posted September 25, 2022 Share Posted September 25, 2022 https://nbickford.wordpress.com/2011/04/03/the-minsky-circle-algorithm/ I think this might be Minsky's quick elipse algorithm. Worth a look? 1 1 Quote Link to comment Share on other sites More sharing options...
D-Type Posted September 25, 2022 Share Posted September 25, 2022 https://scratch.mit.edu/projects/249324997/ And this is Graham Toal's Scratch version of the algorithm. Graham is one of the 6809 Vectrex community. 1 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 26, 2022 Share Posted September 26, 2022 12 hours ago, TheBF said: The version I threw together used raw coordinates to place the sprites so I wondered what it would take to compute the circle in Forth. After all I have a fancy TRIG table in a library file. Truth be told I had never used it. I tried translating the BASIC code literally but guess what? It didn't work because TI BASIC takes the angle in RADIANS. I never noticed that before. Only took me 40 years. I also decided I should at least format the program in a Forth appropriate style, so I used many constants for clarity and factored sections of the program as words. Anyway, here is a Forth version that computes the circle using only integers. (Anybody could do it with floating point) Of course, I could not resist porting this to fbForth! I did use floating point for the trig calculations, so it is not ported exactly—sorry. I added the capability of making the balls any color. I also added all the colors as constants with uppercase names to facilitate user typing of colors. Code is in the spoiler: Spoiler \ Translation from Camel99 Forth to fbForth with embellishments DECIMAL 0 CONSTANT INVISIBLE 1 CONSTANT BLACK 2 CONSTANT MEDIUM_GREEN 3 CONSTANT LIGHT_GREEN 4 CONSTANT DARK_BLUE 5 CONSTANT LIGHT_BLUE 6 CONSTANT DARK_RED 7 CONSTANT CYAN 8 CONSTANT MEDIUM_RED 9 CONSTANT LIGHT_RED 10 CONSTANT DARK_YELLOW 11 CONSTANT LIGHT_YELLOW 12 CONSTANT DARK_GREEN 13 CONSTANT MAGENTA 14 CONSTANT GRAY 15 CONSTANT WHITE MAGENTA CONSTANT color 128 CONSTANT BALL 122 CONSTANT Xbias 92 CONSTANT Ybias >F 0.52359877559830 FCONSTANT AngleInc \ 30 deg in FP radians >F 80 FCONSTANT radius \ radius in FP dots : X_coord ( n -- x) S->F AngleInc F* \ ball# to FP angle COS radius F* F->S \ FP x-distance to integer Xbias + ; \ add x-offset : Y_coord ( n -- y) S->F AngleInc F* \ ball# to FP angle SIN radius F* F->S \ FP y-distance to integer Ybias + ; \ add y-offset : (color) ( n|[] -- ) \ store new color if stack not empty DEPTH 0> IF \ if not empty stack 1 MAX \ at least 1 15 MIN \ at most 15 ' color ! \ store new color THEN ; : CIRCLE 12 0 DO I X_coord I Y_coord color BALL I SPRITE LOOP ; : DELAY ( n -- ) 0 DO I DROP \ do something n times LOOP ; : BLINKER 12 0 DO INVISIBLE I SPRCOL \ blank a ball 1200 DELAY \ delay for blank ball color I SPRCOL \ restore ball color LOOP ; HEX \ Run with or without a color on the stack : RUN ( color|[] -- ) (color) \ see if color change VDPMDE @ \ current VDP mode to stack GRAPHICS GRAY SCREEN \ make it gray CLS \ clear screen COLTAB 020 04E VFILL \ all color sets dark blue on gray 2 MAGNIFY \ use 4-char, unmagnified sprites 010 0C GOTOXY ." +" \ put '+' at col 16, row 12 DELALL \ initialize sprite table \ Pattern data for characters 128-131, 4 for each ball sprite DATA[ 0007 1F3F 3F7F 7F7F 7F7F 3F3F 1F07 0000 00E0 F8FC FCFE FEFE FEFE FCFC F8E0 0000 ]DATA BALL DCHAR \ define BALL char CIRCLE \ set up balls in a circle BEGIN BLINKER \ blink one ball at a time ?TERMINAL \ hold down FCTN-4 to quit UNTIL VMODE ; \ restore VDP mode from value on stack DECIMAL ...lee 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 26, 2022 Author Share Posted September 26, 2022 Very nice. You sounded a bit Canadian there. (Sorry) Ya, it's a fun exercise. That TI-99 floating point is still great after all these years. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 27, 2022 Author Share Posted September 27, 2022 A while back I played with higher order functions (HOF) to emulate some Python capabilities. Part of that exercise was due to a LOGO demonstration created by @pixelpedant. I really like the way logo lets you feed a set of numbers to a function. This is possible because LOGO is based on lists like it's grandfather LISP. My previous HOFs were a bit more complicated than they deserve for manipulating groups of sprites, so I tried to make something simpler. I also wanted to be able to compile the HOF into a definition. I think I have something here that will work, and the syntax is easy to understand. (?) There is a bit of overhead in this version because I wanted a data set to return an (add,len) pair in two cases: When the data is defined with [[ ]] for interpretation while testing When the data is named with SET: This version treats data sets like variables and arrays; they must be defined at compile time. To use a data set in a definition you must name it with SET: That might be a needless complication but that will become clear when I try to use data sets in a real program. MAP in this case does not create new data as before. It just does something to the data in the set. That can be any word that operates on single CELL of memory. With these I will create some sprite control words that take a "set" of parameters I see if I can emulate the LOGO functions. To process the data in a set I purposely use EVALUATE so that a data set can include Forth variables or constants. At the moment they cannot contain another data set. That would require that a data set returns a single address and FOREACH would have to be recursive. (Could be fun) Here is what the test code looks like: \ DATA SETS test code ... : ? ( addr -- ) @ . ; \ print contents of an address DECIMAL [[ 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 ]] SET: EVENS [[ 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 ]] SET: ODDS EVENS MAP ? ODDS MAP ? ODDS 2DUP MAP 1+! MAP ? ODDS 2DUP MAP 1-! MAP ? : TEST EVENS MAP ? ; \ Compiling test TEST Spoiler \ logo style data sets and FOREACH Sep 2022 Brian Fox INCLUDE DSK1.COMPARE DECIMAL 2 CELLS CONSTANT 2CELLS : 2CELLS+ 2CELLS + ; : 2LITERAL ( d -- ) ?COMP SWAP POSTPONE LITERAL POSTPONE LITERAL ; IMMEDIATE \ end a set. Return the address of the data and length in bytes : ]] ( here -- addr len ) DUP HERE OVER - 2CELLS - DUP>R OVER 2! 2CELLS+ R> EXIT \ EXIT forces evaluation to stop at ]] ; : PARSE-DATA ( addr -- addr' len) BEGIN BL PARSE-WORD 2DUP S" ]]" COMPARE WHILE ( <>"]]") DUP WHILE ( len<>0) EVALUATE , \ evaluate can handle named data also REPEAT THEN 2DROP ; \ create a data-set with 2 cell header : [[ ( -- ) HERE 0 , 0 , PARSE-DATA ]] ; \ name a data set. Return the data address and length in bytes : SET: ( addr len -- ) CREATE , , DOES> 2@ ; : FOREACH ( addr size xt-- ) >R BOUNDS ( 'end '1st) BEGIN 2DUP > WHILE DUP ( addr ) \ addr of a set element R@ ( addr xt) EXECUTE 2+ REPEAT R> DROP 2DROP ; : MAP ( <word> ) \ state smart so it can be used in definitions ' ( look up the word ) STATE @ IF ( compiling action) POSTPONE LITERAL POSTPONE FOREACH EXIT THEN ( interpreting action ) FOREACH ; IMMEDIATE \ literal is state smart so these can be used in definitions : SIZEOF ( -- n) ' >BODY @ POSTPONE LITERAL ; IMMEDIATE : #ITEMS ( -- N) ' >BODY @ 2/ POSTPONE LITERAL ; IMMEDIATE 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 28, 2022 Author Share Posted September 28, 2022 So, you learn a lot when you try to do real work with your clever language enhancement. I was using FOREACH to get the address of the data in a dataset, not the actual data. That's fixed. If you want to use the Forth data stack for parameters for mapped functions, you can't use the data stack to iterate on the dataset. DUH! I made a variant of FOREACH called ALTER. This lets you change the contents of a dataset. Not sure if that would be needed but it was simple to add. #2 meant that I needed to rework FOREACH to use an "action" variable and I iterate with a DO/LOOP so the dataset addresses reside on the return stack. Next problem: I needed a way have enough parameters on the data stack to map onto all the elements in a given dataset. You could go crazy and get the number of elements in the data and make enough copies on the stack for all iterations, but I decided to keep it simple and just do the correct dups on each call. This also means that after one of these dataset mappings you must clean the parameters from the data stack. I could automate that but have not yet. I landed on a syntax like this: [1] means there is one argument to be duplicated [2] means there are two arguments to be duplicated For any sprite function that operates on a single sprite you need to make a definition it with the parameter "dupper" in it. Example: : SP.XY ( x y --) [2] LOCATE ; This little video shows some operations. It works pretty fast. With these tools I can add dataset functions for motion very simply. Here is the test code Spoiler INCLUDE DSK1.TOOLS INCLUDE DSK1.AUTOMOTION INCLUDE DSK1.RANDOM INCLUDE DSK2.DATASETS : SPRITES 26 0 DO I [CHAR] A + 16 RND 1+ 6 I * 6 I * I SPRITE LOOP ; DECIMAL [[ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 28 28 29 30 31 ]] SET: :ALL [[ 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 ]] SET: EVENS [[ 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 ]] SET: ODDS : [1] ( n set -- n n set ) >R DUP R> ; : [2] ( n n set -- n n n n set ) >R 2DUP R> ; : VC+! ( n Vadr -- ) DUP>R VC@ + R> VC! ; : SP.Y+ ( n -- ) [1] SP.Y VC+! ; : SP.X+ ( n -- ) [1] SP.X VC+! ; : COLOR ( n -- ) [1] SP.COLOR ; : SP.XY ( x y --) [2] LOCATE ; CLEAR SPRITES Here is the new dataset code Spoiler \ logo style data lists and FOREACH Sep 2022 Brian Fox INCLUDE DSK1.TOOLS HERE INCLUDE DSK1.COMPARE DECIMAL \ ** EXPERIMENTAL DATA STRUCTURE: COUNTED DATA ARRAYS IN DICTIONARY ** 2 CELLS CONSTANT 2CELLS : 2CELLS+ 2CELLS + ; : 2LITERAL ( d -- ) ?COMP SWAP POSTPONE LITERAL POSTPONE LITERAL ; IMMEDIATE \ end a set. Return the address of the data and length in bytes : ]] ( here -- addr len ) DUP HERE OVER - 2CELLS - DUP>R OVER 2! 2CELLS+ R> EXIT \ EXIT forces evaluation to stop at ]] ; : PARSE-DATA ( addr -- addr' len) BEGIN BL PARSE-WORD 2DUP S" ]]" COMPARE WHILE ( <>"]]") DUP WHILE ( len<>0) EVALUATE , \ evaluate can handle named data also REPEAT THEN 2DROP ; \ create a data-set with 2 cell header : [[ ( -- ) HERE 0 , 0 , PARSE-DATA ]] ; \ name a data set. Return the data address and length in bytes : SET: ( addr len -- ) CREATE , , DOES> 2@ ; VARIABLE ACTION : ALTER ( addr size xt-- ) \ changes DATA set itself ACTION ! BOUNDS DO I ( addr) ACTION PERFORM 2 +LOOP ; : FOREACH ( addr size xt-- ) ACTION ! BOUNDS DO I @ ( data) ACTION PERFORM 2 +LOOP ; : MAP ( <word> ) \ state smart so it can be used in definitions ' ( look up the word ) STATE @ IF ( compiling action) POSTPONE LITERAL POSTPONE FOREACH EXIT THEN ( interpreting action ) FOREACH ; IMMEDIATE \ literal is state smart so these can be used in definitions : SIZEOF ( -- n) ' >BODY @ POSTPONE LITERAL ; IMMEDIATE : #ITEMS ( -- N) ' >BODY @ 2/ POSTPONE LITERAL ; IMMEDIATE HERE SWAP - DECIMAL . sprite-datasets_Trim.mp4 3 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 28, 2022 Author Share Posted September 28, 2022 This is pretty fun. I added a dataset ready MOTION word, and I copied the LOGO command FREEZE. : MOTION ( dx dy -- ) [2] MOTION ; : FREEZE 0 0 :ALL MAP MOTION 2DROP ; dataset-motion.mp4 4 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 3, 2022 Author Share Posted October 3, 2022 Sound Markup Language I have been out of the shop for the last 5 days, but I been noodling on finishing something that I have wanted to get done. The project was a way to tame the creation of sound lists by making a lexicon of Forth words. I had most of the bits and pieces but never settled on something that I liked. and I think I have something now. Here is an example of a sound list using the markup language. The curly brackets demarcate a list of sound-bytes as a counted string. the <xxxx> words are commands in the markup language. It is Forth so parameters come before the command if there are any. DECIMAL SOUND: KABOOM { 4 NOISE, 0 DB, } 6 <FRAMES> <MUTE> 3 <FRAMES> { 6 NOISE, 0 DB, } 50 <FRAMES> 9 1 15 <FADE> <MUTE> ;SOUND Parameters for fade are: ( fade_speed, 1st_volume, last_volume) Here is the data that KABOOM compiles to VDP RAM 1000: 02 E4 F0 06 01 FF 03 02 ........ 1008: E6 F0 32 01 F1 09 01 F2 ..2..... 1010: 09 01 F3 09 01 F4 09 01 ........ 1018: F5 09 01 F6 09 01 F7 09 ........ 1020: 01 F8 09 01 F9 09 01 FA ........ 1028: 09 01 FB 09 01 FC 09 01 ........ 1030: FD 09 01 FE 09 01 FF 09 ........ 1038: 01 FF 00 00 00 00 00 00 ........ To do this I used my standard sound library (DSK1.SOUND) and a small VDP memory manager (DSK1.VPDMEM). SOUND gave me the primitives to convert Hz to chip sound code and words to set and manage the active sound generators and VDPMEM turns VDP memory into a Forth-like memory area with V, VC, so you can compile data into VDP RAM easily. There are commands to control envelope called <FADE>, <SWELL>, <FADEALL>, <SWELLALL> as well as <MUTE> (the last used voice> and <MUTEALL> The SOUND: word creates the VDP data structure at compile time but when you invoke the name of the "SOUND:" it fetches the address and runs the ISR sound list player called VDP-PLAY. SOUND: uses the CREATE/DOES> structure to do that. The rest of the detail is in the code for the curious. The video has some examples executed from the console. Library files for reference: Spoiler \ TMS9919 SOUND CHIP DRIVER and CONTROL LEXICON Jan 2017 BJF \ TMS9919 is a memory mapped device on the TI-99 @ >8400 \ SND! is in the CAMEL99 Kernel as : SND! PAUSE 8400 C! ; HERE \ frequency code must be ORed with these numbers to create a sound HEX 8000 CONSTANT OSC1 A000 CONSTANT OSC2 ( oscillators take 2 nibbles) C000 CONSTANT OSC3 E0 CONSTANT OSC4 ( noise takes 1 nibble) \ Attenuation values are ORed with these values to change volume ( 0= max, 15 = off) 90 CONSTANT ATT1 B0 CONSTANT ATT2 D0 CONSTANT ATT3 F0 CONSTANT ATT4 ( OSC4 volume adjust) DECIMAL \ f(clk) for sound chip is 111,860.8 Hz. Round it up to 111,861 works ok. \ create a 32bit LITERAL from primitives : f(clk) ( -- d) [ 0 0 S" 111861" >NUMBER 2DROP SWAP ] LITERAL LITERAL ; \ >FCODE re-arranges freq. value nibbles (4bits) for the TMS9919 HEX CODE >FCODE ( 0abc -- 0cab) \ version by Farmer Potato Atariage 0B44 , \ TOS 4 SRC, \ C0AB C204 , \ TOS W MOV, \ DUP 0948 , \ W 4 SRL, \ 0C0A D108 , \ W TOS MOVB, \ 0CAB NEXT, \ 28 uS ENDCODE \ we set the "ACTIVE CHANNEL" with these variables VARIABLE OSC \ holds the active OSC value VARIABLE ATT \ holds the active ATTENUATOR value \ convert freq. to 9919 chip code DECIMAL : HZ>CODE ( freq -- fcode ) f(clk) ROT UM/MOD NIP >FCODE ; HEX \ **for testing** print sound data to screen AND make sound \ : SND! ( c -- ) ." >" BASE @ >R HEX DUP U. 8400 C! R> BASE ! ; \ Set the sound "GENerator that is active. : GEN! ( osc att -- ) ATT ! OSC ! ; \ ================================================================ \ S C I E N T I F I C S O U N D C O N T R O L L E X I C O N \ sound generator selectors : GEN1 ( -- ) OSC1 ATT1 GEN! ; : GEN2 ( -- ) OSC2 ATT2 GEN! ; : GEN3 ( -- ) OSC3 ATT3 GEN! ; : GEN4 ( -- ) OSC4 ATT4 GEN! ; : (NOISE) ( n -- n) 0F AND GEN4 OSC @ OR ; : (HZ) ( f -- n) HZ>CODE OSC @ OR ; \ convert freq. add OSC : (DB) ( level -- c) ABS 2/ 0F MIN ATT @ OR ; \ DB to attenuation : HZ ( f -- ) (HZ) SPLIT SND! SND! ; : DB ( level -- ) (DB) SND! ; \ Usage: -6 DB : NOISE ( n --) (NOISE) SND! ; : MUTE ( -- ) -30 DB ; : SILENT ( --) 9F SND! BF SND! DF SND! FF SND! ; GEN1 HERE SWAP - DECIMAL . .( bytes) Spoiler \ vdp memory manager lexicon BJF Jan 29 2021 \ VDP Memory Usage in Camel99 Forth when this file is loaded \ | VDP screen | VDP >0000 \ + --------------| \ | RESERVED | sprites, patterns color tables \ |---------------| \ | >460..7FF | *FREE 928 bytes in TEXT mode only* \ |---------------| \ | >800.. | *Pattern descriptor table* \ +---------------+ HEX 1000, VDP HEAP start \ | VHERE | VDP heap moves upwards \ | . | \ | . | \ | . | \ | . | \ | | \ | | \ | | ^^^^^^^ \ | ^^^^^^^ | move downwards \ | PAB stack | PABs start here \ +---------------+ <-- VDPTOP returns this address \ | 99 O/S space | \ |---------------| VDP >3FFF \ INCLUDE DSK1.TOOLS \ debugging only \ VARIABLE VP ( moved to kernel for V2.55 ) HEX 1000 VP ! \ "VDP pointer" start of free VDP RAM : VHERE ( -- addr) VP @ ; \ FETCH the value in VDP pointer : VALLOT ( n -- ) VP +! ; \ add n to the value in VDP pointer : VC, ( n -- ) VHERE VC! 1 VALLOT ; : V, ( n -- ) VHERE V! 2 VALLOT ; : VCOUNT ( vdp$adr -- vdpadr len ) DUP 1+ SWAP VC@ ; : VCREATE ( <text> -- ) VHERE CONSTANT ; \ address when <text> invoked \ : VPLACE ( $addr len Vaddr -- ) \ like PLACE for VDP RAM. In KERNEL 2.6 \ 2DUP VC! 1+ SWAP VWRITE ; The sound compiler with demo sound lists. Spoiler \ TI sound list assembler Aug 22 2022 Brian Fox \ Assembles TI sound lists in VDP RAM NEEDS .S FROM DSK1.TOOLS NEEDS HZ FROM DSK1.SOUND NEEDS VHERE FROM DSK1.VDPMEM HEX : NEWVDP ( addr len -- ) OVER VP ! 0 VFILL ; 83C2 CONSTANT AMSQ \ interrupt DISABLE bits CODE 0LIMI ( -- ) 0300 , 0000 , NEXT, ENDCODE CODE 2LIMI ( -- ) 0300 , 0002 , NEXT, ENDCODE \ ISR Sound List Player in Forth HEX : VDP-PLAY ( Vaddr -- ) 0LIMI 83CC ! \ Vaddr -> sound table 5 AMSQ C@ AND AMSQ C! \ enable sound interrupts 1 83FD C@ OR 83FD C! \ set VDP as sound source 1 83CE C! \ trigger sound processing 2LIMI ; \ Compile time parameter testers DECIMAL : ?FREQ ( n -- n) DUP 110 50000 WITHIN 0= ABORT" Bad frequency" ; : ?LEVEL ( n -- n) DUP 0 17 WITHIN 0= ABORT" Bad level" ; : ?DUR ( n -- n) DUP 1 256 WITHIN 0= ABORT" Bad duration" ; \ sound byte "assembler" commands compile values for the last sound generator used. \ Select ACTIVE sound generator with: GEN1 GEN2 GEN3 : HZ, ( f -- ) ?FREQ (HZ) SPLIT VC, VC, ; \ compiles 2 bytes : DB, ( level -- ) ?LEVEL ATT @ OR VC, ; \ noise channel selects generator 4 by default : NOISE, ( n -- ) GEN4 (NOISE) VC, ; \ Start a counted string of bytes in VDP RAM : { ( -- vaddr1) VHERE 0 VC, ; \ back-fill string length in the list of bytes : } ( vaddr1 vaddr2 -- ) VHERE OVER - 1- SWAP VC! ; \ ===================================================================== \ sound creator. Plays when executed DECIMAL : SOUND: ( <text> -- ) CREATE \ create name in dictionary VHERE , \ remember the VDP address !CSP \ record stack position DOES> @ VDP-PLAY ; \ feed address to player \ mark end of sound list, check for clean DATA stack : ;SOUND ( Vaddr -- ) 0 VC, ?CSP ; HEX : <MUTE> ( -- ) 01 VC, 0F DB, ; \ mutes the ACTIVE generator : <MUTEALL> ( -- ) { 9F VC, BF VC, DF VC, FF VC, } ; : <FRAMES> ( n -- ) ?DUR VC, ; \ duration in video Frames : <MS> ( mS -- frames) 4 RSHIFT <FRAMES> ; \ mS/16 = FRAMES HEX \ wait until sound list is completed : <WAIT> ( -- ) BEGIN 83CE C@ WHILE PAUSE REPEAT ; DECIMAL : <FADE> ( duration start end -- ) 1+ SWAP DO { I DB, } DUP <FRAMES> LOOP DROP ; : <FADEALL> ( duration start end -- ) 1+ SWAP DO { GEN1 I DB, GEN2 I DB, GEN3 I DB, GEN4 I DB, } DUP <FRAMES> LOOP DROP ; : <SWELL> ( duaration start end -- ) SWAP DO { I DB, } DUP <FRAMES> -1 +LOOP DROP ; : <SWELLALL> ( duaration start end -- ) SWAP DO { GEN1 I DB, GEN2 I DB, GEN3 I DB, GEN4 I DB, } DUP <FRAMES> -1 +LOOP DROP ; HEX 1000 2000 NEWVDP \ reset 8K of VDP memory @>1000 DECIMAL SOUND: WEIRD { GEN1 120 HZ, 15 DB, GEN2 121 HZ, 15 DB, GEN3 122 HZ, 15 DB, GEN4 6 NOISE 15 DB, } 1 <FRAMES> 5 15 0 <SWELLALL> 5 0 15 <FADEALL> <MUTEALL> ;SOUND \ HEX ' WEIRD >BODY @ B0 VDUMP DECIMAL SOUND: A440 { GEN1 440 HZ, 0 DB, } 1000 <MS> <MUTE> ;SOUND \ HEX ' A440 >BODY @ 30 VDUMP SOUND: SONAR { GEN1 995 HZ, 0 DB, } 150 <MS> 7 3 15 <FADE> <MUTE> ;SOUND DECIMAL SOUND: SHOOP { 4 NOISE, 15 DB, } 1 <FRAMES> 9 15 0 <SWELL> <MUTE> ;SOUND \ HEX ' SHOOP >BODY @ 70 VDUMP DECIMAL SOUND: KABOOM { 4 NOISE, 0 DB, } 6 <FRAMES> <MUTE> 3 <FRAMES> { 6 NOISE, 0 DB, } 50 <FRAMES> 9 1 15 <FADE> <MUTE> ;SOUND \ HEX ' CHABOOM >BODY @ 70 VDUMP SOUND-COMPILER-DEMO.mp4 5 Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 3, 2022 Share Posted October 3, 2022 (edited) Quote Sounds... The SID99 can be programmed in Forth for sound. It has, like 8 I think registers. I was just reading the manual yesterday and I've already forgotten how many, but that's because there's a bit more to it than just setting those up. But a question came to mind, could both the SID99 AND the TI's internal sound chip be used together and at the same time? Or is it redundant? Maybe @Ksarul would know that. Edited October 3, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
Willsy Posted October 4, 2022 Share Posted October 4, 2022 Yes. They can be both be used together. TurboForth has as library (on block 5 of the companion disk) for SID support. I actually have a SID card so I wrote it in conjunction with Marc Hull back in the day. The code say's it's untested code. I can't remember if I tested it or not, but this would be be a good starting place for SID support for other Forth's too. --BLOCK-00005--------- \ SID chip support code. M.Wills, May 16th, 2011 $5800 CONSTANT SID : DUMMY ( -- ) [ SID $32 + ] LITERAL 0 C! ; : W>SID ( addr word --) DUP 2+ 2 PICK >< SWAP C! C! DUMMY ; : B>SID ( addr byte --) SWAP C! ; : SIDF ( freq ch# --) 14 * [ SID ] LITERAL + W>SID ; : SIDP ( pulse ch# --) 14 * [ SID 4 + ] LITERAL + W>SID ; : SIDW ( wform ch# --) 14 * [ SID 8 + ] LITERAL + B>SID ; : SIDA ( atdec ch# --) 14 * [ SID 10 + ] LITERAL + B>SID ; : SIDS ( susrl ch# --) 14 * [ SID 12 + ] LITERAL + B>SID ; : SFIL ( value --) [ SID $2A + ] LITERAL W>SID ; : SRES ( reson --) [ SID $2E + ] LITERAL B>SID ; : SVOL ( vol --) [ SID $30 + ] LITERAL B>SID ; CR .( SID support loaded.) .( Note: This is un-tested code) 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 4, 2022 Author Share Posted October 4, 2022 Very nice. I didn't know about the chip. Had to do some reading. It's quite a step up from what we have in the 99. Here is your code with a little trick word that I first saw in gForth. --BLOCK-00005--------- \ SID chip support code. M.Wills, May 16th, 2011 : ]L ] [COMPILE] LITERAL ; $5800 CONSTANT SID : DUMMY ( -- ) [ SID $32 + ]L 0 C! ; : W>SID ( addr word --) DUP 2+ 2 PICK >< SWAP C! C! DUMMY ; : B>SID ( addr byte --) SWAP C! ; : SIDF ( freq ch# --) 14 * [ SID ]L + W>SID ; : SIDP ( pulse ch# --) 14 * [ SID 4 + ]L + W>SID ; : SIDW ( wform ch# --) 14 * [ SID 8 + ]L + B>SID ; : SIDA ( atdec ch# --) 14 * [ SID 10 + ]L + B>SID ; : SIDS ( susrl ch# --) 14 * [ SID 12 + ]L + B>SID ; : SFIL ( value --) [ SID $2A + ]L W>SID ; : SRES ( reson --) [ SID $2E + ]L B>SID ; : SVOL ( vol --) [ SID $30 + ]L B>SID ; CR .( SID support loaded.) .( Note: This is un-tested code) Unfortunately, it adds 14 bytes to the code, but if ]L was in the system it would be the same size. 2 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 4, 2022 Share Posted October 4, 2022 Sweet surprise. But can't be tested using classic99 obviously, but I can move my code back and forth to the real machine through TIPI, so not so bad. I'm glad you incorporated that into forth, and we get a breakdown of that>5xxx address range use. Now maybe I can make more sense of the manual..thx 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 5, 2022 Share Posted October 5, 2022 (edited) Oh . this is the same code I already use for my sound utility on my TI-99.. and yes, it does work.. I've been using it for years. But now it looks like I've got to put together another output wire for my monitor from my TI. I don't know what happened to my original wire but it's missing... until that happens I have no sound....duh...but, yes this works for my TI but i haven't plugged in the SID99 yet to test with , and now gotta make a wire .. Edited October 5, 2022 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 5, 2022 Author Share Posted October 5, 2022 (edited) Forth Nerd Code of Interest While searching the inter-web for things Forth I found this code by Sam Falvo regarding a bubble sort challenge in a wiki. I think sometimes I have got the hang of Forth style programming but when I see this, I am not so sure. The unique idea here is that by composing the strings as Forth words and compiling the array as a list of their "execution tokens", you get a smart array that gives you the contents by "executing" the code in the Forth word. the contents of the array. I had heard about this kind of thing in Forth circles but never had example code. \ bubble sort challenge by Sam Falvo Circa 2008 \ https://wiki.c2.com/?BubbleSortChallenge ( source code case changed for Camel99 Forth ) INCLUDE DSK1.COMPARE : Perl S" Perl" ; : Python S" Python" ; : Ruby S" Ruby" ; : JavaScript S" JavaScript" ; : Java S" Java" ; : Fortran S" Fortran" ; : C S" C" ; : C++ S" C++" ; : Basic S" Basic" ; : Pascal S" Pascal" ; : Lisp S" Lisp" ; CREATE POINTERS ' Perl , ' Python , ' Ruby , ' JavaScript , ' Java , ' Fortran , ' C , ' C++ , ' Basic , HERE ' Pascal , ' Lisp , ( -- here ) CONSTANT PENULTIMATE : NAME @ EXECUTE ; \ resolve a table entry to a name string \ swap adjacent table entries : SWP >R R@ @ R@ CELL+ @ SWAP R@ CELL+ ! R> ! ; : PAIR DUP NAME ROT CELL+ NAME ; \ two adjacent names : ARRANGE DUP PAIR COMPARE 0> IF SWP EXIT THEN DROP ; \ bubbles from end of list towards the beginning. : BUBBLE PENULTIMATE BEGIN 2DUP U> IF 2DROP EXIT THEN DUP ARRANGE [ 1 CELLS ] LITERAL - AGAIN ; : SORT POINTERS BEGIN DUP PENULTIMATE U> IF DROP EXIT THEN DUP BUBBLE CELL+ AGAIN ; : E DUP NAME TYPE SPACE CELL+ ; \ display current table state : SHOW POINTERS E E E E E E E E E E E DROP CR ; : DEMO SHOW SORT SHOW ; DEMO bubble-sort-demo.mp4 Edited October 5, 2022 by TheBF Clarification 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 5, 2022 Share Posted October 5, 2022 Oh, wow. Well that's snazzy. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 6, 2022 Share Posted October 6, 2022 10 hours ago, TheBF said: Forth Nerd Code of Interest While searching the inter-web for things Forth I found this code by Sam Falvo regarding a bubble sort challenge in a wiki. I think sometimes I have got the hang of Forth style programming but when I see this, I am not so sure. The unique idea here is that by composing the strings as Forth words and compiling the array as a list of their "execution tokens", you get a smart array that gives you the contents by "executing" the code in the Forth word. the contents of the array. I had heard about this kind of thing in Forth circles but never had example code. As usual, you have inspired me to port this to fbForth. Here it is after adding some words missing from fbForth and accounting for the facts that ' returns the pfa instead of Camel99 Forth’s cfa, and that S" returns only the address of the count byte of a counted string instead of Camel99 Forth’s address of the first character and the character count: Spoiler \ bubble sort challenge by Sam Falvo Circa 2008 \ https://wiki.c2.com/?BubbleSortChallenge ( source code case changed for Camel99 Forth ) ( ---ported to fbForth ) : Perl S" Perl" ; : Python S" Python" ; : Ruby S" Ruby" ; : JavaScript S" JavaScript" ; : Java S" Java" ; : Fortran S" Fortran" ; : C S" C" ; : C++ S" C++" ; : Basic S" Basic" ; : Pascal S" Pascal" ; : Lisp S" Lisp" ; : 2DUP OVER OVER ; : 2DROP DROP DROP ; \ ASM: U> \ *SP+ *SP C, \ *SP CLR, \ L IF, \ *SP INC, \ THEN, \ ;ASM HEX CODE: U> 8679 04D9 1401 0599 ;CODE DECIMAL \ compare 2 counted strings : COMPARE ( adr1 adr2 -- -1|0|+1 ) OVER C@ OVER C@ \ get char counts 2DUP - SGN >R \ get sign of diff to return stack MIN 1+ 0 SWAP \ calc loop limit; 0 to stack 1 DO \ loop by the smaller count DROP \ drop last sign OVER I + C@ \ next char of 1st string OVER I + C@ \ next char of 2nd string - SGN \ sign of diff DUP IF LEAVE THEN \ leave loop if not 0 LOOP R> \ get char count diff from return stack OVER 0= IF \ compared chars =? OR \ yes..leave sign of char-count diff ELSE DROP \ no..leave only last char diff THEN >R 2DROP R> \ clean up ; : 'CFA [COMPILE] ' CFA ; \ get CFA from instream token 0 VARIABLE POINTERS -2 ALLOT 'CFA Perl , 'CFA Python , 'CFA Ruby , 'CFA JavaScript , 'CFA Java , 'CFA Fortran , 'CFA C , 'CFA C++ , 'CFA Basic , HERE 'CFA Pascal , 'CFA Lisp , ( -- here ) CONSTANT PENULTIMATE : NAME @ EXECUTE ; \ resolve a table entry to a name string \ swap adjacent table entries : SWP >R R @ R 2+ @ SWAP R 2+ ! R> ! ; : PAIR DUP NAME ROT 2+ NAME ; \ two adjacent names : ARRANGE DUP PAIR COMPARE 0> IF SWP ;S THEN DROP ; \ bubbles from end of list towards the beginning. : BUBBLE PENULTIMATE BEGIN 2DUP U> IF 2DROP ;S THEN DUP ARRANGE [ 2 ] LITERAL - AGAIN ; : SORT POINTERS BEGIN DUP PENULTIMATE U> IF DROP ;S THEN DUP BUBBLE 2+ AGAIN ; : E DUP NAME COUNT TYPE SPACE 2+ ; \ display current table state : SHOW POINTERS E E E E E E E E E E E DROP CR ; : DEMO SHOW SORT SHOW ; DEMO ...lee 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 6, 2022 Author Share Posted October 6, 2022 Nicely done. You have the brains to write your own COMPARE. I found that challenging. For a Forth version, I used one by Neil Baud. I think I posted this before and you commented on the "non-union" use of COUNT. I think it would be workable with FbForth with a preface like: : $EXPAND ( $addr $addr -- addr len addr len) SWAP COUNT ROT COUNT ; \ Neil Baud's compare in Forth : COMPARE ( a1 n1 a2 n2 -- -1|0|1 ) ROT 2DUP - >R ( a1 a2 n2 n1)( R: n2-n1) MIN ( a1 a2 n3) BOUNDS ?DO ( a1) COUNT I C@ - ( a1 diff) DUP IF NIP 0< 1 OR ( -1|1) UNLOOP R> DROP EXIT ( a1 diff) THEN DROP ( a1) LOOP DROP ( ) R> DUP IF 0> 1 OR THEN \ 2's complement arith. ; (Just tried it and it seems to work with byte-counted strings) I have a dim memory of somebody doing this technique (embedded code in data structure) with a binary tree. Might have been the late Jeff Fox who worked with Chuck Moore. (no relation) It was running on one of Chuck's CPUs and so the "Forth" code was actually machine instructions embedded in the binary tree. Additions and deletions to the tree were reported to be crazy fast. We might be able to that with some carefully chosen ALC words. 2 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 6, 2022 Share Posted October 6, 2022 8 hours ago, TheBF said: Nicely done. You have the brains to write your own COMPARE. I found that challenging. For a Forth version, I used one by Neil Baud. I think I posted this before and you commented on the "non-union" use of COUNT. It seems I wrote that ~6 years ago—and...it took a while to get it right as I recall. Re Neil Baud’s COMPARE , I will definitely incorporate features of that into my COMPARE . I must be very careful with true-value usage because fbForth returns 1 (FIG-Forth) for a true result. I believe -1 was first used in Forth-83. It seems some of Neil’s code depends on the -1 result. ...lee 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 7, 2022 Author Share Posted October 7, 2022 (edited) 18 hours ago, Lee Stewart said: It seems I wrote that ~6 years ago—and...it took a while to get it right as I recall. Re Neil Baud’s COMPARE , I will definitely incorporate features of that into my COMPARE . I must be very careful with true-value usage because fbForth returns 1 (FIG-Forth) for a true result. I believe -1 was first used in Forth-83. It seems some of Neil’s code depends on the -1 result. ...lee 6 years! OMG. Yes, as I recall he was a big proponent of Forth 94 ANS version and wrote a ton of text processing stuff for work that he was doing with large documents. So TRUE was definitely -1 and if it was handy he used it. The use of COUNT to index through the bytes of a string is really very sensible after you think about. I think the name gets in the way of thinking about it in a different way. I used it to re-write my TYPE primitive after I saw this compare. : (TYPE) ( addr cnt -- addr') 0 ?DO COUNT CPUT IF CR THEN LOOP ; : TYPE ( addr cnt --) PAUSE (TYPE) DROP ; Edited October 7, 2022 by TheBF Wrong comment in code 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 8, 2022 Share Posted October 8, 2022 OK—I updated my COMPARE with elements of Baud’s COMPARE . I purposely did not use 2DUP , 2DROP , NIP , UNLOOP because I must use it in un-embellished fbForth. Oh, and MINUS is your NEGATE . I used it to reverse c2-c1 to c1-c2: Spoiler \ compare 2 counted strings : COMPARE ( $adr1 $adr2 -- -1|0|+1 ) SWAP COUNT ROT COUNT \ S:a1' c1 a2' c2 ROT OVER OVER - \ S:a1' a2' c2 c1 c2-c1 SGN \ S:a1' a2' c2 c1 -1|0|1 MINUS >R \ S:a1' a2' c2 c1 R:1|0|-1 MIN \ S:a1' a2' c3 R:1|0|-1 \ loop limit and index OVER + SWAP \ S:a1' c3+a2' a2' R:1|0|-1 DO \ S:a1' R:lim idx 1|0|-1 COUNT I C@ - \ S:a1" c1'-c2' R:lim idx 1|0|-1 SGN \ S:a1" -1|0|1 R:lim idx 1|0|-1 DUP \ S:a1" -1|0|1 -1|0|1 R:lim idx 1|0|-1 IF \ S:a1" -1|0|1 R:lim idx 1|0|-1 SWAP DROP \ S:-1|1 R:lim idx 1|0|-1 \ UNLOOP..drop loop index and limit before exit R> DROP R> DROP \ S:-1|1 R:1|0|-1 R> DROP \ S:-1|1 ..don't need count diff \ exit COMPARE with result on stack ;S \ S:-1|1 THEN DROP \ S:a1" R:lim idx 1|0|-1 LOOP \ if we get this far, all checked chars matched, \ so return stack has the answer DROP R> \ S:1|0|-1 ; ...lee 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 8, 2022 Share Posted October 8, 2022 This is a powerful word now. Nice Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 8, 2022 Author Share Posted October 8, 2022 10 hours ago, Lee Stewart said: OK—I updated my COMPARE with elements of Baud’s COMPARE . I purposely did not use 2DUP , 2DROP , NIP , UNLOOP because I must use it in un-embellished fbForth. Oh, and MINUS is your NEGATE . I used it to reverse c2-c1 to c1-c2: Hide contents \ compare 2 counted strings : COMPARE ( $adr1 $adr2 -- -1|0|+1 ) SWAP COUNT ROT COUNT \ S:a1' c1 a2' c2 ROT OVER OVER - \ S:a1' a2' c2 c1 c2-c1 SGN \ S:a1' a2' c2 c1 -1|0|1 MINUS >R \ S:a1' a2' c2 c1 R:1|0|-1 MIN \ S:a1' a2' c3 R:1|0|-1 \ loop limit and index OVER + SWAP \ S:a1' c3+a2' a2' R:1|0|-1 DO \ S:a1' R:lim idx 1|0|-1 COUNT I C@ - \ S:a1" c1'-c2' R:lim idx 1|0|-1 SGN \ S:a1" -1|0|1 R:lim idx 1|0|-1 DUP \ S:a1" -1|0|1 -1|0|1 R:lim idx 1|0|-1 IF \ S:a1" -1|0|1 R:lim idx 1|0|-1 SWAP DROP \ S:-1|1 R:lim idx 1|0|-1 \ UNLOOP..drop loop index and limit before exit R> DROP R> DROP \ S:-1|1 R:1|0|-1 R> DROP \ S:-1|1 ..don't need count diff \ exit COMPARE with result on stack ;S \ S:-1|1 THEN DROP \ S:a1" R:lim idx 1|0|-1 LOOP \ if we get this far, all checked chars matched, \ so return stack has the answer DROP R> \ S:1|0|-1 ; ...lee Very nice. I have to take off today but I will get back to this. Do you see any performance improvement? One little machine code word ( RDROP) might make it a bit faster and even smaller maybe. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 8, 2022 Share Posted October 8, 2022 (edited) I'll see if TF can run this tonight, it should as is. I'm pretty sure TF already has a string search, but maybe not like this...I don't know the definition of mark's existing word.. but I'll try this. Edited October 8, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 8, 2022 Author Share Posted October 8, 2022 1 hour ago, GDMike said: I'll see if TF can run this tonight, it should as is. I'm pretty sure TF already has a string search, but maybe not like this...I don't know the definition of mark's existing word.. but I'll try this. It's not compatible with TF which is Forth 83 standard. FbForth is the slightly older Forth Interest Group (FIG) standard. And it is not actually a search just the comparison. It's more like: A$="THIS STRING" TF has it's own details when getting out of a DO LOOP. You can also load the string library blocks but that's pretty big if you don't need all of it. Or take a look in the string blocks and see how Willsy did a string comparison. I will see if I can get COMPARE to work under TF. 1 Quote Link to comment Share on other sites More sharing options...
