GDMike Posted October 29, 2022 Share Posted October 29, 2022 6 hours ago, TheBF said: TI-99 Forth implementation idea for discussion Consider this: Screen output on TI-99 goes to VDP RAM File output on TI-99 goes to VDP RAM File input on TI-99 comes from VDP RAM A Forth system could use VDP RAM as method to re-direct output to screen or to file simply by changing the VDP address where the output is written. If the terminal input buffer used VDP RAM, then input could also be redirected from a file by changing the VDP buffer address to a PAB buffer. Penny for your thoughts. (A Canadian penny, which actually doesn't exist anymore so you might not get paid) Sure, like a scratchpad Temp work file I guess of sorts Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 30, 2022 Share Posted October 30, 2022 (edited) On 10/29/2022 at 11:03 AM, TheBF said: TI-99 Forth implementation idea for discussion Consider this: Screen output on TI-99 goes to VDP RAM File output on TI-99 goes to VDP RAM File input on TI-99 comes from VDP RAM A Forth system could use VDP RAM as method to re-direct output to screen or to file simply by changing the VDP address where the output is written. If the terminal input buffer used VDP RAM, then input could also be redirected from a file by changing the VDP buffer address to a PAB buffer. Penny for your thoughts. (A Canadian penny, which actually doesn't exist anymore so you might not get paid) I am used to thinking about blocks of 1024 characters. The 40-column screen will take almost all of one block (1024-960=64 short). The 80-column screen is easy (I think). The 40-column screen could be scrolled up and down 2 rows with no problem. The screen could be the PAB buffer—even in 40-column mode (32 bytes of rollout area1 and 128 bytes of value stack2 will surely not be used while editing). The above use of the screen area should be easy enough to manage for DV80 (or similar) I/O scenarios, as well. ________________ The VDP rollout area is used primarily for temporary storage for GPL floating point transcendental functions, almost certainly not used while doing anything related to editing. The VDP value stack is used for most (all?) console (XML and GPL) floating point operations, but it can be moved elsewhere in VRAM by changing the value stack pointer, VSPTR (>836E). ...lee Edited October 31, 2022 by Lee Stewart CLARIFICATION 3 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 30, 2022 Author Share Posted October 30, 2022 I hadn't thought about how straightforward it is with blocks. With files I will have to keep track of line endings and write to the file buffer and then write to file with every CR. I thinks all doable but might get complicated. It's very tempting though. 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 10, 2022 Author Share Posted November 10, 2022 A light has shone in my darkness I was fighting with MachForth to behave in a way I could understand when using IF ELSE THEN. I decided to look at some of my other projects that needed native code for IF and that brought me to INLINE[ ] Turns out I had never finished a version that "TRIED" to compile IF/THEN or WHILE/REPEAT as native code. Armed with my new experience in MachForth it all suddenly made sense. I realized that the way I did ?BRANCH in threaded Forth would work just as well if it used JMP instruction. ( see: IF, in the code ) DEC the TOS register, do a DROP to refill the TOS register. (*SP+ TOS MOV, ) DROP has no effect on the CARRY flag, so you can JNC to the branch address if the TOS went below zero. My INLINE[ ] system uses a control flow stack, which needed a CS>SWAP word to replace the SWAPs in my normal Forth ELSE and WHILE statements. That was easy. After that I added the new words to the JIT CASE statement and things started coming together. The resulting code is not as fast as hand coded Assembler, but it is about 3 times faster than threaded Forth as you can see in the screen capture. Future: There is no attempt to do PUSH/POP optimization It should be straightforward to optimize variables with symbolic addressing as I have in MachForth Make the JIT able to consume multiple lines or source code Re-write MachForth using these ideas. I am pretty pleased with this now. I want to try it on the Sieve benchmark. Here is the new code which is invoked with JIT[ ] . This JIT compiler uses 1392 bytes of dictionary space. Spoiler \ jit.fth Compiles inline code as headless words in HEAP Nov 10 2022 \ Problem: \ ITC Forth spends 50% of it's time running 3 instructions call NEXT. \ This system compiles primitives from the kernel as super-instructions \ and compiles the execution for the super instructions in a Forth word. NEEDS .S FROM DSK1.TOOLS NEEDS CASE FROM DSK1.CASE NEEDS LIFO: FROM DSK1.STACKS NEEDS ELAPSE FROM DSK1.ELAPSE NEEDS MARKER FROM DSK1.MARKER MARKER /INLINE HERE 8 LIFO: CS \ small CONTROL FLOW STACK for loops and branching : >CS ( n -- ) CS PUSH ; : CS> ( -- n ) CS POP ; : CS>SWAP ( -- ) CS> CS> SWAP >CS >CS ; HEX \ *** changed for kernel V2.69 *** \ Words in scratchpad RAM end in a JMP instruction, not NEXT \ Might change this, but for now just make some conventional versions. CODE DUP 0646 , C584 , NEXT, ENDCODE CODE DROP C136 , NEXT, ENDCODE CODE ! C536 , C136 , NEXT, ENDCODE CODE @ C114 , NEXT, ENDCODE CODE C@ D114 , 0984 , NEXT, ENDCODE CODE + A136 , NEXT, ENDCODE \ Heap management : THERE ( -- addr) H @ ; \ returns end of Target memory in HEAP : HALLOT ( n -- ) H +! ; \ Allocate n bytes of target memory. : T, ( n -- ) THERE ! 2 HALLOT ; \ "target compile" n into heap : NEW-HEAP ( -- ) 2000 2000 0 FILL 2000 H ! ; \ reset HEAP 045A CONSTANT 'NEXT' \ 9900 CODE for B *R10 Camel99 Forth's NEXT code : CODE, ( xt --) \ Read code word from kernel, compile into target memory >BODY DUP 80 CELLS + \ 128 bytes is max size we will try to compile SWAP ( -- IPend IPstart) BEGIN DUP @ 'NEXT' <> \ the instruction is not 'NEXT' WHILE DUP @ ( -- IP instruction) T, \ compile instruction CELL+ \ advance IP 2DUP < ABORT" End of code not found" REPEAT 2DROP ; \ now we can steal code word from the kernel and compile it to target memory : DUP, ['] DUP CODE, ; : DROP, ['] DROP CODE, ; : LIT, ( n -- ) DUP, 0204 T, ( n) T, ; \ DUP TOS and LI R4,n : BEGIN, THERE >CS ; \ push location onto control stack \ <DO> is CODE preamble to setup return stack. : DO, ( -- there) ['] <DO> CODE, BEGIN, ; \ store a byte offset in odd byte of addr. \ Addr is the location of Jump instruction : RESOLVE ( addr offset --) 2- 2/ SWAP 1+ C! ; \ compute offset from addr addr' & complete the jump instruction : <BACK ( addr addr' -- ) TUCK - RESOLVE ; : ?BYTE ( c -- c) DUP FF00 AND ABORT" Jump out of range" ; \ compile misc. jump instructions with offset. : JMP, ( c --) ?BYTE 1000 + T, ; : JNO, ( c --) ?BYTE 1900 + T, ; : JEQ, ( c --) ?BYTE 1300 + T, ; : JNE, ( c --) ?BYTE 1600 + T, ; : JOC, ( c --) ?BYTE 1800 + T, ; : JNC, ( c --) ?BYTE 1700 + T, ; : 1-, ( n -- n') 604 T, ; \ TOS DEC, : LOOP, 0597 T, \ *RP INC, CS> THERE 0 JNO, <BACK \ compute offset, compile into JNO ['] UNLOOP CODE, \ collapse stack frame ; : +LOOP, A5CA T, \ TOS *RP ADD, DROP, \ don't need TOS value anymore LOOP, \ compile loop code ; : AGAIN, CS> THERE 0 JMP, <BACK ; : UNTIL, 1-, DROP, CS> THERE 0 JNC, <BACK ; : IF, ( n -- ) 1-, \ If tos=0, DEC will cause a carry DROP, THERE >CS 0 JNC, ; : THEN, CS> THERE OVER - RESOLVE ; : ELSE, THERE >CS 0 JMP, CS>SWAP THEN, ; : WHILE, ( n -- ) IF, CS>SWAP ; : REPEAT, AGAIN, THEN, ; \ CFA of a code word contains the address of the next cell : NOTCODE? ( XT -- ?) DUP @ 2- - ; : OPT-FORTH ( cfa -- ) ['] DOCOL @ OVER @ = \ a colon definition? IF ( -- cfa) CASE ['] DO OF DO, ENDOF ['] LOOP OF LOOP, ENDOF ['] +LOOP OF +LOOP, ENDOF ['] BEGIN OF BEGIN, ENDOF ['] UNTIL OF UNTIL, ENDOF ['] AGAIN OF AGAIN, ENDOF ['] IF OF IF, ENDOF ['] ELSE OF ELSE, ENDOF ['] THEN OF THEN, ENDOF ['] WHILE OF WHILE, ENDOF ['] REPEAT OF REPEAT, ENDOF TRUE ABORT" Can't optimize word" ENDCASE DROP ELSE \ Other type of Forth word DUP @ \ get the "executor" code routine address CASE ( data words ) ['] DOVAR OF >BODY LIT, ENDOF ['] DOCON OF EXECUTE LIT, ENDOF ['] DOUSER @ OF EXECUTE LIT, ENDOF TRUE ABORT" Unknown data type" ENDCASE DROP THEN ; \ new interpreter loop for inlining : JIT[ ( -- addr) \ Returns address where code has been copied THERE ( -- XT) \ execution token (XT) for the NEW compiled code DUP CELL+ T, \ create the ITC header for CODE word BEGIN BL WORD CHAR+ C@ [CHAR] ] <> WHILE HERE FIND IF ( *it's a word in the dictionary* ) DUP NOTCODE? IF ( -- cfa ) DUP OPT-FORTH ELSE \ it's a CODE primitive CODE, \ compile code without NEXT THEN ELSE ( maybe its a number) COUNT NUMBER? ?ERR ( n ) LIT, \ compile n as a literal THEN REPEAT \ CR .S ( debug line) 'NEXT' T, \ compile NEXT at end of new code word , \ compile CODE word's XT into Forth definition ; IMMEDIATE HERE SWAP - SPACE DECIMAL . .( bytes) \ ================================================== \ Test code NEW-HEAP HEX : FOREVER JIT[ 0 BEGIN 1+ AGAIN ] ; : JITWHILE JIT[ FFFF BEGIN DUP WHILE 1- REPEAT ] . ; : OPTCOUNTDN JIT[ FFFF BEGIN 1- DUP 0= UNTIL ] . ; : IFTEST JIT[ IF -1 ELSE 0 THEN ] . ; : FORTHFILL ( char --) C/SCR @ 0 DO DUP I VC! LOOP DROP ; : FORTHTEST [CHAR] Z BL DO I FORTHFILL LOOP ; : OPT2FILL C/SCR @ 0 DO JIT[ DUP I VC! ] LOOP DROP ; : INNEROPT [CHAR] Z BL DO I OPT2FILL LOOP ; : OPTFILL ( char --) JIT[ C/SCR @ 0 DO DUP I VC! LOOP DROP ] ; : LOOPOPT [CHAR] Z BL DO I OPTFILL LOOP ; : FULLOPT [CHAR] Z JIT[ BL DO I C/SCR @ 0 DO DUP I VC! LOOP DROP LOOP ] ; 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 15, 2022 Author Share Posted November 15, 2022 While trying to make my optimizer swallow multiple lines, I was reading up about the Forth word REFILL which is not implemented in Camel Forth. REFILL - CORE EXT (forth-standard.org) There are three versions of the darn thing. One for console, one for files and one BLOCKs. I have always used a temp buffer for INCLUDEing files but I got the sense from REFILL that I could read files into TIB so I tried it. So far it sems to work fine. Nested INCLUDEs work just like before. To be honest I am not 100% why. ?? I have not built REFILL yet, but I seem to have the pieces to do it. I called this FGET which reads a record into VDP RAM and now it transfers it to TIB. : FGET ( -- tib len) \ read file buffer->TIB TIB [PAB FBUFF] V@ OVER [PAB CHARS] VC@ DUP>R VREAD R> ; For reference here is INCLUDED from the kernel Spoiler : INCLUDED ( caddr len -- ) ?FILE CR T." Loading: " 2DUP TYPE SOURCE-ID @ >IN @ 2>R \ save source-ID, input pointer PSZ NEGATE ^PAB +! \ make new PAB, on pab stack ( $ len ) 50 14 FOPEN ?FILERR \ OPEN as 80 FIXED DV80 INPUT SOURCE-ID 1+! \ incr. source ID (1st file is 1) LINES OFF \ reset the line counter BEGIN 2 FILEOP 0= \ file read operation WHILE FGET INTERPRET \ interpret the buffer LINES 1+! \ count the line REPEAT PSZ ^PAB +! \ remove PAB from pab stack 2R> >IN ! SOURCE-ID ! \ restore >IN, SOURCE-ID ; 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 19, 2022 Author Share Posted November 19, 2022 (edited) I needed a distraction from native code generation so today I got something working that I always wanted. I have a SUPERCART version of Camel99 Forth, which is amazing because it frees up 8K of HI RAM, and still allows one to change the kernel if need be. However it is kind of an orphan. The existing SAVESYS word doesn't know how to deal with it and so you could never make stand-alone binaries with it. I fixed that today with SUPERSAVE. I also went one step further. I added a SAVEHEAP function. If your program moves the H variable ie: uses some LOW RAM at >2000, that gets saved as well as a separate image file. And when the program wakes up the value of H is persevered. preserved. (Damned spelled check) (I could add one more module to save VDP RAM as well but that's for another day) In this test file I load a bunch of libraries and I also put 4660 bytes of CHAR '#' in low RAM and save it as a "fat" Forth called DEVSYS. Spoiler CR .( SUPERSAVE.FTH for SUPERCART Camel99 Forth Nov2022 B Fox) \ creates a binary program E/A 5 format. \ Makes as many files as needed to save the system \ For SUPERCART we must save the kernel at >6000 as the primary file. \ IF the heap is used (H<>$2000) the HEAP is also saved. \ ALL the memory from >A000 to end of dictioanry is saved as secondary files \ test: load up libaries INCLUDE DSK1.TOOLS INCLUDE DSK1.ELAPSE INCLUDE DSK1.GRAFIX INCLUDE DSK1.AUTOMOTION INCLUDE DSK1.WORDLISTS NEEDS LOCK FROM DSK1.MARKER : NEWBOOT WARM INIT-WORDLISTS ABORT ; \ new init word for the system LOCK \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ nothing past here will be in the image. NEEDS LOAD-FILE FROM DSK1.LOADSAVE \ we use SAVE-FILE from this library HERE HEX A000 CONSTANT HIMEM 1000 CONSTANT VDPBUFF 2000 CONSTANT 8K 2000 CONSTANT LOWRAM 13 CONSTANT PROG \ file mode for Program files 3 CELLS CONSTANT HEADLEN 8K 3 CELLS - CONSTANT MAXSIZE \ define the file header fields. *THESE ARE VDP ADDRESSES* VDPBUFF CONSTANT MULTIFLAG VDPBUFF 1 CELLS + CONSTANT PROGSIZE VDPBUFF 2 CELLS + CONSTANT LOADADDR VDPBUFF HEADLEN + CONSTANT CODEBUFF \ COPY 8K program chunks to here VARIABLE FILECOUNT : ?LOCK ORGDP @ A100 < IF BEEP CR ." WARNING: missing LOCK directive" CR THEN ; : ENDMEM ( -- addr ) ?LOCK ORGDP @ ; \ words to compute the himmem parts of the system : ?SIZE DUP 8K > ABORT" Code to big" ; : SYS-SIZE ( -- n) ENDMEM HIMEM - ; : #FILES ( -- n) SYS-SIZE 8K /MOD SWAP IF 1+ THEN ; : CODECHUNK ( n -- addr) MAXSIZE * HIMEM + ; : CHUNKSIZE ( n -- n ) ENDMEM SWAP CODECHUNK - MAXSIZE MIN ; : ?PATH ( addr len -- addr len ) 2DUP [CHAR] . SCAN NIP 0= ABORT" Path expected" ; CREATE FILE$ ( -- caddr) 20 ALLOT : FILENAME ( -- addr len) FILE$ COUNT ; : LASTCHAR++ ( Caddr len --) 1- + 1 SWAP C+! ; : SAVE-IMAGE ( addr len Vaddr size -- ) CR ." Writing file: " FILENAME TYPE HEADLEN + PROG SAVE-FILE FILENAME LASTCHAR++ FILECOUNT 1+! ; : HEADER ( addr size ?) \ store header info in VDP RAM MULTIFLAG V! PROGSIZE V! LOADADDR V! ; \ kernel ................ HEX 6000 CONSTANT KERNORG ' ; 20 + KERNORG - CONSTANT KERNSIZE \ last word in kernel is ';' HEX : SAVEKERNEL ( xt -- <textpath> ) BOOT ! PARSE-NAME ?PATH FILE$ PLACE KERNORG KERNSIZE TRUE HEADER ( Kernel always needs more files ) KERNORG CODEBUFF KERNSIZE VWRITE \ copy kernel to VDP FILENAME VDPBUFF KERNSIZE SAVE-IMAGE ; : HEAPSIZE ( -- n) H @ LOWRAM - ; : SAVEHEAP ( -- ) HEAPSIZE IF LOWRAM HEAPSIZE DUP>R TRUE HEADER LOWRAM CODEBUFF R@ VWRITE \ copy HEAP to VDP FILENAME VDPBUFF R> SAVE-IMAGE THEN ; INCLUDE DSK1.UDOTR : .BYTES&ADDR ( addr size --) DECIMAL 5 U.R ." bytes, at " HEX ." >" 4 U.R ; HEX : REPORT CR CR ." Kernel: " KERNORG KERNSIZE .BYTES&ADDR CR ." Himem : " HIMEM ORGDP @ OVER - .BYTES&ADDR CR ." Heap : " LOWRAM HEAPSIZE .BYTES&ADDR CR ." Saved in " FILECOUNT @ . ." EA5 files" CR ; : SAVEHIMEM ( -- <textpath> ) #FILES 0 ?DO \ Init file header in VDP RAM I CODECHUNK I CHUNKSIZE I 1+ #FILES <> HEADER LOADADDR V@ CODEBUFF PROGSIZE V@ HEADLEN + VWRITE FILENAME VDPBUFF PROGSIZE V@ SAVE-IMAGE LOOP ; : SUPERSAVE ( xt -- <path>) SAVEKERNEL SAVEHEAP SAVEHIMEM REPORT ; ' NEWBOOT SUPERSAVE DSK7.DEVSYS supersave.mp4 Edited November 20, 2022 by TheBF typo 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 20, 2022 Author Share Posted November 20, 2022 Building this SUPERSAVE has opened up a range of options that has me excited. I must have been sleeping on it because I woke up with these ideas. 1. DTC Forth needs more space. (The kernel alone takes ~500 extra bytes) I had abandoned DTC because it really needs the Supercart version, but I could not make fast loading applications. Now you can use SuperCart for the Kernel and compile what you need then save it all off as an application or a FAT Forth that loads in seconds. (Just tested the existing SUPERSAVE code on DTC) 2. With a little more effort I can save SAMS pages as a sequence of binary program files. Then with a simple loader I can pull them back into the machine. If I put that together with the SAMSCODE library I can put SAMS Forth headers at A000 to DFFF, and use E000 to EFFF as a SAMS "code segment". That would create a SAMS based Forth that works pretty much like normal Forth. At the moment you still have to manually specify the code page that the compiler uses but the headers have a SAMS page field so running code is seamless. --- DTC Surprise Observation: I spent a lot of time improving the DOES> runtime in the Camel99 ITC version. It leverages the BL instruction to speed it up. TCREATE: DODOES ( -- a-addr) TOS PUSH, \ save TOS reg on data stack W TOS MOV, \ put defined word's PFA in TOS IP RPUSH, \ push old IP onto return stack R11 IP MOV, \ R11 has the new PFA -> IP NEXT, DTC has to do a bit more work. BL is already used for each Forth word to call _DOCOL. Means I can't use it again to get to _DODOES. l: _DODOES ( -- a-addr) TOS PUSH, \ save TOS reg on data stack R11 TOS MOV, \ After BL, R11 has defined word's PFA. Move to TOS IP RPUSH, \ save current IP on return stack -2 (R11) IP MOV, \ CFA to Forth IP IP 4 ADDI, \ cfa>pfa of the defined word. NEXT, I use the compile time of the Assembler as test of compiling speed. With ITC Forth it is ~13.5 seconds. I was shocked to see that DTC Forth did the same job in ~17 seconds! Other files compile faster with DTC, but I think the lower efficiency of DOES> in DTC is the culprit in the Assembler code. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 21, 2022 Author Share Posted November 21, 2022 (edited) SAMS Code save/load Tests In my SAMSCODE project I limited the code to the top 16 PAGES of the 1M card, so 64K of Forth code potential. I can't imagine a project on TI-99 that would need more code and I suspect the headers would fill the HI-RAM by then. TBD. Simple re-working the SUPERSAVE code gave me the save routine. SAMSCODE gave me a fast CMAP function. This test version saves all 64K. The video shows the speed to save 64k. In reality each page might not be full and we won't save pages that have no code. The loader works like the EA/5 loader and keeps "SLOADing" files until the flag field=0. Looks like I can make this work. (Way more code here than I really want) Spoiler \ SAMSLOADER.FTH E/A file loader for CAMEL99 Forth Nov 2022 Brian Fox MARKER /LOADER NEEDS FAR: FROM DSK1.SAMSCODE NEEDS LOAD-FILE FROM DSK1.LOADSAVE HEX 1000 VP ! \ beginning of free VDP RAM \ define the file header fields in *VDP RAM* VP @ CONSTANT MULTIFLAG VP @ 1 CELLS + CONSTANT PROGSIZE VP @ 2 CELLS + CONSTANT LOADADDR VP @ 3 CELLS + CONSTANT CODEBUFF \ COPY 8K program chunks to here 13 CONSTANT PROG \ file mode for Program files 1000 CONSTANT 4K 3000 CONSTANT CSEG : LASTCHAR++ ( Caddr len --) 1- + 1 SWAP C+! ; : HEADER ( addr size ?) \ store header info in VDP RAM MULTIFLAG V! PROGSIZE V! LOADADDR V! ; CREATE FILE$ 20 ALLOT : FILENAME ( -- addr len) FILE$ COUNT ; : SAMSAVE ( $adr len Vaddr size page# -- ) CR ." Writing SAMS page " . ." to " FILENAME TYPE PROG SAVE-FILE FILENAME LASTCHAR++ ; : SAVE-SAMS ( $adr len 1st last -- ) 2SWAP FILE$ PLACE 1+ SWAP DO I CMAP \ loadaddr size multiflag CSEG 4K 3 CELLS + I _MAXBANK <> HEADER LOADADDR V@ CODEBUFF PROGSIZE V@ VWRITE FILENAME VP @ PROGSIZE V@ I SAMSAVE LOOP ; \ sams loader -------------------------------------------------- : SLOAD ( page# -- ?) \ 4K max code size. FILE$ must be set CMAP FILENAME VP @ 4K 6 + PROG LOAD-FILE \ read into VDP RAM CODEBUFF CSEG PROGSIZE V@ 6 - VREAD \ read VDP to CPU RAM FILENAME LASTCHAR++ MULTIFLAG V@ \ return the multi-file flag ; : LOAD-SAMS ( addr len 1stpage -- ) >R FILE$ PLACE BEGIN R@ SLOAD WHILE R> 1+ >R REPEAT R> DROP ; \ TEST TOOLS HEX : FILLSAMS 100 0F0 DO I CMAP CSEG 4K I FILL LOOP ; : CLEARSAMS 100 0F0 DO I CMAP CSEG 4K 0 FILL LOOP ; SAMS2DISK.mp4 Edited November 21, 2022 by TheBF fixed comment 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 21, 2022 Author Share Posted November 21, 2022 (edited) Since it looks like I may start compiling code into SAMS memory as a matter of course I thought I should fix a little bug waiting to happen in my FAR: compiler. In the original code I used R1 as the page argument in _CMAP, the mapping sub-routine, which would totally blow up if you tried to use VDP routines, for example by using .S to debug some code. Didn't notice that until just recently. So it was back into the code and I am now using the return stack to pass the argument to _CMAP. This works well because FAR: pushes things onto the return stack anyway so it seems consistent for ;FAR to pickup the old SAM page from the return stack. Another thing in the old code that bugged me was that I maintained an array of dictionary pointers, one for each SAMS page that could have code in it. That's crazy when you have a 1M memory card. The array is removed and replaced by using the last memory location in a SAMS code page as a variable. This meant that I had to pull the SAMS page into the window a bit earlier to get at that memory location but it a much better solution because now any SAMS page can be used for code. The system now just needs you to initialize that memory location once with the word FIRSTUSE. After that you just select it with CODEPAGE as required. Example: PASSTHRU CMAP \ init the bank# variable to default memory page DECIMAL 16 CODEPAGE FIRSTUSE FAR: HELLO CR ." Hello SAMS World!" ;FAR 17 CODEPAGE FIRSTUSE FAR: NESTED1 ." nesting 1" ;FAR 18 CODEPAGE FIRSTUSE FAR: NESTED2 NESTED1 ." 2 " ;FAR 19 CODEPAGE FIRSTUSE FAR: NESTED3 NESTED2 ." 3 " ;FAR 16 CODEPAGE ( Use this page again ) FAR: GO NESTED3 HELLO ;FAR Spoiler \ SAMSCODE.FTH for Camel99 Forth Brian Fox \ Code in SAMS memory based on concept in TurboForth by Mark Wills \ Ported to Camel99 Forth with changes Oct 13, 2021, \ Concept: \ FAR: word headers are in the normal Forth memory space so all SAMS words \ can be found. \ FAR: word data structure has two extra fields \ <link> < HEADER> <imm> <len NAME..> <FARCOL> <BANK#> , <IP> , \ FAR: compiles a "fat" header that remember SAMS BANK# and SAMS IP \ ;FAR compiles FARSEMIS in SAMS memory, not in RAM Dictionary to save space. \ Compile time check: ;FAR tests for SAMS memory \ Smart MAP. Remembers the last SAMS page that was mapped. (BANK#) \ Only performs a MAP if it's a new SAMS page \ Update Nov 2022: removed array of SAMS DP variables. \ - Each SAMS page uses last memory cell to hold its own DP. \ - Can now compile code to any SAMS page. \ - You must use ( n) CODEPAGE FIRSTUSE the first time you use a page NEEDS SAMSINI FROM DSK1.SAMSINI \ common code for SAMS card HERE HEX \ **************[ CHANGE CSEG to your requirements ]****************** HEX 3000 CONSTANT CSEG \ CODE window in CPU RAM \ ******************************************************************** \ Derived SAMS memory addresses for code CSEG 0FFE + CONSTANT SAMSDP \ variable at end of SAMS page 4000 CSEG 0B RSHIFT + CONSTANT CREG \ compute CSEG SAMS register CSEG 0C RSHIFT CONSTANT PASSTHRU \ default page for CSEG VARIABLE SAVHERE \ temp holder for RAM Dictionary pointer VARIABLE BANK# \ last SAMS bank# selected VARIABLE CPAGE \ active code page used for compiling HEX \ **LEAF SUB-ROUTINE** CREATE _CMAP ( -- ) ( R: page# -- ) R0 RPOP, \ POP parameter from Rstack R0 BANK# @@ CMP, \ already mapped? NE IF, R0 BANK# @@ MOV, \ update the last bank used R0 SWPB, \ swap bytes R12 1E00 LI, \ set SAMS card CRU address 0 SBO, \ turn on the card R0 CREG @@ MOV, \ map it 0 SBZ, \ turn off card ENDIF, RT, CODE CMAP ( page# --) \ Forth word to map SAMS pages TOS RPUSH, \ need parameter on Rstack _CMAP @@ BL, \ call it TOS POP, \ refill TOS NEXT, ENDCODE \ run time executor for SAMS colon words. CREATE FARCOL IP RPUSH, W IP MOV, \ IP = DATA cell of this word BANK# @@ RPUSH, \ Rpush the currently active SAMS bank *IP+ RPUSH, \ fetch bank# in PFA & save on return stack _CMAP @@ BL, \ call _CMAP (uses RSTACK parameter) *IP IP MOV, \ get SAMS DP & set new IP NEXT, CODE FAREXIT \ exit for SAMS word _CMAP @@ BL, \ RSTACK has old BANK#, map it in IP RPOP, \ Regular FORTH EXIT NEXT, ENDCODE \ \\\\\\\\\\\\\\\\ code words end ////////////////// : FAR: ( -- ) \ special colon for words in FAR memory !CSP HEADER \ compile Forth header with name FARCOL , \ compile the new executor as CFA CPAGE @ DUP , \ compile codepage as the DATA field CMAP \ pull in the SAMS page SAMSDP @ DUP , \ SAMSDP is this word's IP address HERE SAVHERE ! \ save "normal here" ( samsdp) DP ! \ set Forth DP to SAMSDP. Compiling to SAMS now HIDE ] \ turn on the compiler ; : ;FAR ( -- ) \ end SAMS compilation. *NEW* compile time memory test POSTPONE FAREXIT \ compiles at end of SAMS code POSTPONE [ \ turn compiler off REVEAL ?CSP HERE DUP SAMSDP ! \ update HERE for this bank, keep a copy SAVHERE @ DP ! \ restore DP to CPU RAM CSEG 0FF8 + > ABORT" SAMS bank full" ; IMMEDIATE HEX : CODEPAGE ( bank# -- ) CPAGE ! ; \ select SAMS page for compiling : FIRSTUSE CPAGE @ CMAP CSEG 1000 FF FILL \ fill is for debugging CSEG SAMSDP ! \ set the local CSEG DP variable to start of CSEG ; HERE SWAP - DECIMAL CR . .( bytes) Edited November 21, 2022 by TheBF error test had wrong constant 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2022 Author Share Posted November 22, 2022 This SAMS compilation is great but there is one thing you can't do with this "fat" header for SAMS compilation. Things that involve ' and CREATE DOES> do not work with this bigger header. Tick is returning a code field in RAM but the real XT of the word is in SAMS memory. This will also affect EXECUTE and PERFORM. At the moment this affects VALUE and DEFER when I built them with CREATE DOES>/ These could be redone using primitives like HEADER and COMPILE, but it's not that big of deal. It means you compile those kinds of words in conventional RAM. It was easy everybody would be doing it. Hmm.. at the moment I have defined a SAMS vocabulary with special version of : and ; Maybe I can make a new tick as well... Edit: Never easy. New tick is simple but DOES> needs to know how to pull in a SAMS page before running some code. Makes my head spin. It's going to be caveat emptor for now. 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted November 22, 2022 Share Posted November 22, 2022 I got around this by building the headers for SAMS-hosted words in conventional dictionary, and compiling a trampoline function that, upon execution, pages in the appropriate bank, and does a simple branch to word in SAMS memory. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2022 Author Share Posted November 22, 2022 5 hours ago, Willsy said: I got around this by building the headers for SAMS-hosted words in conventional dictionary, and compiling a trampoline function that, upon execution, pages in the appropriate bank, and does a simple branch to word in SAMS memory. Your code sent me down this path. I used your concept, (credits in the file) but wanted to see if I could improve it. Write the hard working code in Assembler. reduce the size of the dictionary entries by putting the Exit code in SAMS memory FAREXIT has been recently improved to be one BL to _CMAP plus Forth's EXIT code. Use the return stack to linkage write a "docol" for SAMS words (called it FARCOL) for faster entry. Make the mapping code as fast as possible. Remove the HERE pointers and keep each pointer in its own SAMS page ( EDIT) The speed is excellent now but it won't compile "compiling" words in SAMS. It is because of the different header size now. \ run time executor for SAMS colon words. CREATE FARCOL IP RPUSH, W IP MOV, \ IP = DATA cell of this word BANK# @@ RPUSH, \ Rpush the currently active SAMS bank *IP+ RPUSH, \ fetch bank# in PFA & save on return stack _CMAP @@ BL, \ call _CMAP (uses RSTACK parameter) *IP IP MOV, \ get SAMS DP & set new IP NEXT, CODE FAREXIT \ exit for SAMS word _CMAP @@ BL, \ RSTACK has old BANK#, map it in IP RPOP, \ Regular FORTH EXIT NEXT, ENDCODE In one benchmark I tested I split the code with half in one bank and the other half in a 2nd calling back and forth continuously. The difference from normal Forth and SAMS version was almost nothing. I think I can find the compromise between the two. Keep standard Forth header with DOCOL Entry to SAMS words can be written as a CODE word instead of Forth. (I had something like this first. Gotta find that) Use Return stack for linkage Fast FAREXIT code Thanks for making me think this over. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 23, 2022 Author Share Posted November 23, 2022 My first round at translating Marks code last year works perfectly. I used DEFER as a test bed because it blew up so completely. I have written a few variants of my changes and they all fail on DEFER. So, I will go back to Mark's methods and slowly add my "improvements" one at a time until I find the culprit. It could be that the return stack can't be used but I can't understand why at the moment. I think I can do these changes: reduce the size of the dictionary entries by putting the Exit code in SAMS memory Use the return stack to linkage Make the mapping code as fast as possible. (done. 6 instructions) Remove the HERE pointers and keep each pointer in its own SAMS page Here is my working translation Spoiler \ Code in SAMS memory based on TurboForth by Mark Wills \ Translation to Camel99 Forth Sept 30 2021 NEEDS MARKER FROM DSK1.MARKER NEEDS VALUE FROM DSK1.VALUES NEEDS DUMP FROM DSK1.TOOLS NEEDS MOV, FROM DSK1.ASM9900 HERE DECIMAL CREATE HERES 32 CELLS ALLOT HEX CODE ]HERE ( ndx -- addr ) A104 , \ TOS TOS ADD, 0224 , HERES , \ TOS SAT AI, NEXT, ENDCODE \ SAMS memory management for code HEX 3000 CONSTANT CSEG \ code seg in CPU RAM 4000 CSEG 0B RSHIFT + CONSTANT CREG \ compute CSEG SAMS register \ CSEG 0C RSHIFT CONSTANT PASSTHRU \ default page for CSEG \ CMAP brings pages of code into the window called CSEG \ The SAMS register is pre-calculated as constant CREG CODE CMAP ( bank# -- ) TOS SWPB, R12 1E00 LI, 0 SBO, \ turn on the card TOS CREG @@ MOV, \ store bank# in SAMS register 0 SBZ, \ turn off card TOS POP, \ refill top of stack register NEXT, ENDCODE -1 VALUE _BANK \ current bank 0 VALUE _MAXBANK 0 VALUE _NHERE \ _____________________________________________ \ Stack to handle pages DECIMAL CREATE BS0 20 CELLS ALLOT CREATE BSP BS0 , \ stack pointer, initialzed to BS0 \ : BSDEPTH ( -- n) BSP @ BS0 - 2/ ; : >BS ( bank# --) DUP 2 BSP +! BSP @ ! CMAP ; : BS> ( -- bank#) BSP @ \ DUP BS0 = ABORT" Bank stack underflow" \ remove line for speed @ CMAP -2 BSP +! ; HEX 0 >BS \ force first entry on bank stack to SAMS page 0 HEX : BANKS ( n -- ) \ reserve space for here pointers for n banks DUP TO _MAXBANK DUP 1+ 0 DO CSEG I ]HERE ! LOOP \ init "here" for each bank CR 4 * . ." K of SAMS reserved." CR ; \ TF uses address branching. Camel Forth uses Offset branching. \ GOTO lets us do a direct branch to a literal address in the Forth code CODE GOTO ( addr -- ) *IP IP MOV, NEXT, ENDCODE : FAR: ( -- ) : \ compile header in CPU RAM \ Run-time action POSTPONE LIT _BANK , \ compile my bank# POSTPONE >BS \ push my bank# and MAP POSTPONE GOTO _BANK ]HERE @ DUP , \ compile jump to here for this bank \ compile-time action HERE TO _NHERE \ save "normal here" DP ! \ set dp to _bank's "here" _BANK CMAP \ map in the appropriate bank ; : ;FAR ( -- ) \ end banked compilation POSTPONE GOTO _NHERE , HERE _BANK ]HERE ! \ update here for bank _NHERE DP ! \ restore dp to "normal" memory POSTPONE BS> POSTPONE ; ; IMMEDIATE HEX : _BFREE ( -- n) 4000 _BANK ]HERE @ - ; : .BFREE ( -- ) DECIMAL CR ." Bank# " _BANK . ." , " _BFREE . ." bytes free." CR ; : CODEPAGE ( bank -- ) DUP _MAXBANK 0 WITHIN ABORT" Bad bank number" DUP TO _BANK CMAP .BFREE ; HERE SWAP - DECIMAL CR . .( bytes) 3 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 23, 2022 Share Posted November 23, 2022 (edited) Moved my question to another post .. Edited November 23, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 23, 2022 Author Share Posted November 23, 2022 I went back to Mark's code with a translation harness to try and get a stable starting place. I even emulated the >MAP function from TF but using SAMS Forth primitives. I re-discovered that I had to make the SAMS semi-colon IMMEDIATE to work in Camel Forth. DEFER works as expected There are some buggy things too: Simple CREATE DOES> worked in testing but something dies when I compile the Assembler. For some reason the last definition in a SAMS block sometimes does not return normally. (The last definition might be getting overwritten by something in my system that uses HERE) ? It's remarkable that it ports as easy as it does. Spoiler \ Literal translation from TF to Camel99 \ HARNESS for CAMEL99 =================================================== INCLUDE DSK1.TOOLS \ debug only INCLUDE DSK1.SAMSINI INCLUDE DSK1.VALUES HERE HEX 3000 CONSTANT $3000 4000 CONSTANT $4000 \ SAMS CARD management HEX $3000 CONSTANT CSEG \ CPU RAM window for SAMS code $4000 CSEG 0B RSHIFT + CONSTANT CREG \ pre-compute CSEG SAMS register CSEG 0C RSHIFT CONSTANT PASSTHRU \ default page for CSEG \ reproduce TF function : >MAP ( bank# window-- ) DROP \ don't need address in this version >< \ swap bytes SAMSCARD \ Select SAMS Card 0SBO \ turn on the card ( bank#) CREG ! \ store bank# in SAMS register 0SBZ ; \ turn off card \ TF uses address branching. Camel Forth uses Offset branching. \ BRANCH lets us do a direct branch to a literal address in the Forth code HEX CODE BRANCH ( addr -- ) C259 , ( *IP IP MOV,) NEXT, ENDCODE \ ===================================================================== \ turbo forth code ( replaced H with DP ) ( replaced COMPILE and [COMPILE] with POSTPONE ) DECIMAL CREATE _BNKSTK 20 CELLS ALLOT \ bank stack \ when Turbo Forth is in its "default" configuration the second \ half of the 8K memory expansion (>3000) is set to SAMS page \ >F9. The following line of code initialises the first page of \ the bank stack to page F9. This ensures that when executing \ nested bank/pages, when it all unwinds, the default page is \ swapped into memory. HEX F9F9 _BNKSTK ! \ force first entry on bank stack to $f9 _BNKSTK VALUE _BSP \ pointer into bank stack -1 VALUE _BANK \ current bank 0 VALUE _HERES \ holds "here" for each bank 0 VALUE _NHERE \ "normal" here 0 VALUE _MAXBANK : >BANK ( BANK -- ) \ push bank to bank stack 2 +TO _BSP DUP _BSP ! $3000 >MAP ; : BANK> ( -- ) \ POP BANK FROM BANK STACK -2 +TO _BSP _BSP @ $3000 >MAP ; : BANKS ( N -- ) \ reserve space for here pointers for n banks HERE TO _HERES DUP TO _MAXBANK DUP 0 DO $3000 , LOOP \ init "here" for each bank to $3000 CR 4 * U. ." K of banked memory reserved." CR ; \ ** added this for code clarity ** : SAMSDP ( -- addr) _BANK CELLS _HERES + ; : B: ( BANK -- ) \ begin compiling a banked definition in bank bank _BANK -1 <> IF : POSTPONE LIT _BANK , POSTPONE >BANK POSTPONE BRANCH SAMSDP @ DUP , HERE TO _NHERE \ save "normal here" DP ! \ set dp to _bank's "here" _BANK $3000 >MAP \ map in the appropriate bank ELSE : THEN ; : _BFREE ( -- ) \ determine free memory in the bank... $4000 SAMSDP @ - . ." BYTES FREE." CR ; : ;B ( -- ) \ end banked compilation POSTPONE BRANCH _NHERE , HERE SAMSDP ! \ update here for bank _BFREE _NHERE DP ! \ restore dp to "normal" memory POSTPONE BANK> POSTPONE ; ; IMMEDIATE ( had to add immediate for CAMEL99 ) : SETBANK ( BANK -- ) \ sets the bank number that will receive colon definitions DUP -1 _MAXBANK WITHIN IF TO _BANK _BANK -1 <> IF CR ." Bank " _BANK . ." is now active. " _BFREE ELSE CR ." Compiling to standard 32K memory." CR THEN ELSE TRUE ABORT" Illegal bank number specified" THEN ; : : ( -- ) \ banked / non-banked compilation _BANK -1 = IF : ELSE B: THEN ; : ; ( -- ) _BANK -1 = IF POSTPONE ; ELSE POSTPONE ;B \ ;b is immediate in camel99 forth THEN ; IMMEDIATE HERE SWAP - DECIMAL . .( bytes) This benchmark code using Forth for SAMS paging, is slower than running from normal RAM by about 2%. When I ran it with CODE word switching it was about 0.4% slower. Spoiler \ DEMO: Compile code in CPU RAM & SAMS memory and compare speed May 2022 BFox 20 BANKS -1 SETBANK INCLUDE DSK1.ELAPSE HEX 5 CONSTANT FIVE 100 CONSTANT MASK 0 VALUE BVAR : INNERBENCH BEGIN DUP SWAP DUP ROT DROP 1 AND IF FIVE + ELSE 1- THEN TO BVAR BVAR DUP MASK AND UNTIL ; : BENCHIE MASK 0 DO 1 INNERBENCH DROP LOOP ; \ 25.55 seconds \ __________________________________________ 1 SETBANK : INNERBENCH2 BEGIN DUP SWAP DUP ROT DROP 1 AND IF FIVE + ELSE 1- THEN TO BVAR BVAR DUP MASK AND UNTIL ; 2 SETBANK : BENCHIE2 MASK 0 DO 1 INNERBENCH2 DROP LOOP ; \ 26.03 seconds using Forth >MAP CR .( To test: BENCHIE: ) CR .( ELAPSE BENCHIE ) CR .( ELAPSE BENCHIE2) CR .( ~25 seconds) 3 Quote Link to comment Share on other sites More sharing options...
Willsy Posted November 24, 2022 Share Posted November 24, 2022 I like how much code it isn't! When you consider the functionality it adds, it's remarkable how little code is required. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 24, 2022 Author Share Posted November 24, 2022 10 hours ago, Willsy said: I like how much code it isn't! When you consider the functionality it adds, it's remarkable how little code is required. I am having hard time making it better. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 30, 2022 Author Share Posted November 30, 2022 I have been trying for some time now to learn how to make a native code compiler for Forth. It's something was always amazed by back in the '90s with TCOM by Tom Zimmer and FORTHCOM by Thomas Almy. I don't have the whole thing figured out yet, but I now have a beginning with a just-in-time compiler for a subset of Forth. It only took me 30 years. One the things that was driving me nuts was making the Forth compile/interpret loop do the correct thing. Making the looping words IMMEDIATE was the key and using a vocabulary with search order control really simplified things. This method does only 3 things: IMMEDIATE looping and branching words that compile machine code. The JIT versions of the words are found first by putting the JITS vocabulary 1st in the search order. When a code word is encountered, copy the machine code from Forth inline in the heap When a VARIABLE, CONSTANT or USER variable is encountered, it is compiled to the TOS register with the LI instruction So, this means it can only optimize CODE words, data words and loops and branches, but you can do a lot with that. My goal was to JIT compile the Byte Magazine sieve program without making a lot of changes to the source code. Here is the new code for the JIT. Things to note: 1. Addition of the NEW-HEAP command to erase the LOW RAM at >2000 and reset the H variable to >2000 2. Use the JIT: compiler only on the inner section because the JIT can't cope with all words 3. Move the printing of the result and the word "PRIMES" out of the computation section The regular code running on Camel99 takes 120 seconds. This JIT version runs in 50.1 seconds. It's a long way off from GCC at 15 seconds but I have a better understanding of why now and that's personal progress. Forth's use of the stack instead of registers is a slowdown, especially since I am not doing any push/pop removals here. (future) Another big one is not using the CPU features like symbolic and indexed addressing. That needs a bit of analysis by the compiler but using symbolic addressing is possible. (future) NEW-HEAP DECIMAL 8190 CONSTANT SIZE 0 VARIABLE FLAGS SIZE ALLOT 0 FLAGS ! JIT: DO-PRIME FLAGS SIZE 1 FILL 0 SIZE 0 DO FLAGS I + C@ IF I DUP + 3 + DUP I + BEGIN DUP SIZE < WHILE 0 OVER FLAGS + C! OVER + REPEAT DROP DROP 1+ THEN LOOP ;JIT : PRIMES ( -- ) PAGE ." 10 Iterations" 10 0 DO DO-PRIME CR . ." PRIMES" LOOP CR ." Done!" ; Here is the code. It compiles to 324 bytes (excluding the libraries) Spoiler \ jit.fth Compiles inline code as headless words in HEAP Nov 29 2022 \ Problem: \ ITC Forth spends 50% of it's time running 3 instructions called NEXT. \ This system compiles primitives from the kernel as super-instructions \ and compiles the execution token for the super instructions in a Forth word. NEEDS .S FROM DSK1.TOOLS NEEDS CASE FROM DSK1.CASE NEEDS LIFO: FROM DSK1.STACKS NEEDS ELAPSE FROM DSK1.ELAPSE NEEDS MARKER FROM DSK1.MARKER NEEDS WORDLIST FROM DSK1.WORDLISTS : EMPTY S" *CLEAN* MARKER *CLEAN*" EVALUATE ; MARKER *CLEAN* EMPTY HERE 8 LIFO: CS \ small CONTROL FLOW STACK for loops and branching : >CS ( n -- ) CS PUSH ; : CS> ( -- n ) CS POP ; : CS>SWAP ( -- ) CS> CS> SWAP >CS >CS ; : ?CS CS STACK-DEPTH ABORT" Un-match IF or loop" ; : ABORT" ( ? --) \ restores normal Forth interpreter DUP IF ['] <INTERP> 'IV ! THEN POSTPONE ABORT" ; IMMEDIATE HEX \ *** changed for kernel V2.69 *** \ Words in scratchpad RAM end in a JMP instruction, not NEXT \ Might change this, but for now make some conventional versions. CODE DUP 0646 , C584 , NEXT, ENDCODE CODE DROP C136 , NEXT, ENDCODE CODE ! C536 , C136 , NEXT, ENDCODE CODE @ C114 , NEXT, ENDCODE CODE C@ D114 , 0984 , NEXT, ENDCODE CODE + A136 , NEXT, ENDCODE \ Heap management : THERE ( -- addr) H @ ; \ returns end of Target memory in HEAP : HALLOT ( n -- ) H +! ; \ Allocate n bytes of target memory. : T, ( n -- ) THERE ! 2 HALLOT ; \ "target compile" n into heap : NEW-HEAP ( -- ) 2000 2000 0 FILL 2000 H ! ; \ reset HEAP 045A CONSTANT 'NEXT' \ 9900 CODE for B *R10 Camel99 Forth's NEXT code : CODE, ( xt --) \ Read code word from kernel, compile into target memory >BODY DUP 80 CELLS + \ 256 bytes is max size we will try to compile SWAP ( -- IPend IPstart) BEGIN DUP @ 'NEXT' <> \ the instruction is not 'NEXT' WHILE DUP @ ( -- IP instruction) T, \ compile instruction CELL+ \ advance IP 2DUP < ABORT" End of code not found" REPEAT 2DROP ; \ now we can steal code word from the kernel and compile it to target memory : DUP, ['] DUP CODE, ; : DROP, ['] DROP CODE, ; : 1-, ( n -- n') ['] 1- CODE, ; \ TOS DEC, : LIT, ( -- n) DUP, 0204 T, ( n) T, ; \ compile n as literal in TOS \ store a byte offset in odd byte of addr. \ Addr is the location of Jump instruction : RESOLVE ( addr offset --) 2- 2/ SWAP 1+ C! ; \ compute offset from addr addr' & complete the jump instruction : <BACK ( addr addr' -- ) TUCK - RESOLVE ; : ?BYTE ( c -- c) DUP FF00 AND ABORT" Jump out of range" ; \ compile misc. jump instructions with no offset. : JMP, ( c --) ?BYTE 1000 + T, ; : JNO, ( c --) ?BYTE 1900 + T, ; : JEQ, ( c --) ?BYTE 1300 + T, ; : JNE, ( c --) ?BYTE 1600 + T, ; : JOC, ( c --) ?BYTE 1800 + T, ; : JNC, ( c --) ?BYTE 1700 + T, ; \ --------[ JIT compilers for LOOPS and BRANCHING ]--------- \ When the JITS wordlist is placed 1st in the search order \ these immediate words will run in place of their normal Forth versions. \ These version compile machine code into the HEAP. \ In the case of DO it "steals" the code for setting up the loop \ from the kernel. VOCABULARY JITS ALSO JITS DEFINITIONS : BEGIN THERE >CS ; IMMEDIATE \ push location onto control stack \ <DO> is CODE preamble to setup return stack. : DO ( -- there) ['] <DO> CODE, POSTPONE BEGIN ; IMMEDIATE : LOOP 0597 T, \ *RP INC, CS> THERE 0 JNO, <BACK \ compute offset, compile into JNO ['] UNLOOP CODE, \ collapse stack frame ; IMMEDIATE : +LOOP 0A5CA T, \ TOS *RP ADD, DROP, \ don't need TOS value anymore POSTPONE LOOP \ compile loop code ; IMMEDIATE : AGAIN CS> THERE 0 JMP, <BACK ; IMMEDIATE : UNTIL 1-, DROP, CS> THERE 0 JNC, <BACK ; IMMEDIATE : IF ( n -- ) 1-, \ If tos=0, DEC will cause a carry DROP, THERE >CS 0 JNC, ; IMMEDIATE : THEN CS> THERE OVER - RESOLVE ; IMMEDIATE : ELSE THERE >CS 0 JMP, CS>SWAP POSTPONE THEN ; IMMEDIATE : WHILE ( n -- ) POSTPONE IF CS>SWAP ; IMMEDIATE : REPEAT POSTPONE AGAIN POSTPONE THEN ; IMMEDIATE \ -------------------------------------------------------------- FORTH DEFINITIONS \ CFA of a code word contains the address of the next cell : CODE? ( XT -- ?) DUP @ 2- = ; : JITCOMPILE, ( xt -- ) DUP CODE? IF CODE, EXIT THEN \ compile kernel code & exit \ xt is not a code word... DUP @ \ FETCH the "executor" address CASE ( data words ) ['] DOVAR OF >BODY LIT, ENDOF ['] DOCON OF EXECUTE LIT, ENDOF ['] DOUSER @ OF EXECUTE LIT, ENDOF TRUE ABORT" Can't optimize word" ( any other Forth word bombs) ENDCASE ; \ new interpreter loop \ 1. Executes Immediate words: BEGIN WHILE IF THEN etc. \ 2. Steals kernel code and compiles any CODE word. \ 3. ABORTS if you try to compile a Forth word \ 4. Compiles literal numbers with LI instruction : <JIT> ( -- addr) 'SOURCE 2! >IN OFF BEGIN BL WORD DUP C@ WHILE FIND ?DUP IF ( it's a word) 1+ STATE @ 0= OR IF EXECUTE \ IF BEGIN etc. are all immediate ELSE JITCOMPILE, \ code and data are not THEN ELSE COUNT NUMBER? ?ERR STATE @ IF LIT, THEN \ special number compiler THEN DEPTH 0< ABORT" JIT: Underflow" REPEAT DROP ; : JIT: ( -- JIT-xt) ALSO JITS : THERE ( -- XT) \ execution token (XT) for the NEW compiled code DUP CELL+ T, \ create the ITC header for a CODE word ['] <JIT> 'IV ! \ switch to JIT compiler ; : ;JIT ( JIT-XT -- ) PREVIOUS ['] <INTERP> 'IV ! 'NEXT' T, \ compile NEXT at end of new code word , \ compile CODE word's XT into Forth definition ?CS POSTPONE ; ; IMMEDIATE HERE SWAP - SPACE DECIMAL . .( bytes) FORTH-JIT-SIEVE.mp4 2 Quote Link to comment Share on other sites More sharing options...
Willsy Posted December 1, 2022 Share Posted December 1, 2022 Is your compiler doing any optimisations such as holding stack values in registers etc? That seems to be the (really) difficult bit. It's relatively easy to have the compiler just essentially copy and paste machine code into a definition, or compile a BL etc. to a machine code routine, but doing optimisations is where it gets really tricky. I wonder how VFX does it? Peephole/pinhole optimsations are relatively simple. I wrote one (un-finished) for TF that would replace oft used Forth incantations with optimised versions. It would replace sequences of words with optimised equivalents - the idea being the equivalents would be written in assembly. Looking at the code, the following (plus some others) are detected: swap 1+ swap swap 1- swap swap 2+ swap swap 2- swap swap 2* swap lit + lit - lit * lit = lit < lit > lit <= lit >= The excercise was to write the code to spot the patterns in the compiled code. After that it's easy to add optimisations. It's just a big CASE statement. Anyway, from a machine code point of view, how would you tackle (for example) this: : test 1 2 + ; Which (naively) would be (pseudo code): push 1 push 2 call + push result Into: LI R0, 3 ; result can be calculated at compile time since both parameters are constants MOV R0, *STACK+ ; push result Which is all that would be required in an optimised form. Interested to hear your thoughts. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 1, 2022 Author Share Posted December 1, 2022 4 hours ago, Willsy said: Is your compiler doing any optimisations such as holding stack values in registers etc? That seems to be the (really) difficult bit. It's relatively easy to have the compiler just essentially copy and paste machine code into a definition, or compile a BL etc. to a machine code routine, but doing optimisations is where it gets really tricky. I wonder how VFX does it? Peephole/pinhole optimsations are relatively simple. I wrote one (un-finished) for TF that would replace oft used Forth incantations with optimised versions. It would replace sequences of words with optimised equivalents - the idea being the equivalents would be written in assembly. Looking at the code, the following (plus some others) are detected: swap 1+ swap swap 1- swap swap 2+ swap swap 2- swap swap 2* swap lit + lit - lit * lit = lit < lit > lit <= lit >= The excercise was to write the code to spot the patterns in the compiled code. After that it's easy to add optimisations. It's just a big CASE statement. Anyway, from a machine code point of view, how would you tackle (for example) this: : test 1 2 + ; Which (naively) would be (pseudo code): push 1 push 2 call + push result Into: LI R0, 3 ; result can be calculated at compile time since both parameters are constants MOV R0, *STACK+ ; push result Which is all that would be required in an optimised form. Interested to hear your thoughts. At the moment it is totally naive. The big wins are removing NEXT and loops are way faster. LOOP is just 2 instructions. So this: JIT: DOTEST FFFF 0 DO LOOP ;JIT Compiles to: 2042 inc *R7 \ bump the index jno >2042 \ jump back if no overflow ai R7,>0004 \ unwind return stack b *R10 \ return to Forth And indeed, the hard parts are reliable effective optimizations. VFX, from what Stephen writes is using all the conventional compiler tricks that you would see in conventional compilers. In my machine Forth project, I made @ and ! and anything that might touch an address smart enough to use symbolic addressing if it could and that really works well for our old friend. I am noodling how to do that under this scheme and also how to reliably remove DROP/DUP code when they are back-to-back. This DROP/DUP happens a lot when you put TOS in a register because any primitive that consumes its arguments ends with DROP to refill the TOS register. For DROP/DUP removal I might just do a second pass after I compile it. Seems easier than doing it on the fly. I could probably use a string search to find the 6 bytes of code, and just MOVE the code after it six bytes to the left. Once you have that 2nd pass you could do anything. Your example with + is constant folding as I have recently learned and is part of Mecrisp Forth. I looked at the optimizing code and it is pretty involved. Thanks for reminding me that I have more work to do! 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 4, 2022 Author Share Posted December 4, 2022 I got a surprise today. I did the minor adjustments to the JIT compiler to make it work under direct threaded Forth. (DTC) It's mostly dealing with the differences in the headers of words. Spoiler \ jit.fth DTC VERSION Dec 4 2022 Brian Fox \ Compiles inline code as headless words in HEAP \ Problem: \ DTC Forth spends upto 50% of it's time running 2 instructions called NEXT. \ This system compiles primitives from the kernel as super-instructions \ and compiles the execution token for the super instructions in a Forth word. \ NEEDS .S FROM DSK1.TOOLS \ NEEDS ELAPSE FROM DSK1.ELAPSE NEEDS CASE FROM DSK1.CASE NEEDS LIFO: FROM DSK1.STACKS NEEDS WORDLIST FROM DSK1.WORDLISTS HERE 8 LIFO: CS \ small control flow stack for loops and branching : >CS ( n -- ) CS PUSH ; : CS> ( -- n ) CS POP ; : CS>SWAP ( -- ) CS> CS> SWAP >CS >CS ; : ?CS CS STACK-DEPTH ABORT" Un-match IF or loop" ; : ABORT" ( ? --) \ restores normal Forth interpreter DUP IF ['] <INTERP> 'IV ! THEN POSTPONE ABORT" ; IMMEDIATE HEX \ *** changed for kernel V2.69 *** \ Words in scratchpad RAM end in a JMP instruction, not NEXT \ Might change this, but for now make some conventional versions. CODE DUP 0646 , C584 , NEXT, ENDCODE CODE DROP C136 , NEXT, ENDCODE CODE ! C536 , C136 , NEXT, ENDCODE CODE @ C114 , NEXT, ENDCODE CODE C@ D114 , 0984 , NEXT, ENDCODE CODE + A136 , NEXT, ENDCODE \ CFA of a Forth word contains the BL @xxxx instruction : FORTH? ( xt -- ?) @ 06A0 = ; \ Heap management : THERE ( -- addr) H @ ; \ returns end of Target memory in HEAP : HALLOT ( n -- ) H +! ; \ Allocate n bytes of target memory. : T, ( n -- ) THERE ! 2 HALLOT ; \ "target compile" n into heap : NEW-HEAP ( -- ) 2000 2000 0 FILL 2000 H ! ; \ reset HEAP 045A CONSTANT 'NEXT' \ 9900 CODE for B *R10 Camel99 Forth's NEXT code : CODE, ( CODExt --) \ Read code word from kernel, compile to HEAP 80 CELLS ( -- addr len) BOUNDS ( -- IPend IPstart) BEGIN DUP @ 'NEXT' <> \ the instruction is not 'NEXT' WHILE DUP @ ( -- IP instruction) T, \ compile instruction CELL+ \ advance to next instruction 2DUP < ABORT" End of code not found" REPEAT 2DROP ; : COMPILES ( <codeword> ) POSTPONE ['] POSTPONE CODE, ; IMMEDIATE \ now we can steal code word from the kernel and compile it to target memory : DUP, COMPILES DUP ; HEX C136 CONSTANT 'DROP' \ 9900 machine code for DROP (*SP+ R4 MOV,) \ Forth primitive compilers : DROP, COMPILES DROP ; : 1-, ( n -- n') COMPILES 1- ; \ TOS DEC, : TOS!, ( n --) 0204 T, ( n) T, ; \ LI R4,nnnn : LIT, ( -- n) DUP, TOS!, ; \ compile n as literal in TOS \ store a byte offset in odd byte of addr. \ Addr is the location of Jump instruction : RESOLVE ( addr offset --) 2- 2/ SWAP 1+ C! ; \ compute offset from addr addr' & complete the jump instruction : <BACK ( addr addr' -- ) TUCK - RESOLVE ; : ?BYTE ( c -- c) DUP FF00 AND ABORT" Jump out of range" ; \ compile jump instructions with no offset : JMP, ( c --) ?BYTE 1000 + T, ; : JNO, ( c --) ?BYTE 1900 + T, ; : JNC, ( c --) ?BYTE 1700 + T, ; \ --------[ JIT compilers for LOOPS and BRANCHING ]--------- \ When the JITS wordlist is placed 1st in the search order \ these immediate words will run in place of their normal Forth versions. \ These version compile machine code into the HEAP. \ In the case of DO it "steals" the code for setting up the loop \ from the kernel. VOCABULARY JITS ALSO JITS DEFINITIONS : BEGIN THERE >CS ; IMMEDIATE \ push location onto control stack \ <DO> is CODE preamble to setup return stack. : DO ( -- there) COMPILES <DO> POSTPONE BEGIN ; IMMEDIATE : LOOP 0597 T, \ *RP INC, CS> THERE 0 JNO, <BACK \ compute offset, compile into JNO COMPILES UNLOOP \ collapse stack frame ; IMMEDIATE : +LOOP 0A5CA T, \ TOS *RP ADD, DROP, \ don't need TOS value anymore POSTPONE LOOP \ compile loop code ; IMMEDIATE : AGAIN CS> THERE 0 JMP, <BACK ; IMMEDIATE : UNTIL 1-, DROP, CS> THERE 0 JNC, <BACK ; IMMEDIATE : IF ( n -- ) 1-, \ If tos=0, DEC will cause a carry DROP, THERE >CS 0 JNC, ; IMMEDIATE : THEN CS> THERE OVER - RESOLVE ; IMMEDIATE : ELSE THERE >CS 0 JMP, CS>SWAP POSTPONE THEN ; IMMEDIATE : WHILE ( n -- ) POSTPONE IF CS>SWAP ; IMMEDIATE : REPEAT POSTPONE AGAIN POSTPONE THEN ; IMMEDIATE \ -------------------------------------------------------------- FORTH DEFINITIONS \ In DTC ad CODE word does not begin with BL instruction : CODE? ( XT -- ?) FORTH? 0= ; : JITCOMPILE, ( xt -- ) DUP CODE? IF CODE, EXIT THEN \ compile kernel code & exit \ xt is not a code word... DUP CELL+ @ \ FETCH the "executor" address CASE ( data words ) _DOVAR OF >BODY LIT, ENDOF _DOCON OF EXECUTE LIT, ENDOF _DOUSER OF EXECUTE LIT, ENDOF TRUE ABORT" Can't optimize word" ( any other Forth word bombs) ENDCASE ; \ new interpreter loop \ 1. Executes Immediate words: BEGIN WHILE IF THEN etc. \ 2. Steals kernel code and compiles any CODE word. \ 3. ABORTS if you try to compile a Forth word \ 4. Compiles literal numbers with LI instruction : <JIT> ( -- addr) 'SOURCE 2! >IN OFF BEGIN BL WORD DUP C@ WHILE FIND ?DUP IF ( it's a word) 1+ STATE @ 0= OR IF EXECUTE \ IF BEGIN etc. are all immediate ELSE JITCOMPILE, \ code and data are not THEN ELSE COUNT NUMBER? ?ERR STATE @ IF LIT, THEN \ special number compiler THEN DEPTH 0< ABORT" JIT: Underflow" REPEAT DROP ; : JIT: ( -- JIT-xt) ALSO JITS \ put JITS VOCABULARY first in search order : THERE ( -- XT) \ execution token (XT) for the NEW compiled code DUP CELL+ T, \ create the ITC header for a CODE word ['] <JIT> 'IV ! \ switch to JIT compiler ; : ;JIT ( JIT-XT -- ) PREVIOUS \ restore previous search order ['] <INTERP> 'IV ! 'NEXT' T, \ compile NEXT at end of new code word , \ compile CODE word's XT into Forth definition ?CS POSTPONE ; ; IMMEDIATE HERE SWAP - SPACE DECIMAL . .( bytes) When I JIT compiled the sieve and ran it under DTC Forth it was .8 seconds slower than when I run the same code in ITC Forth. 🤔 I don't why exactly but it could be the extra BL at the start of every hi-level word eats more time than I ever realized. But program spends most of its time running the machine code in DO-PRIME. ?? ------------- One small change I have made is to create the word COMPILES. This makes it super easy to steal code primitives from the Forth kernel. 045A CONSTANT 'NEXT' \ 9900 CODE for B *R10 Camel99 Forth's NEXT code : CODE, ( CODExt --) \ Read code word from kernel, compile to HEAP 80 CELLS ( -- addr len) BOUNDS ( -- IPend IPstart) BEGIN DUP @ 'NEXT' <> \ the instruction is not 'NEXT' WHILE DUP @ ( -- IP instruction) T, \ compile instruction CELL+ \ advance to next instruction 2DUP < ABORT" End of code not found" REPEAT 2DROP ; : COMPILES ( <codeword> ) POSTPONE ['] POSTPONE CODE, ; IMMEDIATE With COMPILES we can steal code from the kernel and compile it inline. : DUP, COMPILES DUP ; : +, COMPILES + ; CODE 2* DUP, +, NEXT, ENDCODE 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 7, 2022 Author Share Posted December 7, 2022 I think I will start using Visual Studio Code since the Atom editor is being put out to pasture. So far VSC works great and there is even a Forth language hi-lighter. Company Engineering Product Sunsetting Atom We are archiving Atom and all projects under the Atom organization for an official sunset on December 15, 2022. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 10, 2022 Author Share Posted December 10, 2022 On 12/1/2022 at 6:22 AM, Willsy said: Anyway, from a machine code point of view, how would you tackle (for example) this: : test 1 2 + ; Which (naively) would be (pseudo code): push 1 push 2 call + push result Into: LI R0, 3 ; result can be calculated at compile time since both parameters are constants MOV R0, *STACK+ ; push result Which is all that would be required in an optimised form. Interested to hear your thoughts. Getting back to this question from @Willsy An idea that I learned from Tom Almy's native code compiler is to create a literal stack. So at compile time it would work like this (I think): 1 -> literal stack (no code generated) 2 -> literal stack (no code generated) + is smart with 3 cases: nothing on literal stack: Do normal Forth + One literal stack item: Load into temp register add temp to TOS Two literal stack items: Add lit. stack items. Compile as a LIT Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 10, 2022 Author Share Posted December 10, 2022 This code works for a test of this idea. To use it in a functional compiler we would need to make a new interpreter loop that puts literals on the literal stack and all the math operators need a case statement which gets pretty big. \ constant folding tests NEEDS WORDLIST FROM DSK1.WORDLISTS ONLY FORTH DEFINITIONS NEEDS DUMP FROM DSK1.TOOLS NEEDS LIFO: FROM DSK1.STACKS VOCABULARY ASSEMBLER ONLY FORTH ALSO ASSEMBLER DEFINITIONS NEEDS MOV, FROM DSK1.ASM9900 \ Assembler psuedo instruction macros : LOAD, ( n register -- ) SWAP LI, ; : LIT, ( n ) TOS PUSH, TOS LOAD, ; ONLY FORTH DEFINITIONS ALSO ASSEMBLER 8 LIFO: LITSTK : >LS ( n --) LITSTK PUSH ; : LS> ( -- n) LITSTK POP ; : LITS ( -- n ) LITSTK STACK-DEPTH ; : OPT+ LITS CASE 0 OF *SP+ TOS ADD, ENDOF 1 OF LS> R3 LOAD, R3 TOS ADD, ENDOF 2 OF LS> LS> + \ add at compile time LIT, ENDOF ENDCASE ; CODE TEST0 ( n n -- n) \ 2 ARGS on data stack OPT+ NEXT, ENDCODE CODE TEST1 ( n -- n) \ 1 arg on data stack, 1 arg on lit stack 99 >LS OPT+ NEXT, ENDCODE CODE TEST2 ( -- n) \ 2 args on lit stack. constant folding 1 >LS 2 >LS OPT+ NEXT, ENDCODE Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 12, 2022 Author Share Posted December 12, 2022 (edited) I back migrated ideas from SUPERSAVE to the SAVESYS word. SAVESYS now checks the H variable (heap pointer) and will save that memory as well. This is very nice if you have a pile of data in your program that was compiled into the HEAP. Now you don't need to put a file loader in the program. Long overdue but better late than never. I will dump my current library of source code text files on Github tonight. \ ---------------- \ TEST CODE INCLUDE DSK1.MALLOC HEX 800 MALLOC CONSTANT MYBUFFER \ mybuffer is in Low RAM MYBUFFER 800 CHAR $ FILL \ put something in memory to see it work : GO WARM ABORT ; \ minimum startup code to start Forth interpreter LOCK \ lock dictionary to current size on re-boot INCLUDE DSK1.SAVESYS ' GO SAVESYS DSK7.TESTKERNEL \ CODE @ >A000 and DATA @ >2000 will be saved as E/A5 program Quote CR .( SAVESYS.FTH creates EA5 program Jun 2022 B Fox) \ creates a binary program E/A 5 format. \ Makes as many files as needed to save the system \ Jun 2022 version fixed section overlap. Tested with check sum. \ Dec 2022 saves the HEAP (Low RAM) as a file if variable H <> 0 \ Usage example: \ INCLUDE DSK2.MYPOGRAM ( load all your code) \ : STARTUP WARM CR ." Myprogram ready" ABORT" ; \ LOCK ( this locks the dictionary to the current size ) \ \ INCLUDE DSK1.SAVESYS \ ' STARTUP SAVESYS DSK3.MYFILENAME \ NEEDS DUMP FROM DSK1.TOOLS NEEDS LOCK FROM DSK1.MARKER NEEDS LOAD-FILE FROM DSK1.LOADSAVE \ we use SAVE-FILE from this library NEEDS U.R FROM DSK1.UDOTR HERE HEX A000 CONSTANT HIMEM \ start of Camel99 Forth program in CPU RAM 1000 CONSTANT VDPBUFF \ Programs write to file from VDP Ram 2000 CONSTANT LOWRAM 2000 CONSTANT 8K 8K 3 CELLS - CONSTANT IMGSIZE \ makes space for header cells 13 CONSTANT PROGRAM \ file mode for Program files \ define the file header fields. *THESE ARE VDP ADDRESSES* VDPBUFF CONSTANT MULTIFLAG VDPBUFF 1 CELLS + CONSTANT PROGSIZE VDPBUFF 2 CELLS + CONSTANT LOADADDR VDPBUFF 3 CELLS + CONSTANT CODEBUFF \ COPY 8K program chunks to here 3 CELLS CONSTANT HEADLEN : HEADER ( Vaddr size ?) \ store header info in VDP RAM MULTIFLAG V! PROGSIZE V! LOADADDR V! ; : END ( -- addr ) ORGDP @ DUP C000 < IF HONK CR ." WARNING: missing LOCK directive" THEN ; \ words to compute Forth system properties : SYS-SIZE ( -- n) HIMEM END SWAP - ; : #FILES ( -- n) SYS-SIZE 8K /MOD SWAP IF 1+ THEN ; : CODECHUNK ( n -- addr) IMGSIZE * HIMEM + ; : CHUNKSIZE ( n -- n ) CODECHUNK END SWAP - IMGSIZE MIN ; : LASTCHAR++ ( Caddr len --) 1- + 1 SWAP C+! ; : HEAPSIZE ( -- n) H @ LOWRAM - ; : ?PATH ( addr len -- addr len ) 2DUP [CHAR] . SCAN NIP 0= ABORT" Path expected" ; : GET-PATH ( <text>) BL PARSE-WORD ?PATH PAD PLACE ; : FILENAME ( -- addr len) PAD COUNT ; VARIABLE FILECOUNT : SAVE-IMAGE ( addr len Vaddr size -- ) CR ." Writing file: " FILENAME TYPE HEADLEN + PROGRAM SAVE-FILE FILENAME LASTCHAR++ FILECOUNT 1+! ; : SAVELO ( -- ) HEAPSIZE IF LOWRAM HEAPSIZE DUP>R FALSE HEADER \ heap is last file saved LOWRAM CODEBUFF R@ VWRITE \ copy HEAP to VDP FILENAME VDPBUFF R> SAVE-IMAGE THEN ; HEX : SAVEHI ( -- ) #FILES 0 ?DO \ compute file header values I CODECHUNK I CHUNKSIZE ( -- addr size ) I 1+ #FILES <> HEAPSIZE 0> OR \ multiflag=true if heap has data ( addr size ?) HEADER \ store in file header \ Copy to VDP RAM LOADADDR V@ CODEBUFF PROGSIZE V@ HEADLEN + VWRITE \ write VDP to disk" FILENAME VDPBUFF PROGSIZE V@ SAVE-IMAGE LOOP ; : .BYTES&ADDR ( addr size --) DECIMAL 5 U.R ." bytes, at " HEX ." >" 4 U.R ; : REPORT CR CR ." Himem : " HIMEM ORGDP @ OVER - .BYTES&ADDR CR ." Heap : " LOWRAM HEAPSIZE .BYTES&ADDR CR ." Saved in " FILECOUNT @ . ." EA5 files" CR ; : SAVESYS ( xt -- <path>) BOOT ! FILECOUNT OFF GET-PATH SAVEHI SAVELO REPORT ; HERE SWAP - CR DECIMAL . .( bytes) Edited December 12, 2022 by TheBF fixed comment 3 Quote Link to comment Share on other sites More sharing options...
