the official Channel F thread!
12 hours ago, atari2600land said:
Why was Galactic Space Wars and Pro Football described as Keyboard controllers when they apparently didn't need the keyboard controller because the games were released and the keyboard controller wasn't?
Seems a different version was planned according to images - and I'd guess they had to change things to an easier interface...?
Maybe there's remnants in the code...
11 hours ago, atari2600land said:
What is Microtronix?
I think it's just one of the resellers.
 Yes Early licensed reseller, Zircon & Microtronix worked with Fairchild  for a while prior to
Zircon taking over
additional Rear Label, otherwise exactly the same
http://fndcollectables.com/Fairchild/Cart11/n11_g2.jpg
example of the Zircon Rear Label
http://fndcollectables.com/Fairchild/Cart10/cart10-text-whitebox-rear.jpg
Edited by FND
add photo
21 hours ago, atari2600land said:
Why was Galactic Space Wars and Pro Football described as Keyboard controllers when they apparently didn't need the keyboard controller because the games were released and the keyboard controller wasn't? :?
The Keyboard controller was planned but never completed, these ads were printed showing future release expectation
If I remember correctly only a wooden mock-up was made for the controller shown on the front of the
system II box (center bottom picture shows Black K-1 cart and keyboard controller).
I suspect the cart code would of been updated to use the controller but apparently not required as
released
Edited by FND
4 minutes ago, atari2600land said:
How would the keyboard controller be put in if the controllers were hard-wired into the console?
This is a good question, did either model have unpluggable controllers? The only other way would have been a port in the cartridge which would be more things to take into account.
system II only add-on.
There it is from my email interview with Nicholas Talesfore
5.
Any thing you can remember about the Keyboard Carts and Controller ?
The Controller and K-1 Casino Poker is pictured on the System II box and
mentioned in a Brochure, Were any of these ever produced (Carts or
Controller) ? None have ever turned up, also noticed the K-1 Casino Poker
cart pictured on the system II box must be a mock up as the instructions
printed on the label are for Robot War/Torpedo Alley
[Nicholas F. Talesfore]
The Keyboard shown in the photo (was to plug in to a hand controller
port and was not a cartridge) was a solid model I designed it but it was never built. I was asked by
Jerry Lawson to design probably to be used in some games the programmers were developing but it never
was engineered or put into production.
Link to full interview
http://fndcollectables.com/NINTENDO/NES_C_thru_D/SHIPPING/VIDEO_GAMES/INTELLIVISION/working_interview_notes.html
Edited by FND
  • 2 weeks later...
11 minutes ago, atari2601 said:
e5frog how can you do samples on channel f?
I can't, I haven't suceeded in doing so on a real machine, in emulation it works though, the emulation differs a lot from the real thing regarding sound.
Things need to be explored further.
even if its on an emulator i am just curious how you did it on that tetris thing
Sample data is output with this code:
	processor f8
	org	$800
; BIOS Calls ;
clrscrn	= 	$00d0		; uses r31
delay		= 	$008f		; parameter in r5, uses r6
pushk		=	$0107		; uses r7, allows more subroutine stack space
popk		=	$011e		; uses r7
game_size	=	32
CartridgeStart:
	.byte $55, $FB
	clr
	outs	0
	outs	1
	outs	4
;	ins	5
;	ni	%11000000			; Keep audio bits as is (no click)
	outs	5
CartridgeEntry:
	dci	colordata
	lm
	xdc					; Store data counter for color in DC1
clearagain:
	lr	3, A
	pi	clrscrn
	dci	sample_buffer	; set data pointer to buffer
	clr
	com
	lr	0, A			;output_state = 0
outer_loop:
	clr				; 1  cycle
	am				; 2.5 cycles
	bz	end_sample
	lr	1, A			; 1  cycle		Sample counter stores data
	lr	A, 0			; 1  cycle		Fetch output state
	com				; 1  cycle		Invert output state
;	ni	%11000000		; 2.5 cycles	Only  keep the two sound bits
	lr	0, A			; 1  cycle		Store for next data invert
	outs	5			; 4 cycles		Put output state on port
	lr	A, 1			; 1c
	outs	1			; 2c	Color
	outs	4			; 4c	Column
	li	%11100001		; Set top two bits to 1
	ns	0			; And with r0 to set any 0 in top two
	outs	5			; 4c	Row
	lis	6			; 1c
	sl	4			; 1c
	outs	0			; 2c
	sl	1			; 1c
	outs	0			; 2c
inner_loop:
;	nop				; 1 cycle
;	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
	ds	1			; 1.5 cycles	Decrease sample counter
	bnz	inner_loop		; 3.5 cycles branch, 3 cycles no branch
	br	outer_loop		; 3.5 cycles
end_sample:
	li	%00000000
	outs	5
	xdc				; back to color
	clr
	am				; Add ram data to set flags
	xdc				; Change back
	bnz	clearagain		; Restart if not 0
	br	CartridgeEntry	; Start over
colordata:
	.byte $d6			; grey
	.byte $c0			; green
	.byte $21			; b/w
	.byte $93			; blue
	.byte 0
	.byte 0
;	jmp	CartridgeEntry
sample_buffer:
	include "tetris.smp.inc"
	.byte 0
; Signature
	; signature
	org [$800 + [game_size * $400] -$10]
;signature:
	.byte "- e5frog - 2020 "
I converted this code that was given to me by utz (Sleizsa Duo/Trio):
  sample_pointer = sample_buffer
  output_state = 0
outer_loop:
  output_state = ~output_state
  sample_counter = [sample_pointer]
  ++sample_pointer
inner_loop:
  output_state -> port
  --sample_counter
  if sample_counter != 0
   goto inner_loop
  goto outer_loop
sample_buffer
  // PWM data goes here
sample_buffer is where the sample data starts, the end is marked with $00.
Sample data is made from wav by a program called wav2pwm.
https://github.com/JeffAlyanak/pcm2pwm/releases
I used a 44100kHz, 8-bit, mono-file saved as Windows PCM
I was considering using an address-bit for output and have a small speaker in the cart but... feature creep.
	processor f8
	org	$800
; BIOS Calls ;
game_size	=	32
CartridgeStart:
	.byte $55, $FB
	clr
	outs	0
	outs	1
	outs	4
;	ins	5
	outs	5
CartridgeEntry:
	dci	colordata
	lm
clearagain:
	lr	3, A
	pi	clrscrn
	clr
	com
outer_loop:
	clr				; 1  cycle
	am				; 2.5 cycles
	bz	end_sample
	lr	A, 1			; 1c
	outs	1			; 2c	Color
	outs	4			; 4c	Column
	outs	5			; 4c	Row
	lis	6			; 1c
	sl	4			; 1c
	outs	0			; 2c
	sl	1			; 1c
	outs	0			; 2c
inner_loop:
;	nop				; 1 cycle
;	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
end_sample:
	li	%00000000
	outs	5
	xdc				; back to color
	clr
	xdc				; Change back
colordata:
	.byte $d6			; grey
	.byte $c0			; green
	.byte $21			; b/w
	.byte $93			; blue
	.byte 0
	.byte 0
sample_buffer:
	.byte 0
; Signature
	; signature
;signature:
  output_state = 0
outer_loop:
  ++sample_pointer
inner_loop:
  --sample_counter
   goto inner_loop
  goto outer_loop
sample_buffer
Soo. Should i use both what do i call them and is this code here fine?
    .byte $12,$02,$02,$07,$08,$03,$03,$02,$02,$07,$02,$03,$03,$03,$03,$03
    .byte $03,$0C,$02,$03,$02,$03,$03,$03,$02,$03,$0D,$02,$03,$03,$01,$0C
    .byte $07,$02,$03,$03,$02,$04,$02,$03,$04,$02,$03,$01,$06,$02,$03,$02
    .byte $03,$03,$02,$03,$0A,$06,$09,$02,$01,$05,$08,$02,$0A,$03,$04,$04
    .byte $08,$03,$02,$02,$01,$06,$06,$04,$02,$03,$02,$04,$02,$03,$02,$03
    .byte $02,$03,$02,$0B,$02,$0A,$03,$07,$01,$08,$08,$07,$05,$09,$02,$07
    .byte $07,$03,$03,$0A,$03,$0C,$04,$02,$15,$04,$04,$02,$03,$03,$01,$06
    .byte $03,$0A,$04,$03,$09,$03,$0A,$04,$04,$07,$02,$03,$03,$09,$08,$07
    .byte $01,$07,$02,$02,$01,$09,$04,$02,$03,$03,$03,$01,$0C,$04,$02,$04
    .byte $02,$02,$05,$0C,$03,$03,$01,$03,$07,$02,$08,$01,$06,$03,$02,$1A
    .byte $02,$03,$06,$03,$02,$01,$05,$08,$02,$04,$02,$03,$05,$04,$03,$05
    .byte $03,$02,$03,$01,$03,$02,$02,$02,$07,$03,$02,$01,$02,$03,$03,$01
    .byte $03,$04,$08,$03,$02,$05,$03,$02,$08,$04,$04,$04,$02,$03,$11,$03
    .byte $6B,$CA,$C8,$CA,$D2,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF
 so. I dont understand anything
6 minutes ago, e5frog said:
Only the first part is the actual used code, the other is an explanation how playing pwm is played in general.
If you put your data in a file called "tetris.smp.inc" you'd be able to run it right away.
so now my code looks like this
  output_state = 0
outer_loop:
  ++sample_pointer
inner_loop:
  --sample_counter
   goto inner_loop
  goto outer_loop
sample_buffer
and why would converting it to .smp.inc make you be able to run it right away?
That would be the second part of the text marked as code.
Save your data with filename "tetris.smp.inc" and use this code (which was the first part):
... or change the name, or paste your code in there instead of the "include" statement.
	processor f8
	org	$800
; BIOS Calls ;
game_size	=	32
CartridgeStart:
	.byte $55, $FB
	clr
	outs	0
	outs	1
	outs	4
;	ins	5
	outs	5
CartridgeEntry:
	dci	colordata
	lm
clearagain:
	lr	3, A
	pi	clrscrn
	clr
	com
outer_loop:
	clr				; 1  cycle
	am				; 2.5 cycles
	bz	end_sample
	lr	A, 1			; 1c
	outs	1			; 2c	Color
	outs	4			; 4c	Column
	outs	5			; 4c	Row
	lis	6			; 1c
	sl	4			; 1c
	outs	0			; 2c
	sl	1			; 1c
	outs	0			; 2c
inner_loop:
;	nop				; 1 cycle
;	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
end_sample:
	li	%00000000
	outs	5
	xdc				; back to color
	clr
	xdc				; Change back
colordata:
	.byte $d6			; grey
	.byte $c0			; green
	.byte $21			; b/w
	.byte $93			; blue
	.byte 0
	.byte 0
sample_buffer:
	.byte 0
; Signature
	; signature
;signature:
	processor f8
	org	$800
; BIOS Calls ;
game_size	=	32
CartridgeStart:
	.byte $55, $FB
	clr
	outs	0
	outs	1
	outs	4
;	ins	5
	outs	5
CartridgeEntry:
	dci	colordata
	lm
clearagain:
	lr	3, A
	pi	clrscrn
	clr
	com
outer_loop:
	clr				; 1  cycle
	am				; 2.5 cycles
	bz	end_sample
	lr	A, 1			; 1c
	outs	1			; 2c	Color
	outs	4			; 4c	Column
	outs	5			; 4c	Row
	lis	6			; 1c
	sl	4			; 1c
	outs	0			; 2c
	sl	1			; 1c
	outs	0			; 2c
inner_loop:
;	nop				; 1 cycle
;	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
	nop				; 1 cycle
end_sample:
	li	%00000000
	outs	5
	xdc				; back to color
	clr
	xdc				; Change back
colordata:
	.byte $d6			; grey
	.byte $c0			; green
	.byte $21			; b/w
	.byte $93			; blue
	.byte 0
	.byte 0
sample_buffer:
	.byte 0
; Signature
	; signature
;signature:
well im thinking of adding my own sample so. Yeah. where do i add my own data and how do you rum .smp.inc files?
Edited by atari2601
    processor f8
    org    $800
; BIOS Calls ;
game_size    =    32
CartridgeStart:
    .byte $55, $FB
    clr
    outs    0
    outs    1
    outs    4
;    ins    5
    outs    5
CartridgeEntry:
    dci    colordata
    lm
clearagain:
    lr    3, A
    pi    clrscrn
    clr
    com
outer_loop:
    clr                ; 1  cycle
    am                ; 2.5 cycles
    bz    end_sample
    lr    A, 1            ; 1c
    outs    1            ; 2c    Color
    outs    4            ; 4c    Column
    outs    5            ; 4c    Row
    lis    6            ; 1c
    sl    4            ; 1c
    outs    0            ; 2c
    sl    1            ; 1c
    outs    0            ; 2c
inner_loop:
;    nop                ; 1 cycle
;    nop                ; 1 cycle
    nop                ; 1 cycle
    nop                ; 1 cycle
    nop                ; 1 cycle
    nop                ; 1 cycle
end_sample:
    li    %00000000
    outs    5
    xdc                ; back to color
    clr
    xdc                ; Change back
colordata:
    .byte $d6            ; grey
    .byte $c0            ; green
    .byte $21            ; b/w
    .byte $93            ; blue
    .byte 0
    .byte 0
sample_buffer:
    .byte 0
; Signature
    ; signature
;signature:
is this good enough or am i missing something
No need to involve sleiszatrio, the code is standalone, no need for any other code.
You use dasm.exe to compile it from command prompt:
dasm codefilename.asm -f3 -oFILENAME.bin
Your sample data sounds like some sort of thump or maybe like a puff when a steam engine is about to start.
Try this:
; The format is 0
; High value is 140
; Low value is 110
    .byte $FF,$03,$02,$1D,$B5,$02,$02,$02,$02,$02,$2A,$18,$02,$03,$11,$2A
    .byte $6F,$65,$59,$76,$4E,$3F,$37,$43,$36,$01,$32,$42,$31,$3F,$52,$43
    .byte $2A,$44,$0C,$0B,$0F,$17,$45,$3B,$2D,$3D,$3D,$0D,$2F,$02,$0E,$2D
    .byte $39,$3E,$28,$0E,$0B,$08,$30,$3C,$2E,$39,$38,$13,$09,$0A,$2D,$39
    .byte $2D,$3C,$39,$1B,$04,$01,$03,$03,$34,$39,$29,$3D,$2B,$33,$3A,$37
    .byte $2B,$3D,$2D,$32,$42,$02,$03,$2D,$25,$44,$2B,$25,$56,$0C,$09,$92
    .byte $0B,$0B,$A9,$44,$0C,$44,$5B,$07,$4D,$5B,$0C,$2F,$58,$0D,$5E,$47
    .byte $08,$0B,$0C,$2B,$49,$08,$0D,$0C,$0C,$02,$1B,$0E,$16,$01,$03,$02
    .byte $0F,$0F,$02,$35,$0A,$0C,$09,$2A,$48,$10,$0B,$0A,$25,$10,$1A,$02
    .byte $10,$44,$15,$2F,$39,$25,$2B,$23,$2C,$84,$32,$14,$42,$16,$02,$02
    .byte $3A,$89,$6D,$2A,$56,$02,$0D,$4C,$32,$21,$38,$2B,$6B,$52,$4A,$30
    .byte $39,$24,$33,$8C,$3B,$3B,$FF,$69,$C0,$8D,$AA,$A1,$DE,$93,$FF,$5B
    .byte $CB,$80,$2C,$2E,$8D,$3D,$2C,$1F,$02,$0A,$02,$03,$02,$02,$30,$02
    .byte $06,$18,$02,$0F,$02,$05,$02,$03,$02,$02,$03,$02,$2C,$02,$03,$01
    .byte $0B,$02,$02,$02,$03,$02,$02,$02,$02,$02,$02,$02,$03,$04,$02,$02
    .byte $05,$02,$02,$03,$02,$02,$02,$0B,$02,$0E,$02,$03,$01,$0C,$02,$06
    .byte $03,$03,$01,$03,$02,$06,$02,$02,$02,$06,$02,$03,$1A,$02,$03,$02
    .byte $02,$15,$03,$02,$02,$02,$4B,$2B,$02,$06,$02,$0B,$02,$24,$3D,$01
    .byte $03,$02,$02,$0B,$01,$2B,$0B,$01,$03,$02,$49,$45,$39,$36,$37,$02
    .byte $02,$02,$03,$01,$03,$02,$02,$02,$3B,$02,$02,$4B,$2A,$2E,$3E,$31
    .byte $39,$30,$37,$41,$3C,$33,$33,$28,$32,$3A,$8B,$78,$AB,$39,$36,$30
    .byte $3C,$2D,$2F,$3F,$3B,$2B,$9D,$53,$2F,$2D,$3B,$26,$45,$19,$02,$02
    .byte $3D,$48,$3B,$2D,$39,$2F,$32,$22,$02,$01,$09,$09,$2F,$41,$35,$30
    .byte $3B,$02,$02,$2E,$2D,$01,$03,$02,$02,$03,$01,$29,$02,$02,$02,$02
    .byte $03,$01,$2B,$01,$03,$01,$03,$02,$02,$3A,$3B,$2D,$3B,$03,$01,$3A
    .byte $33,$34,$02,$02,$02,$02,$4C,$46,$20,$4C,$30,$22,$43,$32,$3F,$4A
    .byte $28,$32,$3E,$28,$43,$3A,$64,$66,$2F,$1E,$87,$32,$03,$02,$85,$41
    .byte $36,$30,$A4,$26,$3D,$2F,$2D,$94,$BE,$A4,$47,$1D,$02,$2E,$2A,$03
    .byte $12,$02,$25,$02,$15,$02,$03,$02,$0B,$01,$04,$02,$09,$02,$0F,$02
    .byte $0A,$02,$03,$02,$03,$02,$0B,$02,$03,$02,$02,$02,$03,$01,$03,$02
    .byte $03,$02,$02,$02,$06,$03,$06,$15,$03,$04,$02,$03,$02,$04,$02,$03
    .byte $02,$03,$02,$0A,$02,$04,$02,$03,$02,$04,$02,$0B,$02,$08,$02,$03
    .byte $02,$03,$02,$03,$02,$07,$02,$02,$02,$03,$02,$08,$02,$07,$02,$02
    .byte $03,$03,$02,$04,$02,$04,$02,$02,$03,$02,$03,$03,$02,$03,$04,$06
    .byte $04,$04,$03,$02,$03,$02,$03,$02,$03,$02,$02,$03,$07,$02,$02,$02
    .byte $03,$03,$08,$02,$07,$02,$03,$02,$03,$02,$05,$02,$09,$03,$03,$02
    .byte $03,$03,$02,$03,$03,$03,$03,$02,$03,$03,$03,$03,$09,$02,$08,$03
    .byte $03,$02,$02,$02,$06,$03,$09,$03,$03,$03,$06,$02,$02,$02,$03,$02
    .byte $02,$03,$03,$02,$02,$02,$02,$01,$03,$02,$03,$02,$03,$03,$02,$06
    .byte $02,$02,$03,$03,$02,$03,$03,$02,$03,$03,$0A,$02,$03,$03,$05,$02
    .byte $03,$03,$02,$03,$03,$02,$03,$03,$04,$03,$02,$03,$03,$02,$03,$03
    .byte $03,$03,$03,$02,$03,$04,$03,$03,$02,$02,$02,$02,$03,$02,$03,$05
    .byte $02,$03,$02,$03,$03,$03,$04,$02,$03,$02,$02,$03,$03,$03,$04,$02
    .byte $02,$03,$03,$04,$02,$03,$02,$03,$03,$09,$03,$02,$03,$02,$02,$07
    .byte $03,$05,$02,$06,$03,$02,$03,$02,$01,$02,$03,$02,$03,$02,$03,$02
    .byte $03,$03,$05,$06,$02,$02,$02,$03,$02,$02,$02,$03,$04,$06,$03,$03
    .byte $02,$02,$03,$02,$03,$02,$02,$06,$03,$03,$0F,$03,$03,$01,$04,$02
    .byte $16,$02,$03,$02,$04,$02,$03,$02,$03,$02,$02,$03,$03,$03,$02,$03
    .byte $01,$02,$04,$04,$03,$02,$03,$02,$03,$02,$02,$02,$03,$02,$02,$03
    .byte $04,$03,$03,$02,$02,$02,$03,$02,$03,$02,$02,$02,$02,$03,$04,$02
    .byte $02,$03,$03,$03,$02,$02,$03,$03,$02,$02,$02,$03,$02,$02,$03,$03
    .byte $06,$05,$03,$02,$03,$02,$0A,$03,$03,$02,$03,$02,$02,$02,$02,$03
    .byte $03,$03,$02,$03,$03,$02,$02,$02,$03,$02,$02,$02,$03,$02,$03,$02
    .byte $03,$06,$02,$03,$02,$02,$03,$02,$02,$05,$03,$03,$05,$05,$03,$02
    .byte $02,$03,$02,$03,$02,$02,$04,$03,$03,$05,$02,$03,$02,$03,$03,$02
    .byte $03,$02,$02,$03,$02,$03,$02,$02,$01,$02,$03,$03,$02,$02,$02,$03
    .byte $02,$02,$02,$03,$02,$02,$02,$04,$02,$03,$03,$03,$03,$03,$02,$04
    .byte $03,$03,$02,$02,$03,$03,$05,$03,$02,$02,$02,$02,$02,$02,$03,$02
    .byte $02,$03,$04,$06,$03,$03,$03,$05,$02,$02,$05,$03,$07,$02,$07,$02
    .byte $03,$02,$03,$02,$06,$01,$03,$02,$06,$02,$03,$02,$03,$03,$03,$02
    .byte $02,$02,$02,$02,$03,$02,$03,$02,$03,$02,$03,$02,$03,$02,$03,$02
    .byte $0A,$02,$07,$02,$0F,$03,$0B,$02,$03,$02,$02,$02,$03,$05,$02,$03
    .byte $02,$03,$02,$03,$02,$02,$02,$03,$02,$03,$03,$02,$02,$03,$02,$03
    .byte $03,$03,$03,$06,$02,$02,$03,$02,$02,$07,$03,$03,$02,$03,$02,$06
    .byte $03,$09,$02,$04,$02,$06,$02,$02,$03,$03,$05,$03,$03,$02,$02,$03
    .byte $04,$07,$03,$03,$02,$02,$03,$04,$05,$03,$03,$02,$03,$03,$03,$03
    .byte $06,$05,$07,$03,$23,$02,$02,$03,$02,$02,$03,$02,$03,$02,$02,$04
    .byte $03,$03,$02,$02,$03,$05,$05,$03,$03,$03,$03,$03,$02,$03,$04,$02
    .byte $03,$02,$03,$03,$04,$02,$02,$03,$03,$03,$03,$03,$05,$02,$03,$02
    .byte $02,$02,$02,$03,$02,$02,$02,$03,$02,$02,$03,$03,$03,$02,$02,$03
    .byte $04,$07,$05,$03,$03,$03,$02,$02,$03,$03,$02,$04,$03,$02,$03,$02
    .byte $02,$03,$05,$03,$05,$02,$03,$02,$04,$03,$07,$02,$05,$03,$02,$02
    .byte $03,$03,$04,$02,$03,$02,$03,$03,$04,$03,$02,$03,$03,$02,$02,$02
    .byte $05,$03,$03,$03,$03,$03,$02,$03,$03,$02,$02,$03,$0A,$03,$03,$03
    .byte $03,$03,$03,$01,$06,$02,$02,$03,$02,$03,$02,$02,$03,$02,$02,$02
    .byte $02,$03,$02,$03,$02,$05,$02,$11,$02,$03,$07,$03,$03,$02,$02,$02
    .byte $02,$03,$02,$06,$02,$02,$03,$02,$03,$02,$02,$03,$02,$02,$02,$03
    .byte $06,$03,$06,$05,$03,$04,$02,$02,$03,$03,$04,$03,$02,$02,$03,$02
    .byte $0A,$02,$03,$02,$03,$03,$04,$02,$04,$03,$07,$02,$03,$03,$03,$02
    .byte $04,$03,$03,$02,$03,$03,$02,$03,$02,$03,$02,$05,$03,$02,$03,$03
    .byte $03,$02,$02,$02,$03,$05,$02,$02,$03,$03,$02,$02,$05,$03,$03,$02
    .byte $02,$03,$03,$06,$02,$02,$02,$03,$03,$06,$06,$02,$03,$02,$02,$03
    .byte $02,$03,$02,$02,$03,$02,$03,$02,$04,$03,$02,$03,$02,$02,$03,$02
    .byte $02,$02,$03,$02,$02,$02,$03,$03,$02,$01,$02,$02,$03,$03,$05,$05
    .byte $04,$05,$05,$03,$06,$02,$03,$01,$03,$03,$09,$03,$02,$02,$02,$03
    .byte $05,$03,$02,$02,$02,$03,$02,$02,$03,$02,$02,$02,$03,$02,$02,$02
    .byte $03,$04,$04,$06,$04,$06,$05,$04,$06,$04,$03,$03,$02,$03,$04,$03
    .byte $04,$07,$04,$05,$04,$05,$04,$04,$02,$02,$03,$03,$05,$03,$07,$04
    .byte $05,$04,$04,$03,$02,$02,$03,$02,$03,$01,$04,$05,$03,$03,$07,$03
    .byte $05,$02,$02,$02,$04,$05,$06,$03,$06,$06,$03,$03,$06,$06,$03,$05
    .byte $04,$05,$03,$02,$02,$03,$03,$05,$07,$03,$05,$06,$04,$03,$08,$02
    .byte $03,$02,$02,$02,$03,$05,$04,$08,$03,$04,$03,$01,$02,$03,$02,$02
    .byte $03,$03,$02,$01,$03,$03,$06,$03,$05,$03,$05,$02,$02,$03,$02,$03
    .byte $02,$02,$07,$02,$03,$02,$02,$02,$03,$02,$03,$02,$02,$03,$01,$03
    .byte $02,$06,$06,$02,$06,$03,$09,$02,$05,$04,$06,$03,$06,$02,$02,$02
    .byte $03,$02,$02,$02,$03,$04,$05,$05,$04,$06,$03,$05,$06,$03,$06,$06
    .byte $03,$06,$06,$03,$03,$04,$07,$02,$02,$02,$04,$08,$03,$03,$05,$05
    .byte $06,$03,$07,$02,$03,$02,$02,$03,$03,$02,$02,$02,$03,$02,$02,$03
    .byte $06,$02,$02,$03,$03,$04,$03,$02,$03,$03,$03,$02,$02,$03,$03,$03
    .byte $02,$03,$03,$03,$02,$02,$03,$02,$0A,$03,$03,$07,$05,$02,$03,$02
    .byte $03,$02,$03,$03,$12,$02,$03,$02,$04,$02,$02,$03,$03,$02,$04,$03
    .byte $0B,$02,$02,$03,$1B,$02,$1B,$02,$03,$02,$03,$02,$05,$03,$07,$03
    .byte $67
Try this:
; The format is 0
; High value is 140
; Low value is 110
    .byte $67
my sample is a kick
2 hours ago, atari2601 said:
@e5frog do i just need to write that to a .asm file and compile it?
im getting the error Fatal assembly error: Source is not resolvable.
If I copy your code and save it as a text-file with suffix .asm - it works just fine.
So I don't know what you're doing differently.
The suffix doesn't matter at all, you can use .xxx as suffix or none at all, you type what file dasm is going to compile.
Using .asm is just to make it easier for you to know what's in the file.
Edited by e5frog
