Troy_Whelan Posted January 19, 2018 Share Posted January 19, 2018 Anyone here have a handheld emulation console that uses/used Happy Chick? Did you keep Happy Chick or replace it? If you replaced it, did you do it yourself or send the console away to have it done? Cost? Pros and Cons of using Happy Chick? Pros and Cons of replacing Happy Chick? GPD XD, JXD S7800B and JXD S192K (Singularity); all 3 of these use Happy Chick as the "emulator hub" and require you to use their ROMs instead of you using your own. I would like to not use Happy Chick and use my own emulators & ROMs. Please share your experiences with respect to handheld emulation consoles and Happy Chick. Troy Quote Link to comment Share on other sites More sharing options...
discgolfer72 Posted January 22, 2018 Share Posted January 22, 2018 Anyone here have a handheld emulation console that uses/used Happy Chick? Did you keep Happy Chick or replace it? If you replaced it, did you do it yourself or send the console away to have it done? Cost? Pros and Cons of using Happy Chick? Pros and Cons of replacing Happy Chick? GPD XD, JXD S7800B and JXD S192K (Singularity); all 3 of these use Happy Chick as the "emulator hub" and require you to use their ROMs instead of you using your own. I would like to not use Happy Chick and use my own emulators & ROMs. Please share your experiences with respect to handheld emulation consoles and Happy Chick. Troy on both of my 7 inch machines that have happy chick you use your own roms or download from the app just place you roms in the correct folder and they show right up i have a gpd and jxd 7 inch and there is nothing stopping you from using your own emus they are just standard android machines i actually like the happy chick app i backed up the apk and now have it installed on my other standard android tablets and a android tv i like it because it makes a good front end for all the different emus before i had it i was stuck running each emu separate Quote Link to comment Share on other sites More sharing options...
Troy_Whelan Posted January 23, 2018 Author Share Posted January 23, 2018 on both of my 7 inch machines that have happy chick you use your own roms or download from the app just place you roms in the correct folder and they show right up i have a gpd and jxd 7 inch and there is nothing stopping you from using your own emus they are just standard android machines i actually like the happy chick app i backed up the apk and now have it installed on my other standard android tablets and a android tv i like it because it makes a good front end for all the different emus before i had it i was stuck running each emu separate That is good to know. I thought it was going to be either use Happy Chick or my own ROMs but not mingled. Can you see everything even if you are not connected online? That is one of the main reasons I was wanting to avoid Happy Chick as I want to be able to play whatever wherever and not have to be logged into their site. Quote Link to comment Share on other sites More sharing options...
discgolfer72 Posted January 23, 2018 Share Posted January 23, 2018 That is good to know. I thought it was going to be either use Happy Chick or my own ROMs but not mingled. Can you see everything even if you are not connected online? That is one of the main reasons I was wanting to avoid Happy Chick as I want to be able to play whatever wherever and not have to be logged into their site. I have not updated my app I'm a few months but yes unless something has changed I used my jxd all the time with happy chick not connected to the net even the games downloaded show up the only problem you would have offline is if you had not downloaded the emulator yet for the game but once its downloaded its there for good 1 Quote Link to comment Share on other sites More sharing options...
