Andromeda Stardust Posted December 12, 2018 Share Posted December 12, 2018 If you build it, we will buy it!×1,000,000 Okay, maybe not a million. But A LOT of people want this to happen. 1 Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4175315 Share on other sites More sharing options...
xefned Posted December 12, 2018 Share Posted December 12, 2018 Wow, Impressive work MacRorie, and electrotrains, and Dirty Hairy, and anyone else who contributed to this project. It's come a long way since Jan. 2018. Always glad to see a scene stay vibrant. Looks like UnoCart is the new HarmonyCart. Perhaps it should now have its own dedicated subforum. Amazing work! Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4175431 Share on other sites More sharing options...
Trip2018 Posted December 12, 2018 Share Posted December 12, 2018 (edited) Draconian Space Rocks Anguna Dungeon II Panky the Panda Zippy Mappy I'm pretty sure they're all dpc+ game except Zippy, and Anguna. Edited December 12, 2018 by Trip2018 Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4175517 Share on other sites More sharing options...
+-^CrossBow^- Posted December 12, 2018 Share Posted December 12, 2018 I'm pretty sure they're all dpc+ game except Zippy, and Anguna. I can confirm that Zippy works on the Uno. That was how I first played it in fact before buying my own physical cart at this past years's PRGE. Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4175532 Share on other sites More sharing options...
+MacRorie Posted December 15, 2018 Share Posted December 15, 2018 Draconian Space Rocks Anguna Dungeon II Panky the Panda Zippy Mappy Runs Runs Runs Need Binary files Need Binary files Need Binary files Need Binary files When I say "Runs," I found a file and it loads and appears to play. If the sounds are not correct, I would not know unless it was obvious (and it wasn't to me). Also, I am going off of memory from when I tested a few days ago. Finally, these files were 1-10 years old that I found, so maybe there was a later version that I did not see and/or it went commercial and so was not legally available or download. If you have legal files that you can share so I can test them, I am happy to do so. Also, Stay Frosty works, Stay Frosty 2 does not. 1 Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4177458 Share on other sites More sharing options...
+-^CrossBow^- Posted December 15, 2018 Share Posted December 15, 2018 Zippy does work as that rom was released over the summer as I recall and it was actually the UNO that I first tested it on and played the game. I've bought a physical copy at PRGE but yes...ZIPPY does work on the UNO. 1 Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4177646 Share on other sites More sharing options...
Novastar Posted December 22, 2018 Share Posted December 22, 2018 (edited) You stated earlier that you were leaving a space open for a pokey. My understanding is that the pokey is for 7800. Is there any way the 2600 could make use of the pokey on uno? Edited December 22, 2018 by Novastar Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4182469 Share on other sites More sharing options...
+MacRorie Posted December 22, 2018 Share Posted December 22, 2018 You stated earlier that you were leaving a space open for a pokey. My understanding is that the pokey is for 7800. Is there any way the 2600 could make use of the pokey on uno? Which post are you referring to? Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4182486 Share on other sites More sharing options...
rvincent86 Posted December 23, 2018 Share Posted December 23, 2018 (edited) Hi everybody Two questions . Does this works with a 7800 PAL?. Can we put either 2600 and 7800 games.? Merry Christmas Edited December 23, 2018 by rvincent86 Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4182958 Share on other sites More sharing options...
+MacRorie Posted December 23, 2018 Share Posted December 23, 2018 Hi everybody Two questions . Does this works with a 7800 PAL?. Can we put either 2600 and 7800 games.? Merry Christmas It does work on a PAL 7800. I have tested it myself. It will only run 2600 ROMs Merry Christmas! Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4182968 Share on other sites More sharing options...
rvincent86 Posted December 23, 2018 Share Posted December 23, 2018 Thanks ! Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4182972 Share on other sites More sharing options...
boggis the cat Posted December 27, 2018 Share Posted December 27, 2018 That's not correct. The firmware only defines the display of the menu. So the jumper can only change that. A PAL Encore or UnoCart can play NTSC games and vice versa. But for NTSC games displayed in correct colors you need a NTSC console, and for PAL games you a need a PAL console. The flash carts make zero difference here. Just a clarification of what this means, as some people seem to be confused by the jumper option. For a PAL console in a PAL region, such as where I live, you can run either the PAL or NTSC versions of a game on a PAL console fine, but the colours for NTSC will be wrong. The TV will have to be new enough to ‘auto-sense’ an NTSC signal for this to work. If you aren’t sure just try it, as you can’t break anything. For NTSC consoles, running PAL games will often not work at all. There is no harm in trying, though. So if you are confused by the jumper, just remove it. The NTSC menu should display OK on PAL systems (and most TVs out there) and if you are using an NTSC system it probably won’t like the PAL menu. (My NTSC console doesn’t display the PAL menu.) I have formatted my UNO cart with two main folders ‘PAL’ and ‘NTSC’, and left the jumper off. The UNO cart ‘boots’ fine on either type of console (to the NTSC menu), then you just select the NTSC or PAL folder then the game to run. Makes everything easy. (Another caveat is that the PAL consoles run slower, so an NTSC game will have not only have incorrect colours on a PAL console but will also run slower than intended.) Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4185278 Share on other sites More sharing options...
+MacRorie Posted December 28, 2018 Share Posted December 28, 2018 As a side note on the NTSC/PAL thing: I have noticed that the PAL menu will display more titles on screen than the NTSC menu (at least on an NTSC console/monitor). Of course, the menu is in black and white, but the console sorts itself out once it gets to the ROM. Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4185296 Share on other sites More sharing options...
boggis the cat Posted December 28, 2018 Share Posted December 28, 2018 As a side note on the NTSC/PAL thing: I have noticed that the PAL menu will display more titles on screen than the NTSC menu (at least on an NTSC console/monitor). Of course, the menu is in black and white, but the console sorts itself out once it gets to the ROM. A lot of NTSC TVs will just barf and not display anything when a PAL format is presented. It may depend on how that menu system has been implemented, as the VCS builds the display on the fly. Modern TVs all seem to have 'universal' chip-sets in them to allow displaying (almost) everything. Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4185423 Share on other sites More sharing options...
newtmonkey Posted December 28, 2018 Share Posted December 28, 2018 Ordered this a short while back and it arrived safe and sound (after getting misplaced on a mail truck here for a couple weeks haha)! Works great, running it on an NTSC 7800... currently reliving my childhood!~ Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4185485 Share on other sites More sharing options...
+MacRorie Posted December 28, 2018 Share Posted December 28, 2018 Ordered this a short while back and it arrived safe and sound (after getting misplaced on a mail truck here for a couple weeks haha)! Works great, running it on an NTSC 7800... currently reliving my childhood!~ Yeah, that was weird. Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4185695 Share on other sites More sharing options...
xefned Posted December 31, 2018 Share Posted December 31, 2018 Draconian Space Rocks Anguna Dungeon II Panky the Panda Zippy Mappy I can confirm, Panky the Panda runs great on the UnoCart. We've been playing it non-stop for the past few days on the Unocart. Brutally hard! Also successfully run Anguna and Zippy. Does anyone have a rom of Draconian that runs on the UnoCart? Mine just gives a blank screen. Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4187541 Share on other sites More sharing options...
Gábor Orvos Posted January 1, 2019 Share Posted January 1, 2019 As a side note on the NTSC/PAL thing: I have noticed that the PAL menu will display more titles on screen than the NTSC menu (at least on an NTSC console/monitor). Of course, the menu is in black and white, but the console sorts itself out once it gets to the ROM. I think the reason is that PAL video contains more scanlines than NTSC (576 vs. 480). Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4188228 Share on other sites More sharing options...
DirtyHairy Posted January 1, 2019 Share Posted January 1, 2019 (edited) Does anyone have a rom of Draconian that runs on the UnoCart? Mine just gives a blank screen. Draconian will not run as the UnoCard does not currently support the CDF scheme,. Edited January 1, 2019 by DirtyHairy Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4188504 Share on other sites More sharing options...
xefned Posted January 2, 2019 Share Posted January 2, 2019 Draconian will not run as the UnoCard does not currently support the CDF scheme,. Thanks Hairy. I was stupidly confusing it for the Boulder Dash demo that was shared a couple pages back. I found the compatibility clue by visiting the Draconian page and reading that "Draconian is a Melody-enhanced game that takes full advantage of the CDF mode in the Melody." I think that makes Draconian one of the very few games not yet compatible with Uno where the rom is also freely available. Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4188605 Share on other sites More sharing options...
Arenafoot Posted January 2, 2019 Share Posted January 2, 2019 I got mine yesterday!!! Now I have to build a completely new ROM pack for this!!! (Directories) Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4188749 Share on other sites More sharing options...
Paranoid Posted January 18, 2019 Share Posted January 18, 2019 Is anyone making these for sale? I realize I'm about a year late to this post. I've got a CC2 - but I use it almost exclusively for Atari 2600 titles. Would be nice to have one that works directly with the 2600. Does it handle Supercharger game images? Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4199973 Share on other sites More sharing options...
+MacRorie Posted January 18, 2019 Share Posted January 18, 2019 Is anyone making these for sale? I realize I'm about a year late to this post. I've got a CC2 - but I use it almost exclusively for Atari 2600 titles. Would be nice to have one that works directly with the 2600. Does it handle Supercharger game images? Yes, I am making them continuously. check out https://www.thebrewingacademy.com/2600UNO_OrderInfo.html (also from me on eBay for a slightly higher price). Yes, it handles SuperCharger images Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4199998 Share on other sites More sharing options...
Paranoid Posted January 18, 2019 Share Posted January 18, 2019 I found you, MacRorie - and the check is in the mail (or, the Paypal transfer is in your account, anyhow...) 1 Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4200183 Share on other sites More sharing options...
Paranoid Posted January 18, 2019 Share Posted January 18, 2019 In the early 80s/90s, I ran The Santiarium BBS/The Amiga Archives in the 916 area... The Bates Motel BBS sounded super familiar, so I looked it up to see if it was the same one. I'm fairly certain it is. In the early 2000s I put The Sanitarium back up as a telnet BBS on Sparc 5 for a while. It was cool at first, lots of nostalgia and most of the old crowd showed up for a while. But it is rough competing with Facebook. 1 Quote Link to comment https://forums.atariage.com/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600/page/14/#findComment-4200185 Share on other sites More sharing options...
