+Andrew Davie Posted July 18, 2021 Share Posted July 18, 2021 On 7/16/2021 at 10:18 PM, WicoKid said: Any ideas? Has the firmware become specific to the Pcb board design? The very latest PCB design from me is compatible with both UnoCart and PlusCart firmware, as the address lines are "doubled" to the correct pins for both firmwares. Earlier boards AFAIK were either UnoCart boards OR PlusCart boards (but not both). That is, if you are putting firmware on a board that is not my dual-design, then you need to have firmware that is looking at the correct pins, so to speak, on the ARM. That's because the UnoCart and PlusCart firmware use different pins for the address/data lines. This is not a matter of "has the firmware become specific" but that the firmware was always specific, and only with my "dual mode" PCB could you mix and match the firmware/type you used. That is, my board is compatible with the UnoCart AND the PlusCart firmware. Earlier boards were UnoCart OR PlusCart. That's my recollection. It's been a while since I've thought about it. 1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted July 18, 2021 Share Posted July 18, 2021 To refine the previous answer.... The new boards allow PlusCart OR UnoCart (original) firmware, thus allowing you to make a genuine UnoCart with these boards. There was not previously a UnoCart board available, and so you could not DIY UnoCart. Original UnoCart firmware does not run on the older boards, due to an address pin difference. The new board feeds the data/address pins to dual pins on the ARM, and so the firmware can choose either. The PlusCart firmware runs on all boards. And there's a UnoCart-version build of PlusCart, IIRC - which, at a guess, will run on original UnoCarts if you update the firmware on those. 1 Quote Link to comment Share on other sites More sharing options...
WicoKid Posted July 21, 2021 Share Posted July 21, 2021 Thank you for responding. Here are pictures of my construction from the Discovery board described in the Edwards original Unocart build on GitHub. The original instructions do not mention setting boot1/boot0. There is no repetitive pattern or sound the Atari makes, after turning on, it does output video; anything from blank screen and no sound, to locked up but familiar (Atari) sounding beeps and buzzes; occasional black with light colored narrowed vertical stripes, occasionally orange screen with dark narrow vertical stripes. After reading the thread on the PlusCartSD and watching the youtube videos, it is my next DIY project. However later in the thread there are downloads for firmware but after updates to PCB are mentioned, I cannot find the updated Gerber files and cannot locate them on GitHub or even from video links. Sorry if I'm breaking some ettiquitte by asking....its hard to tell if the thread is a developer exchange or an open to all situation as far as the Gerber files. Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted July 21, 2021 Share Posted July 21, 2021 1 hour ago, WicoKid said: The original instructions do not mention setting boot1/boot0. Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted July 21, 2021 Share Posted July 21, 2021 1 hour ago, WicoKid said: After reading the thread on the PlusCartSD and watching the youtube videos, it is my next DIY project. However later in the thread there are downloads for firmware but after updates to PCB are mentioned, I cannot find the updated Gerber files and cannot locate them on GitHub or even from video links. Sorry if I'm breaking some ettiquitte by asking....its hard to tell if the thread is a developer exchange or an open to all situation as far as the Gerber files. The PlusCart Duo (Pluscart with WiFi and SD) is in an experimental stage and is not detected and fully supported by the PlusStore. I think the latest version of the gerber files for the hybrid PlusCart/UnoCart board is in this post by @Andrew Davie Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted July 21, 2021 Share Posted July 21, 2021 Here is a minor update. The holes for the MicroSD module were a bit small, and have been enlarged. 4 hours ago, WicoKid said: After reading the thread on the PlusCartSD and watching the youtube videos, it is my next DIY project. However later in the thread there are downloads for firmware but after updates to PCB are mentioned, I cannot find the updated Gerber files and cannot locate them on GitHub or even from video links. Sorry if I'm breaking some ettiquitte by asking....its hard to tell if the thread is a developer exchange or an open to all situation as far as the Gerber files. I have just posted the latest board/schematics, and a GERBER export using PCBWay's CAM file for 2 layer boards into the tread @Al_Nafuur linked above. There was only a minor hole-size change, but makes all the difference when assembling. 2 Quote Link to comment Share on other sites More sharing options...
youxia Posted November 17, 2021 Share Posted November 17, 2021 Do you know any European sellers? Quote Link to comment Share on other sites More sharing options...
manterola Posted November 19, 2021 Share Posted November 19, 2021 Maybe answered in the previous 17 pages..... Can an UnoCart2600 be housed in a "regular" original 2600 case? For example PacMan is quite common.. Does the PCB fit inside a pacman case? I know I will need to make some mods in order to provide a slot for the SD Card, but beside that modification? I am asking, because I broke the tabs (of the 3d printed case) that open the dust cover of the sixer console. Maybe an Activision type case can also work.... I don't know... Any ideas? Quote Link to comment Share on other sites More sharing options...
xefned Posted November 19, 2021 Share Posted November 19, 2021 20 minutes ago, manterola said: Maybe answered in the previous 17 pages..... Can an UnoCart2600 be housed in a "regular" original 2600 case? For example PacMan is quite common.. Does the PCB fit inside a pacman case? I know I will need to make some mods in order to provide a slot for the SD Card, but beside that modification? I am asking, because I broke the tabs (of the 3d printed case) that open the dust cover of the sixer console. Maybe an Activision type case can also work.... I don't know... Any ideas? Yes, it will fit inside a regular Atari cart. I rehoused my UnoCart in a Combat cartridge. And I sent the 3d printed case back to MacRorie to reuse. Not sure about Activision cartridges, but the PCB aligns with a standard Atari cartridge perfectly, so Pac-Man will be an acceptable substitute. Quote Link to comment Share on other sites More sharing options...
manterola Posted December 1, 2021 Share Posted December 1, 2021 Thanks for the help. I ended up repurposing a Pac-Man cartridge. I needed to cut and file the cart to make room for the PCB and for the SD card. Finally, I took a promotional old picture, applied a filter and used the 2600 label website to quickly create a label so the cart does not look “naked“. Not that bad for quick hack....: Quote Link to comment Share on other sites More sharing options...
xefned Posted December 1, 2021 Share Posted December 1, 2021 7 hours ago, manterola said: OMG, that is WONDERFUL. I love it. Nice work! Quote Link to comment Share on other sites More sharing options...
xefned Posted December 1, 2021 Share Posted December 1, 2021 Yours is way better, but while we're sharing our rehoused Uno-Carts, here's mine in a Combat cartridge. Quote Link to comment Share on other sites More sharing options...
DFL Posted December 23, 2021 Share Posted December 23, 2021 (edited) . Edited December 23, 2021 by DFL Sorry, double posted Quote Link to comment Share on other sites More sharing options...
lopezpb Posted July 26, 2022 Share Posted July 26, 2022 I want to build a Uno 2600, but with the current lack of STM32F407VGT6/7, can I use STM32F407VET6 instead? Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted July 26, 2022 Share Posted July 26, 2022 29 minutes ago, lopezpb said: I want to build a Uno 2600, but with the current lack of STM32F407VGT6/7, can I use STM32F407VET6 instead? Yes you can. The only technical difference between the VGT6 and the VET6 is the flash ROM size ( 1 MiB vs. 512 KiB) and of course a large difference in price and availability. The only drawback is that there will eventually be a bank switching scheme that requires the larger flash memory. Currently there is none supported by the standard UnoCart firmware. Which board do you want to use? You might want to have a look at @Andrew Davie's Unified breakout board (which should work with the v17 UnoCart firmware too) in this thread: Quote Link to comment Share on other sites More sharing options...
lopezpb Posted July 26, 2022 Share Posted July 26, 2022 (edited) 33 minutes ago, Al_Nafuur said: Which board do you want to use? I have PCB from PCBWay: https://www.pcbway.com/project/shareproject/UnoCart_2600FS_v1_03.html I have one more question, is there any replacement for MIC5504-3.3YM5-TR? Edited July 26, 2022 by lopezpb 1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted July 26, 2022 Share Posted July 26, 2022 2 hours ago, Al_Nafuur said: You might want to have a look at @Andrew Davie's Unified breakout board (which should work with the v17 UnoCart firmware too) in this thread: In reality I had very little to do with this; I took an existing design and added a few tracks to the board. The credit for this lovely bit of hardware is all yours, not mine 1 Quote Link to comment Share on other sites More sharing options...
repetto74 Posted September 9, 2022 Share Posted September 9, 2022 On 7/26/2022 at 11:19 AM, Al_Nafuur said: Yes you can. The only technical difference between the VGT6 and the VET6 is the flash ROM size ( 1 MiB vs. 512 KiB) and of course a large difference in price and availability. The only drawback is that there will eventually be a bank switching scheme that requires the larger flash memory. Currently there is none supported by the standard UnoCart firmware. Which board do you want to use? You might want to have a look at @Andrew Davie's Unified breakout board (which should work with the v17 UnoCart firmware too) in this thread: I would like also to build the UnoCart2600 and use the VET6 alternative microcontroller. If I understood correctly the firmware originally developed for the VGT6 is 100% compatible? Do we need to recompile or amend it before flashing it? Quote Link to comment Share on other sites More sharing options...
repetto74 Posted September 10, 2022 Share Posted September 10, 2022 On 7/26/2022 at 11:31 AM, lopezpb said: I have PCB from PCBWay: https://www.pcbway.com/project/shareproject/UnoCart_2600FS_v1_03.html I have one more question, is there any replacement for MIC5504-3.3YM5-TR? MIC5504 is available on Aliexpress at a low price. Quote Link to comment Share on other sites More sharing options...
lopezpb Posted September 14, 2022 Share Posted September 14, 2022 (edited) I used TLV70233DBVR instead, it works fine and I don't had to wait for shipping from China. @repetto74 STM32F407VET6 works fine Edited September 14, 2022 by lopezpb Quote Link to comment Share on other sites More sharing options...
