freewheel Posted January 28, 2018 Share Posted January 28, 2018 I have some questions that the IntyBASIC manual doesn't seem to address: 1. Is there a way to stop the Intellivoice, if it's mid-sentence? ie: if I run VOICE PLAY label, and it's halfway through the contents of <label> - can I stop it? I think I can call VOICE INIT to do this, but is that a good/safe method? 2. Is there a way to detect if the Intellivoice is still speaking? 3. I don't really understand what VOICE WAIT and VOICE PLAY WAIT are supposed to do. Do they literally pause the program until the voice queue is empty? Because just using VOICE PLAY label, it *always* waits until the queue is empty before playing <label>. In jzintv and on real hardware. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted January 28, 2018 Share Posted January 28, 2018 I have some questions that the IntyBASIC manual doesn't seem to address: 1. Is there a way to stop the Intellivoice, if it's mid-sentence? ie: if I run VOICE PLAY label, and it's halfway through the contents of <label> - can I stop it? I think I can call VOICE INIT to do this, but is that a good/safe method? There's no way currently. 2. Is there a way to detect if the Intellivoice is still speaking? Now there is a VOICE.PLAYING expression. 3. I don't really understand what VOICE WAIT and VOICE PLAY WAIT are supposed to do. Do they literally pause the program until the voice queue is empty? Because just using VOICE PLAY label, it *always* waits until the queue is empty before playing <label>. In jzintv and on real hardware. VOICE WAIT is to wait for voice to end playing. VOICE PLAY WAIT is to play a voice and wait for it to end. I'm pretty sure VOICE PLAY stops any other voice playing. I'll need to check about this because the trick to stop voice would be something like putting a VOICE PA4,0 and then VOICE PLAY that voice. Quote Link to comment Share on other sites More sharing options...
intvnut Posted January 28, 2018 Share Posted January 28, 2018 I think I can call VOICE INIT to do this, but is that a good/safe method? You should only call VOICE INIT once, at the start of time. Recall the fun we discovered w/ Crazybus? Also, there was some other game that had voice issues due to calling VOICE INIT more than once. (IMHO, VOICE INIT should be removed from the language, and IntyBASIC should just initialize the Intellivoice automatically, if any VOICE keywords are used. But, that's a different topic.) I'm pretty sure VOICE PLAY stops any other voice playing. I'll need to check about this because the trick to stop voice would be something like putting a VOICE PA4,0 and then VOICE PLAY that voice. Just be sure that IntyBASIC cuts over on phoneme boundaries. We don't want to get our poor SP0256 confused. :-) If it gets confused enough, it'll need to be reset via the hardware reset button. 2 Quote Link to comment Share on other sites More sharing options...
freewheel Posted January 29, 2018 Author Share Posted January 29, 2018 VOICE WAIT is to wait for voice to end playing. VOICE PLAY WAIT is to play a voice and wait for it to end. I'm pretty sure VOICE PLAY stops any other voice playing. I'll need to check about this because the trick to stop voice would be something like putting a VOICE PA4,0 and then VOICE PLAY that voice. I still don't understand - what waits? I've played around a bit, and VOICE WAIT doesn't seem to do anything. The program continues even if a voice is playing. VOICE PLAY and VOICE PLAY WAIT seem to do the exact same thing. VOICE PLAY does *not* stop another voice that's playing. It seems to queue up a PLAY command, and then when the current one is finished, plays the next one. Watching the actual value of VOICE.PLAYING, it seems to change by 1 every time I queue up another VOICE PLAY - and then change by 1 as it de-queues and plays the next one. I'm just using a simple program - 2 VOICE PLAY statements, called when you press keypad 1 or 2. I can play one at a time, but it always plays until the end. And the others queue up (subject to a limit of 10 in the queue, including the one currently playing). Observation: VOICE.PLAYING isn't totally accurate. It resets back to 0 while it's saying the second-to-last phrase/phoneme for a given VOICE PLAY statement. Not a big deal, but I figured I'd mention it as I look at the exact behaviour of these commands Easy test for this - use the MATTEL phrase. VOICE.PLAYING very quickly changes value, and then back to 0. The Intellivoice keeps talking for a bit. Edit: OK, I can "fix" the issue with VOICE.PLAYING. Adding a pause (PA*) at the end of any label, means that it resets to 0 right before the pause. So in effect, it goes to 0 when the Intellivoice stops talking. A simple enough solution. 2 Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted January 31, 2018 Share Posted January 31, 2018 I still don't understand - what waits? I've played around a bit, and VOICE WAIT doesn't seem to do anything. The program continues even if a voice is playing. VOICE PLAY and VOICE PLAY WAIT seem to do the exact same thing. Hehehe. I thought exactly the same thing: "X waits until play ends; Y plays until the end." LOL! However, I think that what it means is that "VOICE WAIT" will wait for the already playing voice string to finish, while "VOICE PLAY WAIT" will accept a voice string and start playing it, and wait until it ends. In other words, "VOICE PLAY WAIT" is the same as "VOICE PLAY" (start playing) followed by "VOICE WAIT" (wait until active voice ends). I could be wrong, but that's my interpretation of the description. Perhaps others would like to chime in. -dZ. 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted January 31, 2018 Share Posted January 31, 2018 I could be wrong, but that's my interpretation of the description. Perhaps others would like to chime in. -dZ. That's exactly what it does. I remind testing it throughly. I'll need to check again in case something slip. Not a great deal of time available these days Quote Link to comment Share on other sites More sharing options...
intvnut Posted February 1, 2018 Share Posted February 1, 2018 Edit: OK, I can "fix" the issue with VOICE.PLAYING. Adding a pause (PA*) at the end of any label, means that it resets to 0 right before the pause. So in effect, it goes to 0 when the Intellivoice stops talking. A simple enough solution. Interestingly enough, I put a note to that effect in my Intellivoice driver, about 15 years ago: ;; ======================================================================== ;; ;; NAME ;; ;; IV_WAIT Wait for voice queue to empty. ;; ;; ;; ;; AUTHOR ;; ;; Joseph Zbiciak <intvnut AT gmail.com> ;; ;; ;; ;; REVISION HISTORY ;; ;; 15-Sep-2002 Initial revision . . . . . . . . . . . J. Zbiciak ;; ;; ;; ;; INPUTS for IV_WAIT ;; ;; R5 Return address ;; ;; ;; ;; OUTPUTS ;; ;; R0 trashed. ;; ;; ;; ;; NOTES ;; ;; This waits until the Intellivoice is nearly completely quiescent. ;; ;; Some voice data may still be spoken from the last triggered ;; ;; phrase. To truly wait for *that* to be spoken, speak a 'pause' ;; ;; (eg. RESROM.pa1) and then call IV_WAIT. ;; ;; ------------------------------------------------------------------------ ;; ;; Copyright (c) 2002, Joseph Zbiciak ;; ;; ======================================================================== ;; The SP0256 doesn't report whether it's still making noise. It only reports whether it can accept new speech data. So, you do have to speak a little bit of silence to know you're done making noise. Quote Link to comment Share on other sites More sharing options...
intvnut Posted February 3, 2018 Share Posted February 3, 2018 (edited) As promised a couple days ago: I've modified intybasic_prologue.asm and intybasic_epilogue.asm such that: You never need to call VOICE INIT. If you use any voice functions in your game, VOICE INIT gets called automagically before your program starts. Zero overhead for games that don't use voice. Calling VOICE INIT is always safe; it really does a VOICE HUSH: Stop speaking the current sample, queue up a PA1 sample, and wait for PA1 to start. You can adopt these changes into IntyBASIC 1.2.9 as-is just by dropping these files in over your existing files. If you're already using modified intybasic_prologue.asm and intybasic_epilogue.asm, here's the diff, should you want to apply the change: . --- ../intybasic-1.2.9b/intybasic_prologue.asm 2016-10-21 11:40:17.000000000 -0700 +++ intybasic_prologue.asm 2018-02-02 23:58:26.000000000 -0800 @@ -148,7 +148,8 @@ MVII #$038,R0 MVO R0,$01F8 ; Configures sound MVO R0,$00F8 ; Configures sound (ECS) - CALL _wait + + CALL _bottom_half ;* ======================================================================== *; ;* These routines are placed into the public domain by their author. All *; --- ../intybasic-1.2.9b/intybasic_epilogue.asm 2016-10-21 11:40:21.000000000 -0700 +++ intybasic_epilogue.asm 2018-02-03 00:36:33.000000000 -0800 @@ -1980,7 +1980,7 @@ ;; Copyright (c) 2002, Joseph Zbiciak ;; ;; ======================================================================== ;; -IV_INIT PROC +IV_INIT_1 PROC MVII #$0400, R0 ; MVO R0, $0081 ; Reset the Intellivoice @@ -2002,9 +2002,11 @@ DECR R0 MVO R0, IV.QH ; Set queue to -1 ("No Intellivoice") MVO R0, IV.QT ; Set queue to -1 ("No Intellivoice") - JR R5 ; Done! +; JR R5 ; Done! + B _wait ; Special for IntyBASIC! ENDP + ;; ======================================================================== ;; ;; NAME ;; ;; IV_ISR Interrupt service routine to feed Intellivoice ;; @@ -2272,6 +2274,67 @@ ;; ======================================================================== ;; ;; NAME ;; +;; IV_HUSH Flush the speech queue, and hush the Intellivoice. ;; +;; ;; +;; AUTHOR ;; +;; Joseph Zbiciak <intvnut AT gmail.com> ;; +;; ;; +;; REVISION HISTORY ;; +;; 02-Feb-2018 Initial revision . . . . . . . . . . . J. Zbiciak ;; +;; ;; +;; INPUTS for IV_HUSH ;; +;; None. ;; +;; ;; +;; OUTPUTS ;; +;; R0 trashed. ;; +;; ;; +;; NOTES ;; +;; Returns via IV_WAIT. ;; +;; ;; +;; ======================================================================== ;; +IV_INIT: ; In IntyBASIC, "VOICE INIT" turns into "VOICE HUSH" now. +IV_HUSH PROC + MVI IV.QH, R0 + SWAP R0, 2 + BMI IV_WAIT.leave + + DIS + ;; We can't stop a phrase segment that's being FIFOed down. + ;; We need to remember if we've committed to pushing ALD. + ;; We _can_ stop new phrase segments from going down, and _can_ + ;; stop new phrases from being started. + + ;; Set head pointer to indicate we've inserted one item. + ;; Do this first, as we already have IV.QH in R0. + ANDI #$F0, R0 + INCR R0 + MVO R0, IV.QH + + ;; Reset tail pointer, keeping "need ALD" bit and other flags. + MVI IV.QT, R0 + ANDI #$F0, R0 + MVO R0, IV.QT + + ;; Reset the phrase pointer, to stop a long phrase. + CLRR R0 + MVO R0, IV.PPTR + + ;; Queue a PA1 in the queue. Since we're can't guarantee the user + ;; has included resrom.asm, let's just use the raw number (5). + MVII #5, R0 + MVO R0, IV.Q + + ;; Re-enable interrupts and wait for Intellivoice to shut up. + ;; + ;; We can't just jump to IV_WAIT.q_loop, as we need to reload + ;; IV.QH into R0, and I'm really committed to only using R0. +; JE IV_WAIT + EIS + ; fallthrough into IV_WAIT + ENDP + +;; ======================================================================== ;; +;; NAME ;; ;; IV_WAIT Wait for voice queue to empty. ;; ;; ;; ;; AUTHOR ;; @@ -2279,6 +2342,7 @@ ;; ;; ;; REVISION HISTORY ;; ;; 15-Sep-2002 Initial revision . . . . . . . . . . . J. Zbiciak ;; +;; 02-Feb-2018 Shave cycles on presence detect . . . J. Zbiciak ;; ;; ;; ;; INPUTS for IV_WAIT ;; ;; R5 Return address ;; @@ -2296,9 +2360,8 @@ ;; ======================================================================== ;; IV_WAIT PROC MVI IV.QH, R0 - SWAP R0 ;\___ test bit 7, leave if set. - SWAP R0 ;/ (SWAP2 corrupts upper byte.) - BMI @@leave + CMPI #$80, R0 + BC @@leave ; Wait for queue to drain. @@q_loop: CMP IV.QT, R0 @@ -2334,7 +2397,7 @@ ;; REVISION HISTORY ;; ;; 16-Sep-2002 Initial revision . . . . . . . . . . . J. Zbiciak ;; ;; ;; -;; INPUTS for IV_INIT ;; +;; INPUTS for IV_SAYNUM16 ;; ;; R0 Number to "speak" ;; ;; R5 Return address ;; ;; ;; @@ -2431,6 +2494,9 @@ ;; ======================================================================== ;; ;; End of File: saynum16.asm ;; ;; ======================================================================== ;; +_bottom_half: EQU IV_INIT_1 + ELSE +_bottom_half: EQU _wait ; No voice init; just WAIT. ENDI intybasic_prologue.asm intybasic_epilogue.asm voice.diff.txt Edited February 3, 2018 by intvnut 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted February 3, 2018 Share Posted February 3, 2018 (edited) Note: I had had a minor error in my previous post; I've updated it to have the corrected code. Specifically, IV_HUSH should start like this: +IV_INIT: ; In IntyBASIC, "VOICE INIT" turns into "VOICE HUSH" now. +IV_HUSH PROC + MVI IV.QH, R0 + SWAP R0, 2 + BMI IV_WAIT.leave I had accidentally had "BC" there instead of BMI. Should really be harmless, but worth fixing. ..... EDIT: Aaaand I forgot the diff hunk for intybasic_prologue.asm. It's in the previously posted intybasic_prologue.asm, but it's missing from the "voice.diff.txt" file. The missing hunk looks like this: --- ../intybasic-1.2.9b/intybasic_prologue.asm 2016-10-21 11:40:17.000000000 -0700 +++ intybasic_prologue.asm 2018-02-02 23:58:26.000000000 -0800 @@ -148,7 +148,8 @@ MVII #$038,R0 MVO R0,$01F8 ; Configures sound MVO R0,$00F8 ; Configures sound (ECS) - CALL _wait + + CALL _bottom_half This is how I transparently hook in the voice initialization, without taking any code size. The _bottom_half label gets defined in intybasic_epilogue.asm. If voice is being used, that label corresponds to IV_INIT_1, which then chains to _wait. If voice is not being used, that label corresponds to _wait directly. I updated the diff accordingly in my previous post. That's what I get for posting in the weeee hours of the night. :-P Edited February 3, 2018 by intvnut Quote Link to comment Share on other sites More sharing options...
freewheel Posted August 2, 2018 Author Share Posted August 2, 2018 Random observation: VOICE.PLAYING will very briefly reset to 0 a few times, during something like this. I had to come up with a clever trick to determine if it's ACTUALLY done playing even if we see VOICE.PLAYING = 0. VOICE PLAY voice_sample_long voice_sample_long: VOICE ONE,TWO,THREE,FOUR,FIVE,SIX,SEVEN,EIGHT,NINE,TEN,ELEVEN,TWELVE,THIRTEEN,FOURTEEN,FIFTEEN,SIXTEEN,SEVENTEEN,EIGHTEEN,NINETEEN,TWENTY,PA4,0 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted August 2, 2018 Share Posted August 2, 2018 Random observation: VOICE.PLAYING will very briefly reset to 0 a few times, during something like this. I had to come up with a clever trick to determine if it's ACTUALLY done playing even if we see VOICE.PLAYING = 0. VOICE PLAY voice_sample_long voice_sample_long: VOICE ONE,TWO,THREE,FOUR,FIVE,SIX,SEVEN,EIGHT,NINE,TEN,ELEVEN,TWELVE,THIRTEEN,FOURTEEN,FIFTEEN,SIXTEEN,SEVENTEEN,EIGHTEEN,NINETEEN,TWENTY,PA4,0 What's interesting about that sequence is that it's all RESROM samples. It appears VOICE.PLAYING doesn't check that the phrase pointer is null, only the FIFO loading pointer: . MVI IV.QT,R0 ANDI #7,R0 SUB IV.QH,R0 BNE $+15 MVI IV.FPTR,R0 TSTR R0 BNE $+10 MVI 129,R0 COMR R0 AND 128,R0 COMR R0 ANDI #32768,R0 MVO R0,V1 . Here's the problem: IV.QH and IV.QT will be equal once the phrase starts playing, because there's only one phrase queued. IV.FPTR will be zero, because there's no data to load into the FIFO. That's used for allophones, but not for RESROM. Location $81 will always report "FIFO ready for data" as there's nothing in it. So then we're left with the question of how big a window we will see LRQ go high ($80 bit 15) between RESROM samples. Note that IV_WAIT will do the wrong thing here too. If you queue a second phrase with PA4, then the right thing will happen, as QH != QT. That's my long-standing suggestion anyway for handling the "still speaking" problem. Adding PA4 to the end of a phrase doesn't help because of the gaps in LRQ. That probably should be fixed. This requires fixes in two places: VOICE.PLAYING should check for IV.PPTR = 0. IV_WAIT should also check for IV.PPTR = 0. For IV_WAIT, I'd suggest something like this in intybasic_epilogue.asm: ;; ======================================================================== ;; ;; NAME ;; ;; IV_WAIT Wait for voice queue to empty. ;; ;; ;; ;; AUTHOR ;; ;; Joseph Zbiciak <intvnut AT gmail.com> ;; ;; ;; ;; REVISION HISTORY ;; ;; 15-Sep-2002 Initial revision . . . . . . . . . . . J. Zbiciak ;; ;; 02-Feb-2018 Shave cycles on presence detect . . . J. Zbiciak ;; ;; 02-Aug-2018 Wait for last phrase to complete . . . J. Zbiciak ;; ;; ;; ;; INPUTS for IV_WAIT ;; ;; R5 Return address ;; ;; ;; ;; OUTPUTS ;; ;; R0 trashed. ;; ;; ;; ;; NOTES ;; ;; This waits until the Intellivoice is nearly completely quiescent. ;; ;; Some voice data may still be spoken from the last triggered ;; ;; phrase. To truly wait for *that* to be spoken, speak a 'pause' ;; ;; (eg. RESROM.pa1) and then call IV_WAIT. ;; ;; ------------------------------------------------------------------------ ;; ;; Copyright (c) 2002, Joseph Zbiciak ;; ;; ======================================================================== ;; IV_WAIT PROC MVI IV.QH, R0 CMPI #$80, R0 BC @@leave ; Wait for queue to drain. @@q_loop: CMP IV.QT, R0 BNEQ @@q_loop ; Wait for last phrase to complete. CLRR R0 @@f_loop: CMP IV.PPTR,R0 BNEQ @@f_loop ; Wait for FIFO and LRQ to say ready. @@s_loop: MVI $81, R0 ; Read FIFO status. 0 == ready. COMR R0 AND $80, R0 ; Merge w/ LRQ status. 1 == ready TSTR R0 BPL @@s_loop ; if bit 15 == 0, not ready. @@leave: JR R5 ENDP . As for VOICE.PLAYING: Rather than open-code like that, it feels like it should just call a library function to save a bit of code-size. Is it really that performance critical to be so bloaty? If it calls a library function, then IV_WAIT could be rewritten in terms of that library function. Something like: . ; Return R0 != 0 if voice is playing _voice_playing PROC MVI IV.QH, R0 XOR IV.QT, R0 ANDI #7, R0 BNEQ @@busy MVI IV.PPTR,R0 TSTR R0 BNEQ @@busy MVI $81, R0 COMR R0 AND $80, R0 COMR R0 ANDI #$8000, R0 @@busy: JR R5 ENDP IV_WAIT PROC PSHR R5 @@loop: CALL _voice_playing TSTR R0 BNEQ @@loop PULR PC ENDP . Thoughts? 1 Quote Link to comment Share on other sites More sharing options...
