ACML Posted February 12, 2018 Share Posted February 12, 2018 I understand that the three OS chips on the 400 can only address 10K, but is there any reason why an Atari 400 could not run a 16K operating system? I'm thinking of tf_hh's "Atari 400 RAM-Card 48/52 KB & external OS-ROM". It has the option to run a 16K EPROM OS. Can this board run the 800XL's Omniview 80 16K OS since it based on the 400/800 OSB? If it does not mess with joyports 3 &4, could it work and if so, would it allow full access to 64K RAM? The Omniview 80 OS is 16K 1) Based on the Atari 400/800 OSB OS ROM 2) Has the fast math floating point 3) Allows full access to 64K of RAM (Its a 64K OSB) 4) Has the ATR-8000 monitor built in 5) Has 80 column output Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 12, 2018 Share Posted February 12, 2018 My 400 has Supermon which occupies $C000-$CFFF so brings it up to 14K. You can't override the IO area $D000-$D7FF which is 2K which is why the Self-Test Rom in the XL gets mapped to $5000 when switched in. The logic and additional mod to do a 4K Rom addition at $C000 I think is fairly simple given that the 400/800 demux the address into 8K blocks to support the memory expansion architecture of the 800. Quote Link to comment Share on other sites More sharing options...
