+DrVenkman Posted March 19, 2019 Share Posted March 19, 2019 Hi, I think you need to solder up the connection - I haven't checked the code, but A5 needs to be connected up to the SIO socket (COMMAND pin for A5), possibly there is a check on the value in the code, which may be undefined if it isn't connected (this is all guesswork though). No, you don't. I flashed my device the first time without anything connected to the Arduino pins aside from the screen plugged into the headers. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted March 20, 2019 Share Posted March 20, 2019 I took the hex files and put them in sdrive max main folder that contained the flasher etc.... I took the screen and attached it to the ardy.. I attached the usb cord to the ardy and the pc with nothing else I made sure I had a proper usb driver I ran the flasher... i gave the ardy time to finish it's flashing then I pulled the usb cord and waited a few moments, then I plugged the usb cord back in and waited for the ardy to init then I pressed a key for the second part of flashing to occur... I waited a couple moments for the that flash to finish on the device... remember it takes a while for the programming to occur even though the PC will show it is done... it isn't... you must wait for the ardy to catch up and finalize each step. then you must set up the micro sd card using the X86 (win linux whatever) and put it in the ardy.. You can plug the usb cord in and use the X86 to power the now programmed sdrive max and calibrate the screen.... then it's time to add the isolation chip and circuitry, etc... then isolate power... add sio cord etc.... us external power not sio power.... party time! 1 Quote Link to comment Share on other sites More sharing options...
MADRAFi Posted March 20, 2019 Share Posted March 20, 2019 (edited) Thanks, I followed the suggestion that you need to flash first and solder later to avoid situation when you do not know if broken unit is due to wrong flashing or soldering remember it takes a while for the programming to occur even though the PC will show it is done... it isn't... you must wait for the ardy to catch up and finalize each step. I have waited few mins each time I think I gave enough time for each step. To me it looks like firmware does not recognize my screen. Does anyone know how to contact with firmware author? Does anyone know where in source code TFT definitions are? Edited March 20, 2019 by MADRAFi Quote Link to comment Share on other sites More sharing options...
E474 Posted March 21, 2019 Share Posted March 21, 2019 Hi, Sources are on GitHub at: https://github.com/kbr-net/sdrive-max Quote Link to comment Share on other sites More sharing options...
MADRAFi Posted March 21, 2019 Share Posted March 21, 2019 I was not asking for sources, I know them have them downloaded. I was asking for contact to author of the code or someone who could point me where is definition of LCD recognition Maybe my screen is slightly different then regular hx8347g Quote Link to comment Share on other sites More sharing options...
JR> Posted March 21, 2019 Share Posted March 21, 2019 A couple of other people have reported problems with the hx8347g earlier in the thread. It does not sound like they were ever resolved. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted March 21, 2019 Share Posted March 21, 2019 I was not asking for sources, I know them have them downloaded. I was asking for contact to author of the code or someone who could point me where is definition of LCD recognition Maybe my screen is slightly different then regular hx8347g You can log an issue at the Github repository so the developer will have notice of your issue and the opportunity to offer suggestions if he has any. Alternately, you can read through past posts in this very thread where there are links to the project developer’s personal page, which, if I recall correctly, had an email link to the author. Quote Link to comment Share on other sites More sharing options...
MADRAFi Posted March 21, 2019 Share Posted March 21, 2019 Thanks for suggestion, I have already sent email to author. Quote Link to comment Share on other sites More sharing options...
MADRAFi Posted March 22, 2019 Share Posted March 22, 2019 I want to thank Klaus, author of the firmware for the support. It turned out my screen has different pin layout and cannot be used. Quote Link to comment Share on other sites More sharing options...
KittyFae Posted April 5, 2019 Share Posted April 5, 2019 (edited) Heya. I just put this together and am having some kind of oddness happening to me and was looking for some help. I have an Elegoo Uno R3 and the Elegoo TFT screen as well as having the SDrive on its own power supply via the barrel jack. When I power up the Atari the screen on the SDrive gets corrupted, but I can just tap the ready on the bottom and then close that window and it redraws the screen fine. However, I think because of this the Atari wont boot from the SDrive on power on. I can get the SDrive to work by typing "bye" and going to the diagnostic screen then pressing the reset button. From there, the Atari will boot from the SDrive and it functions as normal. The SDrive is the only connected SIO device and has the proper diode and there is no 5v connection from the SDrive to the SIO port. I've tried the V0.7 release, the 1.0b2 and 1.1b with the same issue. Edited April 5, 2019 by KittyFae Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted April 6, 2019 Share Posted April 6, 2019 IIRC, I also must press RESET & Reboot. Mine is powered only by SIO, though. If yours has power on before boot then I believe you may have software corruption. That screen thing is very strange. Have you tried re-flashing it? Quote Link to comment Share on other sites More sharing options...
KittyFae Posted April 6, 2019 Share Posted April 6, 2019 IIRC, I also must press RESET & Reboot. Mine is powered only by SIO, though. If yours has power on before boot then I believe you may have software corruption. That screen thing is very strange. Have you tried re-flashing it? It does have power before the 130XE is turned on. I've tried reflashing it and trying 3 different versions and the screen glitches out and wont cold boot the same way on all three. Does the same thing on the 800XL too. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 6, 2019 Share Posted April 6, 2019 (edited) remember to allow each flash section to sit a bit and let the ardy catch up, then disconnect wait a moment reconnect, then let the second part flash... then let is catch up....catch up can take up to a minute... then all should be fine unless something is wrong with the ardy, or firmware choices so double check all wiring... post some pictures... if we don't see it- it may be time to think something is defective.. Edited April 6, 2019 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted April 6, 2019 Share Posted April 6, 2019 What chip is on your display? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted April 6, 2019 Share Posted April 6, 2019 How confident are you with your soldering? Is it possible you have a dodgy connection somewhere when you connected the SIO lines to the UNO? I guess it's also possible you have a bad ATmega chip on the Arduino. Quote Link to comment Share on other sites More sharing options...
KittyFae Posted April 6, 2019 Share Posted April 6, 2019 remember to allow each flash section to sit a bit and let the ardy catch up, then disconnect wait a moment reconnect, then let the second part flash... then let is catch up....catch up can take up to a minute... then all should be fine unless something is wrong with the ardy, or firmware choices so double check all wiring... post some pictures... if we don't see it- it may be time to think something is defective.. I tried it again and let it sit for a while between flashes and still the same issue. What chip is on your display? ILI9341 How confident are you with your soldering? Is it possible you have a dodgy connection somewhere when you connected the SIO lines to the UNO? I guess it's also possible you have a bad ATmega chip on the Arduino. Soldering is fine, beeped it out with a multimeter to make sure. I've done a ton of soldering prior to this project. Could be a bad chip somewhere, but it just strikes me as odd that everything works after the bye/reset thing. I'll order another Uno and see what is up. Quote Link to comment Share on other sites More sharing options...
E474 Posted April 6, 2019 Share Posted April 6, 2019 Hi, Have you tried just powering it from the 8-bit, e.g. unplugging the barrel connector. Also you can use the Atari key to reboot the drive-loader, once you have selected the ATR images you want to use. There is a manual for the sdrive loader, I saw it posted here a few weeks earlier as a PDF. Hope this helps! Quote Link to comment Share on other sites More sharing options...
Farb Posted April 6, 2019 Author Share Posted April 6, 2019 remember to allow each flash section to sit a bit and let the ardy catch up, then disconnect wait a moment reconnect, then let the second part flash... then let is catch up....catch up can take up to a minute... then all should be fine unless something is wrong with the ardy, or firmware choices so double check all wiring... post some pictures... if we don't see it- it may be time to think something is defective.. Just to make sure _The Doctor_'s comment is clear: be sure you flash eeprom_writer.hex BEFORE you flash SDrive.hex. If you don't do this, strange behavior with occur. 2 Quote Link to comment Share on other sites More sharing options...
KittyFae Posted April 6, 2019 Share Posted April 6, 2019 Just to make sure _The Doctor_'s comment is clear: be sure you flash eeprom_writer.hex BEFORE you flash SDrive.hex. If you don't do this, strange behavior with occur. I've made sure to do them in the correct order and waited a minute or two after each step of the eeprom_writer.hex, the reset, and the final sdrive.hex flashes. Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted April 6, 2019 Share Posted April 6, 2019 I've made sure to do them in the correct order and waited a minute or two after each step of the eeprom_writer.hex, the reset, and the final sdrive.hex flashes. Are you using USB or the 6 pin header on the board to program them? The reason I ask is that I tried to program mine with the six pin header and a USBasp. It **seems** to work, and the SDrive will boot, but I get funky behavior. Programming via the USB port is fine. Also, I get mixed results via my Mac & OS X. I get reliable results via Parallels on that same Mac. 1 Quote Link to comment Share on other sites More sharing options...
KittyFae Posted April 6, 2019 Share Posted April 6, 2019 Are you using USB or the 6 pin header on the board to program them? The reason I ask is that I tried to program mine with the six pin header and a USBasp. It **seems** to work, and the SDrive will boot, but I get funky behavior. Programming via the USB port is fine. Also, I get mixed results via my Mac & OS X. I get reliable results via Parallels on that same Mac. I am using USB and Windows / avrdude to program it 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted April 7, 2019 Share Posted April 7, 2019 I am using USB and Windows / avrdude to program it That's what I use. Quote Link to comment Share on other sites More sharing options...
KittyFae Posted April 10, 2019 Share Posted April 10, 2019 Got in a different Arduino Uno R3 today and everything works now. Seems the first one was faulty. Thanks for all the tips, suggestions and help! 3 Quote Link to comment Share on other sites More sharing options...
ricortes Posted April 12, 2019 Share Posted April 12, 2019 FWIW: I just programmed one tonight with XLoader for Windows. Almost a pleasant experience! I ran the MCUFriend code to ID the chip and it came up ILI9341 *BUT* the text was reversed. When the X in the corners came up to calibrate the screen, the touch screen and program hung. Ended up switching to the 9329 versions and everything worked fine. 1 Quote Link to comment Share on other sites More sharing options...
E474 Posted April 13, 2019 Share Posted April 13, 2019 Hi, Am just curious if anyone has tried out version 3 of Mr. Robot's fixer-upper board? Quote Link to comment Share on other sites More sharing options...
