Gamer888 Posted February 21, 2018 Share Posted February 21, 2018 Hi fellow genesis owners I have a genesis 2 which has a modified board. I plugged a scart RGB cable (from the megadrive 2). At best the picture looks great but I keep hearing a slight buzzing sound in the background(which is very clear once the sound is pause, the buzzing sound is present). However, sometimes the cable might distored the picture with a darker tone and with a louder buzzing sound. Whenever I touch the cable where it is plugged on, things go back to normal. All seems to show the cable has a defect but is it possible for a genesis to show such malfunction regardless of the cable??Sadly I have only this cable. No rca cable or else Quote Link to comment Share on other sites More sharing options...
Taijigamer Posted March 20, 2018 Share Posted March 20, 2018 Sounds like your cable has poor/ no shielding or not properly grounded which is why it improves when u touch it (grounding the cable through you). The buzzing is because interference from the Composite line is picked up by the audio lines as a buzz. The dim picture is because your cable may not have the necessary caps and resistors inside. Properly shielded audio lines solves this. Invest in a professional cable like retrogamingcables or HD retrovision. Quote Link to comment Share on other sites More sharing options...
Gamer888 Posted March 21, 2018 Author Share Posted March 21, 2018 I had poor cable...true that....some weeks ago I bought a motherboard-looking device to plug behind my coregrafx and I can play games with RGB like quality. I thought the cable I have been using was coregrafx only but it turned out to be a genesis compatible. I randomly plugged this cable and the picture is near perfect and the sound has lower parasite sounds. So not only I managed to land a quite good rgb cable but it is also compatible with my coregrafx and it is always sweet to save some room behind the TV! I know retrogamingcables or HD retrovision are great but my cable is good enough for me! 1 Quote Link to comment Share on other sites More sharing options...
