Gamesmaster86 Posted May 14, 2022 Share Posted May 14, 2022 I can certainly say that you'll need to solder the JTAG header to the ultra hdmi board, otherwise the pins won't be making contact correctly. You'll just need to make sure you have the header the correct way around, so maybe see if you can find pictures on which way around it should go. You also won't need to have the ribbon cable connected to the ultra hdmi board when flashing to it so disconnect that. Quote Link to comment Share on other sites More sharing options...
Darkhost Posted May 16, 2022 Share Posted May 16, 2022 Hi everyone, The job is done and my ultrahdmi is working again ! ? Here is my return of experience : You need : USB Blaster (I bought mine at 20€ from eBay) --> Windows won't find the driver, so you need to install it yourself by telling your OS to search the driver files in your "Altera" (= Quartus 2 software) folder Quartus 2 software (free from Intel website --> Intel® Quartus® II Web Edition Design Software Version 13.1 for Windows ) The "jtag file (xxx.jic)" to be flashed Some jtag header pins (<1€ from RS-online --> the english name is : "10PCS 2.54mm 10Pin 2x5 Pin Double Row Straight Male Shrouded header IDC Socket") In my previous post I was wondering if I needed to solder the "jtag header pins" on the ultrahdmi board --> the answer is YES This side is the correct one (make match the N°1 & N°2 jtag pin with the N°1 & N°2 writing on the ultrahdmi board). Then you also need to power On your N64 and finally your Quartus software will find your FPGA and you will be able to flash it with your xxx.jic file. Once flashed I put the new firmware (current is 1.10) on an Everdrive and I update it with the standard method (10 to 15 min). Some pics : I hope this will help. Good luck 1 Quote Link to comment Share on other sites More sharing options...
Chilloutsessions Posted August 11, 2022 Share Posted August 11, 2022 Hi @Darkhost I just updated my firmware today and it failed after reaching 99 percent. Shut down the console as per the onscreen instructions and is also bricked. I will follow your guide to the tee. What files do I require? , my installer has gone out of business so I am out of luck in Australia. Thanks, Will Quote Link to comment Share on other sites More sharing options...
kinoX51 Posted January 31, 2023 Share Posted January 31, 2023 @Darkhost @richisawesome since yesterday I’m in the same situation. My power went out in the middle of the firmware upgrade of my HW1. Maybe someone can point me to the needed firmware files for the manual update with the USB Blaster. Thanks, Kevin Quote Link to comment Share on other sites More sharing options...
kinoX51 Posted February 2, 2023 Share Posted February 2, 2023 Sorry for the doublepost - I just got the .jic-file and was able to reflash my UltraHDMI with the Quartus Prime-Software to version 1.05. A normal Update with my Everdrive to 1.10 was then successful 1 2 Quote Link to comment Share on other sites More sharing options...
Darkhost Posted February 4, 2023 Share Posted February 4, 2023 Hi Chilloutsessions, I just sent you the .jic file from PM. Good luck! Hi kinoX51, glad to see your UltraHDMI is working again. Good N64 playing session for both of you ! 1 1 Quote Link to comment Share on other sites More sharing options...
retrojake Posted February 8, 2023 Share Posted February 8, 2023 Hi, I have recently updated my ultraHDMI from version 1.08 -> 1.10 and now I can't get any video output so I think I need to flash it. I have purchased a USB Blaster and header pins, would someone be kind enough to send me the jtag file please? Many thanks Quote Link to comment Share on other sites More sharing options...
Darkhost Posted February 8, 2023 Share Posted February 8, 2023 20 minutes ago, retrojake said: Hi, I have recently updated my ultraHDMI from version 1.08 -> 1.10 and now I can't get any video output so I think I need to flash it. I have purchased a USB Blaster and header pins, would someone be kind enough to send me the jtag file please? Many thanks Hi retrojake I just sent you the .jic file from PM. Good luck! Quote Link to comment Share on other sites More sharing options...
retrojake Posted February 8, 2023 Share Posted February 8, 2023 10 minutes ago, Darkhost said: Hi retrojake I just sent you the .jic file from PM. Good luck! Legend, thank you! Quote Link to comment Share on other sites More sharing options...
doughnutsaint Posted February 17, 2023 Share Posted February 17, 2023 Hello All, I was wondering if someone could also help me with obtaining the .jic file for my UltraHDMI board. I bought mine on game-tech.us many years ago. (Like 2018). Then I just left it in the originally packaging in my closet for several years. However, I just recently (This past January) had it installed by a vetted installer mentioned on gametechs.us website. When I received my modded UltraHDMI N64 back, it worked perfectly initially.... That's until I decided to update the firmware file from 1.07 to 1.10. (Used my Everdrive X7) After the update, the picture would randomly go in and out and then completely lose signal. Every time I try to use my UltraHDMI, I get the quick flashing red lights. Tried multiple Mini HDMI adapters, cables and on different TVs. The Multi AV out on my N64 does work just fine, so their is nothing wrong my N64 Console itself. I think when I updated the UltraHDMI my TV screen went to sleep and this might of been the culprit Anyway, I purchased a USB Blaster off Amazon, as a well as a 10 pin header mentioned by @Darkhost. I plan to try and re-flash the .jic file myself. I have reached out to my installer who but it's been several days without any reply. Would anyone be able to share the .jic file with me? I really would like to be able to use my UltraHDMI again. Thanks to everyone on this forum, as this is the only site I could find any information regarding this issue. Quote Link to comment Share on other sites More sharing options...
Darkhost Posted February 25, 2023 Share Posted February 25, 2023 Hi @doughnutsaint, Check your PM BR 1 Quote Link to comment Share on other sites More sharing options...
Paul777Alejandro Posted March 11, 2023 Share Posted March 11, 2023 (edited) Hi, I have my ultra hdmi 1.08, and thanks to a power cut my console was blocked with the reset message ,would someone be kind enough to send me the jtag file please? Edited March 12, 2023 by Paul777Alejandro Quote Link to comment Share on other sites More sharing options...
Darkhost Posted March 12, 2023 Share Posted March 12, 2023 Hi @Paul777Alejandro Check your PM. BR Quote Link to comment Share on other sites More sharing options...
Vorenus Posted September 1, 2023 Share Posted September 1, 2023 Hello, I too am in the unfortunate boat of bricking my HW1 board. After upgrading from 1.08 to 1.10 and powering down as instructed by the updater, I no longer receive any signal from HDMI output. When using s-video and attempting the update again, I get the same frozen screen that @Darkhost had pictured. I went ahead and ordered a USB Blaster and JTAG header. Would some kind soul be willing to share the required jlc file for the flashing process? Quote Link to comment Share on other sites More sharing options...
Darkhost Posted September 2, 2023 Share Posted September 2, 2023 On 9/1/2023 at 3:05 AM, Vorenus said: Hello, I too am in the unfortunate boat of bricking my HW1 board. After upgrading from 1.08 to 1.10 and powering down as instructed by the updater, I no longer receive any signal from HDMI output. When using s-video and attempting the update again, I get the same frozen screen that @Darkhost had pictured. I went ahead and ordered a USB Blaster and JTAG header. Would some kind soul be willing to share the required jlc file for the flashing process? Hi Vorenus, Check your PM ;) 1 Quote Link to comment Share on other sites More sharing options...
phoenixgaming Posted September 16, 2023 Share Posted September 16, 2023 I am so glad I found this thread! I have the exact same issue. Trying to update causes the frozen odd color screen. @Darkhost can I trouble you for the .jic as well? Quote Link to comment Share on other sites More sharing options...
Darkhost Posted September 16, 2023 Share Posted September 16, 2023 38 minutes ago, phoenixgaming said: I am so glad I found this thread! I have the exact same issue. Trying to update causes the frozen odd color screen. @Darkhost can I trouble you for the .jic as well? Hi phoenixgaming, Check your PM Quote Link to comment Share on other sites More sharing options...
Wasaab Posted December 5, 2023 Share Posted December 5, 2023 Also on 1.08 and need the .jic file to recover a bad update to 1.10. I am glad I found this forum was wondering what I could do to fix it. Never had a problem until updating to this particular version. Thanks in advance for the assist in this forum post. Quote Link to comment Share on other sites More sharing options...
Darkhost Posted December 10, 2023 Share Posted December 10, 2023 On 12/5/2023 at 1:04 PM, Wasaab said: Also on 1.08 and need the .jic file to recover a bad update to 1.10. I am glad I found this forum was wondering what I could do to fix it. Never had a problem until updating to this particular version. Thanks in advance for the assist in this forum post. Hi Wasaab, Check your PM Quote Link to comment Share on other sites More sharing options...
Spade013 Posted April 9 Share Posted April 9 I'm in the same boat as many others with the HW1 version of the UltraHDMI. I have all the parts needed for the repair except for the file. Does anyone have the .jic file they can send me? Quote Link to comment Share on other sites More sharing options...
Darkhost Posted April 9 Share Posted April 9 20 hours ago, Spade013 said: I'm in the same boat as many others with the HW1 version of the UltraHDMI. I have all the parts needed for the repair except for the file. Does anyone have the .jic file they can send me? Hi Spade013, Check your PM BR Quote Link to comment Share on other sites More sharing options...
