RSS Bot Posted March 3, 2018 Share Posted March 3, 2018 One of the difficulties about working with 2 sets of code (6507 assembly and C) is there's some common info that both need to know. Manually maintaining that info in 2 places is error prone, so you want to limit that as much as possible. While developing Stay Frosty 2 I came up with the idea of having the 6507 assembly maintain that info, and have output it for C via echo commands: #define SUB queue[ $0 ]#define SWCHA queue[ $1 ]#define SWCHB queue[ $2 ]#define INPT1 queue[ $3 ]#define INPT4 queue[ $4 ]#define ElevatorHM26 $f7d1#define ElevatorHM31 $f804 I would manually copy/paste that into a C header file, followed by an additional step of find/replace the $ with 0x as dasm and C use incompatible formats for representing hex values.echo "#define SUB queue[", [ARMsub]d ,"]"echo "#define SWCHA queue[", [ARMswcha]d ,"]"echo "#define SWCHB queue[", [ARMswchb]d ,"]"echo "#define INPT1 queue[", [ARMinpt1]d ,"]" echo "#define INPT4 queue[", [ARMinpt4]d ,"]"echo "#define ElevatorHM26 ", [ElevatorHM26]decho "#define ElevatorHM31 ", [ElevatorHM31]d which would output:dasm testrom1.asm -f3 -otestrom1.cu | awk '!x[$$0]++' | grep "#define" > $(BASE)/defines_dasm.h It uses grep to automatically capture the echoed out #defines and stash them in the header file for the C code. Awesome! After implementing that in SpiceC I wondered if I could improve upon that further as writing all those echo statements would be tedious. After reading up on awk and realizing it could process columns of data, I got to thinking that the symbol file dasm outputs was in columns:2.Start, so I'd also need to include some selection logic. After some trial and error, and a bit of pondering, I came up with the following: The dasm step does a normal compile and creates a symbol file. The awk step scans the symbol file for anything starting with _ and creates the define file for C. Given this: #define _ARMmode 0x0009#define _AUDC0 0x000b#define _AUDC1 0x000c#define _AUDF0 0x000d#define _AUDF1 0x000e#define _AUDIO 0x0000#define _AUDIO_MUSIC 0x0001#define _AUDIO_SAMPLES 0x0002#define _AUDIO_TIA_ONLY 0x0000#define _AUDV0 0x000f#define _AUDV1 0x0010#define _COLUBK 0x0012#define _COLUPF 0x0011#define _DISPLAY_DATA_4_ARM 0x0013#define _FRAME 0x000a#define _FUNC 0x0000#define _INPT1 0x0005#define _INPT3 0x0006#define _INTP4 0x0003#define _INTP5 0x0004#define _OSTIME 0x0008#define _RUN_GAME_OS 0x0004#define _RUN_GAME_VB 0x0003#define _RUN_INIT 0x0000#define _RUN_INIT_LEVEL 0x0007#define _RUN_MENU_OS 0x0002#define _RUN_MENU_VB 0x0001#define _RUN_SPLASH_OS 0x0006#define _RUN_SPLASH_VB 0x0005#define _SWCHA 0x0001#define _SWCHB 0x0002#define _VBTIME 0x0007#define _WAVE_SIZE 0x0020 One of the benefits of using _ as a prefix is it lessens the chance of these defines conflicting with any end-user code.http://atariage.com/forums/blog/148/entry-14588-improved-6507-to-c-defines/ Link to comment Share on other sites More sharing options...
