hunter44102 Posted March 4, 2018 Share Posted March 4, 2018 With NanoPEB and Extended basic connected, I turn on the TI computer. (NanoPEB-F18 V1) I select 2 for Extended basic but it takes me to CF7+ Manager How do I exit to Extended basic? What I am trying to do is go to Extended basic, load cassette programs and save them to a volume on the NanoPEB CF card so I can archive them. Also I believe the first two volumes have utilities on them. Do I use the third volume to store my files? Thanks! I am an old TI user but never used Disks. Always used Tape Quote Link to comment Share on other sites More sharing options...
Opry99er Posted March 4, 2018 Share Posted March 4, 2018 Welcome!!! If it is a new CF card, youll need to format it and put yourself a *blank disk* in the virtual drive. You must mount the disks in the drives by using TI BASIC and the CALL MOUNT command. For a good example of how this is done, watch the archive from yesterdays CTIUG meeting on Ustream. Good luck!!!! 2 Quote Link to comment Share on other sites More sharing options...
hunter44102 Posted March 4, 2018 Author Share Posted March 4, 2018 Thats the part I don't get. All my programs are extended basic programs so I need to get into Extended basic to save the programs. I can't do it in TI Basic Quote Link to comment Share on other sites More sharing options...
Shift838 Posted March 4, 2018 Share Posted March 4, 2018 With NanoPEB and Extended basic connected, I turn on the TI computer. (NanoPEB-F18 V1) I select 2 for Extended basic but it takes me to CF7+ Manager How do I exit to Extended basic? What I am trying to do is go to Extended basic, load cassette programs and save them to a volume on the NanoPEB CF card so I can archive them. Also I believe the first two volumes have utilities on them. Do I use the third volume to store my files? Thanks! I am an old TI user but never used Disks. Always used Tape I don't recall but DSK1 may already be mounted and XB searches for 'LOAD' program on the disk. Go into basic (1) and type OLD DSK1.CATALOG and run that and then catalog disk 1, if you see a LOAD program then that's what's happening. Do you have the manual? 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted March 4, 2018 Share Posted March 4, 2018 Correct. Mount the drive in TI BASIC. Power cycle, then open XB and go. Mounting the disk just sets the proper bits in the nanoPEB firmware that tell the nano what to do. It will stay mounted forever until you UNMOUNT it 2 Quote Link to comment Share on other sites More sharing options...
hunter44102 Posted March 4, 2018 Author Share Posted March 4, 2018 OK Sounds like I need to un-mount the volume thats auto-booting into the CF manager, then mount a blank disk so I can save my stuff. Will give it a shot. Thanks all for the super fast responses 1 Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted March 4, 2018 Share Posted March 4, 2018 Upon booting the computer and while it's autoloading the LOAD file on DSK1. you can press and hold FCTN (function) 4 and it will halt the execution of the file. You will then be in Extended Basic and should be able to load your cassette files as you see fit. 2 Quote Link to comment Share on other sites More sharing options...
hunter44102 Posted March 4, 2018 Author Share Posted March 4, 2018 Wow thanks Spark for the bypass tip! Quote Link to comment Share on other sites More sharing options...
klrw111-78 Posted March 4, 2018 Share Posted March 4, 2018 Another suggestion is to rename the LOAD program on "Vol1" to XLOAD and it won't autoload CFMGR. I usually mount my Vol1 as DSK3, i.e.; CALL MOUNT(3,1). That way I can call up a catalog or the CFMGR when I need them and use the other to DSKs for my file saving, copying and manipulating. 2 Quote Link to comment Share on other sites More sharing options...
Casey Posted March 4, 2018 Share Posted March 4, 2018 I was going to make the same suggestion. I have Volume 1 mounted as DSK3 always, and then change up what I want in DSK1 and DSK2. That way, the handy catalog program is always available. 1 Quote Link to comment Share on other sites More sharing options...
+wolhess Posted March 18, 2018 Share Posted March 18, 2018 Hi all,I need some support too. Since nearly three months I'm back in my TI-Hobby after about 30 years. I bought some additional Hardware like a FG99, a Speech Synthesizer and a nanoPEB and tried some old programs I have in TI-Basic and XB. All works fine. Now I did a small XB program to manage my nanoPEB volumes for different Environments. It's a simpl menue with include the disk catalog and Mount the volumes I Need for TI-Basic, XB, TI-Writer and E/A.... When I start my program in TI Basic all works fine. If I start the program in XB the catalog part works, but all parts with the command MOUNT(X,Y) do not work. From XB I get the message "Subprogram Not Found in XXXX". If I try in Command Mode from the XB prompt Mount(X,Y) works. Do you have any suggestions for me? 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 18, 2018 Share Posted March 18, 2018 I think the CALL MOUNT only works in Ti-Basic Quote Link to comment Share on other sites More sharing options...
Opry99er Posted March 18, 2018 Share Posted March 18, 2018 Call Mount is a command-line IMMEDIATE mode function only. Like RESEQUENCE or LIST. Quote Link to comment Share on other sites More sharing options...
Stuart Posted March 18, 2018 Share Posted March 18, 2018 Hi all, I need some support too. Since nearly three months I'm back in my TI-Hobby after about 30 years. I bought some additional Hardware like a FG99, a Speech Synthesizer and a nanoPEB and tried some old programs I have in TI-Basic and XB. All works fine. Now I did a small XB program to manage my nanoPEB volumes for different Environments. It's a simpl menue with include the disk catalog and Mount the volumes I Need for TI-Basic, XB, TI-Writer and E/A.... When I start my program in TI Basic all works fine. If I start the program in XB the catalog part works, but all parts with the command MOUNT(X,Y) do not work. From XB I get the message "Subprogram Not Found in XXXX". If I try in Command Mode from the XB prompt Mount(X,Y) works. Do you have any suggestions for me? CALL MOUNT won't work inside a program, as others have said. But have a look at this page [http://gtello.pagesperso-orange.fr/ti99_e.htm] and there's a program you can use to switch volumes within a program. Scroll down that page to the picture of the NanoPEB and that's where the details are. 1 Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted March 18, 2018 Share Posted March 18, 2018 The XMOUNT that Stuart talks about above works great. I have an 8 meg card that I built up that has games on VOL's 2 thru 8. VOL 1 contains my system disk. I run BOOT from VOL 1 and have it's menu set up to goto each VOL that contains a LOAD menu to boot the games on that particular volume. Once I've played whichever game from whichever VOL it resorts back to VOL 1 mounted correctly.IT WORKS GREAT! no nanoPEB should be without it. Should I upload the disks from this small card? 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 18, 2018 Share Posted March 18, 2018 Wow, great page, great tool ! Never heard before. thx Quote Link to comment Share on other sites More sharing options...
+wolhess Posted March 18, 2018 Share Posted March 18, 2018 Ich bin begeistert, wie schnell hier viele Antworten und die Lösung kommt. Das ist genau was ich suche.Danke an Alle und besonders an Stuart!!! 2 Quote Link to comment Share on other sites More sharing options...
+wolhess Posted March 18, 2018 Share Posted March 18, 2018 I am thrilled how quickly many answers and the solution come here. That's exactly what I'm looking for.Thanks to all and especially to Stuart !!! Quote Link to comment Share on other sites More sharing options...
OX. Posted March 18, 2018 Share Posted March 18, 2018 (edited) Has anyone tried using an IDE to SD card interface with the Nanopeb - https://www.ebay.co.uk/itm/SD-SDHC-SDXC-MMC-Card-to-IDE-40Pin-3-5inch-Male-Adapter-X3J5/222621603322?epid=2184176857&hash=item33d54815fa:g:tcgAAOSwIxxZnSdF instead of the IDE to CF? - https://www.ebay.co.uk/itm/Compact-Flash-CF-to-3-5-Female-40-Pin-IDE-Bootable-Adapter-Converter-WKD/202256171849?epid=1893214903&hash=item2f17684349:g:eL8AAOSwK6RZEiBt Edited March 18, 2018 by OX. Quote Link to comment Share on other sites More sharing options...
+wolhess Posted March 18, 2018 Share Posted March 18, 2018 So, now I have tested the XMOUNT with my XB-Program an it works fine. Thank you all for your support. 2 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted March 18, 2018 Share Posted March 18, 2018 Has anyone tried using an IDE to SD card interface with the Nanopeb - https://www.ebay.co.uk/itm/SD-SDHC-SDXC-MMC-Card-to-IDE-40Pin-3-5inch-Male-Adapter-X3J5/222621603322?epid=2184176857&hash=item33d54815fa:g:tcgAAOSwIxxZnSdF instead of the IDE to CF? - https://www.ebay.co.uk/itm/Compact-Flash-CF-to-3-5-Female-40-Pin-IDE-Bootable-Adapter-Converter-WKD/202256171849?epid=1893214903&hash=item2f17684349:g:eL8AAOSwK6RZEiB Likely wont work. The ide/sdcard has to support the low level access he uses Also there's a thread about this already I believe, maybe a search of the forum? Quote Link to comment Share on other sites More sharing options...
OX. Posted March 18, 2018 Share Posted March 18, 2018 Likely wont work. The ide/sdcard has to support the low level access he uses Also there's a thread about this already I believe, maybe a search of the forum? Do you have a link? Searching for Nanopeb SD only brought this thread up. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted March 24, 2018 Share Posted March 24, 2018 Hallo Wolfgang! Es ist wirklich Lange her seit wir uns gesehen haben! Hi Wolfgang! It is really a long time since we've seen each other. (Jim, the crazy American that was at all of the early TI Treffen). Quote Link to comment Share on other sites More sharing options...
+wolhess Posted March 25, 2018 Share Posted March 25, 2018 The XMOUNT that Stuart talks about above works great. I have an 8 meg card that I built up that has games on VOL's 2 thru 8. VOL 1 contains my system disk. I run BOOT from VOL 1 and have it's menu set up to goto each VOL that contains a LOAD menu to boot the games on that particular volume. Once I've played whichever game from whichever VOL it resorts back to VOL 1 mounted correctly.IT WORKS GREAT! no nanoPEB should be without it. Should I upload the disks from this small card? Quote Link to comment Share on other sites More sharing options...
+wolhess Posted March 25, 2018 Share Posted March 25, 2018 The XMOUNT that Stuart talks about above works great. I have an 8 meg card that I built up that has games on VOL's 2 thru 8. VOL 1 contains my system disk. I run BOOT from VOL 1 and have it's menu set up to goto each VOL that contains a LOAD menu to boot the games on that particular volume. Once I've played whichever game from whichever VOL it resorts back to VOL 1 mounted correctly.IT WORKS GREAT! no nanoPEB should be without it. Should I upload the disks from this small card? Hi sparkdrummer, the same I will do, yes please upload your disks. I will test it on my TI. Quote Link to comment Share on other sites More sharing options...
