+hloberg Posted April 7, 2018 Share Posted April 7, 2018 anyone using TI-Dir with windows 10? when I use it on Win10 the TI-Dir window jumps to the left every time you attempt to do anything. anyone else experience this? 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted April 7, 2018 Share Posted April 7, 2018 I use TI-DIR v6.3a in w10 and i haven't the problem you described, are you using the same version ? 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted April 7, 2018 Share Posted April 7, 2018 I'm using 5.4b and do not experience that issue. Thanks ti99iuc - time to upgrade. Quote Link to comment Share on other sites More sharing options...
+RXB Posted April 7, 2018 Share Posted April 7, 2018 I am using Windows 10 and TI99Dir love it. Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted April 7, 2018 Share Posted April 7, 2018 Vn 6.3a works fine for me. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted April 8, 2018 Share Posted April 8, 2018 6.3a works great for me on Win10 Quote Link to comment Share on other sites More sharing options...
humeur Posted April 8, 2018 Share Posted April 8, 2018 You use Win10 32 or 64 Bits ?? jean louis Quote Link to comment Share on other sites More sharing options...
jonecool Posted April 9, 2018 Share Posted April 9, 2018 I'm using Ti99dir on Windows 10 and used it in this video as well. I haven't run into any issues. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted April 9, 2018 Share Posted April 9, 2018 I've had this same issue... not on all my windows 10, only on my very high-res laptop display. Using the latest Ti99dir available back in January. I tried going into the app compatibility settings in windows and changing the parameters around application scaling, and version compatibility, but never found a combination that worked. I uninstalled Windows, so I don't have the environment that reproduces it anymore. My laptop with the issue has a display of : 13.3" LED QHD Display (3200x1800 dots) - No Nvidia or AMD graphics chip, just Intel HD. The Windows 10 desktop with 4k display without the problem says: 3840 x 2160 Max. Resolution, but I run it at a lower resolution. 25?? x ???? -M@ 1 Quote Link to comment Share on other sites More sharing options...
humeur Posted April 9, 2018 Share Posted April 9, 2018 Some software does not work with windows 10 depending on version. Two Win 10 32 or 64 Bits I have a drawing software that works in 64 bits and not in 32. Jean louis 1 Quote Link to comment Share on other sites More sharing options...
+hloberg Posted April 9, 2018 Author Share Posted April 9, 2018 I'm using 5.4b on a high rez 64bit Win10. someone post 6.3a and i'll see if it still is a problem. Quote Link to comment Share on other sites More sharing options...
+hloberg Posted April 9, 2018 Author Share Posted April 9, 2018 I've had this same issue... not on all my windows 10, only on my very high-res laptop display. Using the latest Ti99dir available back in January. I tried going into the app compatibility settings in windows and changing the parameters around application scaling, and version compatibility, but never found a combination that worked. I uninstalled Windows, so I don't have the environment that reproduces it anymore. My laptop with the issue has a display of : 13.3" LED QHD Display (3200x1800 dots) - No Nvidia or AMD graphics chip, just Intel HD. The Windows 10 desktop with 4k display without the problem says: 3840 x 2160 Max. Resolution, but I run it at a lower resolution. 25?? x ???? -M@ exact same issue with my old Dell Optiplex and a Lenevo laptop. To get around the issue I run My TI99 stuff in an XP VM. But I hate having to fire up the VM every time I need to do something with the TI99 on the PCs. Quote Link to comment Share on other sites More sharing options...
+hloberg Posted April 9, 2018 Author Share Posted April 9, 2018 I use TI-DIR v6.3a in w10 and i haven't the problem you described, are you using the same version ? where download latest version? Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted April 9, 2018 Share Posted April 9, 2018 where download latest version? Under projects - http://www.ti99-geek.nl/ 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted April 9, 2018 Share Posted April 9, 2018 where download latest version? http://www.ti99-geek.nl/Projects/ti99dir/ti99dir.html#tidir Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted April 9, 2018 Share Posted April 9, 2018 where download latest version? http://ftp.whtech.com/Users/fredkaal Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted September 22, 2018 Share Posted September 22, 2018 Same issue with Windows 7. I had to recently reformat my drive due to a crash and re-install Windows. No issues previously. Using the latest Ti99dir 6.4a but even version 5.3b is having the same problem now. I tried different compatibility configurations and screen resolutions to no avail. Fred, help please??? https://youtu.be/_6tfNKB-zoc Update: I changed the screen scaling from the monitor's native to my NVIDIA card's own scaling, restarted the computer, and now the issue is resolved. Might help someone here with similar issues. 4 Quote Link to comment Share on other sites More sharing options...
