TIPI Usage and Support
jedimatt42
5 hours ago, PeBo said:
1st, sorry for originally posting this in the development thread...hadn't noticed I had clicked through...
I have a a PI3B+ connected to the TIPI PEB
CALL TIPI recognizes the TIPI and allowed me to input and save my SSID and PSK. but when I CALL TIPI ("TIPI.NET.TELNET"), I get a "error connecting... press any key" which returns me to the column count selection screen.
I've tried searching the forums but not sure how to word it to get meaningful assistance. I've left the CRU at the default. Other PEB installed items are Shiftt838's Speech-Synth adapted card, a SidMaster card, TI RS232, TI Flex-Cable card (duh), 1MB SAMS card, TI disc controller card and 2 internal drives.
My network requires no special settings, and I've double and triple checked the SSID and PSK input. It should be noted that the TIPI has been assigned an IP and it appears in the DHCP leases in my router, assigning it a MAC address, so I really don't understand why there is a connection issues to telnet.
If anyone can assist with ideas of where/what the issue may be, or point me to where to look in these forums or the Wiki for a solution, I will be forever grateful.
What's it say in the TIPI log?
Both of my TIPI's went off last night do to power issues. I've tried a power reset. There wireless less from the router end seem to be the same.
Yet, they won't ping, ssh or telnet.
What's my easiest approach to getting these online?
Sorry, I am still in the initial installation and set-up phase, and have not explored further. TIPI log? No idea how to access that. I'm a newb still trying to expand the Root-partition of the SD card.
Expanding the root partition not really needed anymore, that was only for those on older smaller images.
Edited by Gary from OPA
telnet to localhost 23 on your ti with TIPI.NET.TELNET  login with tipi tipi
cat /var/log/tipi/tipi.log
or web browser to tipi:9900 and view log in the menu
You should be able to rename directories from the 4A with a TIPI compatible file manager, such as Force Command.
But there seems to be a bug in the rename directory implementation when trying to rename SLASH/ES to SLASHES.
It appears that the '/' to '.' handling is leaving garbage in a string buffer. At least on the latest versions.
Actually I'm getting a bad filename sent to the PI. At least from Force Command. Maybe this is just a bug in my unreleased updates to Force Command... (rename operations are supposed to pad the 10 character file or dirname with spaces, as no length is submitted. Trailing spaces are then truncated for the actual filename - my unreleased Force Command that supports cpu-buffers for such operations wasn't padding on the cpu-buffer codepath)
Special characters should be allowed in the 4A filenames. The file name on the host OS, if it has a periods, should have a '/' on the 4A side. This is the only translation done. Well, technically the byte array passed in from the 4A is converted to python string using 'latin-1' decoding. Then, any '/' in the name are replaced with '.', and then the python code tries to operate on it. Generally the linux OS will tolerate any character in a file name.
That's interesting, I've never used Force Command before so maybe I'll give that a try.  The main reason I asked was because I noticed that when I tried to use Emuwriter 0.3 it wouldn't work but 0.2 worked fine, and the only noticable difference was that when uploaded on the web ui v0.2 came up with the directory name EMUWRITER where as v0.3 was EMUWRITER.  that period seemed to be the only difference and I couldn't figure out how to get rid of it.
Then I remembered that there were other programs that didn't work, all having special characters in the directory name or program name.
Edited by Diesel419
@PeBo  If you can get to the TIPI's WEB UI (http://tipi.local:9900) then the log can be seen here (when the menu isn't on the screen there is a "Go to bottom" button as newest entries are at the bottom of the log.
If you cannot get to the WEB UI, you should go into TI BASIC, and run CALL TIPI with no arguments. This should load the config tool, and that should display the PI's IP address.
I think the original problem/goal was that the TELNET client isn't connecting to some BBS or other host you are trying to go to... The connection attempts should be evidenced in the tipi.log.
Here's the log when i try to telnet localhost 23
2024-10-13 23:54:22,085 TipiService : INFO     TIPI Ready
2024-10-13 23:54:52,393 TipiDisk    : INFO     Opcode 5 LOAD - TIPI.NET.TELNET
2024-10-13 23:54:52,394 Pab         : INFO     opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198
2024-10-13 23:54:52,396 TipiDisk    : INFO     LOAD image size 8192
2024-10-13 23:54:54,006 TipiService : INFO     Request completed.
2024-10-13 23:54:54,220 TipiDisk    : INFO     Opcode 5 LOAD - TIPI.NET.TELNEU
2024-10-13 23:54:54,221 Pab         : INFO     opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198
2024-10-13 23:54:54,223 TipiDisk    : INFO     LOAD image size 5120
2024-10-13 23:54:55,210 TipiService : INFO     Request completed.
2024-10-13 23:55:03,643 TiSocket    : INFO     open socket(0) localhost:23
2024-10-13 23:55:03,647 TiSocket    : INFO     failed to connect socket: 0
2024-10-13 23:55:03,647 TiSocket    : INFO     closing socket
what versions are you running?  maybe post a pic of tipicfg screen?
have you made any changes to the pi linux config?
Got into the Web UI a couple days ago, and felt most of my concerns were addressed. At least I understood things better than sequential reading of the instructions was allowing in my geriatric brain. THEN...
Decided to install the PI in a case, and somehow messed things up (story of my life). Now the PI powers up, but doesn't post (no green light) so I have created a problem where there wasn't one...I'll have to figure this new problem out before I can proceed further, but thank you for the assist. It is appreciated far more than you know.
If anyone can think of a reason why a case (and heatsinks) installation could affect the PI posting, please let me know. (doesn't post anymore if I now remove it from the case, so I messed up something fierce). I really should take up drinking as a new hobby. I am less likely to screw it up. (I'm thinking maybe I should re-burn the image to the SD, although I'm not sure how I might have corrupted it with a case installation.)
But for now, I'm thinking about ANYTHING else.
looks like I corrupted the SD card... reads as 121MB under the Linux "Disks" app (a 32GB card). Partition seems unrepairable by the app I'll try terminal. if everything fails, I'll pick up a new sd card this aft. Hopefully the problem is the SD & I didn't fry-the-PI. (Winter-heating static is a bitch..even with a copper grounding bracelet.)
If I didn't have hassles with simple tasks, it wouldn't be as much fun (or so I keep telling myself).
On 10/15/2024 at 9:09 PM, jedimatt42 said:
The log looks healthy.
I wonder if an upstream package broke telnet. What about other telnet hosts?
TGIF!!!
024-10-17 15:47:39,806 TipiService : INFO     physical mode enabled
2024-10-17 15:47:39,820 TipiService : INFO     TIPI Ready
2024-10-17 15:48:01,775 TipiDisk    : INFO     Opcode 5 LOAD - TIPI.NET.TELNET
2024-10-17 15:48:01,776 Pab         : INFO     opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198
2024-10-17 15:48:01,778 TipiDisk    : INFO     LOAD image size 8192
2024-10-17 15:48:03,368 TipiService : INFO     Request completed.
2024-10-17 15:48:03,582 TipiDisk    : INFO     Opcode 5 LOAD - TIPI.NET.TELNEU
2024-10-17 15:48:03,582 Pab         : INFO     opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198
2024-10-17 15:48:03,584 TipiDisk    : INFO     LOAD image size 5120
2024-10-17 15:48:04,564 TipiService : INFO     Request completed.
2024-10-17 15:48:29,192 TiSocket    : INFO     open socket(0) localhost:23
2024-10-17 15:48:29,197 TiSocket    : INFO     failed to connect socket: 0
2024-10-17 15:48:29,198 TiSocket    : INFO     closing socket
2024-10-17 15:48:34,858 TipiService : INFO     physical mode enabled
2024-10-17 15:48:34,871 TipiService : INFO     TIPI Ready
2024-10-17 15:48:39,791 TipiService : INFO     physical mode enabled
2024-10-17 15:48:39,803 TipiService : INFO     TIPI Ready
2024-10-17 15:48:53,850 TipiDisk    : INFO     Opcode 5 LOAD - TIPI.NET.TELNET
2024-10-17 15:48:53,850 Pab         : INFO     opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198
2024-10-17 15:48:53,853 TipiDisk    : INFO     LOAD image size 8192
2024-10-17 15:48:55,439 TipiService : INFO     Request completed.
2024-10-17 15:48:55,654 TipiDisk    : INFO     Opcode 5 LOAD - TIPI.NET.TELNEU
2024-10-17 15:48:55,654 Pab         : INFO     opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198
2024-10-17 15:48:55,656 TipiDisk    : INFO     LOAD image size 5120
2024-10-17 15:48:56,636 TipiService : INFO     Request completed.
2024-10-17 15:49:04,474 TiSocket    : INFO     open socket(0) THEKEEP.NET:9918
2024-10-17 15:49:04,636 TiSocket    : INFO     connected
2024-10-17 15:49:07,935 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:08,030 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:08,106 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:08,211 TiSocket    : INFO     read 5 bytes from 0
2024-10-17 15:49:08,327 TiSocket    : INFO     read 11 bytes from 0
2024-10-17 15:49:08,390 TiSocket    : INFO     read 23 bytes from 0
2024-10-17 15:49:08,469 TiSocket    : INFO     read 2 bytes from 0
2024-10-17 15:49:08,738 TiSocket    : INFO     read 24 bytes from 0
2024-10-17 15:49:08,796 TiSocket    : INFO     read 8 bytes from 0
2024-10-17 15:49:08,865 TiSocket    : INFO     read 2 bytes from 0
2024-10-17 15:49:08,932 TiSocket    : INFO     read 14 bytes from 0
2024-10-17 15:49:09,024 TiSocket    : INFO     read 2 bytes from 0
2024-10-17 15:49:09,415 TiSocket    : INFO     read 10 bytes from 0
2024-10-17 15:49:11,004 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:11,239 TiSocket    : INFO     read 47 bytes from 0
2024-10-17 15:49:11,391 TiSocket    : INFO     read 8 bytes from 0
2024-10-17 15:49:11,920 TiSocket    : INFO     read 14 bytes from 0
2024-10-17 15:49:12,884 TiSocket    : INFO     read 36 bytes from 0
2024-10-17 15:49:13,025 TiSocket    : INFO     read 30 bytes from 0
2024-10-17 15:49:13,054 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:13,109 TiSocket    : INFO     read 10 bytes from 0
2024-10-17 15:49:13,160 TiSocket    : INFO     read 5 bytes from 0
2024-10-17 15:49:13,210 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:13,262 TiSocket    : INFO     read 13 bytes from 0
2024-10-17 15:49:13,321 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:13,376 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:13,438 TiSocket    : INFO     read 13 bytes from 0
2024-10-17 15:49:13,494 TiSocket    : INFO     read 15 bytes from 0
2024-10-17 15:49:13,550 TiSocket    : INFO     read 17 bytes from 0
2024-10-17 15:49:13,609 TiSocket    : INFO     read 17 bytes from 0
2024-10-17 15:49:13,663 TiSocket    : INFO     read 9 bytes from 0
2024-10-17 15:49:13,729 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:13,862 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:13,938 TiSocket    : INFO     read 31 bytes from 0
2024-10-17 15:49:13,993 TiSocket    : INFO     read 6 bytes from 0
2024-10-17 15:49:14,052 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:14,110 TiSocket    : INFO     read 10 bytes from 0
2024-10-17 15:49:14,164 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:14,214 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:14,270 TiSocket    : INFO     read 15 bytes from 0
2024-10-17 15:49:14,323 TiSocket    : INFO     read 7 bytes from 0
2024-10-17 15:49:14,383 TiSocket    : INFO     read 15 bytes from 0
2024-10-17 15:49:14,439 TiSocket    : INFO     read 11 bytes from 0
2024-10-17 15:49:14,515 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:14,578 TiSocket    : INFO     read 18 bytes from 0
2024-10-17 15:49:14,646 TiSocket    : INFO     read 18 bytes from 0
2024-10-17 15:49:14,703 TiSocket    : INFO     read 12 bytes from 0
2024-10-17 15:49:14,761 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:14,822 TiSocket    : INFO     read 11 bytes from 0
2024-10-17 15:49:14,883 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:14,945 TiSocket    : INFO     read 4 bytes from 0
2024-10-17 15:49:15,003 TiSocket    : INFO     read 18 bytes from 0
2024-10-17 15:49:15,054 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:15,109 TiSocket    : INFO     read 15 bytes from 0
2024-10-17 15:49:15,169 TiSocket    : INFO     read 17 bytes from 0
2024-10-17 15:49:15,223 TiSocket    : INFO     read 9 bytes from 0
2024-10-17 15:49:15,275 TiSocket    : INFO     read 12 bytes from 0
2024-10-17 15:49:15,357 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:15,409 TiSocket    : INFO     read 13 bytes from 0
2024-10-17 15:49:15,472 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:15,530 TiSocket    : INFO     read 2 bytes from 0
2024-10-17 15:49:15,590 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:15,652 TiSocket    : INFO     read 13 bytes from 0
2024-10-17 15:49:15,704 TiSocket    : INFO     read 18 bytes from 0
2024-10-17 15:49:15,761 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:15,823 TiSocket    : INFO     read 18 bytes from 0
2024-10-17 15:49:15,878 TiSocket    : INFO     read 7 bytes from 0
2024-10-17 15:49:15,934 TiSocket    : INFO     read 15 bytes from 0
2024-10-17 15:49:16,002 TiSocket    : INFO     read 5 bytes from 0
2024-10-17 15:49:16,056 TiSocket    : INFO     read 4 bytes from 0
2024-10-17 15:49:16,123 TiSocket    : INFO     read 17 bytes from 0
2024-10-17 15:49:16,177 TiSocket    : INFO     read 18 bytes from 0
2024-10-17 15:49:16,231 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:16,290 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:16,345 TiSocket    : INFO     read 9 bytes from 0
2024-10-17 15:49:16,405 TiSocket    : INFO     read 18 bytes from 0
2024-10-17 15:49:16,463 TiSocket    : INFO     read 15 bytes from 0
2024-10-17 15:49:16,530 TiSocket    : INFO     read 22 bytes from 0
2024-10-17 15:49:16,585 TiSocket    : INFO     read 12 bytes from 0
2024-10-17 15:49:16,635 TiSocket    : INFO     read 9 bytes from 0
2024-10-17 15:49:16,690 TiSocket    : INFO     read 4 bytes from 0
2024-10-17 15:49:16,750 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:16,804 TiSocket    : INFO     read 10 bytes from 0
2024-10-17 15:49:16,871 TiSocket    : INFO     read 15 bytes from 0
2024-10-17 15:49:16,935 TiSocket    : INFO     read 19 bytes from 0
2024-10-17 15:49:17,006 TiSocket    : INFO     read 8 bytes from 0
2024-10-17 15:49:17,075 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:17,137 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:17,213 TiSocket    : INFO     read 19 bytes from 0
2024-10-17 15:49:17,269 TiSocket    : INFO     read 18 bytes from 0
2024-10-17 15:49:17,327 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:17,378 TiSocket    : INFO     read 9 bytes from 0
2024-10-17 15:49:17,443 TiSocket    : INFO     read 13 bytes from 0
2024-10-17 15:49:17,529 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:17,584 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:17,650 TiSocket    : INFO     read 16 bytes from 0
2024-10-17 15:49:17,711 TiSocket    : INFO     read 19 bytes from 0
2024-10-17 15:49:17,868 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:17,934 TiSocket    : INFO     read 25 bytes from 0
2024-10-17 15:49:17,995 TiSocket    : INFO     read 19 bytes from 0
2024-10-17 15:49:18,055 TiSocket    : INFO     read 17 bytes from 0
2024-10-17 15:49:18,113 TiSocket    : INFO     read 14 bytes from 0
2024-10-17 15:49:18,169 TiSocket    : INFO     read 13 bytes from 0
2024-10-17 15:49:18,234 TiSocket    : INFO     read 1 bytes from 0
2024-10-17 15:49:18,293 TiSocket    : INFO     read 7 bytes from 0
2024-10-17 15:49:19,866 TipiService : INFO     physical mode enabled
2024-10-17 15:49:19,878 TipiService : INFO     TIPI Ready
@arcadeshopper
About TIPI
TIPI software version info:
  • Version: 4.3
  • Release Date: 2024-06-30
  • Source Branch: bookworm_release
Changes to linux - not that I am aware of
Not too terribly worried about it, it's just an oddity.  don't care if I need to re-image etc, but I probably won't
On 10/17/2024 at 5:37 PM, arcadeshopper said:
if you can ssh in to the pi
Edit /etc/inetd.conf and verify line 23 (line number is just a co-incidence) is uncommented
Code: Select all
#:STANDARD: These are standard services.
telnet  stream  tcp     nowait  root    /usr/sbin/tcpd  /usr/sbin/telnetd
Thanks Greg, localhost port 23 replies connected, but hangs. Others work.
2024-10-18 21:57:43,964 TipiService : INFO     physical mode enabled
2024-10-18 21:57:43,978 TipiService : INFO     TIPI Ready
2024-10-18 21:59:12,167 TipiService : INFO     physical mode enabled
2024-10-18 21:59:12,181 TipiService : INFO     TIPI Ready
2024-10-18 21:59:25,186 TipiDisk    : INFO     Opcode 5 LOAD - TIPI.NET.TELNET
2024-10-18 21:59:25,187 Pab         : INFO     opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198
2024-10-18 21:59:25,189 TipiDisk    : INFO     LOAD image size 8192
2024-10-18 21:59:26,801 TipiService : INFO     Request completed.
2024-10-18 21:59:27,016 TipiDisk    : INFO     Opcode 5 LOAD - TIPI.NET.TELNEU
2024-10-18 21:59:27,016 Pab         : INFO     opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198
2024-10-18 21:59:27,018 TipiDisk    : INFO     LOAD image size 5120
2024-10-18 21:59:28,009 TipiService : INFO     Request completed.
2024-10-18 21:59:33,249 TiSocket    : INFO     open socket(0) localhost:23
2024-10-18 21:59:33,254 TiSocket    : INFO     connected
2024-10-18 21:59:33,583 TiSocket    : INFO     read 21 bytes from 0
2024-10-18 22:00:41,304 TipiService : INFO     physical mode enabled
2024-10-18 22:00:41,316 TipiService : INFO     TIPI Ready
2024-10-18 22:00:53,648 TipiDisk    : INFO     Opcode 5 LOAD - TIPI.NET.TELNET
2024-10-18 22:00:53,649 Pab         : INFO     opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198
2024-10-18 22:00:53,651 TipiDisk    : INFO     LOAD image size 8192
2024-10-18 22:00:55,239 TipiService : INFO     Request completed.
2024-10-18 22:00:55,453 TipiDisk    : INFO     Opcode 5 LOAD - TIPI.NET.TELNEU
2024-10-18 22:00:55,454 Pab         : INFO     opcode: Load, fileType: Sequential, mode: Update, dataType: Display, recordType: Fixed, recordLength: 0, recordNumber: 8198
2024-10-18 22:00:55,456 TipiDisk    : INFO     LOAD image size 5120
2024-10-18 22:00:56,444 TipiService : INFO     Request completed.
2024-10-18 22:01:03,215 TiSocket    : INFO     open socket(0) thekeep.net:9918
2024-10-18 22:01:03,414 TiSocket    : INFO     connected
2024-10-18 22:01:05,060 TiSocket    : INFO     read 1 bytes from 0
2024-10-18 22:01:05,321 TiSocket    : INFO     read 7 bytes from 0
2024-10-18 22:01:05,674 TiSocket    : INFO     read 36 bytes from 0
2024-10-18 22:01:05,965 TiSocket    : INFO     read 32 bytes from 0
