+Vorticon Posted July 22, 2021 Share Posted July 22, 2021 (edited) 5 hours ago, jedimatt42 said: TIPI's Samba configuration for /etc/samba/smb.conf: [TIPI] comment=TI-99/4A Files path=/home/tipi/tipi_disk public=no browseable=Yes writeable=Yes only guest=no guest ok=Yes create mask=0644 directory mask=0755 force user=tipi then, you should be able to force some restarting: sudo systemctl reenable smbd sudo systemctl restart smbd If there are issues, they'll be in the /var/log/daemon.log, I believe... you can also sudo systemctl status smbd Still an issue it seems... tipi@tipi:~ $ sudo systemctl reenable smbd Removed /etc/systemd/system/multi-user.target.wants/smbd.service. Created symlink /etc/systemd/system/multi-user.target.wants/smbd.service → /lib/systemd/system/smbd.service. tipi@tipi:~ $ sudo systemctl restart smbd Job for smbd.service failed because the control process exited with error code. See "systemctl status smbd.service" and "journalctl -xe" for details. tipi@tipi:~ $ sudo system ctl status smbd sudo: system: command not found tipi@tipi:~ $ sudo systemctl status smbd ● smbd.service - Samba SMB Daemon Loaded: loaded (/lib/systemd/system/smbd.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Wed 2021-07-21 20:20:16 CDT; 30s ago Docs: man:smbd(8) man:samba(7) man:smb.conf(5) Process: 21710 ExecStartPre=/usr/share/samba/update-apparmor-samba-profile (code=exited, status=0/SUCCESS) Process: 21711 ExecStart=/usr/sbin/smbd --foreground --no-process-group $SMBDOPTIONS (code=exited, status=127) Main PID: 21711 (code=exited, status=127) Jul 21 20:20:16 tipi systemd[1]: Starting Samba SMB Daemon... Jul 21 20:20:16 tipi smbd[21711]: /usr/sbin/smbd: error while loading shared libraries: libldb.so.1: cannot open shared object file: No such file or directory Jul 21 20:20:16 tipi systemd[1]: smbd.service: Main process exited, code=exited, status=127/n/a Jul 21 20:20:16 tipi systemd[1]: smbd.service: Failed with result 'exit-code'. Jul 21 20:20:16 tipi systemd[1]: Failed to start Samba SMB Daemon. Edited July 22, 2021 by Vorticon 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 22, 2021 Author Share Posted July 22, 2021 Ok, that looks like evidence that the filesystem corrupted and files were lost... 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 22, 2021 Share Posted July 22, 2021 2 hours ago, jedimatt42 said: Ok, that looks like evidence that the filesystem corrupted and files were lost... I guess there is no fixing that without re-imaging. Sigh... 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 22, 2021 Author Share Posted July 22, 2021 21 minutes ago, Vorticon said: I guess there is no fixing that without re-imaging. Sigh... Not reliably... 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 22, 2021 Share Posted July 22, 2021 (edited) Make a couple images. .as cards are cheap. I have a mapped drive on my PC pointing to the raspberry pi and am constantly making backups because my daily code writing changes as I progress on the program I'm writing. But I can also reach it with my cellphone and backup to the pi after a bunch of photos or docs I downloaded since my automated backup will get it off the pi later. Edited July 22, 2021 by GDMike 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 24, 2021 Share Posted July 24, 2021 I understand the TIPI can load from an http address. Can it load from https? Is this a straight GET request, and what is the user-agent string? Can it also save? How is that handled? 1 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted July 24, 2021 Share Posted July 24, 2021 Yes it's in the wiki open PI.HTTPS:URL Sent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 24, 2021 Share Posted July 24, 2021 21 minutes ago, arcadeshopper said: Yes it's in the wiki open PI.HTTPS:URL I am working on some searches, but can you point me there? I just went through to wikis and an FAQ and could not find specs on this. Via a Google search, I found your blog which shows syntax example OLD PI.HTTP://ftp.whtech.com/Users/Gregory%20McGill/TIPIMAP/TIPIMAP https://www.arcadeshopper.com/wp/category/tiblog/ I might need some assistance sometime in the next month or so. 1 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted July 24, 2021 Share Posted July 24, 2021 8 minutes ago, OLD CS1 said: I am working on some searches, but can you point me there? I just went through to wikis and an FAQ and could not find specs on this. Via a Google search, I found your blog which shows syntax example OLD PI.HTTP://ftp.whtech.com/Users/Gregory%20McGill/TIPIMAP/TIPIMAP https://www.arcadeshopper.com/wp/category/tiblog/ I might need some assistance sometime in the next month or so. https://github.com/jedimatt42/tipi/wiki specifically https://github.com/jedimatt42/tipi/wiki/PI.HTTP also you can do https servers and full io with https://github.com/jedimatt42/tipi/wiki/PI.TCP 1 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 24, 2021 Share Posted July 24, 2021 1 minute ago, arcadeshopper said: https://github.com/jedimatt42/tipi/wiki I just found that, thank you. The right-side navigation panel was hidden by my browser. Some of my block recipes are pretty aggressive. 2 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted July 24, 2021 Share Posted July 24, 2021 5 minutes ago, OLD CS1 said: I just found that, thank you. The right-side navigation panel was hidden by my browser. Some of my block recipes are pretty aggressive. https://giphy.com/clips/hamlet-lord-of-the-rings-gandalf-you-shall-not-pass-BZMggpshzrPvbfQHIF 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 24, 2021 Share Posted July 24, 2021 Two questions remain unanswered: I am assuming OLD is a GET request, but what is the user-agent string? Also, how is SAVE handled via a URL at the http protocol level? 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 24, 2021 Author Share Posted July 24, 2021 1 hour ago, OLD CS1 said: Two questions remain unanswered: I am assuming OLD is a GET request, but what is the user-agent string? Also, how is SAVE handled via a URL at the http protocol level? PI.HTTP works more like this: The PI performs a file transfer of the URL, such as with curl... Then depending on the operation requested, it attempts to OPEN or LOAD the file. If it was a LOAD ( like when BASIC does OLD ) then it is a one and done program image... if it is an OPEN, the file is converted to a bunch of records, and held in memory until CLOSE or you revisit the title screen. There is no SAVE to the PI.HTTP, or WRITE, those operations will return an error. I don't set an explicit user agent, or special HTTP request headers... https://github.com/jedimatt42/tipi/blob/be9f31256ebca10940406428141164886a1d65c3/services/CurlFile.py#L156 <- Oh, hey! it's not a curl, but a wget shell command - I think that was because wget had pretty favorable defaults... PI.TCP opens a socket... you can OPEN, READ, WRITE, and CLOSE...you cannot seek ( RESET ) and whatever you send needs to be compatible with the server hosting that port. There is no automatic insertion of newlines or anything like that... if you need to send a CR, then you send a CR ( CHR$(13) ) PI.TCP does not do SSL, and you have to implement whatever application layer protocol in the TI side software.. You can implement HTTP POST this way. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 24, 2021 Share Posted July 24, 2021 @jedimatt42 Any chance I can convince you to add a -U or --user-agent= to your wget? Classic99 uses "Classic99TipiSim/1.0" as its user-agent string. Something similar would help automatically identify the TIPI. 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 24, 2021 Author Share Posted July 24, 2021 23 minutes ago, OLD CS1 said: @jedimatt42 Any chance I can convince you to add a -U or --user-agent= to your wget? Classic99 uses "Classic99TipiSim/1.0" as its user-agent string. Something similar would help automatically identify the TIPI. Sure... that'll be easy enough... I'll include the substring "Tipi" to allow a common matching criteria on the server. edit: easy enough for sure... it'll look like "ti994a-Tipi/2.30" where 2.30 is the TIPI PI side version number. I'll release the update after caffeine and breakfast tomorrow. 3 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 24, 2021 Share Posted July 24, 2021 33 minutes ago, jedimatt42 said: I'll release the update after caffeine and breakfast tomorrow. Rock on! So, no SAVE with PI.HTTP and no PI.FTP. Now I am sad. Does the TIPI include curl? 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 24, 2021 Author Share Posted July 24, 2021 6 minutes ago, OLD CS1 said: Rock on! So, no SAVE with PI.HTTP and no PI.FTP. Now I am sad. Does the TIPI include curl? I've implemented FTP in 4A space: https://github.com/jedimatt42/ti99-ftp Originally I implemented PI.HTTP directly in python... but then had trouble with certs and HTTPS support, so just started delegating to an OS tool... I should add a more generalized PI.WGET that handles all the url types it supports... 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 24, 2021 Share Posted July 24, 2021 41 minutes ago, jedimatt42 said: I've implemented FTP in 4A space: https://github.com/jedimatt42/ti99-ftp Originally I implemented PI.HTTP directly in python... but then had trouble with certs and HTTPS support, so just started delegating to an OS tool... I should add a more generalized PI.WGET that handles all the url types it supports... Gotcha. My goal is to be able to host files which are accessible from the TIPI via OLD and SAVE. Not a big deal if you are using system tools. wget and curl work just fine. For my saving purposes, curl -F would work just fine. Something like curl -A 'Tipi/2.30' -F 'TIFILES=@filename' https://web.site/user/ (bear in mind, I do not have a TIPI yet... so I will have to pester @Tursi, too ) 3 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 24, 2021 Author Share Posted July 24, 2021 I would argue that isn't your goal. Sounds like a solution proposal to an actual goal. Posting to web servers is extremely specific to the server. If I am going to offer SAVE over PI.HTTP, I think I need to offer the server it can save to. Along with authentication in the very least. User agent isn't good enough as I am prone to angering bad actors that could retaliate against the user base. Something like a 4A writable NETRC that holds extra user details per server to pass as headers... I haven't gone down that route, cause it is easier to use the Linux OS to configure synchronization of a folder under 'tipi_disk' and satisfy most general goals. Using tools like ssh certs and rsync. Or other suites like owncloud, nextcloud, or their big commercial friends. Then you get normal full set of file operations from the 4A. PI.HTTP acts more like RS232. than DSK1. presently, from a device point of view. None of that is a 'no', but rather a request for use case details and brainstorming. Might also be time to write up file sync solutions... Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 24, 2021 Author Share Posted July 24, 2021 @Vorticon noticed, that TIPI's /BAS /XB DV80 to PROGRAM image loading doesn't handle lines longer than 80 characters... What should the line continuation be? This will require pre-processing before sending to xbas.py ( which I already do to extract the DV80 into a linux text file... ) so I can join lines together before conversion to PROGRAM image. ?? next line starting with a number could indicate not to join... no number would indicate to definately join... Or maybe the better solution is to use TIDBIT syntax... IDK if it joins lines automatically or not? Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted July 24, 2021 Share Posted July 24, 2021 14 minutes ago, jedimatt42 said: What should the line continuation be? This will require pre-processing before sending to xbas.py ( which I already do to extract the DV80 into a linux text file... ) so I can join lines together before conversion to PROGRAM image. ?? next line starting with a number could indicate not to join... no number would indicate to definately join... Or maybe the better solution is to use TIDBIT syntax... IDK if it joins lines automatically or not? I thought about that while taking a walk few moments ago and also came up with the idea to look for the line number as indicator of the new line. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 24, 2021 Share Posted July 24, 2021 1 hour ago, jedimatt42 said: I would argue that isn't your goal. Sounds like a solution proposal to an actual goal. Posting to web servers is extremely specific to the server. If I am going to offer SAVE over PI.HTTP, I think I need to offer the server it can save to. I promise I am not hiding anything else. Simply, if SAVE PI.HTTP produces a predictable submission, then it is easier to write the server-side. I do not see it was your responsibility to provide a server-side solution, just document how it is done. Using the curl I gave above, it is a simple matter in PHP to accept the submission. To prevent anyone from over-writing a file, there will also be a token in the URL provided from the TI side so the TIPI side of things does not need to be more complicated than separating out the file from the URL. The goal is, simply put, a repository for files to be stored and accessed via TIPI's available HTTP facility. Nothing more, nothing less. A TIPI-specific* web filesystem, if you will. I was playing a little last night and it is feasible, but the back-end is going to be a bit of a bitch. 21 minutes ago, jedimatt42 said: Or maybe the better solution is to use TIDBIT syntax... IDK if it joins lines automatically or not? From https://dnotq.io/tidbit/tidbit.html Quote Long lines can be split by ending a line with .. (double period). These lines will be joined into one long line and the XB limit of 140 characters will be checked. Lines that end with the XB multi-statement operator ::, THEN, or ELSE, or where an ELSE statement is on the next line, will automatically join the next line. Is this what you meant? * Though it need not be limited to the TIPI. So long as the page knows that the file is in the PUT field TIFILES and there is an authentication token in the URL, it can accept the submission. There are some minutia to work out, like response codes for bad submissions (bad token, not in TIFILES format, &c.) 1 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 24, 2021 Author Share Posted July 24, 2021 30 minutes ago, retroclouds said: I thought about that while taking a walk few moments ago and also came up with the idea to look for the line number as indicator of the new line. Does anyone already know... is it safe to join with a ' ' (SPACE) or maybe I should only join if the line ends with a "::" so that the author is in control. Tidbit docs to the rescue Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 24, 2021 Author Share Posted July 24, 2021 5 minutes ago, OLD CS1 said: I promise I am not hiding anything else. Simply, if SAVE PI.HTTP produces a predictable submission, then it is easier to write the server-side. I do not see it was your responsibility to provide a server-side solution, just document how it is done. Using the curl I gave above, it is a simple matter in PHP to accept the submission. To prevent anyone from over-writing a file, there will also be a token in the URL provided from the TI side so the TIPI side of things does not need to be more complicated than separating out the file from the URL. 5 minutes ago, OLD CS1 said: The goal is, simply put, a repository for files to be stored and accessed via TIPI's available HTTP facility. Nothing more, nothing less. A TIPI-specific web filesystem, if you will. I was playing a little last night and it is feasible, but the back-end is going to be a bit of a bitch. There is a whole lot missing operation wise... no LVL2 IO support for anything under 'PI.' device. Only LVL3 (basically, the set of operations you can do from BASIC) URI1-3. devices are aliases for PI.HTTP or PI.HTTPS.. so they inherit the functionality and restrictions. In theory if a CATALOG is implemented by the server, and it sends back something like a TIFILES DIS/FIX38(or whatever, I always get that wrong) with the catalog data, then something versatile like older DM2K's might even browse it. A couple people have proven this theory. 5 minutes ago, OLD CS1 said: From https://dnotq.io/tidbit/tidbit.html Is this what you meant? Awesome! Thanks! 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted July 24, 2021 Share Posted July 24, 2021 A RESTful API maps well to the DSR operations. I integrated JS99er with the Google Drive API some years ago, but because of increased security restrictions this it getting more difficult to maintain, and I'm not sure how well it works any longer. But if saving is allowed there has to be a way to authorize the user, and using a token issued by a public authentication provider like Google is probably the easiest way to go if you don't want to maintain your own use database and authentication server. 2 Quote Link to comment Share on other sites More sharing options...
