digdugnate Posted April 23, 2018 Share Posted April 23, 2018 My el cheapo tv that currently has my TI and my modded 2600 only has one set of RCA inputs- i'd hate to have to switch cables back and forth all the time. Is there such a thing as a 'switch box' that would let me connect both and just toggle output from one device or another to the TV using one set of inputs? If so, and anyone has such a thing rattling around spare I'm in the market for one I even have a couple of CIB TI games I could trade (Super Demon Attack and Sneggit). Thanks in advance! Quote Link to comment Share on other sites More sharing options...
jrhodes Posted April 23, 2018 Share Posted April 23, 2018 (edited) https://www.aliexpress.com/item/2-Way-Audio-Video-AV-RCA-Switch-Selector-Box-Splitter-w-3-RCA-Cable-for-XBox/32357292628.html?src=google&albslr=220028354&isdl=y&aff_short_key=UneMJZVf&source=%7Bifdyn:dyn%7D%7Bifpla:pla%7D%7Bifdbm:DBM&albch=DID%7D&src=google&albch=shopping&acnt=708-803-3821&isdl=y&albcp=653153647&albag=34728528644&slnk=&trgt=68416666751&plac=&crea=en32357292628&netw=g&device=c&mtctp=&gclid=CjwKCAjwiPbWBRBtEiwAJakcpDjvHEGmIfqwm7fxQmQghbULVkuG8KAGjf1Kg5fnwJsjXonr8yAm5BoCANwQAvD_BwE&gclsrc=aw.ds I have seen similar products with four inputs. The version i have also has a headphone jack. Edited April 23, 2018 by jrhodes 1 Quote Link to comment Share on other sites More sharing options...
LASooner Posted April 23, 2018 Share Posted April 23, 2018 Just be aware that switch boxes can introduce noise into the signal depending on the quality 2 Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted April 23, 2018 Share Posted April 23, 2018 This is the kind I've used before https://www.ebay.com/itm/New-3-Way-Audio-Video-AV-RCA-Black-Switch-Box-Splitter-US-Seller-fast-Shipping/300895140295?hash=item460ebf79c7:g:ZisAAOSwdGFYyIO~ 1 Quote Link to comment Share on other sites More sharing options...
+RXB Posted April 24, 2018 Share Posted April 24, 2018 Our TV has input and output RCA jacks for INPUT, OUTPUT and ACCESSORY. 1 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted April 24, 2018 Share Posted April 24, 2018 https://www.ebay.com/itm/8-Way-Selector-Switch-Boxes-Composite-Video-Audio-RCA-AV-Switcher-In-Out-8x1-EKO/222867641657?epid=1777455402&hash=item33e3f25539:g:tfQAAOSwEoxanLlo 1 Quote Link to comment Share on other sites More sharing options...
jjh76 Posted April 24, 2018 Share Posted April 24, 2018 Check your local Goodwill, etc..., I usually see a few when I go thrifting. Or, if you're only using those two machines with this tv then you could just use some rca y-cables and then you wouldn't even need a switchbox (as long as you only have one of them turned on at a time) 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 24, 2018 Share Posted April 24, 2018 This was going to be my first *big* hardware project back in High School.... An RCA *bank* if you will. I bought a breadboard and a bunch of RCA jacks and basically just never did it. I had planned on a 5 input selector (for my NES, Genesis, SNES, Dreamcast, and my TI-99/4A) to run to one TV. I even planned for a separate input to allow me to plug in my Atari 2600, but gave up on that when I realized that Id have to convert the signal multiple times to make it flow through the bus and into the composite inputs on my TV. Anyway, theyre out there, but usually theyre A/B boxes and not necessarily the multi-line switches I had planned. 1 Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted April 24, 2018 Share Posted April 24, 2018 I use this one for me: https://www.ukdj.co.uk/pro-audio-lighting-c1/general-audio-visual-c219/audio-visual-accessories-c222/ukdj-scart-switch-box-3-scart-in-1-scart-out-plus-6-rca-phono-sockets-p4500 it can also manage RGB signal by SCART, i can use SCART to RCA adaptor if it needed more RCA 3 Quote Link to comment Share on other sites More sharing options...
digdugnate Posted April 24, 2018 Author Share Posted April 24, 2018 thanks guys for all the input! for the moment this will be a more practical solution than me finding another tv with multiple inputs i really appreciate it. Quote Link to comment Share on other sites More sharing options...
Galactus Posted April 25, 2018 Share Posted April 25, 2018 I have a 4 port one. It has both composite and S-video. It hasn't been tested in a while, so I would have to do that. Quote Link to comment Share on other sites More sharing options...
