IntyBASIC Foreground Color Change in CS Mode?
In Color Stack Mode, background is black on the entire stack. Attempting to change foeground color of a tile works fine if the color is from 0-7, but the higher numbered colors (for example CS_BROWN) are not working. I am pretty sure this goes back to "magic numbers" and my AND NOT but I don't see where I am messing up. Can anyone point me in the right direction? I did look at http://knox.ac.free.fr/inty_workshop/to get a clue but didn't...
For colorCycleLoop = 0 to 5
   tilePaintColor = ColorsTanShort(colorCycleLoop)
   #BACKTAB(133) = (#BACKTAB(133) AND NOT $0007) + tilePaintColor
   Wait: Wait: Wait
ColorsTanShort:
DATA  CS_BROWN , CS_DARKGREEN , CS_BROWN , CS_DARKGREEN , CS_GREEN ,  CS_TAN
Thanks.
Three issues as far as I can tell:
1. The variable tilePaintColor needs to be 16-bit, i.e. #tilePaintColor. You can avoid that by skipping the assignment of a variable at all, and address the DATA directly.
2. Use AND $0FF8 instead of AND NOT $0007 in order to clear bit 12 (FG Bit 3) as well as bit 13 (Advance CS) unless you want to maintain that bit.
3. #BACKTAB contains a GRAM character, right? The colours 8-15 are only available for GRAM, not GROM.
This program kind of does what you ask for:
INCLUDE "samples/constants.bas"
  MODE 0,CS_BLACK,CS_WHITE,CS_RED,CS_BLUE:DEFINE 0,1,graphic:WAIT
  FOR i=0 TO 5
    #BACKTAB(110 + i) = $0800 + 0*8 + ColorsShort(i)
  NEXT
  #BACKTAB(133) = $0800 + 0*8 + CS_BROWN
loop:
  For I = 0 to 5
     #BACKTAB(133) = (#BACKTAB(133) AND $0FF8) + ColorsShort(I)
     WAIT
     WHILE CONT.BUTTON=0:WEND
  GOTO loop
ColorsShort:
  DATA CS_BROWN, CS_DARKGREEN, CS_BROWN, CS_DARKGREEN, CS_GREEN, CS_TAN
graphic:
  BITMAP "...oo..."
  BITMAP "..oooo.."
  BITMAP "..oooo.."
  BITMAP "...oo..."
  BITMAP ".oooooo."
  BITMAP "...oo..."
  BITMAP "..o..o.."
  BITMAP ".o....o."
   Wait: Wait: Wait
Two things:
  1. The foreground color bits are not contiguous. Bit 3 of the color is in bit 12 of the BACKTAB word.
  2. You cannot use the "pastel" colors (color numbers 8 and up) cards that come from GROM, as this triggers Colored Squares mode. Compare:
You can read more over here: http://wiki.intellivision.us/index.php?title=STIC
(And yes, I drew those images, long ago...)
EDIT: I meant to add, if your BACKTAB cards are indeed coming from GRAM, you can modify your loop like so:
   #BACKTAB(133) = (#BACKTAB(133) AND NOT $1007) + tilePaintColor
   Wait: Wait: Wait
Edited by intvnut
Oh yes, if bits 14-15 are used for own content and he wants to preserve the Advance CS bit, he should use use AND $EFF8 which equals AND NOT $1007. The latter may be easier to understand, but the former I would suppose generates less code and runs a tick faster.
I see that in constants.bas there are two constants CS_CARD_DATA_MASK = $07F8 and FGBG_CARD_DATA_MASK = $01F8. It appears to me that both of these would clear the GROM/GRAM bit but perhaps those constants do it on purpose, for extracting the actual GROM/GRAM number without needing to know which it was?
They generate identical code due to IntyBASIC's constant folding, so I'd prefer the more readable version:
    ;FILE not.bas
    ;[1] #var = #var AND $EFF8
    SRCFILE "not.bas",1
    MVI V1,R0
    ANDI #61432,R0
    MVO R0,V1
    ;[2] #var = #var AND NOT $1007
    SRCFILE "not.bas",2
    ANDI #61432,R0
    MVO R0,V1
    ;ENDFILE
