AVGCART - THE average SD multicart for 8bit Atari
FPGA based multicart for 8bit Atari computers, extensible with SIO and/or ECI/PBI cables
supports CAR (cartridge dump) files up to 1MB and most bankswitching types
supports XEX (executable) files
supports ATR (floppy image) files (read/write) - support is limited without an optional SIO or ECI/PBI cable due to Atari cartridge port constraints (e.g. SW that uses RAM under OS does not work)
new beta
- ability to enable 1088kB in settings, needs powercycle after running stuff that uses it, works only with ATR (convert XEX to ATR if needed)
- CAR emulation rewritten so report broken stuff
- fixes (joystick now works in search, X should work in sdx stack, search through > 8192 folders shouldn't freeze anymore)
