tmp Posted May 15, 2019 Author Share Posted May 15, 2019 Hmmm, in the zip-archive of the update there is a file, named "AVFPlay" (no extender)...?!? What's its purpose ? Threw it into the main/root directory of the SD-card, but it does not show up on the menu, so no clue what's it for. it's a slightly patched version of phaeron's player from this thread it might be playing videos from that thread if you're lucky, they need to have AVF file extension and be contiguous (defragmented - use contig to check/defragment) you also need pal videos for pal machines and ntsc for ntsc 4 Quote Link to comment Share on other sites More sharing options...
pajero_pn Posted May 15, 2019 Share Posted May 15, 2019 Selecting a joystick- fire on file: as launch- missing: backspace parent dir - see photo Quote Link to comment Share on other sites More sharing options...
tmp Posted May 15, 2019 Author Share Posted May 15, 2019 - missing: backspace parent dir - see photoleft+fire 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 15, 2019 Share Posted May 15, 2019 move the stick then press joy button I suspect the stick controls will be modified at next release. Unless you are selecting an image using the button to launch, or go into a directory. always move the stick first and hold it in whatever direction then press and release the button. Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted May 16, 2019 Share Posted May 16, 2019 (edited) it's a slightly patched version of phaeron's player from this thread it might be playing videos from that thread if you're lucky, they need to have AVF file extension and be contiguous (defragmented - use contig to check/defragment) you also need pal videos for pal machines and ntsc for ntsc W-O-W-!!! I can hereby confirm that all videos that I downloaded from that thread do work fine from the AVG cart. All I had to do is download them, extract/unzip them on the PC, change the extender (DD, IMG, BIN, etc.) into .AVF and copy them onto my AVG SD-card. Since I already copied the loader AVFPlay onto the card (root directory), the AVG menu displayed and loaded the movies fine... My A8 system is PAL, it should only load the PAL videos, but it also loaded the NTSC videos - with extremely awful colors and extremely awful sound, but it loaded them. They are good for a gag or a quiz maybe The PAL videos were much nicer of course, some with low quality (Skyfall intro, first Tron_PAL movie, Matrix scene - no good audio) and some with great quality (2Unlimited videos, Amiga demos, 2nd Tron_PAL movie, etc.). Since I have never done such a movie conversion and know nothing about VirtualDub or muxing audio+video together, I am quite sure that my conversions would belong to the low quality ones, so hats off to the Atarians that created/converted videos with great audio & video quality! I noticed that videos with a lot of black(ness) and darkness often had lots of green pixels on the screen which made the video(s) look not as good as they could be, e.g. The Matrix. Is this a PAL problem or what is it that makes those green pixels appear where there is originally black ? (Think I have seen a similar thing in the JPEG converter by R.Espino, all JPEG pictures that had black parts in them displayed lots of green pixels there after the conversion...) Anyways, most videos are great and I will present them on the next HATZ meeting (not sure if the visitors are still interested in the PDM sounds then)... P.S.: When I first saw the AVFPlay file, I guessed that AV could mean Atari Video or AudioVideo, but had no clue what F could mean and so I thought, no, its most-likely no video-player. But now I know, it really is ! AVF = Atari Video File ?!? Edited May 16, 2019 by CharlieChaplin 3 Quote Link to comment Share on other sites More sharing options...
tmp Posted May 16, 2019 Author Share Posted May 16, 2019 I noticed that videos with a lot of black(ness) and darkness often had lots of green pixels on the screen which made the video(s) look not as good as they could be, e.g. The Matrix. Is this a PAL problem or what is it that makes those green pixels appear where there is originally black ? (Think I have seen a similar thing in the JPEG converter by R.Espino, all JPEG pictures that had black parts in them displayed lots of green pixels there after the conversion...) i can't tell since i don't see what you're seeing, you can try to create a zero filled file (e.g. 10MB) and play that, it should be completely black if you're still seeing any green pixels, you can try a different sd card (preferably from a different manufacturer) to see whether there's a difference 1 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted May 17, 2019 Share Posted May 17, 2019 Thank you for joystick control update! I have done exactly what CharlieChaplin did but I only get garbage and noises (tron_pal and dl_intro_pal). Quote Link to comment Share on other sites More sharing options...
tmp Posted May 17, 2019 Author Share Posted May 17, 2019 it's hard to guess what could be wrong, you could try a different sd card and also make sure the avf files are defragmented Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 17, 2019 Share Posted May 17, 2019 make sure the sd card is fast enough and the files a contiguous, also different fats yield different results. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted May 17, 2019 Share Posted May 17, 2019 I tested a newer SanDisk class 10 card. I formatted (Windows FAT32), copied tron_pal then copied AVFPLAY. Now it works for about 2 seconds then garbage. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted May 17, 2019 Share Posted May 17, 2019 Tested with a micro SDHC card (with SD adapter) and it works! Quote Link to comment Share on other sites More sharing options...
tmp Posted May 17, 2019 Author Share Posted May 17, 2019 nice and what were the non working cards (manufacturer, size)? Quote Link to comment Share on other sites More sharing options...
+Philsan Posted May 17, 2019 Share Posted May 17, 2019 WORKING: SanDisk Ultra A1 Micro SDHC 32GB (with adapter) NOT WORKING: SanDisk SDHC Card Class 4 16GB SanDisk Ultra SDHC Class 10 32GB Quote Link to comment Share on other sites More sharing options...
tmp Posted May 18, 2019 Author Share Posted May 18, 2019 hm, that doesn't make much sense i can't locate any full size sandisk card at this moment, anyone else can confirm? Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 18, 2019 Share Posted May 18, 2019 Possibility they are snide / copies of the real thing? Quote Link to comment Share on other sites More sharing options...
+Philsan Posted May 18, 2019 Share Posted May 18, 2019 Possibility they are snide / copies of the real thing? I don't think so, IIRC I bought the older ones from physical stores in Switzerland. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 18, 2019 Share Posted May 18, 2019 (edited) Ah ok, just so many horrendous quality fakes of just about everything inc SD's these days.. The trouble I have buying new / 2nd hand blu rays cheaply, so many Chinese fakes and bad ones at that.. Edited May 18, 2019 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted May 18, 2019 Share Posted May 18, 2019 (edited) I am using the following SD-cards: a) working: Sandisk Ultra SDHC I, 16GB, class 10 (in use with AVG-1); FAT 32, re-formatted with 32k clusters; Sandisk Ultra SDHC I, 32GB, class 10 (in use with AVG-2); FAT 32, re-formatted with 32k clusters; Sandisk SD 2GB, blue/red, nothing else printed on it (in use with two SIO2SD); FAT 16 Sandisk SD 2GB, blue/red, class 2 printed on it (in use with two Ultimate cart.); FAT 16 Transcend SD 2GB, nothing else printed on it (in use with two SIO2SD/PC micro by santosp); FAT 16 b) non-working: errmm, nothing atm. (looks like I am lucky...) Edited May 18, 2019 by CharlieChaplin 1 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted May 18, 2019 Share Posted May 18, 2019 I made a video: Philsan_Goldrake_pal.zip 7 Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted May 18, 2019 Share Posted May 18, 2019 (edited) Hey Philsan, your Goldrake video looks very good. I know it was once available for download (dropbox?) - can you upload it again, please ?!? Edited May 18, 2019 by CharlieChaplin Quote Link to comment Share on other sites More sharing options...
+Roydea6 Posted May 18, 2019 Share Posted May 18, 2019 Philsan is this AVP file available here on AtariAge anywhere I would like to try it out with my AVGCART. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted May 18, 2019 Share Posted May 18, 2019 File added to previous post, thanks for appreciation. Did you notice that it's easier to play those videos with AVGCart? IIRC with Side2 I had to put the file inside compact flash with win32diskimager and load the player from a SIO device. 4 Quote Link to comment Share on other sites More sharing options...
rkindig Posted May 19, 2019 Share Posted May 19, 2019 I would like one!! Randy Quote Link to comment Share on other sites More sharing options...
+Roydea6 Posted May 19, 2019 Share Posted May 19, 2019 I have not done any videos, but the ones that I downloaded from AtariAge forums have a very green tint with greys and some off red.. except for two files that were marked as ntsc and show very good color and sound. Dragon Lair and Half_Life .. Quote Link to comment Share on other sites More sharing options...
manterola Posted May 19, 2019 Share Posted May 19, 2019 I tried several ones and none worked for me. Maybe I did something wrong. I'll upload a video of what I got. But it is basically corrupted images and sound with a band (pm?) moving slowly from top to bottom. Quote Link to comment Share on other sites More sharing options...
