rcamp48 Posted December 11, 2022 Share Posted December 11, 2022 I am in need of some help, what I want to do has maybe been tried before , but I have my AVG cart hooked up to my 850 interface. I would like to try and run first the Basic XE cart on the AVG cart then boot into Forem XE, I have a nice WIFI card plugged into port 1 on the 850 Interface , what I would need would be to put the Forem XE program into slot one and just see what I need to get it running on my 850 interface. If I can get all 4 ports working with WIFI cards (I can get them for $10.00 Canadian each, already made up and in the housing of an analog modem with all lights connected. There is a guy that makes these WIFI modems for me with power supplies and cables for the 850 interface. Obviously ports 2,3,4 on the 850 have to be wired right, IF I can get one WIFI modem to work , I will probably work on Puff BBS so that it uses all 4 ports instead of a black box. Russ Quote Link to comment Share on other sites More sharing options...
tmp Posted December 12, 2022 Author Share Posted December 12, 2022 On 12/10/2022 at 6:15 PM, Mclaneinc said: Hi @tmp, will the whole thing get to a customer level at some point? i don't see why not, if there's interest 17 hours ago, rcamp48 said: I am in need of some help, what I want to do has maybe been tried before , but I have my AVG cart hooked up to my 850 interface. I would like to try and run first the Basic XE cart on the AVG cart then boot into Forem XE, I have a nice WIFI card plugged into port 1 on the 850 Interface , what I would need would be to put the Forem XE program into slot one and just see what I need to get it running on my 850 interface. If I can get all 4 ports working with WIFI cards (I can get them for $10.00 Canadian each, already made up and in the housing of an analog modem with all lights connected. There is a guy that makes these WIFI modems for me with power supplies and cables for the 850 interface. Obviously ports 2,3,4 on the 850 have to be wired right, IF I can get one WIFI modem to work , I will probably work on Puff BBS so that it uses all 4 ports instead of a black box. Russ I'm not sure what you need help with, you should be able to run both CAR and ATR at the same time, mount one using TAB and run the other with RETURN Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted December 12, 2022 Share Posted December 12, 2022 (edited) 8 hours ago, tmp said: i don't see why not, if there's interest I'm not sure what you need help with, you should be able to run both CAR and ATR at the same time, mount one using TAB and run the other with RETURN I got it working but my my program that I have written does not write to drive 2 on the AVG cart even after using shift 1 and shift 2 , the Hardball Disk Editor that I wrote 35 years ago I thing writes to disk 1 even though I pressed 2 on the keyboard for it to write to disk 2, have a look at it tmp , I was a lot more creative back in the 80s, half of what I did then I do not remember now. Part of growing old I guess. Oh ya you have to boot with Basi enabled 1791346056_HardBallTeamEditorTutorialWithBasicListings.mp4 Hardball-Team-Editor.atr hardball Team Creator Docs.atr HardBall (1985)(Accolade)(US) Master.atr HardBall (1985)(Accolade)(US)Copy.ATR Automatically calculate HEX strings for Hardball Editing.atr Edited December 12, 2022 by rcamp48 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 12, 2022 Share Posted December 12, 2022 Is the SD card write protected? Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 12, 2022 Share Posted December 12, 2022 12 hours ago, tmp said: i don't see why not, if there's interest Count me in (as long as my old AVG is ok for it) Quote Link to comment Share on other sites More sharing options...
tmp Posted December 12, 2022 Author Share Posted December 12, 2022 4 hours ago, rcamp48 said: I got it working but my my program that I have written does not write to drive 2 on the AVG cart even after using shift 1 and shift 2 , the Hardball Disk Editor that I wrote 35 years ago I thing writes to disk 1 even though I pressed 2 on the keyboard for it to write to disk 2, have a look at it tmp , I was a lot more creative back in the 80s, half of what I did then I do not remember now. Part of growing old I guess. Oh ya you have to boot with Basi enabled check whether the atr file on card does not have read-only attribute set is this via sio cable? Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted December 12, 2022 Share Posted December 12, 2022 On 12/11/2022 at 8:37 AM, rcamp48 said: Obviously ports 2,3,4 on the 850 have to be wired right, IF I can get one WIFI modem to work , I will probably work on Puff BBS so that it uses all 4 ports instead of a black box. Depending on what signals the WiFi needs to work, port #2 and #3 may be an issue. I don't think port #4 can be used at all for things like a modem. Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted December 13, 2022 Share Posted December 13, 2022 12 hours ago, tmp said: check whether the atr file on card does not have read-only attribute set is this via sio cable? Ya it is , I will check it out later but for now I am using the Fujinet , and I did complete my program for both creating the Master disk from several Team disks and creating Team disks from the newly created Masters Quote Link to comment Share on other sites More sharing options...
mimo Posted December 29, 2022 Share Posted December 29, 2022 An Xmas gift from @tmp ? Not sure how to enable it or if it is for the newer carts only? 4 Quote Link to comment Share on other sites More sharing options...
tmp Posted December 30, 2022 Author Share Posted December 30, 2022 14 hours ago, mimo said: An Xmas gift from @tmp ? Not sure how to enable it or if it is for the newer carts only? it needs a firmware upgrade which i can't release because last month i nuked the cart emulation code and started to rewrite it so it's not such a huge convoluted mess and it's not done yet it should be out next year 9 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 30, 2022 Share Posted December 30, 2022 Sorry to hear you had a code loss, starting from an earlier base must be a pain. Hope you get back to speed as soon as you want to, lift and work first.. Paul.. Quote Link to comment Share on other sites More sharing options...
tmp Posted January 2, 2023 Author Share Posted January 2, 2023 new beta - ability to enable 1088kB in settings, needs powercycle after running stuff that uses it, works only with ATR (convert XEX to ATR if needed) - CAR emulation rewritten so report broken stuff - fixes (joystick now works in search, X should work in sdx stack, search through > 8192 folders shouldn't freeze anymore) 11 3 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted January 2, 2023 Share Posted January 2, 2023 Just incase people look at the discord, there was an a version of this beta but the search was not working, this is the fixed b version. Quote Link to comment Share on other sites More sharing options...
matosimi Posted January 4, 2023 Share Posted January 4, 2023 On 1/2/2023 at 3:09 PM, tmp said: - ability to enable 1088kB in settings, needs powercycle after running stuff that uses it, works only with ATR (convert XEX to ATR if needed) 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted January 4, 2023 Share Posted January 4, 2023 My machine has an ultimate 1MB in so I've not tested that, have you tried the force 1MB in settings as well? Quote Link to comment Share on other sites More sharing options...
TZJB Posted January 4, 2023 Share Posted January 4, 2023 On 1/2/2023 at 2:09 PM, tmp said: new beta - ability to enable 1088kB in settings, needs powercycle after running stuff that uses it, works only with ATR (convert XEX to ATR if needed) - CAR emulation rewritten so report broken stuff - fixes (joystick now works in search, X should work in sdx stack, search through > 8192 folders shouldn't freeze anymore) Thanks @tmp. I received an AVGCART for Christmas with all of the cables (and sweets). I wasn't sure about upgrading to a beta firmware just after I received it but I held my breath as instructed and the upgrade completed. I am running AVGCART with my 256K 800XL. With the PBI cable attached I now have 512KB expanded memory instead of 192K as expected, but see no way to enable 1MB. What key combo is required please? Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted January 4, 2023 Share Posted January 4, 2023 (edited) Hit the CAPS key, that bring's up the Settings menu.. Edited January 4, 2023 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
TZJB Posted January 4, 2023 Share Posted January 4, 2023 5 minutes ago, Mclaneinc said: Hit the CAPS key Ta. I found the settings now. Quote Link to comment Share on other sites More sharing options...
tmp Posted January 4, 2023 Author Share Posted January 4, 2023 new beta for newer carts only (those that have "e" suffix in fw version), fixes right button (e.g. atr swap, that's what @matosimi was hitting) 3 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 26, 2023 Share Posted January 26, 2023 (edited) @Albert your mailbox is full, please disregard the fix request in this thread, it's fine the way it is and you can delete this message once the flag is handled. The post was correct but probably needed a line for clarity which was cleared up later. Edited January 26, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted February 2, 2023 Share Posted February 2, 2023 I have seen somewhere in my searches instructions on how to reset the AVG cart, I originally tried to set it up as a side 2 loader cart and ever since then the AVF movies have never worked right. From what I hear I need to reset my AVG cart and that should solve the problem. I want to start making AVF movies again, in both PAL and NTSC. Here are some of my ideas for AVF movies: TV series: Mash Hogan's Heroes all seasons The Muppet Show all seasons The Simpsons all seasons Hee Haw all seasons Ms Brown's Boys I Dream of Jeanie Cartoons: Bugs Bunny Coyote and The Road Runner The Jetsons The Flintstones I am sure that others can think of many many more TV series or Cartoons that would be good to digitize , as for music I have access soon to over 350 GIGS of MP3s from ABBA to ZZ-Top, and in fact have a lot of them. Another thing is to take all of my 10000+ midi files as convert them too , as they sound really nice when played back as MIDI , (I specialize in making popular MIDI tunes sound like they are being played on an NES machine with the MES plugin from Mixcraft 9 Pro Studio, I basically can put in ANY instruments that I want and write out either a newer MIDI file or even better write out the same thing in an MP3 file). Hows that for an Atari , playing back an NES rendition of say Red Red Wine from UB40 (I think its UB40) or some other popular reggae tune Russ Quote Link to comment Share on other sites More sharing options...
lexx Posted February 2, 2023 Share Posted February 2, 2023 Hello, I have a small problem after connecting to sio avg cart + atari 1010 tape recorder avgcart does not load atr files, goes into self test, while xc12 works properly, which may be the problem. tested on 2 tape recorders 1010 Japanese version. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
tmp Posted February 2, 2023 Author Share Posted February 2, 2023 1 hour ago, lexx said: Hello, I have a small problem after connecting to sio avg cart + atari 1010 tape recorder avgcart does not load atr files, goes into self test, while xc12 works properly, which may be the problem. tested on 2 tape recorders 1010 Japanese version. Thanks for the help. can you elaborate a bit on your setup, i'm a bit lost here i assume you're connecting both avgcart sio cable and 1010 at the same time, using passthrough on 1010 or do you have a splitter? how does xc12 work properly, in what setup? (xc12 doesn't have passtrough sio connector afaik) going into self test means that atari doesn't get response for d1: requests and since avgcart disables basic when atr is started, it goes into self test if you have eci/pbi cable, you cart run atr through it (shift-return if sio cable is connected) Quote Link to comment Share on other sites More sharing options...
lexx Posted February 2, 2023 Share Posted February 2, 2023 (edited) I connect everything through a sio splitter manufactured by lotharek Edited February 2, 2023 by lexx Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 2, 2023 Share Posted February 2, 2023 (edited) I haven't had the AVGcart SIO cord/eci/pbi and wanted 2 for testing and fun. If it isn't a configuration issue... I can work vicariously through lexx then, Lexx are you sure to set up AVG before then connecting cassette deck making sure tape is not on or empty in AVG. does the AVGcart play nice with external disk drives, using the normal methods of empty slots in AVGcart for real drives assigned to that slot being turned on and in use. We can't have 2 drives occupying the same slot. If either are not working, then we have to consider SIO contention mods either in firmware if the chip can work in that mode for the pins purposed or isolation chip controlled by the AVG. Edited February 2, 2023 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
