First Spear Posted May 1, 2018 Share Posted May 1, 2018 What is the fast/elegant way to pick a random BACKTAB tile within a square area? In this example I want to pick one between 92/97/172/177. Should I be thinking about this in terms of "X/Y coordinates" instead of BACKTAB locations? Thanks. Quote Link to comment Share on other sites More sharing options...
artrag Posted May 1, 2018 Share Posted May 1, 2018 (edited) Maybe this #BACKTAB(12+RANDOM(5+1)+(4+RANDOM(4+1))*20) = what_you_like where 12 is the x offset, 4 is the y offset, 5 is the width and 4 is the height of the square area Edited May 2, 2018 by artrag 1 Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted May 1, 2018 Share Posted May 1, 2018 dont know if its fast but i would use 92+random(6)+20*random(5) but it dont seem to be very random 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted May 1, 2018 Share Posted May 1, 2018 (edited) It's a 6 * 5 area, so that has 30 squares. I'd just do something like this: . idx = RANDOM(30) idx = idx + (idx / 6) * 19 + 92 . When this is done, idx will be your BACKTAB index. Edited May 1, 2018 by intvnut 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted May 2, 2018 Share Posted May 2, 2018 (edited) Using a single random number is fine but it needs a modulus operator and a division I would have used (idx % 6)+idx/6*20+92 Where idx is random(30) Edited May 2, 2018 by artrag 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted May 7, 2018 Share Posted May 7, 2018 Using a single random number is fine but it needs a modulus operator and a division I would have used (idx % 6)+idx/6*20+92 Where idx is random(30) Since division rounds down, you don't need both division and modulus. Instead, what you need is the formula I originally posted, and not the stupid edit I made after the fact. I originally posted: idx = idx + (idx / 6) * 14 + 92. Notice the 14 rather than 19. I had it right, and then edited my post with that silly think-o. What was I thinking? *wipes egg from face* Anyway, if you put 14 there, it works great. When idx = 6 .. 11, for example, we want row 1, col 0 .. 5. Your formula gets there bu computing the column and row directly. My formula takes advantage of the fact that 'idx' already added an extra 6 to the result, so it just needs 14 more to make 20. When idx = 12 .. 17, my formulat takes advantage of the fact that 'idx' has already added an extra 12 to the result, and so it just needs an extra 28. etc. I wrote the following C program to verify your formula against mine: . #include <stdio.h> int main() { int i; for (i = 0; i < 30; ++i) { int jz = i + (i / 6) * 14 + 92; int at = (i % 6) + (i / 6) * 20 + 92; printf("i=%2d jz=%2d at=%2d\n", i, jz, at); } return 0; } . That outputs: . i= 0 jz=92 at=92 i= 1 jz=93 at=93 i= 2 jz=94 at=94 i= 3 jz=95 at=95 i= 4 jz=96 at=96 i= 5 jz=97 at=97 i= 6 jz=112 at=112 i= 7 jz=113 at=113 i= 8 jz=114 at=114 i= 9 jz=115 at=115 i=10 jz=116 at=116 i=11 jz=117 at=117 i=12 jz=132 at=132 i=13 jz=133 at=133 i=14 jz=134 at=134 i=15 jz=135 at=135 i=16 jz=136 at=136 i=17 jz=137 at=137 i=18 jz=152 at=152 i=19 jz=153 at=153 i=20 jz=154 at=154 i=21 jz=155 at=155 i=22 jz=156 at=156 i=23 jz=157 at=157 i=24 jz=172 at=172 i=25 jz=173 at=173 i=26 jz=174 at=174 i=27 jz=175 at=175 i=28 jz=176 at=176 i=29 jz=177 at=177 . Ta da! It really is worth avoiding the modulo, as it's just as expensive as the division. Avoiding it cuts the cost nearly in half in the worst case. (Granted, the cost was never huge to begin with, but every cycle counts.) 2 Quote Link to comment Share on other sites More sharing options...
artrag Posted May 7, 2018 Share Posted May 7, 2018 (edited) Actually I see that i=i%6+6*(i/6) So we have i%6+(i/6)*20=i+i/6*14 [Edited to fix a mistake] Edited May 7, 2018 by artrag 2 Quote Link to comment Share on other sites More sharing options...
