Mads assembler best way to end align code?
Not just Mads, but I'm kinda new to Mads and maybe there's an easy way in Mads:
I've some compressed data/code where it allocates memory to the uncompressed size, but to save memory the compressed data should be aligned to the end of uncompressed area, not the start. Obviously I don't want data the full size of the uncompressed data to be assembled.
EG
/0000000000000000/ (uncompressed)
/0000000000xxxxxx/
X being the compressed data.
Anyone have experience of doing this without it being run through an external packer utility?
Thanks!
You need some way to get the length of the compressed data so that you can compute the starting address by subtracting the length from the ending address that you want to align it to. I couldn't find a way to do that in one pass in MADS. You can use .get to read a file into memory within MADS but I don't see a way to get the length of the array. You could do it in two passes. Create one file like this:
    org $0
    ins 'compressed.dat'
    .put [0] = <*
    .put [1] = >*
    .sav 'compressed.len',2
This will create a two byte file named compressed.len which will contain the length of the file compressed.dat. Now you have what you need to align the data as follows:
    .get 'compressed.len'
?length equ .wget[0]
    .get 'compressed.dat'
    org $C000-?length
    .sav ?length
You can then set up your build process to assemble these files in the correct order. Example Makefile:
endalign.obx: endalign.asm compressed.len compressed.dat
        mads $<
compressed.len: getlength.asm compressed.dat
        mads $<
Code:
endalign.zip
?length =.filesize 'compressed.dat'
org $c000-?length
should work.
Thanks JAC! That's what I was looking for. Looks like the English version of the documentation needs to be updated. It also doesn't have .WGET and a few other commands I noticed.
