+InsaneMultitasker Posted March 12, 2022 Author Share Posted March 12, 2022 7 hours ago, publicarni said: I just tested it on a real TI-99 with EVPC 80 column card and it works great, also saving and loading a game on a real disk ... ? Thank you! That is good news. Are you using the FG99 to load the game file? Your test reminds me that there are TI devices like the HSGPL that can make use of cartridges, so I will make a gram file later today for hsgpl, gram kracker, etc. 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 12, 2022 Author Share Posted March 12, 2022 8 hours ago, Asmusr said: That's strange. Even though it goes through GPL it should end up calling either DSR subprogram >16 or FILES, right? I am using dsr subprogram >16 to set CALL FILES(1). The code I introduced looks similar to this, I'll have to check the binary for its location in grom. CALL G@docallfiles call our routine BYTE >01 with a parameter of 1 docallfiles FETC @>834C # of files from parameter DST >0116,V@>077E set up 'pab' DST >077E,@>8356 pointer CALL G@>10 dsrlnk BYTE >0A subprogram list 2 Quote Link to comment Share on other sites More sharing options...
+RXB Posted March 12, 2022 Share Posted March 12, 2022 RXB has CALL FILES(0) or up to CALL FILES(15) and they all work. *********************************************************** * CALL FILES(number) 0 to 15 * *********************************************************** SFILES DATA SSIZE STRI 'FILES' * FILES DATA $+2 CALL COMB * ( CALL CLSALL * Close all open files CALL RXBFIL * Set files BR RXBNEW * Go do a NEW RXBFIL CALL SUBLP3 * Get Files value DCZ @FAC * Zero? BS RXBF0 * Yes, RXB CALL FILES(0) DCHE 16,@FAC * 16 or more to high BS ERRBV * Yes, BAD VALUE error CEQ RPARZ,@CHAT * )? BR ERRSYN * SYNTAX ERROR XML PGMCHR * Skip ) DCLR @FAC2 * Clear ST @FAC1,@FAC2 * Load file value DST >0116,V@VROAZ * Set files buffer space DCHE 256,@PAD * BR DSRDSS * ADD >10,@VROAZ+1 * DSRDSS DST VROAZ,@FAC12 * CALL LINK * BYTE >0A * ST @ERCODE,@PAD2 * SRL 4,@FAC6 * CZ @FAC6 * BR ERRFE * CEQ >20,@PAD2 * BS ERRFE * RTN * RXBF0 CEQ RPARZ,@CHAT * )? BR ERRSYN * SYNTAX ERROR XML PGMCHR * Skip ) DST >3CEF,@>8370 * Set FILE(0) VDP Highest address RTN * Return Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 12, 2022 Author Share Posted March 12, 2022 47 minutes ago, RXB said: RXB has CALL FILES(0) or up to CALL FILES(15) and they all work. Thanks Rich. I tried the included RXB2020 (in js99er) and CALL FILES(1) resulted in an XB error message. Maybe the same issue my Adventure code runs into? I then tested the included BASIC and XBASIC 2.9. Both succeeded with this log entry: Executing disk DSR FILES routine (n = 1). So we know the DSR routine works. Js99er doesn't have grom view/debug, so I'm at a loss why it fails there and not in Classic99. I'll try to trace the BASIC CALL FILES routine in classic99 for clues. 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 12, 2022 Author Share Posted March 12, 2022 First post has been updated with the current .bin file and a TIFILES-format gram file. 1 Quote Link to comment Share on other sites More sharing options...
+RXB Posted March 12, 2022 Share Posted March 12, 2022 2 hours ago, InsaneMultitasker said: Thanks Rich. I tried the included RXB2020 (in js99er) and CALL FILES(1) resulted in an XB error message. Maybe the same issue my Adventure code runs into? I then tested the included BASIC and XBASIC 2.9. Both succeeded with this log entry: Executing disk DSR FILES routine (n = 1). So we know the DSR routine works. Js99er doesn't have grom view/debug, so I'm at a loss why it fails there and not in Classic99. I'll try to trace the BASIC CALL FILES routine in classic99 for clues. Just tested RXB 2020 and 2021 with FinalGrom in TI99/4A console with NO 32K or P-BOX just console CALL FILES(0) works fine VDP stack size 13144 bytes free CALL FILES(1) up to CALL FILES(15) all crash without a DSK Controller. Suppose I could created a RXB only version that does what the DSK Controller does... 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 12, 2022 Author Share Posted March 12, 2022 10 minutes ago, RXB said: Just tested RXB 2020 and 2021 with FinalGrom in TI99/4A console with NO 32K or P-BOX just console CALL FILES(0) works fine VDP stack size 13144 bytes free CALL FILES(1) up to CALL FILES(15) all crash without a DSK Controller. Suppose I could created a RXB only version that does what the DSK Controller does... Thanks for testing. Without a controller, I would be inclined to just ignore the call files error and skip the routine (the DSRLNK should return an error). I sent Rasmus a PM with what I believe is the reason js99er reacts differently. I'll hold on any further testing or comments until he has a chance to review. 2 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted March 13, 2022 Share Posted March 13, 2022 9 hours ago, InsaneMultitasker said: Thanks for testing. Without a controller, I would be inclined to just ignore the call files error and skip the routine (the DSRLNK should return an error). I sent Rasmus a PM with what I believe is the reason js99er reacts differently. I'll hold on any further testing or comments until he has a chance to review. Fixed. It was an error in the subprogram list in the DSR, which meant that subprogram >16 was never found. 6 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 13, 2022 Author Share Posted March 13, 2022 6 hours ago, Asmusr said: Fixed. It was an error in the subprogram list in the DSR, which meant that subprogram >16 was never found. Thank you, the subprogram >16 is now successfully executing from the Adventure 80 cartridge. 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 14, 2022 Author Share Posted March 14, 2022 On 3/12/2022 at 3:25 PM, InsaneMultitasker said: First post has been updated with the current .bin file and a TIFILES-format gram file. See the Geneve OS Development topic for the program PLAYE, which can be used to run the Adventure 80 cartridge GROM file on the Geneve. 1 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 12, 2022 Author Share Posted June 12, 2022 Is there a "simple" list of GPL instructions and their operation? Like a Cliff Notes for the GPL language? Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted June 12, 2022 Share Posted June 12, 2022 I use these, not exactly a cheat sheet... GPL: the GROM language (I) Part II 3 Quote Link to comment Share on other sites More sharing options...
+Torrax Posted June 12, 2022 Share Posted June 12, 2022 Thierry Nouspikel's "The TI-99/4A Tech Pages" has lots of great info there. There are also disassembled GPL listings of the E/A, Mini-Memory, and TI-Writer carts. 3 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted June 12, 2022 Share Posted June 12, 2022 1 hour ago, InsaneMultitasker said: Is there a "simple" list of GPL instructions and their operation? Like a Cliff Notes for the GPL language? You can start with the instruction list starting at page J-1 of the GPL Programmer's Guide and dive into section 4 of the document for extremely detailed explanations. Thierry Nouspikel's pages also have a lot of useful data here. gpl_programmers_guide-OCRed.pdf 3 Quote Link to comment Share on other sites More sharing options...
InfiniteTape Posted March 13 Share Posted March 13 I finally got an F18A set up and tried this out using a FinalGROM. It stays on the cyan screen, never getting to the yellow loading screen. Any thoughts on troubleshooting? Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 13 Author Share Posted March 13 10 hours ago, InfiniteTape said: I finally got an F18A set up and tried this out using a FinalGROM. It stays on the cyan screen, never getting to the yellow loading screen. Any thoughts on troubleshooting? I'm not familiar with the FinalGrom as I do not own/use one. I had asked a few people if they tried my files with the FG99 but never received confirmation. Perhaps someone reading this can confirm that it works or offer guidance. Quote Link to comment Share on other sites More sharing options...
InfiniteTape Posted March 15 Share Posted March 15 On 3/13/2023 at 3:25 PM, InsaneMultitasker said: I'm not familiar with the FinalGrom as I do not own/use one. I had asked a few people if they tried my files with the FG99 but never received confirmation. Perhaps someone reading this can confirm that it works or offer guidance. I definitely noticed while reviewing the thread people mentioning FG99 but not actually providing any results. Surely there's some other brave soul who's willing to try it! 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 18 Author Share Posted March 18 On 3/15/2023 at 11:06 AM, InfiniteTape said: I definitely noticed while reviewing the thread people mentioning FG99 but not actually providing any results. Surely there's some other brave soul who's willing to try it! Does the original Scott Adams cartridge work for you? The 80 column cart is the same code, with changes to the display routines and DSR. So in theory, if the original works, so should my version. What is your system configuration? Maybe we can figure it out together. Quote Link to comment Share on other sites More sharing options...
InfiniteTape Posted March 19 Share Posted March 19 22 hours ago, InsaneMultitasker said: Does the original Scott Adams cartridge work for you? The 80 column cart is the same code, with changes to the display routines and DSR. So in theory, if the original works, so should my version. What is your system configuration? Maybe we can figure it out together. Yep, I just tried loading the original from FG99 and was able to get a game started. I've tried with just the console+F18A and with my PEB (TIPI-PEB, SAMS, 838-Speech, TI Disk Controller) attached. Both fail in the same way. 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 19 Author Share Posted March 19 33 minutes ago, InfiniteTape said: Yep, I just tried loading the original from FG99 and was able to get a game started. I've tried with just the console+F18A and with my PEB (TIPI-PEB, SAMS, 838-Speech, TI Disk Controller) attached. Both fail in the same way. Could you post the working and not-working files here or PM them to me? I'll compare them and see if anything stands out. Thank you for the update and testing... Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 19 Author Share Posted March 19 51 minutes ago, InfiniteTape said: Yep, I just tried loading the original from FG99 and was able to get a game started. I've tried with just the console+F18A and with my PEB (TIPI-PEB, SAMS, 838-Speech, TI Disk Controller) attached. Both fail in the same way. Try renaming the file to "ADV80G.BIN". The file I posted uses a long filename which, if I read this correctly, is going to be shortened to a name that will likely exclude the indicator. Excerpt from finalgrom documentation: The filesystem used on SD cards has an filename character limitation, which ignores case and shortens all filenames to fit into a 8.3 schema. Thus, hellogromg.bin would be seen as HELLOG~1.BIN, and the trailing GROM indicator G would be missed. IMPORTANT! When using split files, make sure that each filename has no more than 8 characters (excluding the extension)! This is always true for legacy cartridge dumps. HINT: A filename with more than 8 characters for a single file ROM-only image will never end incorrectly in D or G. In summary, don't rename cartridge dumps. GROM filenames must not exceed 8 characters AND must end in G. ROM filename must have more than 8 characters OR must not end in D or G. For all images, there is always a main file that is used for help texts or RAM/GRAM configurations. For GROM and mixed images, the main file is the G file, for ROM-only files this is the C file or the actual filename of a single-file image. 1 Quote Link to comment Share on other sites More sharing options...
InfiniteTape Posted March 20 Share Posted March 20 On 3/18/2023 at 10:35 PM, InsaneMultitasker said: Try renaming the file to "ADV80G.BIN". The file I posted uses a long filename which, if I read this correctly, is going to be shortened to a name that will likely exclude the indicator. I remembered to shorten it, but forgot the "G". "ADV80G.BIN" works. Thanks!!! 3 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 20 Author Share Posted March 20 2 hours ago, InfiniteTape said: I remembered to shorten it, but forgot the "G". "ADV80G.BIN" works. Thanks!!! I updated the first post with a note to rename the file. Glad to hear it worked! Quote Link to comment Share on other sites More sharing options...
