IntyBASIC Rough Song - Always on the Run - for ECS
You'll have to start jzIntv with something like this to make it work.
start jzintv --jlp  -b10 -v1 -z "640x480,8"  -E "C:\Program Files (x86)\jzIntv\bin\ecs.bin"  -e "C:\Program Files (x86)\jzIntv\bin\exec.bin" -g "C:\Program Files (x86)\jzIntv\bin\grom.bin" thissong.bin
alwaysonrun.zip
To build, use the Alpha bits from https://github.com/nanochess/IntyBASIC.
Mode 0,1,0,1,0
Wait
Border 1,0
Scroll 4,4,0
For borderNew=0 to 200 Step 20 : Poke $200+borderNew, $2000: Poke $213+borderNew, $2000 : Next borderNew
Wait
Wait
Print At 21 Color 7 , "Always on the Run"
Print At 141 Color 5 , "Restart: Top side"
Print At 161 Color 6 , "Exit: Bottom side"
Wait
Play Full
Wait
Play AlwaysOnRun
Wait
Goto PlayLoop
PlayLoop:
Wait
If Cont.B0 Then Wait : Play Off : Wait : Play AlwaysOnRun
If Cont.B1 Then Goto ExitThis
If Cont.B2 Then Goto ExitThis
Wait
Goto PlayLoop
ExitThis:
Wait
Print At 213 Color (Rand and 7) , "Bye."
For spinWait = 0 to 5
Wait
Play Off
ASM ORG $A000
AlwaysOnRun:
Data 6
Music - , - , - , - , - , -
Music F4Z , - , F4W , - , - , -
Music S , - , S , - , - , -
Music - , - , S , - , - , -
Music E3 , - , S , - , - , -
Music E4 , - , S , - , - , -
Music D4 , - , S , - , - , -
Music C4# , - , S , - , - , -
Music G4 , - , S , - , - , -
Music B3 , - , S , - , - , -
Music G3 , - , S , - , - , -
Music E3 , - , E3 , - , - , -
Music E4 , - , E4 , - , - , -
Music D4 , - , D4 , - , - , -
Music C4# , - , C4# , - , - , -
Music G4 , - , G4 , - , - , -
Music B3 , - , B3 , - , - , -
Music G3 , - , G3 , - , - , -
Music E3 , B2X , S , - , - , -
Music E4 , - , G4 , - , - , -
Music D4 , - , A4 , - , - , -
Music S , - , D4 , - , - , -
Music S , B2 , E4 , - , - , -
Music - , S , S , - , - , -
Music G4 , S , S , - , - , -
Music D4 , S , G4 , - , - , -
Music S , S , S , - , - , -
Music E4 , S , C4# , - , - , -
Music S , S , D4 , - , - , -
Music S , - , E4 , - , - , -
Music E3 , B2 , S , - , - , -
Music D4 , S , S , - , - , -
Music B3 , S , S , - , - , -
Music G3 , S , F5 , - , - , -
Music D4 , S , G5 , - , - , -
Music E4 , S , G5 , - , - , -
Music A4 , S , S , - , - , -
Music S , S , G4 , - , - , -
Music G4 , - , C4# , - , - , -
Music S , G4 , E4 , - , - , -
Music E3 , S , F5 , - , - , -
Music F3# , - , G5 , - , - , -
Music S , - , G5 , - , - , -
Music G3 , B2 , S , - , - , -
Music G3 , B2 , G4 , - , - , -
Music G3 , - , A4 , - , - , -
Music G3 , - , D4 , - , - , -
Music A3 , B2 , S , - , - , -
Music A3 , B2 , G4 , - , - , -
Music A3 , - , A4 , - , - , -
Music A3 , - , S , - , - , -
Music A3 , - , D4 , - , - , -
Music D4 , - , A4 , - , B4 , B5
Music C4# , - , S , - , S , S
Music S , - , D4 , - , S , S
Music D4 , - , S , - , S , S
Music S , B2 , E4 , - , S , S
Music - , S , S , - , S , S
Music G4 , S , S , - , S , S
Music D4 , S , G4 , - , S , S
Music S , S , S , - , S , S
Music E4 , S , C4# , - , S , S
Music S , S , D4 , - , S , S
Music S , - , - , - , S , S
Music G3 , B2 , - , - , S , S
Music G3 , B2 , G4 , - , S , S
Music S , - , S , - , S , S
Music G3 , - , A4 , - , S , S
Music G3 , - , S , - , S , S
Music G3 , - , D4 , - , S , S
Music A3 , B2 , S , - , S , S
Music A3 , B2 , G4 , - , S , S
Music A3 , - , A4 , - , S , S
Music A3 , - , S , - , S , S
Music A3 , - , D4 , - , S , S
Music E3 , B2 , S , - , S , S
Music E4 , - , G4 , - , S , S
Music E3 , B2 , - , - , S , S
Music - , - , - , - , S , S
Music D4 , - , A4 , - , S , S
Music D4 , S , S , - , S , S
Music B3 , S , S , - , S , S
Music G3 , S , F5 , - , S , S
Music D4 , S , G5 , - , S , S
Music E4 , S , G5 , - , S , S
Music S , - , E4 , - , S , S
Music - , - , S , - , S , S
Music A4 , S , S , - , S , S
Music S , S , G4 , - , S , S
Music G4 , - , C4# , - , S , S
Music S , G4 , E4 , - , S , S
Music E3 , S , F5 , - , S , S
Music F3# , - , G5 , - , S , S
Music S , - , G5 , - , S , S
Music G3 , B2 , S , - , S , S
Music S , B2 , S , - , S , S
Music F3 , S , F5 , - , S , S
Music - , S , S , - , G4 , G4
Music D4 , S , G5 , - , A4 , A4
Music E4 , S , G5 , - , G4 , G4
Music E3 , B2 , S , - , A4 , D5
Music E4 , - , G4 , - , A4 , D5
Music D4 , - , A4 , - , A4 , A4
Music C4# , - , S , - , G4 , G4
Music S , - , D4 , - , A4 , A4
Music D4 , - , S , - , G4 , G4
Music S , B2 , E4 , - , A4 , A4
Music - , S , S , - , B4 , B4
Music A4 , S , S , - , A4 , A4
Music S , S , G4 , - , G4 , G4
Music G4 , - , C4# , - , G4 , G4
Music S , G4 , E4 , - , G4 , G4
Music G4 , S , S , - , A4 , A4
Music S , S , S , - , G4 , G4
Music S , S , F5 , - , S , S
Music - , S , G5 , - , A4 , A4
Music - , - , G5 , - , G4 , G4
Music D4 , S , S , - , A4 , A4
Music B3 , S , G4 , - , G4 , G4
Music G3 , S , S , - , S , S
Music E3 , S , C4# , - , G4 , G4
Music D4 , S , D4 , - , A4 , A4
Music E4 , S , E4 , - , G4 , G4
Music G4 , - , A4 , - , A4 , A4
Music G4 , - , S , - , G4 , G4
Music A4 , - , D4 , - , A4 , A4
Music B4 , - , S , - , G4 , G4
Music D5 , B2 , E4 , - , A4 , A4
Music E5 , S , S , - , A4 , A4
Music D5 , S , S , - , G4 , G4
Music E5 , S , F5 , - , S , S
Music G5 , S , G5 , - , A4 , A4
Music S , - , G5 , - , G4 , G4
Music D4 , S , G4 , - , G4 , G4
Music E4 , S , C4# , - , G4 , G4
Music S , S , D4 , - , A4 , A4
Music S , - , E4 , - , G4 , G4
Music B3 , S , S , - , G4 , G4
Music C4# , S , S , - , A4 , A4
Music C4# , S , S , - , G4 , G4
Music C4# , S , F5 , - , S , S
Music C4# , S , G5 , - , A4 , A4
Music C4# , S , G5 , - , G4 , G4
Music D4 , B2 , S , - , A4 , D5
Music E4 , B2 , S , - , A4 , D5
Music Stop
Edited by First Spear
I think you need to post a CFG file (the forum won't allow you unless you zip them together) or convert BIN + CFG to ROM, since your program doesn't use a sequential memory layout. At least jzintv crashes right away for me no matter which parameters I give it. Also I must have an older version of the compiler since I was unable to compile the 6 channel ECS music syntax.
Edited the original with a .zip containing the bin and cfg, and a path to the new music functionality. I think I get the award for the longest-running pain in the butt for Nanochess regarding IntyBASIC sound/music, btw. :)
