Question about session 9...sorry I am behind
First of all, I would like to thank everyone for help on my last question. I am now up and (mostly) running with things so far.
My trouble is with the sample kernel that we are supposed to test. When I copy it into a notepad file, save it as a .asm file, run dasm, and then put it in my Z26 to test, the screen is 80% right, with a column of wierd stuff one in from the left (imagine if you will, splitting the screen into 5 even colums starting from left to right, my second column in is "inverted"; the colors start dark and go light the other direction. I have not been able to get a screenshot of it. I will try on my work computer tomorrow, this was on my home computer).
Just wondering what I should be looking for, as far as casuse.
Thanks to all,
Cassdiy
Thanks to all,
Cassdiy
This sounds like it's working correctly. The section of code I posted in the "help! sesson 8" request was the latest section of code at that stage, and we were playing with timing of things mid-scanline.
If you replace the 'picture' part of the code with the following, you should have a 'clean' display...
; 192 scanlines of picture...
   ldx #0
   inx
   stx COLUBK
   sta WSYNC
   cpx #192
   bne Picture
Cheers
A
when I drop the kernel;.bin or test.bin file onto Z26, it loads, but only shows a black screen - the file assembles ok - I am I right in thinking the file will not be written if the code is incorrect??? :?
No, it will be written, but only partially.
How large exactly is your file? It should have 2048 or 4096 Bytes.
they are all 0-kb - looks like i'm good at programming black screen shots :D - I didn't think it worked as dasm says
DASM V2.20.05, Macro Assembler ©1988-2003
START OF PASS: 1
warning: Unable to open 'kernel.asm'
then a table appears & it says complete & an empty .bin file is created. :x
:?: :x :?:
Archived
This topic is now archived and is closed to further replies.
