Atari Master Posted March 4, 2002 Share Posted March 4, 2002 I was wondering.Is there a way to make my own out of another.Do I just change somthing on a plug or somthing? Quote Link to comment Share on other sites More sharing options...
VidGameKing Posted March 4, 2002 Share Posted March 4, 2002 you could get somthing like this: power adaptor. Quote Link to comment Share on other sites More sharing options...
zanza Posted March 4, 2002 Share Posted March 4, 2002 You can take anyting you find that outputs 9 Volts DC and then solder a mono or stereo jack . the polarity should be "the plus of the voltage at the end of the pin" and the minus of the voltage at the base (the long one) But you will need a solder iron (with a fine tip, for electronical use, not a big one to burn the whole house) and you need to buy a mono/stereo jack to solder at the end of the 9V DC power supply you must find too. Quote Link to comment Share on other sites More sharing options...
Skatepunk60 Posted March 6, 2002 Share Posted March 6, 2002 One more note : make sure its current is 500ma or above or you run the risk of burning out the internal transformer, BTW i do this all the time because the atari and pong power supplys die SOOOOO easy Quote Link to comment Share on other sites More sharing options...
