TIME PILOT - final release
solo/ng
1 hour ago, ndary said:
On the cartridge version I out together there is a hidden feature :) if the game sense you have a acceleration 65816 board (like Rapidus etc) the game will play with More sprites and smoother scrolling
Would it be possible to get an 8-bit conversion for the 5200?
I think kyle is running the upgraded processor without and frequency changes and all that other stuff
There was a thread about it a while ago:
which ended up... well, see yourself.
Not only it, latest file version has this feature as well.
1 hour ago, solo/ng said:
The domain changed (permanent now), the website is here: https://timepilot.atariscene.pl/
would be awesome if a mod could edit it in first post (I cant).
I have edited the first post.  I also flipped the switch to allow you to make your own edits. I can't for the life of me get the .png links to update. Maybe you will have better luck.
  • Thanks 2
I downloaded the game from this location but when I play it with rapidus enabled I get A LOT more planes than in the video above. Any ideas why this happens?
I mean it nearly gets unplayable that way. Apart from that in normal 8-bit mode the game is fantastic! ?
44 minutes ago, Keatah said:
It's like a demo. Swarm mode. START starts normally. SELECT turns on SWARM mode.
It does?
Maybe I'm missing what swarm mode is, also, after a set of hits I heard a fx and thought I saw a box around a plane?  Am I losing it (easy, yes) but if not what does it do, I tried space but it just paused the game. TIA
Yeah, I'm running a 1.79 Mhz 65C802 in my Incognito.
Edit: Time Pilot 16 works, but has some small graphic glitches and is slow.
Can you measure the CPU speed and act accordingly?
Edited by Kyle22
