Myarc cards for sale/repair tips
10 hours ago, AwkwardPotato said:
It's a symbol found on many bottom-of-the-barrel phony TI parts. Seems that they only bother engraving one half of the TX... :ponder:
@Ksarul said something similar to me about this looking like a partial or deformed TI logo.  The chip initially "worked" and then failed miserably.  I now wonder if the failure coincided with my HFDC gate array going bad, and if the chip somehow caused that damage.  Doubtful, but it makes me pause and think...
I found this article interesting as I have used the named suppliers in the past and one of them is where the bad chip came from
https://northcoastsynthesis.com/news/beware-fake-parts/
  • Sad 5
Ok, no more tears!!!   The Genmod system is on its way to its owner as of this afternoon.  And for the first time in a long time, my bench is clear of all pending repairs, and my room is again recognizable!   I might have to celebrate by tearing down my development Geneve to refresh the capacitors and install (test) a few DC-to-DC converters on the HFDC and SCSI cards.   Woohoo!
  • Like 10
I have used 8 of these buck converters:
10PCS DC-DC 12-24V To 5V 3A Step Down Power Supply Module Voltage Buck Converter | eBay
10 pcs = $10.95 + $1 for shipping.
Example: I have replaced the 7805 TI PEB side) on the Myarc 512 card with one of these. It runs very cool, almost no heat. I also removed the externally supplied 7805 and "OR'ed" the external and PEBox supplies using the card's existing diodes that are in-line with the power traces. This allows the single buck regulator to work with either supply (I used a regulated 9 volt 1 amp supply and the PEBox supplies about 11.5 volts). When the two 7805s were used the external 7805 got very hot. This is a simpler, more cost effective, and prevents the two regulators from "fighting" each other.
The buck converters above are adjustable (variable) but also have a fixed mode for 3.3, 5, 9, and 12v.  believe they adjust up to 24v and supply up to 3A. They default is variable. To use the fixed mode you must cut the small trace connecting the variable option and use a solder bridge or a jump to select the fixed option. I put header pins on them and can drop them in place of the 7805s. I have also used these to power my HDs for the HFDC. They work great, again with virtually no heat and they are far more efficient then the power/heat waste of the 7805s.
I hope this helps and may save you some time.
Mark
26 minutes ago, mvancopp said:
Thanks, Mark. I will check this out!
See the below link for the part that was recommended to me years ago - I've used it in a few cards, including the Heatwave BBS's Geneve that has been running 24x7 for nearly four years. Heat is negligible, running in the 80-90F range last time I checked.   They are however more expensive.
What sort of hard drive (HD) are you powering and how did you set that up?  Did you use both 12v and 5v converters?  Would be neat to see a few pictures, too :)
https://www.cui.com/product/dc-dc-converters/non-isolated/v78-1500r-series
I believe I looked at the CUI regulators but I did not have any reliability history or recommendations, they lacked the ability to change the voltage, and the cost seemed out of line. So when I found some inexpensive regulators that could handle 3A, were "pin compatible" to the TO-220 78XX, had a wide input voltage tolerance, and could fulfill multiple voltage needs, I decided it was worth a try. Although they have worked very well I only have a few months of continuous operational experience, no long term reliability knowledge yet.
I power ST-225 HD drives with them and a few cards (I haven't done the Geneve yet). I did power both 12v and 5v using them for the HD, but decided to use a wall 12v PS and only regulate the 5v. It powers both the ST-225 and a GoTek in the same floppy enclosure, an old TRS-80 drive enclosure. The 12v also ran only a little warmer than ambient under normal use, which should have been 1.25A - 1.5A.
I do not have any pics but the next time I am in those machines I take some.
Mark
The chip distributor refunded me for the LS02 and LS00 chips with an apology for "the mistake". There was no admission that the parts were counterfeit nor was any other reason given.  I will be wary of purchasing from them in the future, and wonder if I need to consider any other chips suspect, even though they have what look like proper labels that match what was advertised in the parts info.
10 hours ago, Ksarul said:
I usually use Unicorn, Mouser, or Digi-Key for parts orders, as they all generally buy their stocks from the OEM. That generally minimizes the chance for bad parts.
I like Mouser, but this time neither Mouser nor Unicorn had all the parts I was needing.  fortunately, I obtained what appear to be good DRAM chips, so not all was a loss.  :)   It does make me wonder how many others have been burned by the substandard parts; fortunately, I had older parts around that I could use to troubleshoot as I doubt I would have solved the issue without them, since replacing a suspect new part with another new part got me nowhere...
  • 1 month later...
  • 3 months later...
Have been trying to organize the TI/Geneve stuff I still have here and came across some MYARC FDC and Geneve boards. Of course as far as I can tell so far these boards are not working boards. I did spend some time today with what looked to be an FDC just like it came from MYARC. After playing with it for a while I found the 74LS245 was fried and replaced it with a new one. This got me to the system being locked up with a cyan screen when I powered up the TI. After about 4 hours and a new PAL and EPROM updated to version 1.5 and a new 70 nano second RAM chip just for heck of it the card is as you see it in the image and working very nicely with 5.25 disks and I'm guessing will work just as well with 3.5 disks but I don't have 3.5 drives hooked up to my TI repair system. Now that the card is working I'm thinking it should have both original electrolytic capacitors replaced. If anyone is interested in this FDC I'm asking $150.00 + shipping. Contact me here privately if interested.
  • Like 9
This board has been taken. Stand by as I'll have a few more of these available as time allows. Haven't setup a P-Box yet to start testing what shape the Geneves are in.
  • 2 months later...
This weekend I finished installing a NOS power supply into my ancient Geneve tower case. (Some day I want to redo it using an 838 PEB).   As most projects go, one change spawned another 15 or so.
After I removed the old supply from the case (it was still functional) I opened it up and looked inside.  There were four or five capacitors bulging and/or leaking.  I set the power supply aside and installed the new one into the case.  I soldered a 24-pin ATX connector to the PEB backplane wiring so that I didn't have to cut the new power supply's connector. After some validation tests, I powered up the Geneve.
What I noticed right away is that my old 8CM515 monitor produced a crisp, clear output; there was no interference or waviness.  The monitor has a few issues and is on its last legs, so a clear picture was the last thing I expected.  I am guessing that the old supply was putting out a lot of noise due to the failing caps and/or its age.  Before I attribute the problem solely to the power supply, I need to test with another system and monitor. Still, it is something for us to keep in mind.
The next phase was to migrate my development system back into the PC tower case from the PEB.  The system consists of a Geneve, SCSI card, HFDC, two ramdisks, TIPI, RS232, and Myarc FDC.  As I started experimenting with card placement in the tower, I found it very difficult to get all of the cables satisfactorily routed to the various drives. And if I needed to test a different configuration, pulling things apart was going to be an ugly mess.  I opted to continue with my PEB system for this development cycle, sans the Myarc HFDC. (The external power supply for the MFM and floppy drives failed not too long ago). I'll revisit my setup after the next release.
I removed one of my two 5.25" drives from the PEB and replaced with a 3.5" drive. It took me a while to figure out that this drive had a drive selector for DS0,1,2,3.  ;)  After 25 years, I guess I had set-it-and-forgotten-it.  Tomorrow, I will wire up a power adapter for my EZ135 drive so that I can use that device for OS tests.
One last thought for those of you with battery-operated devices like the Horizon RAMdisk:  if you haven't checked your batteries in a while, take a moment to inspect them.   While I did not have any leaking batteries, my Horizon Ramdisk 3000 uses alkaline batteries that are close to needing replacement.  I haven't used my Geneve since last summer, so there has been a constant draw for months.
  • Like 6
