ProtoType Atari 8-bit IC's
KLund1
I procured a box of Atari prototype IC’s. They were in an old moldy box. They are not in the best condition. One is missing a pin. Many have many bent pins, but look fixable. Some look new. I pulled all the IC’s out of the crumbling gray moldy anti-static pad. There were not in any particular order on the pad.
I could not find much about most of them. I was told that the original person that had these, worked at Atari back in the good days. So I’d thought I should post them here for all to review, and comment.
Left column with gold covers
C0125052-10 PROTO 1978
C0125058-10 PROTO 1982
C012610A-10 PROTO 1981 x2
C012645-06 1979
C012654-01 1981 x2
Next column to the right
C69007
C011208-05
C011222-08 1981 X2
C011227-07 1978
C011299B-03 (810?)
C012009-08 1981 (2600?)
C012016 1980 X2
C012512-02 1977 X2
3rd column
C012608A
C012610A-02 1981 X2
C012654-02 1981 X2
C012645-02 1979 X2
C016484-02 1983 X2
4th column, the 3 shifted right are known OS ROMS and not listed here
C014512-08 1981
C016449B-22 1981
C060617B-01 1982 (1200XL rom?)
C022734A-07 Qual Samples
Black but was next top the one just above
CN7292N 1978
CN7293N
CN7295N 1978
Large black pad (this pad is pretty good condition, but still going to replace it. This was on top of the other pads)
C016474-22 x2
9316B-4E52 330030 1982
94132B Tandon X2
TMM2016AP-15 (Commodore Floppy drive RAM ??)
The double IC has no label. The soldering of the pin is very professionally done. The other IC with it on the lad is C025953. This chip works with FREDDY. SO I think this might be a prototype of a FREDDY?
Also in the box were about 15 of the items in the clear plastic bag. There is no writing on it and all the sockets are loose in the pin holes. What could this be?
I tried to read the eprom's in my cheapo burner. The small one was readable, mostly “V” and “~” all over. The other two will not read.
I would like to test some of these in a machine. I have an 800 bare. Just the PCB’s all connected not plastics at all. It is my 800 ‘test bench’ system. I also have several 600XL motherboards in both NTSC, and PAL. There good as they are all socketed.
I might be able to read the ROM's if I new what part number to select in my burner. It may not have many of these older chips in it's library. I am new to this area of our hobby.
I also have about the same number of IC’s for ST’s that I can’t ID. But most of those have rusted off pins. But I’ll post that later in the other forum.
  • Like 7
C011299B-03 is definitely 810 Revision B ROM - I recently acquired one as well http://atariage.com/forums/topic/279363-the-atari-810-revision-b-rom-has-finally-been-found-dumped/
94132B Tandon part # matches the stock Roms (Rev L?) I have here on my desk, recently pulled from 1050's to install other upgrades. But mine say 2131, yours are 2124. There are at least 4 known production stock 1050 ROM's though..
The vast majority of these are EPROMS and ROMS.
Covering the windows is a good idea if you keep them out of the box.....I've seen uncovered EPROMs in arcade machines of 30 years without a problem....but very little sunlight comes into closed arcade cabs :) Would't be surprised if most of them are games or other cartridge software.
Kr0tki - That list was Very helpful! Most are 2600 games. But definitely not all.
Here is the updated list with some of the other IC's not shown above. The top list is where I am having the most trouble identifying what they, what they do, or what system they go in. The second list I have found what they are. But some I do not know what they are for. Those are marked with a *. The last list is all the 2600/5200 games. I have put the IC's in numerically organized AS-pads. see pics. There are several eproms. I can read most of them. I could upload the BIN's if someone(s) would like to translate/ID the code. The left side of the pad with the large IC's I already know are ANTIC's, POKY's, GTIS, CTIA, PIA's (PAL & NTSC) The last pads are all ST IC's
12 6 82 COMBO 40 PIN hand written label rusted and or missing pins
9128C-1015 Qual Samples x2 ???
C014512-08 1981 ???
C018969 x7 40 PIN 6507/6532 COMBO Custom rusted and or missing pins
C019901-3 ???
C020231B 128x8 RAM - Sara cart ram
C027734A-07 in range of 800 games
C198623 40 PIN ??? rusted and or missing pins
C69007 ???
CN7292N 1978 ???
CN7293N ???
CN7295N 1978 ???
HM46810P HM6810P ???
ROCK COMBO 1/21/83 x2 40 PIN ??? rusted and or missing pins
STEPHANIE B 11/23/82 40 PIN hand typed lebel rusted and or missing pins
NCR 2332 32K ROM (no uv window)
94132B Tandon X2 1050 IC
Arcadia 1982 Cassette Starpath Supercharger for 2600
C011299B-03 Custom Rom 810 Rev C
C025985 ST/Mega acia 6850 1040ST IC *
C060302A-29 XL Basic "B" ROM 8K x 8
C060617B-01 1982 1200XL os rom rev B
C061598B-08 XL/XE OS
C062024 OS ROM 16K x 8 270PN 600XL
HM6116LP 16K SRAM *
MM74C150J 16 to 1 Multiplexer *
MPP-1100 ROM Micobits ROM Joystick printer interface *
TMM2016AP Commodore floppy drive ram *
TMS4016-45NKL 16K SRAM
C011205-11 x3 Outlaw CX2605
C011206-05 Slot Racers cx2606
C011222-08 1981 X2 Breakout cx2622
C011223-07 Home Run CX2623
C011225-19 x2 Football CX2625
C011227-07 x3 1978 Human Canonball cx2627
C012009-08 1981 defender csx2609
C012016 1980 X2 Championship soccer cx2622
C012045-12 Video Chess CX2645
C012052-10 PROTO 1978 Casino cx2652
C012058-02 Math Grand Prix cx2658
C012058-10 PROTO 1982 Math Grand Prix cx2658
C012512-02 1977 X2 Streeet racer cx2612p
C012608A Super breackout cx2608p
C012610A-02 1981 X2 War Loard CX2610p
C012610A-10 PROTO 1981 x2 War Loard CX2610p
C012645-02 1979 X2 Video Chess CX2645p
C012654-01 1981 x2 Haunted House CX2654p
C016449B-22 1981 Asteroids CX2649
C016474-22 x2 E.T. CX2674
C016484-02 1983 X2 Galaxin CX2684
C019407A-10 Footbal 64K ROM #2 CX5207
  • 7 months later...
