ultima Posted June 24, 2018 Share Posted June 24, 2018 Just had it working (before setting up mame) and it generated the .asm .a78 .bin files but now it won't compile any samples commandline is complaining about not reading png. any thoughts? Quote Link to comment Share on other sites More sharing options...
+SmittyB Posted June 25, 2018 Share Posted June 25, 2018 (edited) Can you show us the exact error? It sounds like the filename or filepath to your graphics may not be correct. Did you move any thing in that process? How do you compile your code, are you running the commands from a different location? Another possibility would be if it's complaining about the format of the graphics or them having too many colours but I couldn't say without seeing the wording it gives you. Also it's worth mentioning that when you import graphics the filename isn't case sensitive but when you refer to it later in your code it is. Edited June 25, 2018 by SmittyB Quote Link to comment Share on other sites More sharing options...
ultima Posted June 25, 2018 Author Share Posted June 25, 2018 it says *** (9): ERROR, couldn't open png file 'face1.png' for reading Compilation failed. C:\7800basic> since then I reinstalled all of it but still get this error, on the working side I ran your homebrew spire of the ancients in mame and it runs fine. Quote Link to comment Share on other sites More sharing options...
+SmittyB Posted June 25, 2018 Share Posted June 25, 2018 Ah, I might be wrong but where C:\7800basic> is your current directory it could be looking at it relative to that folder. Is your face1.png image at that location or is it possible that it's open in another program? I don't think you need to try reinstalling anything, it sounds like your setup is okay besides it not being able to find or otherwise open the file. Quote Link to comment Share on other sites More sharing options...
Mord Posted June 25, 2018 Share Posted June 25, 2018 From the looks of it, I'll assume you copied the simple.bas file to the c:\7800basic folder and tried to compile it there. You'd get the error above if you forgot to also copy the .png file to the same directory. That being the case there's no reason why you should have copied it to that directory. You should be able to move to the C:\7800basic\samples\simple directory and run 7800bas directly in that folder. Does it give you an error when you do that? Quote Link to comment Share on other sites More sharing options...
ultima Posted June 25, 2018 Author Share Posted June 25, 2018 I tried moving the simple.bas file and the face.png into the root (7800basic) and reran the compiler and it produced a -simple.bas.asm -simple.bin but did not make the simple.a78 command prompt: 7800basic 0.6 Jul 12 2017 22:46:35 ***(): INFO, GFX Block #0 starts @ $E000 face1 ***(): INFO, GFX block #0 has 2032 bytes left (254 x 8 bytes) 7800basic compilation complete. User-defined 7800.asm found in current directory '7800filter' is not recognized as an internal or external command, operable program or batch file. C:\7800basic> Quote Link to comment Share on other sites More sharing options...
+SmittyB Posted June 25, 2018 Share Posted June 25, 2018 (edited) Ah, the ol' 7800filter not recognised problem. Your antivirus will have quarantined it, you'll need to restore it and add it as an exception otherwise your antivirus will keep doing this whenever you try to compile. On the plus side it's further than it was so once 7800filter is restored it should work. Edited June 25, 2018 by SmittyB Quote Link to comment Share on other sites More sharing options...
ultima Posted June 25, 2018 Author Share Posted June 25, 2018 From the looks of it, I'll assume you copied the simple.bas file to the c:\7800basic folder and tried to compile it there. You'd get the error above if you forgot to also copy the .png file to the same directory. That being the case there's no reason why you should have copied it to that directory. You should be able to move to the C:\7800basic\samples\simple directory and run 7800bas directly in that folder. Does it give you an error when you do that? Tried that just now it compiled but still no simple.a78 file still complains about 7800filter Quote Link to comment Share on other sites More sharing options...
ultima Posted June 25, 2018 Author Share Posted June 25, 2018 Ah, the ol' 7800filter not recognised problem. Your antivirus will have quarantined it, you'll need to restore it and add it as an exception otherwise your antivirus will keep doing this whenever you try to compile. On the plus side it's further than it was so once 7800filter is restored it should work. BINGO!!! YEAH THAT DID IT!!!! THANKS SMITTYB!!!! Quote Link to comment Share on other sites More sharing options...
+SmittyB Posted June 25, 2018 Share Posted June 25, 2018 No problem, if there's anything worse than being stuck on a problem it's being stuck on a problem that nobody wants to help with. 1 Quote Link to comment Share on other sites More sharing options...
Mord Posted June 25, 2018 Share Posted June 25, 2018 Tried that just now it compiled but still no simple.a78 file still complains about 7800filter Now that the antivirus issue is dealt with, try compiling simple.bas from it's own directory again to see if it compiles this time. (It'll be a lot more convenient on you to make sure you can do that rather than working directly from the 7800basic directory all the time once you're working on your own projects.) 1 Quote Link to comment Share on other sites More sharing options...
