lonesome_pa Posted May 8, 2002 Share Posted May 8, 2002 I just ordered slide and momentary replacement switches for my atari 2600. Is there a place with instructions on how to change them or do I need to have an "experienced" person do it. Is it simple enough for someone as "electronically challenged" as myself can do? Quote Link to comment Share on other sites More sharing options...
Darius Nefarious Posted May 8, 2002 Share Posted May 8, 2002 I need to replace the game select switch, and some other switches are getting old. Where did you find the replacements? Do they look like the original switches? Quote Link to comment Share on other sites More sharing options...
lonesome_pa Posted May 8, 2002 Author Share Posted May 8, 2002 I am ordering them from Best Electronics (www.best-electronics-ca.com). The parts I am ordering are the slide switch (for the on/off) and 2 momentary switches (reset and game select). They go for $2.50 each and I am told that they are exactly the same as the original. I'm just not "electronics gifted" and not really sure how easy or hard they are to put in. I figure that it can't be that difficult. Quote Link to comment Share on other sites More sharing options...
Junie Posted May 8, 2002 Share Posted May 8, 2002 quote: Originally posted by lonesome_pa: I'm just not "electronics gifted" and not really sure how easy or hard they are to put in. I figure that it can't be that difficult. As long as you have the tools and have experince using a Soldering Iron it isn't difficult, I doubt there are instructions on this as you are simply replacing the switches. You will need to take your Atari apart so you can get at the switches on the PCB. De-solder and remove the switches you are replacing. Put in the new switches and solder them in place. If you actually need more help, e-mail me at junies_c@hotpop.com and I will try and help you. Quote Link to comment Share on other sites More sharing options...
lonesome_pa Posted May 8, 2002 Author Share Posted May 8, 2002 Thanks Junie. I'll open my atari and see if I feel comfortable doing it. When I get the switches, I'll keep you in mind. I do have someone at work that is in electronics and I may ask him. Thanks. Quote Link to comment Share on other sites More sharing options...
tbfinley2 Posted May 9, 2002 Share Posted May 9, 2002 The swithes on mine were soldered on both sides of the board.Liked to have never got them off. Just make sure you get a de-soldering tool. Once you get the switches out,Its a peice of cake.web page Quote Link to comment Share on other sites More sharing options...
Junie Posted May 9, 2002 Share Posted May 9, 2002 quote: Originally posted by lonesome_pa: Thanks Junie. I'll open my atari and see if I feel comfortable doing it. When I get the switches, I'll keep you in mind. I do have someone at work that is in electronics and I may ask him. Thanks. Sure, no problem. Glad to see that you do have someone available that can actually help you out "hands-on" if necessary. Let us know how it turns out. Quote Link to comment Share on other sites More sharing options...
bradjewell Posted May 9, 2002 Share Posted May 9, 2002 I actually recently did that myself. I bought a few 2600's and one had a broke switch so I had to replace it with one from another unit. It's an easy procedure, and a perfect one to get your own experience. Not too difficult. Brad Quote Link to comment Share on other sites More sharing options...
