Ranger03 Posted July 18, 2018 Share Posted July 18, 2018 on applewin, the apple II boots into a monitor with the upper screen looking like white static. there are 4 objects blinking: 2$, y6, %7, wd. all flashing white the rest is a cascading wall of @@ signs and question marks is this normal? Quote Link to comment Share on other sites More sharing options...
Osgeld Posted July 18, 2018 Share Posted July 18, 2018 yes for an original II you will see it for a moment on the later machines before the basic rom kicks in Quote Link to comment Share on other sites More sharing options...
Ranger03 Posted July 18, 2018 Author Share Posted July 18, 2018 so, how was basic done? Quote Link to comment Share on other sites More sharing options...
Osgeld Posted July 18, 2018 Share Posted July 18, 2018 (edited) loaded from tape or booted from disk if you want to port your quiz program I would set applewin as an apple II+, there's not much difference tween them other than more ram (and I doubt anyone is rocking the stock ram in a OG][ anyway) basic in rom and some bug fixes Edited July 18, 2018 by Osgeld Quote Link to comment Share on other sites More sharing options...
BassGuitari Posted July 18, 2018 Share Posted July 18, 2018 (edited) on applewin, the apple II boots into a monitor with the upper screen looking like white static. there are 4 objects blinking: 2$, y6, %7, wd. all flashing white the rest is a cascading wall of @@ signs and question marks is this normal? Yep! The gibberish on the screen may vary, but that's the boot screen for an Apple equipped with the original Integer ROM set. Generally that's going to be the original Apple II, but Integer ROM cards were a popular accessory when the auto-booting, Applesoft-equipped Apple II+ came out. so, how was basic done? CTRL-B or CTRL-C. From Apple2.info: "From within the monitor, the easiest ways to get out are either "^B" or "^C" (don't forget to hit <return> at the end of your line), which return you to either Applesoft or Integer Basic. ^B zaps any program and variables in memory, while ^C preserves them..." EDIT: I should add that this applies to Apple II and II+ systems. IIRC with the //e and //c you can use the Reset key, but chances are you're not going to have Integer ROMs with those systems anyway. loaded from tape or booted from disk It's there in ROM. Just gotta jump over to it from the monitor. If you want to use a different version of BASIC (Applesoft vs. Integer), yeah, you can load it from a DOS disk or BASICs disk. Edited July 18, 2018 by BassGuitari Quote Link to comment Share on other sites More sharing options...
Ranger03 Posted July 19, 2018 Author Share Posted July 19, 2018 loaded from tape or booted from disk if you want to port your quiz program I would set applewin as an apple II+, there's not much difference tween them other than more ram (and I doubt anyone is rocking the stock ram in a OG][ anyway) basic in rom and some bug fixes My quiz program is finished. it's for the vic 20, though i may do an updated version Quote Link to comment Share on other sites More sharing options...
Osgeld Posted July 19, 2018 Share Posted July 19, 2018 It's there in ROM. Just gotta jump over to it from the monitor. If you want to use a different version of BASIC (Applesoft vs. Integer), yeah, you can load it from a DOS disk or BASICs disk. Ah thanks, its been a long time since I messed with the OG ][, we had a ][e growing up and even the +'s would irritate me as it would not let me play some games (like when I had to spend the day with my mother in her dental lab class, they had a + in her office and a dec terminal) Quote Link to comment Share on other sites More sharing options...
Osgeld Posted July 19, 2018 Share Posted July 19, 2018 My quiz program is finished. it's for the vic 20, though i may do an updated version sorry, I just assumed that since you had it complete for one system you might be porting it over to another for giggles Quote Link to comment Share on other sites More sharing options...
Ranger03 Posted July 19, 2018 Author Share Posted July 19, 2018 sorry, I just assumed that since you had it complete for one system you might be porting it over to another for giggles Porting is an alien concept to me. unless i have code examples, i cannot do it btw, inkey$ sucks Quote Link to comment Share on other sites More sharing options...
Ranger03 Posted July 19, 2018 Author Share Posted July 19, 2018 tried ctrl-b and c, didn't work Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted July 19, 2018 Share Posted July 19, 2018 At the star prompt, <Ctrl-B><Enter> should give you intbasic's > prompt. Anywho, I don't know about INTBASIC, because I don't use it. Check for key from the keyboard: PEEK(49152)<128 no key pressed. Closest to A$=INKEY$ is GET A$, but on the Apple it does wait for a key, so you'll want the peek(49152) test. Before GET A$, I'll use WAIT 49152,128 if I don't want the cursor to show up. 1 Quote Link to comment Share on other sites More sharing options...
Ranger03 Posted July 19, 2018 Author Share Posted July 19, 2018 I'm considering making a game of chance: here is the code 10 print "roll dice?" 11 input a$ 12 let d=die:let D=RND(D/45):if d<45 then 20 13 print "die cast": if d=45 then 30 20 print "landed on snake, you are poisoned":goto 10 30 print "a cross, you're safe for now" 45 print "dead" (if the die landed on 0, 12 or 15) 50 print "alive, doomed to wander until death (if the die lands on a straight 45 or a cross it then repeats until the user either gets bored or decides to improve the program. relatively basic (sorry for the pun) but about my level. just need a way to separate the good and bad endings. saving throws not yet implemented Apple II/e (btw, how do i save to the hard disk, the emulator hangs when saving manually) Quote Link to comment Share on other sites More sharing options...
Ranger03 Posted July 21, 2018 Author Share Posted July 21, 2018 anyone have an answer? Quote Link to comment Share on other sites More sharing options...
Tommyptr Posted August 6, 2018 Share Posted August 6, 2018 SAVE GAME doesn't work? are you in 80 col mode? Quote Link to comment Share on other sites More sharing options...
Ranger03 Posted August 6, 2018 Author Share Posted August 6, 2018 nope, doesn't work Quote Link to comment Share on other sites More sharing options...
