Ranger03 Posted July 21, 2018 Share Posted July 21, 2018 for some reason whenever i use the RTS command, the emulator hangs indefinitely and it drives me nuts. RTS and BRk are both liable to freeze the emulator and force me to lose whatever progress i've made. any help? i'm running an HP Pavillion laptop 64 bit Quote Link to comment Share on other sites More sharing options...
Tommyptr Posted August 6, 2018 Share Posted August 6, 2018 Are you attempting to BRUN a program you have made. Sometimes a BRUN from applesoft will hang a system indefinitely because the way the output charrecter links with the internal structure. Most professional programs exit their programs in a different manner. I was having trouble with my first versions of Idiot Compiler doing this, so after some research, I now end my programs with JMP 976, which links it back to the Applesoft prompt. If you CALL the location of the program you usually wont have a problem, but if you BRUN the same program, it could hang. Quote Link to comment Share on other sites More sharing options...
