RetroN 77 Community Build Image
remowilliams
1 hour ago, Thomas Jentzsch said:
Quite uninformed, not confused I would say. Here is the changelog since 3.9.3 (which Hyperkin's default image is based on):
  Reveal hidden contents
     SSSS    tt          lll  lll
    SS  SS   tt           ll   ll
    SS     tttttt  eeee   ll   ll   aaaa
     SSSS    tt   ee  ee  ll   ll      aa
        SS   tt   eeeeee  ll   ll   aaaaa  --  "An Atari 2600 VCS Emulator"
    SS  SS   tt   ee      ll   ll  aa  aa
     SSSS     ttt  eeeee llll llll  aaaaa
                              Release History
6.5.3 to 6.6 (November 16, 2021)
  * Added preliminary PlusROM support for saving high scores.
  * Added preliminary support for 'MVC' bankswitching scheme by
    Rob Bairos.
  * Added web links for many games.
  * Added dead zone and linearity settings for analog controllers.
  * Added 'Check for Update' button to Help dialog.
  * Added different mask patterns for scanline emulation.
  * Fixed MindLink controller.
  * Fixed SaveKey not working with QuadTari.
  * Added TIA randomization on startup option.
  * Added different debug color luminances for player and missile copies.
  * Added hotkeys for TV roll speed and toggling 'Developer settings' sets.
  * Debugger: enhanced prompt's auto complete and history.
  * Debugger: added optional logging of breaks and traps.
  * Debugger: added Thumb cycle counting.
6.5.2 to 6.5.3 (April 20, 2021)
  * Added context-sensitive help.
  * Improved support of multiple monitors with different resolutions.
  * Improved analog input reading (Paddles, Keyboards...).
  * Fixed QuadTari support for controller types other than Joysticks.
  * Fixed palette and TV effects saving for Retron77.
  * Fixed immediate disassembling when switching options in debugger.
6.5.1 to 6.5.2 (February 25, 2021)
  * Fixed broken Driving Controller support for Stelladaptor/2600-daptor
    devices.
  * Fixed missing QuadTari option in UI.
  * Improved QuadTari timing.
  * Added CPU usage stats to ARM cart classes debug widgets.
6.5 to 6.5.1 (January 24, 2021)
  * Fixed paddle button bug for jittering controllers.
  * Improved switching between joysticks and paddles on Retron77 port.
  * Improved memory usage on Retron77 port.
6.4 to 6.5 (January 9, 2021)
  * Added high scores saving.
  * Improved text editing functionality (except PromptWidget):
    - Enhanced selection and cut/copy/paste from keyboard.
    - Added undo and redo support.
    - Added mouse support (selection, cut/copy/paste).
    - All actions have keyboard shortcuts.
  * Various improvements to the ROM launcher:
    - Added wildcard support to the dialog filter
    - Added option to search subdirectories
  * Added static tooltips to some UI items.
  * Added dynamic tooltips to most debugger items.
  * Added sound to Time Machine playback.
  * Added browser dialogs for user saved files.
  * Extended global hotkeys for input devices & ports settings.
  * Moved to using an SQLite database for storing user settings, properties
    and highscores.  More work will follow in future releases.
  * Increased sample size for CDFJ+.
  * Fixed autofire bug for trackball controllers.
  * Fixed bug in TV autodetection in filenames; a filename containing
    'PAL' inside a word would sometimes misdetect as a PAL ROM.
  * Fixed Stelladaptor/2600'daptor devices sometimes not being assigned
    correct default mappings.
  * Codebase now uses C++17 features, which means a minimum of gcc7
    or clang5 for Linux/Mac, and Visual Studio 2019 for Windows.
6.3 to 6.4 (November 2, 2020)
  * Added basic (entire and single line only) text cut/copy and paste.
  * Added color parameters to 'Custom' palette.
  * Some improvements to AtariVox-USB adaptor functionality:
    - Made serial port used for an AtariVox-USB adaptor editable.
    - Autodetection of serial ports no longer messes up devices plugged
      into other serial ports.
  * Added CPU load stats to debugger.  Related to this, added debugger
    pseudo-registers '_ftimreadcycles' and '_fwsynccycles' to show the
    number of cycles since the start of frame under certain circumstances
    (see manual for more details).
  * Fixed bug with aspect correction and fullscreen mode; snapshots from
    such a mode are now pixel-exact.
  * Fixed a bug that caused CDF ROMs to crash on the Retron77 and reduced
    ARM emulation performance for CDF ROMs on other platforms.
  * Fixed crash with missing or incorrectly sized SaveKey data file, and
    with certain functions not working (erase pages, erase entire EEPROM).
  * Fixed Atari mouse autodetection.
  * Fixed bug in ROM launcher, with last ROM selected not being remembered
    when exiting and re-entering a directory.
6.2.1 to 6.3 (October 7, 2020)
  * Added adjustable autofire.
  * Added 'Dark' UI theme.
  * Extended global hotkeys for debug options.
  * Added option to playback a game using the Time Machine.
  * Allow taking snapshots from within the Time Machine dialog.
  * Added the ability to access most files that Stella uses from within a
    ZIP file. This includes the following:
      - Per-ROM properties file (so one can distribute a ROM and its
        associated properties).
      - Debugger symbol (.sym) and list (.lst) files, etc.
      - Several others, as we extend the support.
    Basically, you are now able to put many files that Stella uses inside
    one ZIP file, and distribute just that file.
  * Extended AtariVox support to handle flow control, so that long phrases
    are no longer corrupted/cut off.  This includes properly supporting the
    2600-daptor II, which is flashable to an AVox-USB converter.
  * Added auto-detection of the serial port used for an AtariVox-USB adaptor.
  * Added QuadTari controller support.
  * Added option to select the audio device.
  * Added support for CDFJ+ bankswitching type.
  * Further enhanced UA bankswitching to support more Brazilian carts.
  * Added option to display detected settings info when a ROM is loaded.
  * Added another oddball TIA glitch option for delayed background color.
  * Added option to disable aspect ratio correct scaling.
  * Added debugger pseudo-registers '_timwrapread' and '_timwrapwrite',
    which are set when the RIOT timer is read/written on timer wraparound,
    respectively.
  * Bankswitching schemes BUS, DPC+ and CDFx now work when startup bank
    randomization is enabled (these schemes now ignore that setting).
  * Replaced "Re-disassemble" with "Disassemble @ current line" in debugger.
  * Fixed bug when taking fullscreen snapshots; the dimensions were
    sometimes cut off.
6.2.1 to 6.2.2 (August 25, 2020)
  * Fixed a bug in initial controller mapping.
6.2 to 6.2.1: (June 20, 2020)
  * Fixed Pitfall II ROM not working correctly.
  * Fixed crashes when using some combinations of bankswitching schemes on
    incorrect ROMs, or when using invalid ROM file sizes, etc.
  * Fixed RIOT timer behaviour on reading/writing at the wraparound cycle.
  * Fixed incorrectly setting D6 bit on TIA reads in some cases.  Related
    to this, improve 'tiadriven' option to randomize only D5..D0 bits.
  * Fixed custom palette and TV effects adjustable slider rounding issue.
  * Fixed some bugs in 3E+ scheme when using non-standard ROM sizes.
  * Fixed crash in Audio & Video dialog when opened from debugger, and the
    debugger window sometimes being resized when using the Options dialog.
  * Make NTSC custom phase shift not affect Yellow anymore.
  * Fixed '1x' snapshot mode; TV effects are now disabled.  This mode
    now generates a clean, pixel-exact image.
  * Fixed mappings sometimes not being saved in the Retron77 port.
  * A ROM properties file may now be placed next to the ROM (with the same
    name as the ROM, except ending in .pro), and Stella will automatically
    apply the properties to the ROM. [NOTE: this was present in 6.2, but
    was mistakenly left out of the changelog]
  * Added button to Game Info dialog to save properties of the currently
    loaded ROM to a separate properties file (in the default save directory).
    This is useful in conjunction with the previous item.
  * Allow changing custom palette and TV effects adjustables in 1% steps
    again.
  * Updated documentation for changes in ROM properties key names.
  * The codebase now compiles under gcc6 again.  Future versions will
    require gcc7, though.
6.1.2 to 6.2: (June 7, 2020)
  * Added interactive palette to Video & Audio settings.
  * Added 'Custom' palette, generated from user controlled phase shifts.
  * Added that adjustable audio & video settings are displayed as gauge bars.
  * Added four global hotkeys which allow selecting and changing numerous
    audio & video settings without having to remember the dedicated hotkeys.
  * Added 'Turbo' mode, runs the game as fast as the computer allows.
  * Added that paddle centering (per ROM) and sensitivity can be adjusted.
  * Added that mouse sensitivity for Driving controller can be adjusted.
  * Added paddle filtering in UI to avoid unwanted navigation events.
  * Added selectable dialog fonts.
  * Added separate positioning of launcher, emulator and debugger.
  * Added optional display to game refresh rate adaption in fullscreen mode.
  * Added option which lets default ROM path follow launcher navigation.
  * Added debugger 'saveaccess' function, which saves memory access counts to
    a CSV file.
  * Added displaying last write address in the debugger.
  * Added debugger pseudo-register '_scanend', which gives the number of
    scanlines at the end of the last frame.
  * Added detection of color and audio data in DiStella.
  * Restored 'cfg' directory for Distella config files.
  * Added TV Boy and 3EX bank switching types.
  * Removed unused CV+ and DASH bank switching types.
  * Added support for loading grayscale PNG images in the ROM launcher.
6.1.1 to 6.1.2: (April 25, 2020)
  * Fixed bug with remapped events not being reloaded in certain cases.
  * Fixed bug in debugger for 3E scheme when displaying active RAM bank.
  * Fixed bug in "Dragon Defender" ROM being misconfigured for Mindlink
    controller.
6.1 to 6.1.1: (April 4, 2020)
  * Fixed crash in 3E bankswitching scheme when writing to ROM addresses.
  * Fix snapshots on Retina HiDPI displays capturing only the top-left
    corner.
  * Fixed wrong color for BK (background) swatch in the debugger.
  * Fixed 'Right Diff' button in Command menu changing left difficulty
    instead.
  * Fixed compilation of libretro port on Debian Buster.
6.0.2 to 6.1: (March 22, 2020)
  * IMPORTANT NOTES:
    - Because of major event remapping changes, all remappings will be reset
      to defaults; if you had custom mappings, they will need to be
      re-entered again.
    - Because of major internal changes, all state files are now invalid.
    - Support for Windows XP has been discontinued as of this version.  WinXP
      is now completely out of support from Microsoft, so we are doing the
      same.
  * Major improvements to display mode handling in NTSC vs. PAL.  The window
    is now the same size for both modes, and scaling is applied to simulate
    the height of scanlines (in PAL mode, there are more scanlines and hence
    each is narrower).  This more properly emulates how the display would look
    on a real TV.
  * Removed the 'Display_Height' property, changing it to 'Display_VCenter'.
    This new feature, along with the display mode changes above, almost
    completely eliminate having to manually tweak each ROM so that it will
    not have part of the image cut off.
  * Removed the 'Display_YStart' property and all automatic detection of
    ystart.  It caused problems on some ROMs, and was not the way a real
    console would work anyway.  Related to this, ROMs now load much faster.
  * Major improvements to event remapping:
    - Allow mapping of modifier-key and button-direction combinations
    - Physical controllers can map the same action to different events on
      different virtual controllers
    - Many more events can be remapped
    - Events can be filtered by type in UI
  * Paths have been simplified:
    - The following file/directory locations are no longer configurable
      (statedir, nvramdir, cheatfile, palettefile, propsfile); they are
      now all under the base directory
    - Removed cfgdir; Distella config files are now placed with their
      associated ROMs
    - Added 'basedir' commandline argument, which allows to change the
      base directory where almost all config-related items are stored;
      related to this, discontinued the 'basedir.txt' functionality
    - Added 'baseinappdir' commandline argument, which sets the base
      directory to the application folder (Windows only for now); this
      replaces the functionality of 'basedir.txt'
  * Added automatic controller detection.
  * Controllers can be changed during emulation (no ROM reload required
    anymore).
  * Added support for Light Gun controller.
  * Added limited KidVid support (8, 9 and 0 start the games).
  * Removed superfluous controller option 'PADDLES_IDIR'.
  * Added configurable paddle dejittering.
  * Key-repeat mode improved; entering Time Machine by holding down a key
    combo continues to send events (previously, you had to release and then
    press the combo again).
  * Certain buttons in the UI can now be activated repeatedly by holding
    down the mouse button (Time Machine, debugger step/trace/frame advance,
    etc.)
  * Added option to configure mouse double click speed.
  * Added option to configure controller input repeat speed.
  * Added high quality scaling.
  * Made scanlines better aligned to scaling.
  * Added 'HiDPI' mode, which scales the UI by 2x when enabled.  This is
    meant for 4k and above monitors, but can actually be used at any
    lower resolution that is large enough to display the scaled UI.
  * Fixed TIA 'Center' option, Stella now remembers the last windowed position.
  * Added fractional (25% increments) TIA zooms.
  * Removed 'tia.fsfill' option, replacing it with 'tia.fs_stretch'.  This
    new option allows to preserve TIA image aspect ratio in fullscreen
    mode, or stretch to fill the entire screen.
  * Added configurable 'Overscan' option for fullscreen modes.
  * Fullscreen TIA modes no longer assume that desktop taskbars, etc
    are present, hence they are scaled to the proper fullscreen size.
  * Added option to display dialogs in screen corners.
  * Added hotkey for sound on/off.
  * Enhanced 'Command' menu to display current state and more commands.
  * Added option to save and load all TimeMachine states at once.
  * Added option to automatically load/save states when entering/exiting
    emulation.
  * Added option to change pitch of Pitfall II music.
  * ROM Info Viewer size is not limited to fixed zoom steps anymore.
  * ROM Info Viewer can now display multiple lines per property and the
    bank switching type.
  * In file listings, you can now select directories by holding 'Shift' on
    the first character entered.  Entering characters in lowercase still
    selects files, as before.
  * Fixed bug when starting ROMs via MacOS finder.
  * Added various developer options for oddball TIAs:
    - stuffed player, missiles and ball move
    - delayed playfield bits and color
    - delayed players and ball VDEL swap
  * Disabled some developer options for 'Player settings'.
  * Writes to RAM read ports are ignored now.
  * Added Developer setting, which breaks on writes to read ports.
  * Improved breakpoints to now consider the banks.
  * Improved debugger's TIA display and zoom windows.
  * Improved hotkeys, now many emulation keys work in debugger too.
  * Fixed display of negative values in debugger; sometimes they were
    shown as positive.
  * Reworked ROM properties database, making it load faster in certain cases.
  * Updated internal ROM properties database to ROM-Hunter version 16
    (thanks go to RomHunter for his tireless research in this area).
    Related to this, updated the snapshot collection.
  * Fixed 'Dancing Plate (Unknown) (PAL)' to use joystick.
  * Fixed cheatcode handling in 2K and 4K ROMs.
  * Fixed bug where ROMs smaller than 64 bytes were not recognized.
  * Fixed bug where frying one ROM was continued with the next ROM.
  * Fixed not working 7800 pause key.
  * Enhanced UA bankswitching to support certain Brazilian carts.
  * Fixed WD bankswitching.
  * Added FC bankswitching for Amiga's Power Play Arcade Video Game Album.
  * Added auto-detection of display format based on filename.
  * Auto-detection of bankswitch scheme by file extension now includes
    more human-readable formats (not restricted to DOS 3-char length).
    See the documentation for the new names.
  * Fixed bug in DPC+ scheme; 'fast fetch mode' was enabled at startup,
    when it should be disabled by default.
  * Some more work on DPC+ playfield 'jitter' effect for certain older DPC+
    driver versions; more ROMs are now detected properly.  Special thanks
    to SpiceWare for his research in this area.
  * Added proper Retron77 port.
  * Added proper libretro port, and fixed display for OpenGLES renderers.
  * PNG/ZIP image support is now conditionally compiled into Stella.
    All major ports (Linux/macOS/Windows) have it enabled by default.
  * SDL/GUI support is now conditionally compiled into Stella.  All major
    ports (Linux/macOS/Windows) have it enabled by default.  This is
    currently needed by the libretro port.
  * Updated included PNG library to latest stable version.
  * Updated UNIX configure script to work with the gcc version 10 and
    above.
6.0.1 to 6.0.2: (October 11, 2019)
  * Updated properties database for Pink Panther ROM.
6.0 to 6.0.1: (June 5, 2019)
  * Added support for CDFJ bankswitching type (Galaga, Wizard of War, etc).
  * Allow the DPC+ scheme to not enable playfield 'jitter' effect for
    certain older DPC+ driver versions; this allows 'Epic Adventure' ROM
    to finally work in Stella.
5.1.3 to 6.0: (December 23, 2018)
  * Note: because of major TIA sound changes, the state file format has
          changed, and old state files will not work with this release.
  * New cycle exact audio core based on work by Chris Brenner (crispy);
    greatly improved audio emulation accuracy (i.e. E.T., Ms. Pacman).
  * Full rewrite of the audio subsystem; resample TIA output to target
    sample rate directly in Stella.
  * Added option to force stereo sound for all ROMs, or to use the
    setting on a per-ROM basis.
  * Threading: decouple emulation from frame rendering.
  * Main loop rewritten; emulating speed and timing is now much more
    faithful (i.e. speed in Pick'n'Pile).
  * Added preliminary support for 'CTY' bankswitching scheme and recently
    released 'Chetiry' ROMs.  Special thanks to SpiceWare for adding music
    support to this scheme.
  * UI modernization (new widget look, dialog titles added, dialogs
    refactored).
  * The bankswitch scheme can now be forced by naming the ROM with a
    specific extension (ie: .f8s for F8SC, .fe for FE, etc).  The
    supported extensions are the same as the ones from HarmonyCart and
    UnoCart.
  * Audio settings replaced with new 'audio.xxx' settings.
  * FPS setting replaced with speed setting for adjusting emulation speed.
  * Extra functionality for Time Machine dialog (start/stop recording;
    minor fixes).
  * When logging messages to the System Logger, condense similar messages
    that arrive in batches into fewer messages (including timestamps).
  * Fixes for collision corner cases (during HBlank).
  * Fixed excessive CPU usage while in UI modes (ROM launcher, debugger,
    etc).
  * The 'launcherexts' option has been replaced by a true/false option
    named 'launcherroms', which specifies to show only ROMs or all files
  * Changes in 'Game Properties' dialog
    - 'Default' button now affects only current tab like in all other
      dialogs.
    - 'Display' and 'Console' tab changes are now immediate.
    - Fixed bug when selecting 'Auto-detect' format for 50Hz ROMs
  * Fixed bug in autodetecting Genesis controllers.
  * Fixed bug with 'thumb.trapfatal' commandline argument; sometimes Stella
    would lock up when encountering a fatal error instead of entering the
    debugger and displaying a message.
  * Fixed bug in reading from settings file with entries that were empty;
    the parsing was failing.  This affected the 'cpurandom' argument; when
    all options in it were turned off, they were all turned on again during
    the next program run.
  * Fixed bug with 'hold' events; they are now released a short time after
    starting a ROM.
  * When starting Stella for the first time, the first ROM selected will
    determine which path to use by default for subsequent runs.
  * Fixed emulator crash when starting SaveKey ROMs from commandline with
    SaveKey messages enabled.
  * Fixed missing TV format update in frame stats dialog when switching
    display type.
  * Fixed missing debug color update when switching display type.
  * 'Fill to scanline' now works for scanlines above current scanline too.
  * The debugger 'uhex' command is now honoured in CDF and BUS schemes.
  * When switching screenmodes, the sound is now paused and later resumed.
    This fixes popping and cracking sounds apparent on some systems, notably
    OSX when toggling windowed/fullscreen mode.
  * State file format has been optimized to be smaller, and faster loading
    and saving.  This affects both the files saved to your computer as well
    as Time Machine functionality.
  * The ROM name saved in a PNG tEXt chunk now honours the 'snapname'
    setting.
  * Improved snapshots when phosphor is enabled.
  * Updated PAL palette.
  * Added 'Cartridge.StartBank' ROM property, to force a ROM to use a
    specific bank for its reset vector.
  * Added Developer setting, which breaks on reads from write ports.  It
    now detects such conditions in many more cases.  This new way of
    detecting RWP errors obsoletes the old '_rwport' debugger command,
    which has now been removed.
  * Added recently released 'Arkyology' prototype ROM to the database.
  * Added 'Amoeba Jump' and 'Flappy' ROMs (from the Retron77) to the
    database.
  * Fixed 'Street Racer' and 'Video Olympics' ROMs to use paddles in both
    ports.
  * If using SDL 2.0.5 or above, the calculated desktop size now takes
    the taskbar/dock into account (so windows should no longer overlap
    those areas).
  * For UNIX systems: in the ROM launcher, when using symlinks use the
    symlink pathname instead of the underlying filesystem pathname.
  * The UNIX builds now use the system-installed PNG and ZLIB libraries
    by default.
  * The Macintosh builds are now named 'macOS' throughout the codebase to
    reflect the new naming from Apple.
  * For better compatibility, the Windows 32-bit version does not require
    SSE2 anymore.
5.1.2 to 5.1.3: (June 10, 2018)
  * Fixed crash in OpenBSD when quitting the app, which can also be
    happening on other systems (no reports yet, but the problem is now
    fixed for good).
  * Fixed configure/build scripts to work natively under OpenBSD.
5.1.1 to 5.1.2: (May 20, 2018)
  * Fixed bug with SaveKey autodetection; some ROMs were not correctly
    detecting that a virtual SaveKey device was plugged in.  This notably
    fixes issues in "Super Cobra" and "Scramble" ROMs.
  * Make previously mentioned ROMs use the SaveKey device by default.
  * Fixed bug in UI navigation with joystick hat movement.
5.1 to 5.1.1: (February 21, 2018)
  * Fixed bug in Stargunner ROM starting with a blank screen.
5.0.2 to 5.1: (February 4, 2018)
  * Added "Time Machine" mode, which automatically creates save states
    in user-defined intervals.  The user can navigate back and forth within
    these states inside the emulator and the debugger.
  * Huge improvements to the disassembly view in the debugger and
    disassembly files created:
    - reformatting in debugger for better space utilization
    - much improved code and data detection
    - access tracking and indicators for TIA/IO/RAM adresses in disassembly
    - break vector is tracked (if used)
    - improved cycle count (page penalties, sums created in disassembly)
    - improved handling of instruction masking opcodes (e.g. BIT)
  * Fixed change tracking bug during rewind; changes were accumulated
    instead of being displayed only for the last rewind step.
  * Extended 'rewind' to take a second parameter which allows rewinding
    multiple states.
  * Added 'unwind' command, which undoes the latest rewind(s)
  * Added '<' (unwind) button to debugger.
  * Thumbulator support is not conditional any more.
  * Moved various developer related settings in new Developer Settings
    dialog. These settings now come in two groups (player/developer) and
    allow switching all settings at once.
  * Don't trap write accesses to the datastream pointers in CDF and BUS.
    This fixes -dev.thumb.trapfatal 1.
  * Complete rework of TV mode and ystart autodetection. The new
    implementation is more robust and reduces startup time.
  * Add two "grace lines" of black to the top of the frame when
    autodetecting ystart.
  * Fixed Genesis controller autodetect (Stay Frosty 2, Scramble, etc).
  * Fixed a bug in ystart autodetection that could cause screen jumps.
  * Fixed several bugs in holdselect, holdreset and holdjoyX commandline
    arguments; these now work as expected.
  * Fixed bug in TIA collision handling; it is now disabled in VBlank.
  * Improve TIA PF collision handling during hblank; this fixes a bug in
    Thrust ROM.
  * Fixed wrong display of HM values in debugger after 'HMCLR' has been
    executed.
  * Fixed bug with the debugger 'savedis' command in Windows; it wasn't
    actually saving the files at all.  This has never been reported
    before, so I guess it shows how many people use that functionality.
  * The debugger 'savedis', 'saverom' and 'saveses' now save files in
    a default, user-visible directory (see the documentation for more
    information).  In the case of 'saveses', the filename is now named
    based on the date and time of when the command was entered.
  * Fixed bug with saving snapshots in 1x mode; there was graphical
    corruption in some cases.  Such snapshots also now include any TV
    effects / phosphor blending currently in use.
  * Fixed regular-sized snapshots when phosphor effect was enabled;
    sometimes the image was 'double-blended', resulting in a snapshot that
    was too dark.
  * Fixed crash when selecting 'CompuMate' as a controller type for a non-
    CompuMate ROM; this controller type can no longer be manually
    selected, and will be used automatically used for CompuMate ROMs.
  * Fixed cheat codes, so 7 digits codes are now accepted as described in
    the doc.
  * Fixed swapped ports being displayed wrong in System Logs and debugger.
  * Added options to erase the AtariVox/Savekey flash memory, either for
    all ROMs or only the current one.  Also added a message (configurable)
    when the flash memory is accessed.
  * Access to the AtariVox/SaveKey can be signaled with a message.
  * Added new interface palette 'Light'.
  * Frame stats display made transparent. Also it now displays the real
    frame rate and if the developer settings group is enabled.
  * Improved tab auto-complete in debugger.
  * Added conditional traps and savestate creation to debugger.
  * Added 'Options...' button to debugger which gives access to the options
    menu during debugging.
  * Added debugger pseudo-register '_cyclesLo' and '_cyclesHi', which give
    the number of CPU cycles that have occurred since emulation started.
  * Added debugger pseudo-register '_fcycles', which gives the number of
    CPU cycles that have occurred since the frame started.
  * Added debugger pseudo-register '_icycles', which gives the number of
    CPU cycles of the last instruction.
  * Extended debugger 'dump' command to take a second argument, indicating
    the end of the range to dump data.
  * Improved change tracking; more values are tracked and change tracking
    now works in case of a break too.
  * Added widgets for trackball and SaveKey/AtariVox controllers.
  * Improved emulation of 'FE' bankswitch scheme (no user-visible changes,
    but internally the emulation is much more accurate compared to the
    real thing).  Related to this, improved the debugger support for this
    scheme (you can now switch banks in the debugger view).
  * Added emulation of 7800 initial RAM values and Pause key.
  * Added ROM properties for 'Scramble' ROMs, and updated info for all
    "Champ Games" ROMs.
  * Added ROM properties for 'Zippy the Porcupine' ROMs, and updated
    info for all "Chris Spry (Sprybug)" ROMs.
  * Support UNIX style builds (configure / make) on OSX with both
    XCode / clang and g++.
  * Fixed error when building with uClibc-ng for ARM (thanks to Sergio
    Prado).
5.0.1 to 5.0.2: (August 20, 2017)
  * Improved emulation of Trakball controller, eliminating bias in left/
    right directions.  Thanks to Thomas Jentzsch for the idea and code.
    Related to this, added 'tsense' commandline argument and associated
    UI item, to allow changing sensitivity of mouse trackball emulation.
  * Added preliminary support for multi-threading in the Blargg TV effects
    code.  This is still a WIP; more improvements are coming.  Related to
    this, further optimized the TIA rendering code.  Also added 'threads'
    commandline argument and associated UI item to enable/disable
    multi-threading.  Thanks to Thomas Jentzsch for the bulk of the work
    in this area.
  * Blargg TV effects now no longer cut off the right side of the image
    (by several pixels) in certain cases.
  * Updated CDF scheme to latest version from Spiceware.  In addition,
    this scheme now supports versioning, so older and newer ROMs will
    continue to work.
  * Fixed an annoying bug in Linux, where Alt-Tab'ing out of a window and
    then back again would pass a 'Tab' key event to the app, which in
    most cases would navigate to the next UI element.
  * Fixed potential issue with state file saving and the debugger; under
    certain circumstances a rewind would give a different state than
    before (note that the state file format has changed because of this).
  * Fixed lockups when entering the debugger under certain circumstances.
  * The debugger 'listtraps' command now shows all traps set, not just
    the first one(s).
  * Reverted joystick changes for Decathlon ROMs from last release, as
    it was added by mistake.
5.0 to 5.0.1: (July 23, 2017)
  * Fixed issues in keypad, Genesis and various other controllers that use
    INPTx registers; the emulation is now much more accurate in this area.
  * Various 'Bumper Bash' and 'Decathlon' ROMs are marked as always having
    all 4 directions on a joystick enabled, since they can't be played
    properly otherwise.
  * Added 'Hunchy II' from Chris Walton (cd-w) to ROM properties database.
  * Codebase now uses C++14 features.
4.7.3 to 5.0: (July 16, 2017)
  * Note: because of major TIA/6502/RIOT changes, the state file format
          has changed, and old state files will not work with this release.
  * Stella has moved from Sourceforge to Github.
  * Completely new TIA core is now available, ported from 6502ts by
    Christian Speckner (DirtyHairy). This new core is extremely accurate,
    and matches real hardware in almost every test we've performed.
    New features include:
     - Meltdown emulates correct
     - The lap number in Pole Positions displays correctly
     - Artifacts in the mountains on Snoopy and the Red baron are gone
     - Line artifacts in Title Match Pro Wrestling and Realsports Boxing
       are fixed
     - The spurious line at the left border of Video Chess now displays
       correctly
     - All 32 char text demos from AtariAge now work perfectly (Stella 4
       shows artifacts on several of these)
     - Stella is now the only emulator to display the "Mega Bitmap Demo"
       (atext.bin) from AtariAge correctly
     - Improved starfield effect for missiles (still TODO for ball and
       players)
     - RSYNC emulation has improved, all testcases now match real
       hardware
     - Several other ROMs that have never worked in any emulator are now
       emulated correctly
     - RDY behavior with respect to write cycles is accurate
     - Optional YStart autodetect and more robust frame handling
     - NUSIZ during player draw matches hardware
     - RESMx during missile draw matches hardware
     - Paddle emulation is slightly more accurate. As a consequence, the
       "paddle feel" may be slightly different from Stella 4
     - Fixed debug colors can now be set for each graphical object, from
       a choice of 'red', 'orange', 'yellow', 'green', 'blue' and
       'purple'.  This is accessible through the new 'tia.dbgcolors'
       commandline argument and within the UI.
  * Implemented new phosphor emulation mode, which is much closer to real
    TV output.  Related to this, added ability to change the default
    phosphor blend level in the UI and through the new 'tv.phosblend'
    commandline argument.  Special thanks to Thomas Jentzsch for the idea
    and implementation.
  * TV phosphor effect can now be force-enabled for all ROMs, instead
    of manually setting ROM properties for each ROM.  This is accessible
    in the UI and through the 'tv.phosphor' commandline argument, and
    defaults to being off (or enabled per-ROM).
  * PAL color-loss and Blargg TV effects can now be enabled at the same
    time.  Previously, when Blargg effects were enabled, PAL color-loss
    couldn't be shown.  Related to this, the Blargg effects now use much
    less memory and in some cases run faster than before.
  * Much improved RIOT timer emulation never before seen in any emulator.
    Special thanks to Christian Speckner (DirtyHairy) for the
    implementation, and alex_79 for finding documentation that finally
    describes in more detail how the M6532 chip actually works.
  * Added BUS (experimental) and CDF bankswitching schemes, and also
    ARM Timer 1 support; special thanks to SpiceWare for the code.
  * Fixed bug with SaveKey and AtariVox not properly closing their memory
    files before starting another instance of the same ROM, when the ROM
    was opened in the ROM launcher.
  * Various improvements to the debugger and command prompt:
    - The 'cls' command now only clears the screen, not the history
    - The 'help' command now accepts other commands, and gives extra
      information about the command (ie, 'help breakif' prints extended
      information about the breakif command)
    - Added 'palette' command, which shows a color swatch of the
      currently active TIA palette
    - Added 'debugcolors' command, which shows a legend for 'fixed debug
      colors' mode
    - The previous trap'm' commands now work when setting TIA read
      addresses; previously they only worked for write addresses
    - The previous trap'm' commands are now renamed 'trap', 'trapread'
      and 'trapwrite'
    - The TIA tab now shows 'old' contents of player and ball registers
    - Various UI items are crossed out when disabled, to more clearly
      indicate their current state
    - Various UI items that previously required a double-click to toggle
      (pixel and bit widgets) now require only a single-click.
    - Command completion now works with internal functions and pseudo-ops
      (basically, anything starting with the '_' character)
    - System labels (aka, register names, etc) can now be typed in lower-
      case.  Previously, these labels always had to be uppercase.
    - In general, input error checking is much more strictly enforced
    - Read-only UI items now have a different background color, to
      clearly indicate if an item can be modified.
    - Debugger '.lst' and '.sym' files are now searched based on the name
      of the ROM file, and not on the internal properties name.
    - Snapshots can now be saved by pressing the F12 key (the various
      other ways to save snapshots still exist).
  * Mouse grabbing is now enabled in windowed mode only when the ROM is
    using a virtual analog controller (paddles, trakball, etc).
  * Renamed various trakball-like controllers more accurately: AmigaMouse,
    AtariMouse (previously CX80) and Trakball (previously CX22).  Related
    to this, reduced the resolution of the Trakball by half, to properly
    match real hardware.
  * The stack pointer (SP) is now initialized to $FD instead of $FF, to
    match research done in other 6502 projects.
  * Fixed bug in debugger tracing and displaying the partial TIA image;
    the first time entering the debugger and starting to trace, the image
    was blanked out (black) instead of being drawn in greyscale.  Also, the
    image is now synchronized, instead of being two frames behind.
  * Fixed crash with zipped ROMs that are less than 4K in size; so far
    this bug has only ever occurred in Windows XP, but it's been there
    since Stella 4.1.
  * Fixed bug in 'Rom Audit' functionality; sometimes ROMs without a
    valid properties entry were being renamed as "Untitled.bin".
  * For the entire UI, removed colons and generally made the UI items
    easier to read.
  * When in 'ROM launcher mode', Stella now uses slightly less CPU time.
    More work is required in this area, though.
  * Added ROM properties for D.K. VCS homebrew ROM, thanks to Andreas
    Dietrich.
  * Added slight improvement for auto-detecting Superchip bankswitching;
    the new implementation now works for the NTSC 'Dig Dug' ROM.  Special
    thanks for SpiceWare for the idea and modified implementation.
  * Fixed long-standing bug in 3-voice music in DPC+ bankswitching scheme;
    the music now sounds much more like the real thing.
  * For the Linux/UNIX port:
    - The settings directory now uses the XDG Base Directory Specification.
      In most cases, this means that your files will now be stored in
      '~/.config/stella' instead of '~/.stella'.  To keep your old settings,
      run the following commands from the terminal:
        cd ~
        mv .stella .config/stella
      You will probably need to edit '~/.config/stella/stellarc' and change
      some paths accordingly.
  * For the OSX port:
    - Always use the built-in png and zlib libraries instead of the system
      versions.
    - The preferences file has changed from 'net.sourceforge.Stella.plist'
      to 'Stella-emu.plist'.  To keep your old settings, run the following
        cd ~/Library/Preferences
        mv net.sourceforge.Stella.plist Stella-emu.plist
  * Updated internal ROM properties database to ROM-Hunter version 13
  * Updated included PNG and ZLIB libraries to latest stable version.  Also,
    both libraries are now compiled into the app whenever one is selected.
    This fixes issues with a newer ZLIB not working with an older PNG, etc.
  * Updated build scripts for Visual Studio 2017 (Windows) and MacOS
    Sierra (latest version of Xcode), and make these the minimum supported
    versions for building Stella.
  * Updated UNIX configure script to work with the clang 5+ and gcc 7+
    compiler versions, and fixed compile issues on AArch64 and ppc64le
    architectures.
4.7.2 to 4.7.3: (Nov. 21, 2016)
  * Added preliminary support for the 3E+ bankswitching scheme, developed
    by Thomas Jentzsch.
  * Fixed HMOVE positioning bug that occurred under certain circumstances.
    Thanks to Omegamatrix of AtariAge for the bug report and patch to fix
    the issue.
  * Added 'trapm', 'trapreadm', 'trapwritem' commands to debugger prompt.
    These are similar to the non-'m' versions, except that they also trap
    on all mirrors of the given address.
  * Fixed bug in debugger 'reset' command; it wasn't resetting the
    bankswitching, so after a reset the banks were in an undefined state.
  * Updated UNIX configure script to fix a bug where it fails in
    cross-compilation under certain circumstances.  Thanks to Vlad
    Zakharov for providing a patch to fix this issue.
4.7.1 to 4.7.2: (Mar. 25, 2016)
  * Fixed bug when entering and exiting the debugger; sometimes the
    character corresponding to the '`' key would be output in the
    prompt area.
  * Updated DPC+ Thumb ARM emulation code to latest from David Welch.
    In particular, this fixes incorrect handling of the V flag when
    adding and subtracting, but also fixes compile-time warnings that
    I couldn't get rid of before.
  * Updated UNIX configure script to work with GCC 6.x compilers, and to
    remove references to obsolete compiler versions that can no longer
    be used to compile Stella.
4.7 to 4.7.1: (Feb. 13, 2016)
  * Improved TV 'jitter' emulation; the recovery time can now be spread
    over multiple frame, to simulate a real TV taking multiple frames to
    recover.  Related to this, added new commandline argument
    'tv.jitter_recovery' to set the recovery time.  Finally, enabling
    the jitter effect and the recovery time are now accessible through
    the UI.  Special thanks to SpiceWare of AtariAge for the initial idea
    and implementation.
  * Fixed bug with 'Medieval Mayhem' ROMs; the paddle range was set too
    low, and as a result the number of players couldn't be selected.
  * Fixed bug when using more than two input controllers with the same
    name; each controller after the second one was named the same as the
    second one.  This caused the joystick mappings to be lost, since there
    was only information about two controllers being saved.
  * Indirectly fixed issues with Stelladaptor/2600-daptor devices and
    paddles having too large of a deadzone in Linux.  Currently, this
    involves running an external application to set the deadzone,
    since SDL2 does not yet expose this information.  The program is
    called 'evdev-joystick', and will be released separately from Stella.
  * Updated internal ROM properties database to ROM-Hunter version 11
4.6.7 to 4.7: (January 25, 2016)
  * Improved paddle emulation in several ways:
    - Added ability to specify the maximum range of movement for paddles
      when using a mouse or digital device to emulate the paddle.  This is
      useful since on a real console most paddle games use very little of
      the paddle range, and could result in moving the mouse onscreen with
      nothing appearing to happen (when in effect it was as if you turned
      a real paddle all the way to the end of the range).  This eliminates
      issues in (for example) Kaboom, where there was a huge 'deadzone'
      when moving to the left.  All applicable ROMS in the internal
      database have been updated.
    - The range for paddle emulation now takes an integer from 1 - 20,
      indicating how much to scale movement (ie, how fast the onscreen
      paddle will move when you move the mouse).  The movement itself
      is now also smoother than before.
  * Fixed bug in 'Score mode' in TIA emulation; the TIA object colours
    were correct, but the associated priority was sometimes incorrect.
  * Fixed bug in ROM launcher; selecting 'Options -> Game Properties' after
    loading a ROM would always point to the last opened ROM, not to the one
    currently selected.
  * Fixed bug in storing ROM properties; in some cases, a copy of the
    ROM properties was being stored in the external file when it was
    exactly the same as the internal entry.
  * Added 'CV+' bankswitching scheme, developed by myself and LS_Dracon
    (of AtariAge).  This scheme contains RAM like the CV scheme, and
    also switchable 2K ROM segments by writing to $3D.
  * Added more C++11 updates all over the codebase, and ran Stella
    through Coverity for the first time.  I'm proud to say that Stella
    now has a 0.00 defect rate!
4.6.6 to 4.6.7: (October 28, 2015)
  * Fixed bug when using real paddles plugged into a Stelladaptor
    2600-daptor device; the movement was very erratic.
  * Fixed small logic error in 'MDM' bankswitching scheme.
4.6.5 to 4.6.6: (October 11, 2015)
  * Added 'Alt/Cmd + j' shortcut key and 'tv.jitter' commandline argument
    to toggle the TV scanline jittering emulation added in the last
    release.  Also, this jittering now defaults to off.
  * Fixed bug in 'MDM' bankswitch scheme; bankswitching wasn't being
    done under certain circumstances.
4.6.1 to 4.6.5: (September 26, 2015)
  * Added mappable events for toggling TV color/BW, left difficulty A/B
    and right difficulty A/B.  This means that one key, joystick button,
    etc. can be used to toggle each event.  Thanks to Buzbard of AtariAge
    for the suggestion.
  * Added ability to edit values in more widgets in the debugger.  For
    now, this applies mainly to the various decimal and binary fields.
    More widgets will be made editable in future releases.
  * The TIA now emulates the jitter that occurs when scanline counts
    are not consistent frame-over-frame.  Also, the DPC+ scheme now
    emulates jitter that can occur when using its Fractional Datafetchers
    if the DFxFRACINC registers are not re-initialized every frame.
    Special thanks to SpiceWare for this implementation.
  * Tweaked 'MDM' scheme autodetection to detect that the identification
    string can be in either bank 0 or bank 1.
  * Changed 'hidecursor' commandline argument (and associated UI item) to
    'cursor'.  The new argument allows to set mouse cursor visibility
    separately for both UI and emulation modes.
  * Fixed snapshot bug most noticeable in MacOSX, where taking a snapshot
    of a TIA image sometimes left parts of the UI onscreen (and in the
    resulting picture).
  * Fixed memory leak; the game console wasn't being closed after exiting
    a ROM.
  * For the Windows port: added an application icon for Stella in the
    Control Panel "Add/Remove Programs" list.
  * For the OSX port: Updated build scripts to be compatible with Xcode 7.
4.6 to 4.6.1: (April 22, 2015)
  * Fixed bug whereby text input could not be entered in certain widgets
    in the debugger.
  * Updated UNIX configure script to work with GCC 5.x compilers.
4.5 to 4.6: (March 21, 2015)
  * Finally fixed fullscreen rendering issues on some OpenGL
    implementations in Linux (mostly Intel-specific).  Basically, the
    concept of 'dirty updates' has been removed; the window is now
    updated continuously.  This may also fix issues some people were
    having with triple-buffering in Windows Direct3D, etc.
  * Fixed sound corruption that happened when running a ROM for the
    first time.  This was most obvious under OSX, but occasionally
    happened on other systems too.
  * Reverted some minor C++11 features (std::regex and cbegin/cend
    iterators) in a few places, since otherwise GCC 4.9 is required to
    compile Stella, and it isn't available on many systems yet.  These
    changes allow Stella to be built with GCC 4.8, which is present in
    the latest 'long term release' of Ubuntu.
  * Fixed error messages on state loading; sometimes multiple messages
    were being added together and displayed.
  * Fixed bug when running ROMs using AtariVox controllers; the app would
    crash upon exiting the ROM.
  * Snapshot functionality now works while the emulation is paused.
  * Certain textfields in the UI now have filtering enabled, preventing
    insertion of illegal characters.  This will be extended throughout
    the code in future releases.
  * DataGridWidgets in the debugger now respond to keypad '+' and '-'.
4.2 to 4.5: (January 1, 2015)
  * The conversion to C++11 has begun :)  From this point on, to build
    Stella you will need a C++11 compatible compiler (Visual Studio 2013,
    Clang 3.3, gcc 4.9, Xcode 6, etc).  Eventually, this will bring more
    bug-free and (hopefully) faster code.
  * Fixed major bug with joysticks, where mapping was being lost on reset,
    the app would crash when plugging/unplugging certain sticks, etc.
  * Fixed major (but rare) crash that could occur when state files were
    zero'ed or corrupted.
  * Added dialog which shows the internal joystick database (all the
    joysticks that Stella knows about) and the ability to remove
    (currently unplugged) joysticks from this database.
  * Added preliminary support for 'WD' (Wickstead Design) bankswitching
    scheme, used for a previously unreleased prototype ROM.
  * Improved ZIP file handling, so that it now works as a normal
    filesystem does (it properly shows nested files and directories).
  * The debugger 'reset' command now does a complete system reset,
    instead of simply setting the PC to the reset vector address.
  * The 'listdelay' command now accepts a value of zero, indicating that
    list-skipping (jumping to a line in a list by keypress) is disabled.
  * The 'ctrlcombo' command now has a GUI item, allowing it to be changed
    from within the application.
  * Added 'Shift-Alt/Shift-Cmd s' keyboard shortcut, to enable continuous
    snapshot mode for each frame.  This is really only useful if you
    save snapshots in 1x mode; using it in high-resolution mode is
    not recommended.  Special thanks to SvOlli for the idea and code.
  * The minimum supported version for the OSX port is now OSX 10.7.
    Because of this, the 32-bit version is also discontinued, as 10.7
    supports 64-bit Intel only apps.
  * Updated internal ROM properties database to ROM-Hunter version 10
4.1.1 to 4.2: (October 28, 2014)
  * Text input from non-US keyboard layouts is now supported.  Note that
    all text in Stella is still ASCII-only, but at least it can now be
    entered using a native layout.
  * Related to the text input changes, the debugger Alt-combo shortcuts
    have been changed; they now use the same key but with Control instead
    of Alt (Control-F for frame advance, etc).
  * Controllers are now detected dynamically by Stella.  This means that
    you can plug/unplug joysticks/paddles/etc while Stella is running,
    and they will be added and removed automatically.  Also fixed is
    a bug whereby sometimes custom joystick mappings weren't being saved.
  * The 'cpurandom' option is now broken down by register type, so you
    can selectively enable/disable randomization for each one.  The
    default is to disable randomization for all registers.
  * Fixed 'MDM' scheme to trigger bankswitching on writes to hotspots
    (previously it only triggered on reads).  Also, the scheme has been
    modified as originally designed by E. Blink; hotspots are now in the
    range $800-$BFF instead of $800-$FFF.
  * The OSX app-icon now includes 32x32 and 16x16 versions, so 'small'
    icons will be viewable in 'Finder', 'Get Info', etc.
  * The Linux port now uses an app-icon; this seems to be needed for
    some window managers.
4.1 to 4.1.1: (September 14, 2014)
  * Re-added 'uipalette' option due to popular demand (of at least one
    person :)).
  * Fixed bug in Windows port where pressing 'Alt' key combos resulted in
    an annoying system beep.  Currently this is fixed by patching the SDL2
    library and including a modified version with Stella.
4.0 to 4.1: (September 1, 2014)
  * Improved 'DASH' bankswitching scheme support; there is now a debugger
    tab for changing banks and viewing internal cart RAM, and
    autodetection is now implemented.
  * Added 'MDM' (Menu Driven Megacart) bankswitch scheme as described on
    AtariAge and originally developed by Edwin Blink.
  * Improved snapshot viewing in the ROM launcher; snapshots are now
    scaled to the available space, and can better accommodate sizes
    other than those generated by Stella itself.
  * Improved support on multi-monitor systems.  Stella will now use the
    same monitor for fullscreen-windowed mode switches.  Special thanks
    to Magnus Lind for patches that added this functionality.
  * Removed the 'bank' command from the debugger prompt, as it only worked
    (inconsistently) with certain bankswitch types.  The bankswitch UI
    should now be used to query/set bank state.
  * Fixed bug in disassembly output; instructions at $F000 were never
    being highlighted during execution.
  * The UNIX configure script now supports newer versions of Hurd.
    Special thanks to Stephen Kitt for the patch.
3.9.3 to 4.0: (July 1, 2014)
  * Ported Stella to SDL2, which brings many new features.  Among the
    largest improvements is native hardware acceleration support for
    Windows (Direct3D) and Linux/OSX (OpenGL).  It is also now possible
    to port Stella to iOS and Android devices using OpenGLES.
    Hardware acceleration is now required, which means up-to-date drivers
    are needed.  Software rendering is still present, but is somewhat
    unoptimized and unsupported going forward.
  * Fullscreen video modes now use the desktop resolution.  Switching
    to fullscreen and back to windowed mode no longer rearranges icons
    on your desktop.
  * TIA TV effects are now available in all video modes, since hardware
    acceleration is a requirement.
  * Added a much more detailed view of cart extended RAM to a new
    debugger tab.  Special thanks to SpiceWare for this implementation.
  * Added preliminary support for 'DASH' bankswitching scheme by A. Davie.
  * The AtariVox and SaveKey controllers now have the ability in the
    debugger to completely erase the virtual EEPROM data.
  * Added 'savesnap' debugger prompt command, and also associated
    context menu item to the debugger TIA output area.  This saves the
    current TIA image to a PNG file.
  * Added 'hidecursor' commandline option, which allows to completely
    disable showing the mouse cursor (useful on systems that don't have
    a mouse).
  * Removed 'uipalette' option, as the original palette is no longer
    supported.
With 4.0 we switched to SDL2, which was a major step (e.g. hardware acceleration, no more screen tearing). 5.0 saw the all new TIA emulation core, which finally allowed correct emulation of multiple original games (e.g. Meltdown). With 6.0 the sound emulation was completely rewriten and became much more faithful to real hardware (e.g. intro in Ms PacMan). Besides that many other changes have been added, including ARM based games support. These have ~50 times more CPU power than the original games, thus requiring much more CPU time for emulation too. And modern Stella manages that with just 20% more CPU power than the original image.
Not all changes are relevant for Stella on R77, but many are.
AFAIK you are the only one having problems here. Which shows that the community image does a very good job. If your console has problems even without overclocking, then the hardware (not the software) has a problem.
Then you don't read enough threads.  This one included.
The community build is problem ridden.  Yes it has some advantages (mostly for PC).  But when problems occur, people like you blame users and or hardware 1st.  As evidenced by you, just now.
  • Confused 1
Point me to them.
Quote
Maybe we should just stop with it... :ponder:
AFAIK no one forced you to use the community build. Probably it is better for you (and us!) if you stick with the original Hyperkin image.
Edited by Thomas Jentzsch
  • Like 6
Woah there.
What is the goal here?  To put people down, or to solve a problem?
  • Like 5
1 minute ago, Thomas Jentzsch said:
Point me to them.
I don't give two sh!ts if you stop.
I will not search and post several threads where people are having issues (which on at least one, you were actively posting).  That's your gig.  The proof is in the pudding and your original comment to me shows where any discussion will go and the kind of person you are.
My advice to you is to start listening.  My advice to all including you, with a Retron 77 community build is when you find an issue, test it with the Hyperkin image.  You may be surprised as many users haven't even used the Hyperkin image at all.  You don't have to share results here (do as to spare hurt feelings and egos)
  • Confused 2
Suspicious_milk, if you feel that the firmware supplied is best for your needs, why not just stay with that.
You download a custom firmware that is being developed and provided for free and then you complain when it doesn’t work as you feel it should.
The team that works on this do it out of love for the Atari 2600 and love of programming.
I’ll bet that virtually everyone who uses their firmware understands and appreciates all the time and effort that they put in, I certainly do.
If you are so lazy that you can’t be bothered to read through threads to try to resolve and issue, why would you EVER decide to use a product that is always in development.
Your anger should actually be focused on Hyperkin for releasing a product with little follow up support and not on the talented group of enthusiasts who help us all get more enjoyment out of a product with many limitations out of the box.
You should publicly apologize for your childish, rude behavior or just go away and leave this forum to the people who understand what a benefit is is to have this custom firmware available from such dedicated enthusiasts.
  • Like 13
Hi, I'm very thankful for the community build and the support :)
Speaking of support, can someone just advise me as to how to get a larger than 80gb partition on my micro sd card, and the easiest/best software to do that?  I'd like to either:
1) convert the 80MB image, which I've written to SD cards sized 128MB and 32GB, to fill up one those cards... I can't find any "extend" or resize option in Windows disk imager to fix those cards.
or
2) rewrite the image to one of those cards with a program which has an option/setting to resize after writing the image.  I couldn't find such an option in Win32diskimager, USB Image Tool, or Etcher
Thank you!
Also is the mouse supposed to be working for joystick emulation?
I was able to pay Demon Attack with the keyboard (which worked quite well, I didn't feel any lag), but not with the mouse (it only fired with the mouse button, movement back and forth was minimal and inconsistent). I've always enjoyed using the mouse for 2 direction movement with shooters on Stella on PC. Yes, I did make sure that the mouse tab was set to use the mouse for digital controllers, and nothing else was plugged in...
39 minutes ago, Thomas Jentzsch said:
Hm, it works for I me. I just tested with Combat.
Like I said, it seemed to jiggle a little with left right movement. Try with a shooter involving sustained movement like demon attack or space invaders.
Could be my otg adaptor or mouse though, who knows. Which otg adaptor do you use?
Works for me. Maybe not as smooth than on a PC though. I never used the mouse for digital games before.
Quote
No idea. It was a dead cheap one.
I suspect that the mouse driver of the old Linux which the R77 firmware is based on, doesn't work well. Or is not configured well for mouse use. However my trackball hacks work well with the USB mouse
I tried it on a lark on Stella on PC with Demon Attack as a time killer while on a phone call. Wasn't expecting the mouse to work so well. It worked so well, especially with guided missiles, that I broke my personal high score. As I recall, not as good with space invaders, I think because the horizontal field takes longer to move across...
  • 2 weeks later...
I did say that.
I can leave my experience here, even if it's negative experience?
I know they do it out of love, they certainly aren't doing it for loads of cash.
I also appreciate the time and effort put in to Stella.  I couldn't BEGIN to code such complex things, but know enough to appreciate how difficult it is.  I also have criticisms.
You are calling me "so lazy" to do something I already did.  I have no problems with the shipped firmware.   I've ~100 carts that load fine (only one did not).  No freezes.  No lockups.   My paddle games play great without issue, no OTG or other adapters.   Community build however is another story.  I don't care too much, though.  Just tried it out of curiosity and all.
I'm not angry at all.  Just providing feedback.  If you don't like the feedback - feel free to ignore it, as is often done with truth and criticisms.
I'm no more "rude" than statements made by Jentzsch when talking about OTHER peoples projects and hard work (I could provide quotes and links; but it's not about that - - he too is allowed criticisms, I'm not trying to embarrass).
I'm trying to save some people some trouble.  If you have problems with the community build, which is MUCH more taxing on the system than the shipped firmware - - - you shouldn't listen to people who say your system is "buggy" or jump through hoops troubleshooting something that ain't gonna work to begin with.  People come here, too, that aren't apart of y'alls circle jerk.  All they see is how the promise of the Community Build will fix all their problems - - only to have more --- then told they are doing something wrong  - - "try this!"   - - "buy that!"    ----    "Sorry, bro, Your machine is buggy".    Don't complain though.   I'm not blaming anyone, that's just the way it is.  BUT some people here (lurkers mostly) will probably like to know ALL experiences, not just the ones you approve of.
I'm sorry if I hurt you or your boyfriends feelings.
  • Confused 1
Suspicious_milk, Wow, you are such a dbag.
I recently purchased my 77 and have had no involvement in this project or with any forum members other than coming here to learn more about the 77.
You once again show your pettiness and ignorance by trying to make it sound like you did this for the benefit of others.
I am certain that you are an entitled, self-centered narcissist who feels the world owes him.
Also, that was a nice touch using the homophobic statement to end your post in an attempt to insult me and the developer.
I remember using those tactics when I was about 9 years old.
I’ll bet anything that you will continue to use the community build for non-paddle games (current and future) without ever admitting it.
If you ever do admit it, you will whine about something just because you are you and can’t help yourself.
You must be a very strong man to carry around that massive chip on your shoulder.
As I stated at the beginning of this post….
Edited by Microbc
  • 2 weeks later...
17 minutes ago, ClassicGMR said:
It is a 3rd party seller but I figure I'd have almost zero trouble getting this refunded in case something happens. ;)
I felt the same way, but I already own the woodgrain one. It's super tempting.
I typically don't share links to stuff that seems off, but, it seems sort of legit. the website thirdlust .com is an adult novelty toys store, and the walmart seller feedback is 50%, but only 8 entries, and doesn't have any huge red flags, but IDK, still weird all the way around. my main concern was, is this the console or just the joystick?
While the Amber color isn't my cup of tea, this is a solid little system and if you can grab one for 30 bucks, thats not bad. Those Trooper Joysticks are around 20 by themselves.
Good luck, buddy. Let us know what happens.
Edited by Slikatel
This, right here, tells you that Sam Walton is long dead and buried. The Walmart of old would never have done business with them. It's all shareholders, cutting hours and driving the few employees harder than they deserve. ? But I digress...
From what I can see the price is for the console and controller. There's a separate selection just for a controller and all descriptions and pics show a full console and joystick combo. It's estimated to be delivered April 28th. I'll let you know! :)
I went ahead and order an amber one as well.
The thing about the website is that it looks real, and it not PS5s for 100 bucks and other things of that nature. Weird, but maybe they got some consles on deals and just want to flip them.
I thought maybe it was a bit sketchy because of the price alone, joystick only was a just a guess, but, yes, all the pics and descripts seem to indicate "Retro Game Console".
From what I heard the two versions are identical and merely just a cosmetic change, maybe someone here knows more.
Edited by Slikatel
That's the only difference.  There have been three (!) different iterations of the sticker design on the sticks (and two on the woodgrain console), but even more amusingly, extra amber joysticks can only be acquired directly through Hyperkin and were never sold at retail (unlike all the woodgrain varieties).
Being identical in hardware, the Ranger also works equally well (or poorly, depending on your perspective) on both.
