RetroN 77 Community Build Image
remowilliams
I've mentioned this before and I guess I'll say it again; what should be and what is are two different things. Someone asked for help on something, and I suggested a possible fix/workaround. I didn't design the hardware the way it is, nor can be expected to fix it.
To be clear, the best approach has already been suggested in another thread; the port hardware should detect what type of input it's receiving, and just pass that info to Stella. Or the GPIO pins should be somehow connected directly to Stella in code, so it can read as appropriate.
I cannot fix what I did not design. And TBH, I'm kind of getting tired of having to take responsibility for a product that is (a) out of my control, and (b) based on a version of Stella that 6+ years out of date. So I won't be working on it any longer.
Stephena, perhaps I came across bit harsh. Thank you for all your hard work.
The community build image already states whether each rom utilizes joystick or paddles via a checksum, however there is no option currently to change the controller type prior to boot. Better if it saves changes to the stella.pro config. It should be easy enough to configure the boot menu to select the controller type prior to starting a rom.
Then you only need the stella.pro file for paddle compatible physical carts that don't auto detect.
Writing config(s) on this sytem isn't a good idea due to the complete lack of proper process management on Hyperkin's part, and the resulting fact that Stella can be unexpectedly killed at any given time.
from the Stella R77 commit log:
- Completely disabled saving the settings file, since it was sometimes being corrupted, and this is pointless on this system.
Heh. Using a proper dual-config system this problem wouldn't exist. If one file gets corrupt by power-off during write, the system falls back to defaults or a backup of the previously working file. Then it recreates the bad file. Such a simple solution.
Automotive electronics do this. "Secure" copy utilities do this. NTFS does this. NTFS writes a file, and doesn't flag it good till the entire file is written. If power is lost at an inopportune time, the flag isn't set, and the previous file remains marked as valid.
Edited by Keatah
Why are we even "selecting" controllers to begin with? R77 should simply look to the proper I/O pins and be done with it.
What's going on now is a rather convoluted solution in comparison the original 1977 hardware.
And this is exactly what I did for the config file in the R77-specific port, and fixes the 'joystick loses fire button' bug. The proper, default config is hardcoded into the app itself. If the config file is ever deleted, corrupted, etc, then it reverts to the built-in one. This means that you'll never lose the fire button again.
I understand how this is supposed to work; that's why I added code to do it that way. As to why the maintainers of the system didn't do it, I can't say. But it's now fixed. I noticed it after a week or so of receiving the device, and released an update soon after that. I, nor anyone else on the Stella team, couldn't have possibly fixed it sooner; we didn't have the hardware! Not that we are responsible for it anyway.
And this is exactly one of the solutions I proposed above, when I referenced having Stella access the GPIO pins directly.
  • Like 5
Could you please leave this in any of the other threads where you've repeatedly said the same things?
  • Like 4
Oh dear..
Exactly. It is trivially simple to detect the controller type.
Pins 5 and 9 is low = joystick.
Pins 5 and 9 is high = paddle.
One pin is high, the other is low, then it is a hybrid Coleco Gemini joystick with built in paddle.
Just pass the status of these data inputs to Stella. It isn't rocket science.
Logically if the Retron77 can detect controller types and reconfigure the input, then it is possible for Stella to read them as well. No logical reason to guess or assume what should be or is actually connected. Certainly not "The crc index for this game is not in the paddle database. Please assign it to use joystick."
The active controller type is whatever the user has plugged into the console. This would also allow hotswapping of controllers, as well as games which allow for dual functionality, ie joystick in one port, paddles in the other.
I could be exposing myself as fairly dumb, but I need a bit of help.
I found an extra Micro SD card kicking around, so I decided to burn this image and give it a try. I'm pretty sure it was successful, since my Retron 77 does boot into the Stella UI, and it does play carts when I plug them in.
The problem is that I can't seem to find the roms on the SD card from the Retron. I know where they are when the card is plugged into the computer, but no matter where I poke around from inside Stella on the Retron, I can't see them. Little help?
The homebrew roms included with the image are in the Games folder. They are accessed by the R77 when you turn it on without a cart.
Well, that's what I assumed would happen, but the fact that isn't happening leads me to wonder why and what I can do to correct this anomaly.
I've re-imaged the card, but with the same results. The Retron 77 just doesn't seem to see the roms inside the Games folder on the card. I'm using a 4GB card formatted in FAT at 2048 bytes.
Edited by Akito01
Try FAT32
I guess I don't understand what I'm doing wrong. I format the card in FAT and burn the image from the Dropbox link with Etcher. There are literally no other extra steps in the process that I've taken. It loads the UI on the Retron and plays games from cartridges. The only thing that is missing, as far as I can tell, are the roms, which are definitely in the Games folder since I can see them on the computer - they just seem invisible from within the Retron.
Edited by Akito01
