Explosive Fairchild Channel F problems
TheSolderMonger
Drat, well that rules out the PSU. I'm looking at doing a recap of the main logic board or a MUCH closer look at the soldering to rule out cold/broken joints and another 12 regulator replacement. Could it be possible for you to measure the 12 volt regulator INPUT voltage? If so I could reverse the path of the traces to a possible malfunctioning component.
  • 2 weeks later...
I have a channel f that's doing the exact same thing yours is doing. I already swapped all the caps and both voltage regulators with no change. When the system is cold it runs alright for a min or so but then the screen goes blank. The 7812 has 24v coming in and 12v coming out and the 7805 has 12v in and 5v out. Have you been able to identify the problem yours is having? My though it something ahead of the 7812 is the source of the issue.
I managed to kind of sort of identify the problem area in my channel f that's doing the same thing yours is. I went over the board while it was turned on with freeze spray and it seems that the fcm9101/n chip is the culprit. As soon as the screen went all crazy I hit that chip with the freeze spray and it went right back to normal. Unfortunately none if the solder joints are suspect and u can't seem to find any shorts going into that chip, so my guess is that the chip itself has gone bad and needs to be replaced.
  • 1 year later...
I am ressurrecting this topic because this is precisely my issue. My series 1 Channel F would come up fine at first but over about a minute the picture would slowly degrade until it finally went black. I opened it up, hit the board with freeze spray, waited (this time took several minutes because it was cold) and when it started to go wonky I hit the fcm9101n chip with the spray and it went back to normal. My bother and I looked all over the board and nothing seems to be wrong with any of the soldering or anything, no obvious burnt out caps or whatnot. I have tried shielding all around the chip when spraying it so only the chip is getting the freeze spray. Fixes it every time.
Dumb question, but that means I have to find another of those chips right? And the only way to do that would be to find a Channel F for parts? I'm pretty sure it would have to be the series 1 kind to work with mine.
In addition...I'm not actually sure how to remove the motherboard completely from the aluminum bottom. There's something next to the controller ports holding it in place I'm afraid to force. If anybody knows how to get it apart I'd appreciate it. Obviously if I have to do any soldering I have to get to the underside. (We lifted it up as much as we could so we could see and again it looked fine.)
Amazingly I just got one of these units and am experiencing the same issue, plugged it in, powered it up and after about 5 min loses power. If I wait a few minutes i can turn it back on and play again. If any of the other members that had this problem and fixed it please post how/what you did.
NeitherSparky: I saw this on another site earlier and might be what you are talking about, look like there are 2 clips you have to pry at.
Thank you but no, I got the top and bottom cases apart, the problem is the motherboard is attached underneath to the bottom case by something I can't see so I'm afraid to try and rip the motherboard away.
On 6/17/2020 at 2:51 PM, mistermarc said:
I haven't taken mine apart yet but have you looked over the service manual? It goes into a little detail about disassembly.
https://archive.org/details/Fairchild_VES_Service_Manual_1976_Fairchild/mode/1up
Yes, but I don't really understand it fully, a visual aid would help. ?
