JosueCom Posted August 12, 2018 Share Posted August 12, 2018 I having been trying to find a text editor that supports Basics Programming but I have not been able to find one. Do you guys know of any that I could use? Also, do you know if there is a IDE that allows one to use things such as intymusic and intycolor? Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted August 12, 2018 Share Posted August 12, 2018 For a text edition in Windows, I use EditPlus. I have a language file for IntyBASIC that enables syntax highlighting. I also integrate it with the IntyBASIC SDK tools so that I can compile and test from the editor. 1 Quote Link to comment Share on other sites More sharing options...
PuzZLeR Posted August 13, 2018 Share Posted August 13, 2018 There is apparently something available from Brazil - an IDE dedicated to IntyBASIC, including IntyColor, and it's been mentioned here, but I have not used it. I'm personally fine with Notepad++. 1 Quote Link to comment Share on other sites More sharing options...
First Spear Posted August 14, 2018 Share Posted August 14, 2018 The stock installation of Visual Studio Code will see IntyBASIC as MS Visual Basic, and give syntax hilight, minor code completion, etc. It has saved me from making quite a few typos with long variable names, which would be a *bear* to deal with at debug time. It's cross-OS, worth a look. What do you mean about an IDE for IntyColor? I having been trying to find a text editor that supports Basics Programming but I have not been able to find one. Do you guys know of any that I could use? Also, do you know if there is a IDE that allows one to use things such as intymusic and intycolor? Quote Link to comment Share on other sites More sharing options...
