adonis_minus_20 Posted June 9, 2003 Share Posted June 9, 2003 I had a question on trakball hacks, e.g. Missile CommandTB. Is this difficult to implement? Is there a portion of input handling code that is standard that can easily be replaced with code for handling the trakball rather than a joystick. I would like to see TB versions of other 2600 and 7800 games, e.g. Centipede, Millipede, etc. I would try to do these myself if possible. Jim Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 9, 2003 Share Posted June 9, 2003 I had a question on trakball hacks, e.g. Missile CommandTB. Is this difficult to implement? Is there a portion of input handling code that is standard that can easily be replaced with code for handling the trakball rather than a joystick. For the 2600 the answer is NO and NO. Missile Command will probably stay unique. The trakball code needs quite a lot of space and especially CPU time inside the kernel. Only because the MC kernel was so dead simple with a lot of free cycles left this was (just) possible. I had a look at the kernels of a few other promising games, but they are all way to complicated. The code for reading the trakball differs a lot from the joystick code. The joystick is usually only read once/frame (or less), but (like the paddles) the trakball has to be read several times/frame. Therefore the kernel is the only place where this can happen. And implementing the code there requires a lot of rewriting (if you compare MC TB an the original using CloneSpy there are about 30% of code changes). And the code is slightly different for each trakball type, therefore there are different versions of my hack available. Link to comment Share on other sites More sharing options...
adonis_minus_20 Posted June 10, 2003 Author Share Posted June 10, 2003 For the 2600 the answer is NO and NO. That's too bad What about for the 7800? Jim Link to comment Share on other sites More sharing options...
Video Posted June 11, 2003 Share Posted June 11, 2003 Few games (if any, that I'm aware of) have been hacked. Though it should technically be easier, since the 7800 has more ram to work with. Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
