Shawn Posted August 23, 2018 Share Posted August 23, 2018 Hey, Is it possible to add resistance to the liniar pots inside a apple joystick to get it up to 500k to use with a 5200. Obviously there is much more than just the pots that need attention but this is the only part I'm currently looking for some help\advice on. I know this sounds too simple to work but I'm down to try The apple joysticks have a 150ohms resistance and I was considering adding the equal to 350ohms on one end of the variable resistor. Is this a pipe dream or possible? Shawn Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted August 24, 2018 Share Posted August 24, 2018 (edited) Short answer is no. If the apple pots were a higher value than those used by the Atari you could but a resistor in parallel to reduce it to the correct value, as they are not using a parallel resistance will always be lower than you want. Putting a resistor in series will not work either, although the total resistance would be the same the result is not. For example if you have a 10K pot the resistance ranges is 0 - 10K, if you have a 5K pot and put a 5K resistor in series while the total resistance will be 10K the range will only be 5K - 10K which is not the same as a 10K pot. Edited August 24, 2018 by Stephen Moss Quote Link to comment Share on other sites More sharing options...
Shawn Posted August 26, 2018 Author Share Posted August 26, 2018 ok thanks Quote Link to comment Share on other sites More sharing options...
