emarti Posted August 24, 2018 Share Posted August 24, 2018 Hi, I have got 1040stfm. How much voltages (and amperes) power socket pins for power unit where plugged on the motherboard? Quote Link to comment Share on other sites More sharing options...
oracle_jedi Posted August 25, 2018 Share Posted August 25, 2018 There's been a few discussions on the STF's power supply requirements, below is one: http://atariage.com/forums/topic/198431-diy-retro-fitting-a-picopsu-into-a-stffme-machine/ The red lines are +5V. The black lines are ground. The blue is +12V. This is the same for the STF, STE, Mega ST and Atari PC1. From memory the +5V needs about 2A. The +12V much less. Maybe 0.5A? In the thread referenced you can see they used Pico and ATX PSUs to drive the Atari, the Mean Well RT50B will also drive it, as will the excellent replacement PSUs from Exxos' web store: https://www.exxoshost.co.uk/atari/last/storenew/ 2 Quote Link to comment Share on other sites More sharing options...
tzok Posted September 23, 2018 Share Posted September 23, 2018 The 12V line isn't really needed at all. Only older FDDs use it, if you have a Gotek or HxC Floppy Emulator, you don't need it at all. It is also available on the monitor port (via the resistor) and is used by some TVs to switch to SCART-RGB mode, also UbeSwitch uses it for power. Quote Link to comment Share on other sites More sharing options...
