Coolcrab Posted September 15, 2018 Share Posted September 15, 2018 (edited) Edit: Something strange is happening with the game now. It goes to 263 scanlines on seemingly random moments but always at playfieldpos = 0 and 3 lines before the top stump and branches are made. It only happens when the AI is being used. It does not seem to have to do with the missiles and coconut. (although the coconut moving up also seems to have glitched the scanlines too, but only if it also happened on this same scanline.) It also only seems to happen when AI is used. So either the AI code makes the loop too long (Which I do not expect, as then it would happen more often and regurarly?) or it does something that causes the slowdown. I am a bit at a loss here and it would be great if someone could take a look. I left the rest of this topic in tact so that the answers below make sense. Check here for latest upload: http://atariage.com/forums/topic/283009-strange-b-w-effect-in-game/?p=4114107 Old topic: I got a strange error in my game that draws the color slowly every few? frames. The framerate seems to be OK so I am not sure what is wrong and how to google for this error. (Black and white drawing didnt bring up anything.) You don't see it at all in Stella but on real hardware it blinks. I added a screenshot of the B&W effect and the code. MonkeyKing0.22.bas.bin MonkeyKing0.22.bas Edited September 15, 2018 by Coolcrab Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/ Share on other sites More sharing options...
alex_79 Posted September 15, 2018 Share Posted September 15, 2018 The framerate is not stable if you set the left difficulty switch to "A" position by pressing F5 (default in Stella is both difficulty set to "B"). Many PAL TVs will display in B/W if there's an odd number of scanlines and that's what you're seeing on your TV (it's the same on my CRT) . Stella emulates this effect: go to "Options" > "Developer Settings", then select the "Video" tab and enable "PAL color-loss". Since this is an effect that only applies to PAL TVs, you must also tell Stella to run the game in PAL60 mode: you can cycle through the various modes with CTRL+F while playing the rom, or you can set it by selecting "Options" > "Game Properites" and change the "Format" in the "Display" TAB.Once you do all these three steps (enable PAL color loss, set left difficulty to A and set Format to PAL60), you'll see the game in Stella behave like on your TV. 3 Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113865 Share on other sites More sharing options...
iesposta Posted September 15, 2018 Share Posted September 15, 2018 Don't know about your question, however: this is an invalid bB command: player1scorecolor = $fe add a space after: ;dim _startgame = p Then it compiles for me. How many bytes does your game have left? I see places in your source code that can get you back a lot of ROM if you need it for things. Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113870 Share on other sites More sharing options...
RevEng Posted September 15, 2018 Share Posted September 15, 2018 Also, the B&W effect in Stella you screengrabbed is a feature in the debugger. The B&W portion is the previous frame, and the color portion indicates how much of the current frame is drawn, at this particular instant. If you hit the "scan +1" button a few times, the emulation will run for a few more scanlines, and you'll see a few more lines of color. Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113871 Share on other sites More sharing options...
Coolcrab Posted September 15, 2018 Author Share Posted September 15, 2018 The framerate is not stable if you set the left difficulty switch to "A" position by pressing F5 (default in Stella is both difficulty set to "B"). Many PAL TVs will display in B/W if there's an odd number of scanlines and that's what you're seeing on your TV (it's the same on my CRT) . Stella emulates this effect: go to "Options" > "Developer Settings", then select the "Video" tab and enable "PAL color-loss". Since this is an effect that only applies to PAL TVs, you must also tell Stella to run the game in PAL60 mode: you can cycle through the various modes with CTRL+F while playing the rom, or you can set it by selecting "Options" > "Game Properites" and change the "Format" in the "Display" TAB. Once you do all these three steps (enable PAL color loss, set left difficulty to A and set Format to PAL60), you'll see the game in Stella behave like on your TV. Aha that helped! odd that its only in PAL though. I think that I narrowed it down to branch creation of destruction. Thanks! Don't know about your question, however: this is an invalid bB command: player1scorecolor = $fe add a space after: ;dim _startgame = p Then it compiles for me. How many bytes does your game have left? I see places in your source code that can get you back a lot of ROM if you need it for things. That command is from a minikernel (that I didn't add here..oops) You can find it in the MK main thread. Where do you see rom space? I would be very happy to have some more. I got ~17b now. Also, the B&W effect in Stella you screengrabbed is a feature in the debugger. The B&W portion is the previous frame, and the color portion indicates how much of the current frame is drawn, at this particular instant. If you hit the "scan +1" button a few times, the emulation will run for a few more scanlines, and you'll see a few more lines of color. Ah thats good to know! I confused that effect with the blinking. But its something else. Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113873 Share on other sites More sharing options...
alex_79 Posted September 15, 2018 Share Posted September 15, 2018 (edited) Aha that helped! odd that its only in PAL though.It depends on the way old PAL TVs processed the color information. Modern LCDs probably don't show this effect at all. Edited September 15, 2018 by alex_79 Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113878 Share on other sites More sharing options...
iesposta Posted September 15, 2018 Share Posted September 15, 2018 This is about 64 bytes returned, by re-arranging, and dropping "goto" (in "if then goto" IF "goto label" is close). Really you need to code "If - then - goto" and then remove the goto and recompile and see if it gives a savings or errors. If it errors, you need to add the "goto" back. If it saves bytes, you don't need the "goto". Technically assembly can jump to a label "free" if it is within 128 bytes of the "if statement". Usually goto jumps to the label over "collision detections" is too far away, and it will error. In the attached code you need to add back my commented out player1scorecolor and add back the "inline xxx.asm" at the end. MonkeyKing0.22.bas 1 Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113879 Share on other sites More sharing options...
Coolcrab Posted September 15, 2018 Author Share Posted September 15, 2018 It depends on the way old PAL TVs processed the color information. Modern LCDs probably don't show this effect at all. Modern tv's lose sync if you use HDMI. So I really need to kill that glitch. Trying to narrow it down but no luck yet. This is about 64 bytes returned, by re-arranging, and dropping "goto" (in "if then goto" IF "goto label" is close). Really you need to code "If - then - goto" and then remove the goto and recompile and see if it gives a savings or errors. If it errors, you need to add the "goto" back. If it saves bytes, you don't need the "goto". Technically assembly can jump to a label "free" if it is within 128 bytes of the "if statement". Usually goto jumps to the label over "collision detections" is too far away, and it will error. In the attached code you need to add back my commented out player1scorecolor and add back the "inline xxx.asm" at the end. No way you solved the framerate problem and freed up rom! Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113882 Share on other sites More sharing options...
Impaler_26 Posted September 15, 2018 Share Posted September 15, 2018 You can try using smartbranching and see if it helps with saving bytes for "if - then - goto" statements: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#smartbranching Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113884 Share on other sites More sharing options...
iesposta Posted September 15, 2018 Share Posted September 15, 2018 Modern tv's lose sync if you use HDMI. So I really need to kill that glitch. Trying to narrow it down but no luck yet. No way you solved the framerate problem and freed up rom! Wow. Save very often. Sometimes a file will compile, and then it will not due to some "invisible text character". For instance, I was getting an error at the " = q " which was written okay. Some return character or other before or after that was not letting it compile. That's what I mean by "invisible text character". As soon as I commented that out and retyped the exact same thing, it compiled. It's hard explaining something that doesn't seem to make sense! Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113886 Share on other sites More sharing options...
Coolcrab Posted September 15, 2018 Author Share Posted September 15, 2018 You can try using smartbranching and see if it helps with saving bytes for "if - then - goto" statements: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#smartbranching I went through all the goto's (got about 3 more out) and now have a staggering 90b left. THis is a good idea though. Wow. Save very often. Sometimes a file will compile, and then it will not due to some "invisible text character". For instance, I was getting an error at the " = q " which was written okay. Some return character or other before or after that was not letting it compile. That's what I mean by "invisible text character". As soon as I commented that out and retyped the exact same thing, it compiled. It's hard explaining something that doesn't seem to make sense! I've never ad that issue yet. (fingers crossed) Very odd though. Also do you have any tips on my AI btw? Trying to invest the new bytes into that, but if I add much more pfchecks It needs draw screens again. I added a 'if missile1 < player1y then player1y = player1y - 1' then I added a y and rewrote the pf pixels to read on the AI's level. Hoewever, he only looks above him now so if he goes down he hits everything. =/ I think that it would be awesome if he had this behaviour bit IDK if its doable. (Replace the AI with this to have a look at what I mean) ; AI controll if !switchleftb then __AI goto __skipAI __AI if _invisible0 then goto __skipAIball ; he does ! work when invisible if !(rand & 127) then goto __skipAIball temp1 = (player1x - 14) / 4 temp2 = (player1y ) / 8 temp3 = player1y - bally temp4 = %00000000 if player1score = $c && bally < player1y then gosub __killbranch2 : gosub __firesound if player1score = $d then gosub __livesplus2 if missile1y < player1y && player1y > 10 then player1y = player1y - 1 else if missile1y > player1y && player1y < 82 then player1y = player1y + 1 if pfread(temp1, temp2) then _left_right = _left_right ^ 32 : __skipAIball if ballx = player1x + 3 && temp3 < 30 then temp4{0} = 1 if !pfread(23,10) then temp4{1} = 1 if !pfread(25,10) then temp4{2} = 1 if !pfread(23,9) then temp4{3} = 1 if !pfread(25,9) then temp4{4} = 1 if temp4 = %00011111 then _left_right = _left_right ^ 32 __skipAIball __skipAI Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113892 Share on other sites More sharing options...
iesposta Posted September 15, 2018 Share Posted September 15, 2018 Sorry I cant help with AI. Everything but game logic. Sound, music, samples, graphics, color, layout... I started with bB DPC+ kernel so I know that better than the standard kernel options. I can optimize even if I dont understand the code. The smartbranching will add back in a goto if it cant branch for free, but some dropped goto commands get missed even by smartbranching on and will error on compile, thats why I said it is best to write code using them, and then to remove and test compile later. That and the put as many things=(same value) on one line using : between them, are 2 large optimizations, even though it makes the code harder to read. I dont know about writing a compiler, but if I were to add a compile pass it would be to look for seperate defines to the same value and combine because it compiles like this: player1x=0 player0x=0 AUDV0=0 AUDV1=0 _apple=0 _anything=0 Compiles To (load / store): lda 0 sta player1x lda 0 sta player0x lda 0 sta AUDV0 lda 0 sta AUDV1 lda 0 sta _apple lda 0 sta _anything When: player1x=0: player0x=0: AUDV0=0: AUDV1=0: _apple=0: _anything=0 compiles to (one load / store): lda 0 sta player1x sta player0x sta AUDV0 sta AUDV1 sta _apple sta _anything So thats where you get ROM back by writing it differently. 1 Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4113956 Share on other sites More sharing options...
Impaler_26 Posted September 15, 2018 Share Posted September 15, 2018 The smartbranching will add back in a goto if it cant branch for free, but some dropped goto commands get missed even by smartbranching on and will error on compile, thats why I said it is best to write code using them, and then to remove and test compile later. Good point. I always set smartbranching on but it's probably better to not use it and check if goto is needed by hand. Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4114097 Share on other sites More sharing options...
Coolcrab Posted September 15, 2018 Author Share Posted September 15, 2018 (edited) Sorry I cant help with AI. Everything but game logic. Sound, music, samples, graphics, color, layout... I started with bB DPC+ kernel so I know that better than the standard kernel options. I can optimize even if I dont understand the code. The smartbranching will add back in a goto if it cant branch for free, but some dropped goto commands get missed even by smartbranching on and will error on compile, thats why I said it is best to write code using them, and then to remove and test compile later. That and the put as many things=(same value) on one line using : between them, are 2 large optimizations, even though it makes the code harder to read. I dont know about writing a compiler, but if I were to add a compile pass it would be to look for seperate defines to the same value and combine because it compiles like this: player1x=0 player0x=0 AUDV0=0 AUDV1=0 _apple=0 _anything=0 Compiles To (load / store): lda 0 sta player1x lda 0 sta player0x lda 0 sta AUDV0 lda 0 sta AUDV1 lda 0 sta _apple lda 0 sta _anything When: player1x=0: player0x=0: AUDV0=0: AUDV1=0: _apple=0: _anything=0 compiles to (one load / store): lda 0 sta player1x sta player0x sta AUDV0 sta AUDV1 sta _apple sta _anything So thats where you get ROM back by writing it differently. I tried some of that but im low on memory now. WOuld really be happy with a few more bytes. Want to add 2 more ifs. Could you take a look? EDIT: I found 22b and added them in. However the original error of this thread is back T_T The AI does too much I think and it just eats frames, but only when new branches are made. So a smartly placed drawscreen somewhere might fix it. If anyone sees it please tell me! MonkeyKing0.23.bas score_graphics.asm playerscores.asm Edited September 15, 2018 by Coolcrab Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4114107 Share on other sites More sharing options...
iesposta Posted September 15, 2018 Share Posted September 15, 2018 (edited) How about this? Found 4 bytes. Made 1 drawscreen. Found 41 bytes. Is the sound broken now? MonkeyKing0.23c.bas Edited September 15, 2018 by iesposta Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4114183 Share on other sites More sharing options...
Coolcrab Posted September 15, 2018 Author Share Posted September 15, 2018 How about this? Found 4 bytes. Made 1 drawscreen. Found 41 bytes. Is the sound broken now? Sound seems fine, but there is a graphics glitch now that appears when there is a gosub tree that goes more than 2 levels (it corrupts the memory apparently) The scanline problem is still there though. (it drives me crazy!) I'll compare the two programs for the space though, it amazes me how you squeeze so much out. Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4114190 Share on other sites More sharing options...
Coolcrab Posted October 1, 2018 Author Share Posted October 1, 2018 So I am almost done with this game but when trying it out on real hardware I noticed that there still is a problem when playing with the AI. (So left difficulty to A) I don't know why this is happening as it only seems to be an issue when playfieldpos = 0. (Also at higher scores of 60+) I tried to turn off the AI when playfieldpos=8 but it doesnt seem to work. if !switchleftb && playfieldpos <> 8 then __AI It might have to do with it drawing the top of the tree at playfieldpos=1, I tried setting it to 2 and that worked until the speed doubled. if playfieldpos = 1 then _left_right{0} = 1 : pfpixel 8 0 8 on : pfpixel 24 0 24 on else _left_right{0} = 0 I'm not sure why its doing this all of a sudden. Does anybody know a way around this? MonkeyKing1.0.bas.bin MonkeyKing1.0.bas Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4125274 Share on other sites More sharing options...
RevEng Posted October 2, 2018 Share Posted October 2, 2018 When the playfieldpos transitions back to 0, it does a coarse scroll. This is expensive cyclewise, because a bunch of memory has to be moved around. Here's another thread on it. You're doing the right thing, trying to eliminate cycle overages by skipping stuff, but it needs to be on the frame prior to transitioning to 0, IIRC. 1 Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4125659 Share on other sites More sharing options...
Coolcrab Posted October 2, 2018 Author Share Posted October 2, 2018 When the playfieldpos transitions back to 0, it does a coarse scroll. This is expensive cyclewise, because a bunch of memory has to be moved around. Here's another thread on it. You're doing the right thing, trying to eliminate cycle overages by skipping stuff, but it needs to be on the frame prior to transitioning to 0, IIRC. That seemed to work a bit it now doesn't jump when the speed is below the 254. Once it moves into higher speeds and goes >1 block per frame it starts flickering like mad. But still always at the playfieldpos = 0 I think that it is flipping when it does a double jump at either 6 or 7, but I'm not sure on how to fix that. Here you can see what I do to make it scroll faster than 256 + some other stuff _left_right{2} = 1 if _sum > _speed then __skipscroll __scrolldown ;animate sprite _animate = _animate + 1 if _animate > 5 then _animate = 0 ; check if a new tree block needs to be made and then see if a branch should be made if playfieldpos = 1 then _left_right{0} = 1 : pfpixel 8 0 8 on : pfpixel 24 0 24 on else _left_right{0} = 0 if _left_right{0} && (rand & 1) then gosub __branch ;Move magic stones & ball & scroll screen missile0y = missile0y + 1 missile1y = missile1y + 1 bally = bally + 2 pfscroll down if !switchleftb then __AIscroll goto __AIscrollskip __AIscroll if missile1y > player1y && player1y < 82 then player1y = player1y + 1 __AIscrollskip __skipscroll if _left_right{1} && _left_right{2} then _left_right{2} =0 : goto __scrolldown ; speed up the tree _sum = _sum + _speed And here I increase speed to a preset maximum. if playfieldpos = 7 then __skip_new_row __skip11 if pfread(8,11) then gosub __sprite_color : drawscreen : _speed = _speed + 1 : pfhline 4 11 13 off : pfhline 20 11 28 off : score = score + 1 : gosub __bleep : gosub __sprite_color : drawscreen __skip_new_row if _speed > 254 && !_left_right{1} then _left_right{1} = 1 : _speed = 0 if _speed > 100 && _left_right{1} then _speed = 100 I just wish that it worked MonkeyKing_NTSC.bas Quote Link to comment https://forums.atariage.com/topic/283009-very-odd-scanlines-problem-strange-bw-effect-in-game/#findComment-4125901 Share on other sites More sharing options...
