NOP and timing
ufosolar
Hi there, welcome :)
It is important to understand that the TIA continues to do it's thing without instruction from the CPU. The CPU's job is to set the registers in the TIA (at the correct time) to change the picture. The TIA will draw the same line over and over again if the registers are not changed. This is just like what happens when you turn on the console without a cartridge.
When you execute a NOP instruction, you are not changing any registers, but you are wasting 2 cycles of CPU time. The TIA will draw 6 pixels in that time (6 'color clocks').
You can't think of programming the VCS in this way. There is no "drawing something after a nop."
You have to think of the TIA and 6507 as being in lock step with each other. You have 76 CPU cycles across each scanline. Whatever CPU cycle *at that moment* along a particular scanline is what is going to determine where on the screen a particular change will take place. The TIA always does what it was last doing until it is told otherwise...the CPU clock cycle timing is what determines just about everything.
  • 10 months later...
On 10/29/2018 at 1:01 PM, ufosolar said:
Ok maybe I start to understand how it works ... p.s. I noticed that not using the SLEEP macro the first scanline was drawn out of phase with respect to the others, (I went to attempts). Thank you
Lda #50 ;load the A register with the value 50. Fyi this should be in hexidecimal form "lda #$50" not #50 range of the register #$00 - #$FF or #0 - #255 but #$50 and #50 are not equivalent.
sta COLUBK ;This stores the value of A register into the TIA's COLUBK register #$09.
nop  ; for each nop
nop  ; the TIA is drawing
nop  ; two color clocks to the screen
This is the drawing time.
If other code follows after the line has began to draw each cpu cycle used by the following code will draw two more color clocks to the screen.
See documentation to understand the number of machine cycles used for each instruction.
nop  ; for each nop
I regret this part of the tutorial where I had REPEAT 192. Just so that's out there.
I just want to comment on the above - each "nop" is two CPU cycles, NOT two colour clocks.
Each CPU cycle is 3 colour clocks, so each "nop" is actually 6 colour cycles.
There are 76 CPU cycles per scanline, which is 76*3 = 228 TIA colour clocks.
