HOME AUTOMATION Posted November 11, 2018 Share Posted November 11, 2018 If your like me... had your lifetime share of rock-n-roll...Classical music has to much annoying stereo separation...Not feeling it with the JAZZ thing...Than... you probably just can't get enough CS1 SOUND...Since most DATA TAPES only play for a few minutes at most(due to the max. 16K buffer limit)Getting long play versions has only been possible using a .wav editor, audio sequencer or by tediously splicing tapes together. At long last, there is a convenient alternative!!!Now I release my latest VDP scrambling solution... CS1-O-MaticThis will not only scramble VDP memory but will also record an endlessCS1 data SAVE.Two versions are ready...V.1 Prompts visible(at first)V.2 More psychedelic(constant data) "Just set it and forget it" CS14EVER.dsk 2 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted November 11, 2018 Author Share Posted November 11, 2018 The above should be used with EA or MINI MEMORY LOAD and RUN...PROGRAM NAME: RUN The above is FOR ENTERTAINMENT VALUE ONLY and serves as no proven utility. HOME AUTOMATION unlimited... assumes no responsibility for damages from listening to long... with the volume turned up to high! Quote Link to comment Share on other sites More sharing options...
Opry99er Posted November 11, 2018 Share Posted November 11, 2018 This could potentially solve the multiplexer issue as well as cancer. Props. 2 Quote Link to comment Share on other sites More sharing options...
JB Posted November 11, 2018 Share Posted November 11, 2018 Instant techno album! 2 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted November 12, 2018 Share Posted November 12, 2018 I was playing some music on my way home from the Faire and the speakers started spitting out modem connection tones followed by about two minutes of a data stream. My son wanted to know what that was. . .then I remembered that the CD I had ripped it from was mixed media, and that the data was actually a usable input stream. I'll have to pull it out sometime and check to see what the program was. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted November 12, 2018 Share Posted November 12, 2018 Nah, I am fine now. Took something for my headache and I am no longer malfunctioning. 6 Quote Link to comment Share on other sites More sharing options...
