42bs Posted November 25, 2018 Share Posted November 25, 2018 It might be an improvement to draw small triangles using Bresenham and avoid the division to calc tilt and stretch. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted November 25, 2018 Share Posted November 25, 2018 (edited) My first 3d engine on Lynx worked with that and Suzy only doing the span filling. Edited November 27, 2018 by Heaven/TQA Quote Link to comment Share on other sites More sharing options...
42bs Posted November 25, 2018 Share Posted November 25, 2018 (edited) Polygons can have up to 15 vertices. See our description at www.arsantica-online.com in the stccc section. Oh, it is plain 2D. Here a bin2asm converter for the scene file, for those interested. #include <stdio.h> #include <stdlib.h> #include <stdint.h> int pos; uint8_t getByte(FILE *in) { int inbyte0; inbyte0 = fgetc(in); ++pos; if ( inbyte0 < 0 ){ printf("Error\n"); exit(1); } return (uint8_t)inbyte0; } uint16_t getWord(FILE *in) { return (uint16_t)((getByte(in)<<|getByte(in)); } int main(void) { FILE *in; int inbyte; uint8_t fb; uint16_t word; uint16_t color; int frame; int idx; in = fopen("scene1.bin","r"); frame = 0; pos = 0; while( !feof(in) ){ fb = getByte(in); printf("frame%03d:\n",frame); printf(" dc.b $%02x\n",fb); if ( fb & 1 ){ printf("; /* clear screen */\n"); } if ( fb & 2 ){ printf("palette%03d:\n",frame); word = getWord(in); printf(" dc.w $%04x\n",word); for(idx = 0; word ; word <<= 1, idx += 1){ if ( word & 0x8000 ){ color = getWord(in); printf(" dc.w $%04x ; %d\n",color,idx); } } } if ( fb & 4 ){ uint8_t cntVert; printf("; /* frame indexes */\n" "frameIdx%03d:\n", frame); cntVert = getByte(in); printf(" dc.b %d ; number of vertices\n", cntVert); for( ; cntVert > 0; --cntVert){ uint8_t x,y; x = getByte(in); y = getByte(in); printf( " dc.b %3d,%3d\n",x,y); } int vert = 0; while( 1 ){ fb = getByte(in); printf("desc%03d_%03d:\n" " dc.b $%02x\n",frame, vert,fb); if ( fb == 0xfd ){ printf(" .end\n"); exit(0); } if ( fb == 0xff ){ break; } if ( fb == 0xfe ){ while( (pos & 0xffff) ){ (void)getByte(in); } break; } printf(" dc.b "); for ( fb &= 0xf; fb; --fb){ printf("%d",getByte(in)); if ( fb != 1 ){ printf(","); } else { printf("\n"); } } ++vert; } } else { printf("; /* non-indexed */\n"); int vert = 0; while( 1 ){ fb = getByte(in); printf("desc%03d_%03d:\n" " dc.b $%02x\n",frame, vert,fb); if ( fb == 0xfd ){ printf(" .end\n"); exit(0); } if ( fb == 0xff ){ break; } if ( fb == 0xfe ){ while( (pos & 0xffff) ){ (void)getByte(in); } break; } printf(" dc.b "); for ( fb &= 0xf; fb; --fb){ printf("%d,%d",getByte(in),getByte(in)); if ( fb != 1 ){ printf(","); } else { printf("\n"); } } ++vert; } } ++frame; } return 0; } The output seems to be correct. Edited November 25, 2018 by 42bs 1 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted November 27, 2018 Share Posted November 27, 2018 (edited) Btw we find out that fc28-fc2b (hoff and voff) can effect kind of subpix adjustment. The Epyx manual describe those as magic numbers. Are those kind of init value for Suzy like the init value in the Amiga Blitter when applying bresenham line? And can those be used to minimize the edge jitter? Edited November 27, 2018 by Heaven/TQA Quote Link to comment Share on other sites More sharing options...
42bs Posted November 27, 2018 Share Posted November 27, 2018 Btw we find out that fc28-fc2b (hoff and voff) can effect kind of subpix adjustment. The Epyx manual describe those as magic numbers. Are those kind of init value for Suzy like the init value in the Amiga Blitter when applying bresenham line? And can those be used to minimize the edge jitter? From the manual: Horizontal and Vertical Size Offset In order to balance the visual 'bump' that occurs at the reference point of a multi- quadrant sized sprite, we implemented a 'cheat' value of initial offset for both horizontal and vertical size. They are programmed independently at the time of sprite engine initialization. For horizontal, the left direction offset is forced to zero, and the right direction offset is programmed to 007F. For vertical, the up direction offset is forced to zero, and the down direction offset is programmed to 007F. So these offsets are not related to the "jitter" on the edges. These are simply due to rounding errors when summing up. A triangle is simply a one pixel sprite which is stretched in Y an X direction and tilted. Quote Link to comment Share on other sites More sharing options...
sage Posted November 27, 2018 Share Posted November 27, 2018 And can those be used to minimize the edge jitter? no. :-) What is possible is to split in two triangles /| and |\ . then one can get rid of it. but at what price. 1 Quote Link to comment Share on other sites More sharing options...
42bs Posted November 27, 2018 Share Posted November 27, 2018 A large improvement (speed wise) would be to "cache" the tilt and stretch values for common edges. But I guess this is heavy lifting ... Quote Link to comment Share on other sites More sharing options...
42bs Posted November 30, 2018 Share Posted November 30, 2018 Tried myself to draw the stnicc scene on the Lynx. No good progress so far, but I made a Processing program to develop the poly-routine. If someone is interested I may post it here. Quote Link to comment Share on other sites More sharing options...
sage Posted December 1, 2018 Share Posted December 1, 2018 Yeah a competition 1 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted December 3, 2018 Share Posted December 3, 2018 Yeah. Good. I even had got my Lynx out of basement and tested the flashcard I won last year.... but me tied up with different project. Quote Link to comment Share on other sites More sharing options...
42bs Posted December 3, 2018 Share Posted December 3, 2018 Yes, the real thing is slower than the emulator. In my version the OXYGENE zoom takes 7 VBL (60Hz) per frame but handybug only 5 or 6. But it shows clearly that the triangle routine needs a lot of optimization to detect single pixel triangles or ones with no tilt. But actually, I take it as competition against myself It is funny how many bugs one can place in a few hundred lines of code 1 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted December 3, 2018 Share Posted December 3, 2018 Can you not preprocess data and flag those polys? Ah... good old 512kb limit Btw thanks for BLL without your work none of my demos for Lynx had made the light 1 Quote Link to comment Share on other sites More sharing options...
sage Posted December 3, 2018 Share Posted December 3, 2018 (edited) hm the data file is already 640kb. And I have the very bad feeling that it will get slower if you have to unpack it in addtion to playing the video. Anyway, the latest emulator core can handle 2MB ROMs Edited December 3, 2018 by sage Quote Link to comment Share on other sites More sharing options...
42bs Posted December 3, 2018 Share Posted December 3, 2018 Some findings: - the data file is (at least with lzma or lz4) not compressible. - pre-processing saves a few cycles, but that's against the rule - I thought the calculation of the tilt is the biggest problem. Three divides, each 174+n cycles. So I made a 1/y table and used multiplication (only 54 cycles). Guess what? No change. The first frame takes 7 VBLs(60Hz) to render. With or without divide. So I really think, optimizing has to check for all those single pixel triangles. - With Processing I could show that the n-poly to triangle can be rather simple: Keeping x0,y0 and draw a triangle to the next two points. Then go to the next and so on. X0,Y0 is always kept. while ( true ) { marker = getByte(); if ( marker == 0xff || marker == 0xfe || marker == 0xfd ) { return marker; } col = (marker >> 4); fill(r[col], g[col], b[col]); stroke(r[col], g[col], b[col]); nvertices = marker & 0xf; v0 = getByte(); v1 = getByte(); { for ( nvertices-=2; nvertices > 0; --nvertices) { v2 = getByte(); mytriangle(x[v0], y[v0], x[v1], y[v1], x[v2], y[v2]); v1 = v2; } } } Too bad, in my Lynx code is still a bug, sometime the screen is corrupted. But the Processing version looks correct. Regarding BLL: If you define "DEBUG" then the loader is active and you reload directly without entering BLL. This way, you can store the scene file on the flash card just download the demo via ComLynx. 1 Quote Link to comment Share on other sites More sharing options...
42bs Posted December 3, 2018 Share Posted December 3, 2018 hm the data file is already 640kb. And I have the very bad feeling that it will get slower if you have to unpack it in addtion to playing the video. Anyway, the latest emulator core can handle 2MB ROMs Too bad I have to stick with version 0.95. Anything else does not run on my PC. Something M$ broke in one of the updates over the last year Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted December 3, 2018 Share Posted December 3, 2018 Btw Bastian, preprocessing is allowed. Otherwise no C64 version possible . I did not went yet to test lz4 but thought it might help in packed streaming depacking. 1 Quote Link to comment Share on other sites More sharing options...
42bs Posted December 3, 2018 Share Posted December 3, 2018 Btw Bastian, preprocessing is allowed. Otherwise no C64 version possible . I did not went yet to test lz4 but thought it might help in packed streaming depacking. Ah, ok, then at least the "lsr" for the vertices can be off-loaded. Quote Link to comment Share on other sites More sharing options...
42bs Posted December 4, 2018 Share Posted December 4, 2018 It seems the scene1.bin contains a lot of filler bytes. The pure binary (removing the fillers) is only 200k. With LZ4 it compresses down to 170K and LZMA even 114K! But I think LZ4 is ok as it leave 50K space. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted December 4, 2018 Share Posted December 4, 2018 Bastian, what do you mean with filler bytes? as Leonard filled up to 64k boundary with "filler bytes". but that's not like you can save 400k or do you mean by double vertices due to your "you can draw everything with triangles"? Quote Link to comment Share on other sites More sharing options...
42bs Posted December 4, 2018 Share Posted December 4, 2018 Bastian, what do you mean with filler bytes? as Leonard filled up to 64k boundary with "filler bytes". but that's not like you can save 400k Ok, yes, now seeing the pure numbers I might have a big-bug in my converter ... back to start, no $4000 ... Quote Link to comment Share on other sites More sharing options...
yami Posted December 4, 2018 Author Share Posted December 4, 2018 Managed to get packing working. But it is too slow. But fits in 500k. For some reason the colors are not 100% right. Close, but not completely correct. packed.zip 1 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted December 4, 2018 Share Posted December 4, 2018 cool. what is v1 and v2? btw. "some colors" are wrong is unlikely... because normally all colors are wrong but not some Quote Link to comment Share on other sites More sharing options...
42bs Posted December 4, 2018 Share Posted December 4, 2018 Managed to get packing working. But it is too slow. But fits in 500k. For some reason the colors are not 100% right. Close, but not completely correct. packed.zip if ( fb & 2 ){ if ( !out ){ printf("palette%04d:\n",frame); printf(" dc.b "); } for(cnt = 0, idx = 0; word ; word <<= 1, ++idx){ if ( word & 0x8000 ){ //00000RRR0GGG0BBB => 0G BR int r = (getByte(in) & 0x7)<<1; int g = getByte(in); int b = (g & 0x7)<<1; g = (g >> 4) & 0xe; if ( out ){ fputc(idx,out); fputc(g,out); fputc((b<<4)|r,out); } else { printf("%d,", idx); printf("$%02x,", g); if ( word & 0x7fff ){ printf("$%02x,",(b<<4)|r); } else { printf("$%02x\n",(b<<4)|r); } } cnt += 2; } } } &7 is the trick, shift for brightness Quote Link to comment Share on other sites More sharing options...
42bs Posted December 4, 2018 Share Posted December 4, 2018 Intro sequence .... (BTW: Why can't I upload 7zip files?!) intro.zip 1 Quote Link to comment Share on other sites More sharing options...
Turbo Laser Lynx Posted December 4, 2018 Share Posted December 4, 2018 It looks very nice! Quote Link to comment Share on other sites More sharing options...
