360's hard drive?
walter_J64bit
  • 2 years later...
On 11/28/2018 at 8:41 AM, walter_J64bit said:
I know that the 360 uses a SATA drive but is a SATA 1, SATA 2 or a SATA 3? I'm thinking of using a SATA SSD drive for my internal hard drive. Thanks!
I don't know. Also, it does not matter. SATA is backwards and forwards compatible.
For example, the the chipset on the motherboard is SATA1 and you plug in a SATA3 HDD, they will talk to each other and settle on the slower interface, which is SATA1.
For example, the the chipset on the motherboard is SATA2 and you plug in a SATA1 HDD, they will talk to each other and settle on the slower interface, which is SATA1.
I don't think that you can plug in any HDD. The XBox 360 will simply not show that it saw a HDD plugged in. I have tried it.
It has to be a XBox 360 HDD. These contain a certain firmware.
Someone made a tool that allows you to flash the firmware of your PC and laptop HDD. But, it is limited to only a few models.
