RespeQt 4.3 beta
ebiguy
  • 1 month later...
There is a way to use the Mini Speedy as a Happy drive and copy all of your ATX files , the trick is in the disk image options you put a check mark on all of the options, and it will copy some of the ATX files properly, it I not yet up to par but I managed to get two files working I will let you know which ones in a few mins. Oh by the way by doing this and turning on the option for Happy the speedy thinks its a Happy Speedy, (pun intended)…. I get the stuff copied but it does not all work..... Russ
I might do a video of all the settings and a successful copy.
  • 4 months later...
On 1/7/2019 at 9:01 PM, ebiguy said:
So, now, how can you make a backup from your physical drive to your RespeQt image ?
I can not check with my real Atari but I guess this will work (feel free to ask again if it does not work):
Just use 2 drives (D1: and D2:)
1. Turn your real Happy drive OFF.
2. Change jumpers to set it as D1:
3. Load Happy software 7.1 image in RespeQt as D1:
4. Load your destination image (blank image) as D2:
5. Turn Happy mode ON for both D1: and D2:
6. Boot your Atari
7. Select option 4 in the main menu (Happy Backup).
8. When the pre-defined Backup option question is displayed, do NOT answer
9. Empty the image in D1:
10. Turn your real Happy drive on.
11. Answer N to the pre-defined Backup option question and answer the remaining questions
I also get the Hi Speed Error.
Tried it exactly this way, didn't work ?
Tested again:
Running the Hi Speed Xfer Diagnostic on D1: (real Happy drive)... pass!
Running the Hi Speed Xfer Diagnostic on D2: (RespeQt Happy drive)... fail!
[Disk 2] Happy High Speed Write memory at $8380
Data frame checksum error, expected: 131, got: 99. (00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000f032778083ad32778083ad32778083ad32778083ad32778083ad32778083ad32778083ad32778083ad32778083ad32778083ad32778083ad32778083ad32778083)
[Disk 2] Sending [ERROR] to Atari
I'm quite new to the Happy Drive topic, surely I miss something. Any hint?
Hi,
In the console log, do you see something like:
RespeQt version inquiry: $xx
If yes, what is the value of xx
If no, then you have a Happy backup disk that is not compatible with RespeQt. Please download a 5.3 for a 810 or a 7.1 for a 1050.
And do you see this line:
Happy Warp Speed Software V7.1 patched on the fly to be compatible with RespeQt
Edited by ebiguy
Added question about second RespeQt message
1 hour ago, ebiguy said:
Hi,
This message does not show up
I use 7.1 for a 1050, though
Nope, don't see this line
Serial port speed set to 19200.
Emulation started through standard serial port backend on 'COM2' with DSR handshaking
[Disk 1] Mounted 'Happy Warp Speed Software V7.1 Side 1.ATR' as 'SD Diskette (90k)'.
[Disk 1] Get status: $ff
[Disk 1] Read Sector 1 ($001) #1 in track 0 ($00)
[Disk 1] Read Sector 2 ($002) #2 in track 0 ($00)
[Disk 1] Read Sector 3 ($003) #3 in track 0 ($00)
[Disk 1] Read Sector 4 ($004) #4 in track 0 ($00)
[Disk 1] Read Sector 5 ($005) #5 in track 0 ($00)
[Disk 1] Read Sector 6 ($006) #6 in track 0 ($00)
[Disk 1] Read Sector 7 ($007) #7 in track 0 ($00)
[Disk 1] Read Sector 8 ($008) #8 in track 0 ($00)
[Disk 1] Sending [COMMAND NAK] to Atari
[Disk 1] Read sector $03b1 NAKed.
[Disk 14] command: $52, aux: $03b1 ignored. [x4]
[Disk 1] Read Sector 9 ($009) #9 in track 0 ($00)
[Disk 1] Read Sector 10 ($00a) #10 in track 0 ($00)
[Disk 1] Read Sector 11 ($00b) #11 in track 0 ($00)
[Disk 1] Read Sector 12 ($00c) #12 in track 0 ($00)
[Disk 1] Read Sector 13 ($00d) #13 in track 0 ($00)
[Disk 1] Read Sector 14 ($00e) #14 in track 0 ($00)
[Disk 1] Read Sector 15 ($00f) #15 in track 0 ($00)
[Disk 1] Read Sector 16 ($010) #16 in track 0 ($00)
[Disk 1] Read Sector 17 ($011) #17 in track 0 ($00)
[Disk 1] Read Sector 18 ($012) #18 in track 0 ($00)
[Disk 1] Read Sector 19 ($013) #1 in track 1 ($01)
[Disk 1] Read Sector 20 ($014) #2 in track 1 ($01)
[Disk 1] Read Sector 21 ($015) #3 in track 1 ($01)
[Disk 1] Read Sector 22 ($016) #4 in track 1 ($01)
[Disk 1] Read Sector 23 ($017) #5 in track 1 ($01)
[Disk 1] Read Sector 24 ($018) #6 in track 1 ($01)
[Disk 1] Read Sector 25 ($019) #7 in track 1 ($01)
[Disk 1] Read Sector 26 ($01a) #8 in track 1 ($01)
[Disk 1] Read Sector 27 ($01b) #9 in track 1 ($01)
[Disk 1] Read Sector 28 ($01c) #10 in track 1 ($01)
[Disk 1] Read Sector 29 ($01d) #11 in track 1 ($01)
[Disk 1] Read Sector 30 ($01e) #12 in track 1 ($01)
[Disk 1] Read Sector 31 ($01f) #13 in track 1 ($01)
[Disk 1] Read Sector 32 ($020) #14 in track 1 ($01)
[Disk 1] Read Sector 33 ($021) #15 in track 1 ($01)
[Disk 1] Read Sector 34 ($022) #16 in track 1 ($01)
[Disk 1] Read Sector 35 ($023) #17 in track 1 ($01)
[Disk 1] Read Sector 36 ($024) #18 in track 1 ($01)
[Disk 1] Read Sector 37 ($025) #1 in track 2 ($02)
[Disk 1] Read Sector 38 ($026) #2 in track 2 ($02)
[Disk 1] Read Sector 39 ($027) #3 in track 2 ($02)
[Disk 1] Read Sector 40 ($028) #4 in track 2 ($02)
[Disk 1] Read Sector 41 ($029) #5 in track 2 ($02)
[Disk 1] Read Sector 42 ($02a) #6 in track 2 ($02)
[Disk 1] Read Sector 43 ($02b) #7 in track 2 ($02)
[Disk 1] Read Sector 44 ($02c) #8 in track 2 ($02)
[Disk 1] Read Sector 45 ($02d) #9 in track 2 ($02)
[Disk 1] Read Sector 46 ($02e) #10 in track 2 ($02)
[Disk 1] Read Sector 47 ($02f) #11 in track 2 ($02)
[Disk 1] Read Sector 48 ($030) #12 in track 2 ($02)
[Disk 1] Read Sector 49 ($031) #13 in track 2 ($02)
[Disk 1] Read Sector 50 ($032) #14 in track 2 ($02)
[Disk 1] Read Sector 51 ($033) #15 in track 2 ($02)
[Disk 1] Read Sector 52 ($034) #16 in track 2 ($02)
[Disk 1] Read Sector 53 ($035) #17 in track 2 ($02)
[Disk 1] Read Sector 54 ($036) #18 in track 2 ($02)
[Disk 4] command: $53, aux: $0000 ignored. [x4]
[Disk 3] command: $53, aux: $0000 ignored. [x4]
[Disk 2] command: $53, aux: $0000 ignored. [x4]
[Disk 1] Happy Read memory at $9780
[Disk 1] Read Sector 217 ($0d9) #1 in track 12 ($0c)
[Disk 1] Read Sector 218 ($0da) #2 in track 12 ($0c)
[Disk 1] Read Sector 219 ($0db) #3 in track 12 ($0c)
[Disk 1] Read Sector 220 ($0dc) #4 in track 12 ($0c)
[Disk 1] Read Sector 221 ($0dd) #5 in track 12 ($0c)
[Disk 1] Read Sector 222 ($0de) #6 in track 12 ($0c)
[Disk 1] Read Sector 223 ($0df) #7 in track 12 ($0c)
[Disk 1] Read Sector 224 ($0e0) #8 in track 12 ($0c)
[Disk 1] Read Sector 225 ($0e1) #9 in track 12 ($0c)
[Disk 1] Read Sector 226 ($0e2) #10 in track 12 ($0c)
[Disk 1] Read Sector 227 ($0e3) #11 in track 12 ($0c)
[Disk 1] Read Sector 228 ($0e4) #12 in track 12 ($0c)
[Disk 1] Read Sector 229 ($0e5) #13 in track 12 ($0c)
[Disk 1] Read Sector 230 ($0e6) #14 in track 12 ($0c)
[Disk 1] Read Sector 231 ($0e7) #15 in track 12 ($0c)
[Disk 1] Read Sector 232 ($0e8) #16 in track 12 ($0c)
[Disk 1] Read Sector 233 ($0e9) #17 in track 12 ($0c)
[Disk 1] Read Sector 234 ($0ea) #18 in track 12 ($0c)
[Disk 1] Read Sector 235 ($0eb) #1 in track 13 ($0d)
[Disk 1] Read Sector 236 ($0ec) #2 in track 13 ($0d)
[Disk 1] Read Sector 237 ($0ed) #3 in track 13 ($0d)
[Disk 1] Read Sector 238 ($0ee) #4 in track 13 ($0d)
[Disk 1] Read Sector 239 ($0ef) #5 in track 13 ($0d)
[Disk 1] Read Sector 240 ($0f0) #6 in track 13 ($0d)
[Disk 1] Read Sector 241 ($0f1) #7 in track 13 ($0d)
[Disk 1] Read Sector 242 ($0f2) #8 in track 13 ($0d)
[Disk 1] Read Sector 243 ($0f3) #9 in track 13 ($0d)
[Disk 1] Read Sector 244 ($0f4) #10 in track 13 ($0d)
[Disk 1] Read Sector 245 ($0f5) #11 in track 13 ($0d)
[Disk 1] Read Sector 246 ($0f6) #12 in track 13 ($0d)
[Disk 1] Read Sector 247 ($0f7) #13 in track 13 ($0d)
[Disk 1] Read Sector 248 ($0f8) #14 in track 13 ($0d)
[Disk 1] Read Sector 249 ($0f9) #15 in track 13 ($0d)
[Disk 1] Read Sector 250 ($0fa) #16 in track 13 ($0d)
[Disk 1] Read Sector 251 ($0fb) #17 in track 13 ($0d)
[Disk 1] Read Sector 252 ($0fc) #18 in track 13 ($0d)
[Disk 1] Read Sector 253 ($0fd) #1 in track 14 ($0e)
[Disk 1] Read Sector 254 ($0fe) #2 in track 14 ($0e)
[Disk 1] Read Sector 255 ($0ff) #3 in track 14 ($0e)
[Disk 1] Read Sector 256 ($100) #4 in track 14 ($0e)
[Disk 1] Read Sector 257 ($101) #5 in track 14 ($0e)
[Disk 1] Read Sector 258 ($102) #6 in track 14 ($0e)
[Disk 1] Read Sector 259 ($103) #7 in track 14 ($0e)
[Disk 1] Read Sector 260 ($104) #8 in track 14 ($0e)
[Disk 1] Read Sector 261 ($105) #9 in track 14 ($0e)
[Disk 1] Read Sector 262 ($106) #10 in track 14 ($0e)
[Disk 1] Read Sector 263 ($107) #11 in track 14 ($0e)
[Disk 1] Read Sector 264 ($108) #12 in track 14 ($0e)
[Disk 1] Read Sector 265 ($109) #13 in track 14 ($0e)
[Disk 1] Read Sector 266 ($10a) #14 in track 14 ($0e)
[Disk 1] Read Sector 267 ($10b) #15 in track 14 ($0e)
[Disk 1] Read Sector 268 ($10c) #16 in track 14 ($0e)
[Disk 1] Read Sector 269 ($10d) #17 in track 14 ($0e)
[Disk 1] Read Sector 270 ($10e) #18 in track 14 ($0e)
[Disk 1] Read Sector 271 ($10f) #1 in track 15 ($0f)
[Disk 1] Read Sector 272 ($110) #2 in track 15 ($0f)
[Disk 1] Read Sector 273 ($111) #3 in track 15 ($0f)
[Disk 1] Read Sector 274 ($112) #4 in track 15 ($0f)
[Disk 1] Read Sector 275 ($113) #5 in track 15 ($0f)
[Disk 1] Read Sector 276 ($114) #6 in track 15 ($0f)
[Disk 1] Read Sector 277 ($115) #7 in track 15 ($0f)
[Disk 1] Read Sector 278 ($116) #8 in track 15 ($0f)
[Disk 1] Read Sector 279 ($117) #9 in track 15 ($0f)
[Disk 1] Read Sector 280 ($118) #10 in track 15 ($0f)
[Disk 1] Read Sector 281 ($119) #11 in track 15 ($0f)
[Disk 1] Read Sector 282 ($11a) #12 in track 15 ($0f)
[Disk 1] Read Sector 283 ($11b) #13 in track 15 ($0f)
[Disk 1] Read Sector 284 ($11c) #14 in track 15 ($0f)
[Disk 1] Read Sector 285 ($11d) #15 in track 15 ($0f)
[Disk 1] Read Sector 286 ($11e) #16 in track 15 ($0f)
[Disk 1] Read Sector 287 ($11f) #17 in track 15 ($0f)
[Disk 1] Read Sector 288 ($120) #18 in track 15 ($0f)
[Disk 1] Read Sector 289 ($121) #1 in track 16 ($10)
[Disk 1] Read Sector 290 ($122) #2 in track 16 ($10)
[Disk 1] Read Sector 291 ($123) #3 in track 16 ($10)
[Disk 1] Read Sector 292 ($124) #4 in track 16 ($10)
[Disk 1] Read Sector 293 ($125) #5 in track 16 ($10)
[Disk 1] Read Sector 294 ($126) #6 in track 16 ($10)
[Disk 1] Read Sector 295 ($127) #7 in track 16 ($10)
[Disk 1] Read Sector 296 ($128) #8 in track 16 ($10)
[Disk 1] Read Sector 297 ($129) #9 in track 16 ($10)
[Disk 1] Read Sector 298 ($12a) #10 in track 16 ($10)
[Disk 1] Read Sector 299 ($12b) #11 in track 16 ($10)
[Disk 1] Read Sector 300 ($12c) #12 in track 16 ($10)
[Disk 1] Read Sector 301 ($12d) #13 in track 16 ($10)
[Disk 1] Read Sector 302 ($12e) #14 in track 16 ($10)
[Disk 1] Read Sector 303 ($12f) #15 in track 16 ($10)
[Disk 1] Read Sector 304 ($130) #16 in track 16 ($10)
[Disk 1] Read Sector 305 ($131) #17 in track 16 ($10)
[Disk 1] Read Sector 306 ($132) #18 in track 16 ($10)
[Disk 1] Happy Configure drive with AUX $0000
[Disk 1] Read sector $0800 NAKed.
[Disk 1] Happy Read memory at $8000
[Disk 1] Happy High Speed Write memory at $8380
Data frame checksum error, expected: 131, got: 74. (00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000f031778083ac31778083ac31778083ac31778083ac31778083ac31778083ac31778083ac31778083ac31778083ac31778083ac31778083ac31778083ac31778083)
[Disk 1] Sending [ERROR] to Atari
Serial port read timeout.
It can NOT work without a patched version of Happy v7.1.
There is no Happy ATR patched file.
The way it works is that if RespeQt recognize Happy v7.1, it patches on the fly the software as it is read from RespeQt.
But for this to work, you need:
- a genuine Happy v7.1 ATR file so that RespeQt knows it is Happy v7.1
- to boot this ATR file from RespeQt in D1:
And the latest release of RespeQt 4.3 in this thread.
I tried this one
Quote
I did
Quote
I do use 4.3
still won't work ?
Edited by WIZARD.NC8
I am sorry but I don't have any idea why it does not work.
Maybe if someone else could confirm that it is working, maybe he could help you find what is different in you configuration or in your procedure.
Anyway it can only work if you see the second message about the patch on the fly.
You are using 4.3 but is it the latest found in the latest posts of this thread?
11 hours ago, WIZARD.NC8 said:
I tried several Happy 7.1 ATRs, all of them won't be patched on the fly.
So, the problem seems to be right at the start of the procedure, which leads me to the question: are there specific settings at Tools > Options required to make it work?
Could you take snapshot of all the tabs in Options so I can see how it is configured.
If you are not in a hurry, I may have a look at your issue during Christmas holidays.
I need to set up everything (Happy drive, SIO2PC...) and figured out how it is supposed to work (I left the code for 5 to 6 month).
Ping me again if I forget!
Hi together,
Really need the help of the community.
This is my very first post here in the RespeQt forum. I am running out of time and hope, I am right here. Is it possible with RespeQt 4.3 and a Happy drive to make a disk dump near or close to a Kryo or SCP dump? If so, with the RespeQt 4.3 software and how? Sorry, I haven't read the pages 1 through 7, because I am running out of time.
Thank you all so much for your help in advance.
So true for many of us!
  • 3 months later...
  • The topic was locked
