Zendocon Posted June 28, 2019 Share Posted June 28, 2019 I know I'll find out the answer to this by experimentation, but I thought I'd ask ahead of time and save some effort. Does PLAY SIMPLE still play all the ECS channels, leaving only SOUND 2 available, or does it leave SOUND 7 available as well? Would there then be 6 or 7 arguments for MUSIC? Same goes for NO DRUMS. Is it possible to have percussion for one sound chip and not the other? I'm asking because I'm planning to have SOUND 2 be available to play both a tone and noise for a sound effect, while all the other channels and the other percussion are put to use. Thank you for your time. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted June 30, 2019 Author Share Posted June 30, 2019 In ECS mode: PLAY SIMPLE leaves SOUND 2 and 7 available. PLAY SIMPLE NO DRUMS also ceases to play drums in both chips. Didn't think on that. Sorry! I'll devise something for next version. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted July 2, 2019 Author Share Posted July 2, 2019 Just noticed in the manual for IntyBASIC v1.4.1 that I did a mistake, I described BITMAP REVERSE, when the right thing is BITMAP INVERSE. The compiler is right, the posts in this thread are right, but only the included manual has this slight mistake. Just heads up. I know that no one ever reads the manuals 1 Quote Link to comment Share on other sites More sharing options...
carlsson Posted December 18, 2019 Share Posted December 18, 2019 (edited) Regarding the PLAY function, does it somehow support having multiple songs and dynamically select which one to play? I see in the manual that label can be a 16-bits array for dynamically generated music but I don't think that is what I am trying to do. Basically I have this code: song_pointers: DATA VARPTR song1(0) DATA VARPTR song2(0) ... DATA VARPTR song9(0) When I tried to use PLAY song_pointers(x), it would try to read the data at that address as music, not as an indirect pointer. In the mean time, I came up with a workaround: #ptr = song_pointers(x) ASM MVI var_&PTR,R0 ASM CALL _play_music which of course works with minimal overhead. Perhaps this is a use case nobody else would have use of? Not sure what it would be called, PLAY VARPTR? Edited December 18, 2019 by carlsson 2 Quote Link to comment Share on other sites More sharing options...
First Spear Posted June 8, 2020 Share Posted June 8, 2020 On 6/12/2019 at 2:44 PM, nanochess said: Update to version 1.4.1, check first post. Changes, enhancements and fixes in v1.4.1: o Added BITMAP NORMAL, BITMAP INVERSE and BITMAP MIRROR_X to ease reusing BITMAP statements in Color Stack mode. o Optimizes POKE to direct address with a single MVO. o Solved bug in local labels preceded with comma, it required a space. o Solved bug compiling nn = (varptr sfx2_v(0)-varptr sfx2_n(0))-sfxstep o Solved bug in MUSIC.PLAYING (relative to new music format) o Solved bug in music player because new _ntsc interpretation. o Solved crash bug in drums for ECS side of music player. Is there an example of the BITMAP NORMAL/INVERSE/MIRROR statements I can try? Thanks. Quote Link to comment Share on other sites More sharing options...
carlsson Posted June 8, 2020 Share Posted June 8, 2020 @First Spear, it is not any more complex than this: BITMAP INVERSE BITMAP ".oo.oo.." BITMAP "ooooooo." BITMAP "ooooooo." BITMAP "ooooooo." BITMAP ".ooooo.." BITMAP "..ooo..." BITMAP "...o...." BITMAP "........" BITMAP NORMAL BITMAP "...o...." BITMAP "..ooo..." BITMAP ".ooooo.." BITMAP "ooooooo." BITMAP "ooooooo." BITMAP "..ooo..." BITMAP ".ooooo.." BITMAP "........" Basically it allows you to change a pattern at compile time so you can use foreground as background and vice versa. I don't think it is dynamic in any way, so you could flip an already defined GRAM, if that is something you'd want to do. 2 Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted June 14, 2020 Share Posted June 14, 2020 Just a quick note that the IntyBASIC SDK has been updated with the latest version of the compiler (1.4.1) and even a Mac Edition. -dZ. 3 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted August 20, 2020 Author Share Posted August 20, 2020 Just updated IntyBASIC to v1.4.2 in time for the new IntyBASIC 2020 Programming Contest!!! 3 Quote Link to comment Share on other sites More sharing options...
+cmadruga Posted August 20, 2020 Share Posted August 20, 2020 11 hours ago, nanochess said: Just updated IntyBASIC to v1.4.2 in time for the new IntyBASIC 2020 Programming Contest!!! Man, you are ON FIRE! 2 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted August 20, 2020 Author Share Posted August 20, 2020 (edited) 12 minutes ago, cmadruga said: Man, you are ON FIRE! Maybe in slow fire because it has been cooking for almost one year! ? Edited August 20, 2020 by nanochess Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted August 22, 2020 Share Posted August 22, 2020 On 8/19/2020 at 11:26 PM, nanochess said: Just updated IntyBASIC to v1.4.2 in time for the new IntyBASIC 2020 Programming Contest!!! Damn, just when I thought I quit. ? *sigh* Updated IntyBASIC SDK coming out this week-end in time for the contest ... Really, the things you make me do. :P -dZ. 2 Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted August 24, 2020 Share Posted August 24, 2020 Just in time for the programming contest, I've updated the IntyBASIC SDK to include the latest, bleeding edge IntyBASIC and development tools -- fresh off the oven! https://atariage.com/forums/topic/240526-introducing-the-intybasic-sdk/ This version includes a new "miniecs.bin" and the tools have been updated to include it automatically when loading the emulator, so you can run your ECS-enabled IntyBASIC. -dZ. 2 Quote Link to comment Share on other sites More sharing options...
Kiwi Posted November 25, 2020 Share Posted November 25, 2020 (edited) I found a small Intybasic bug that I can't map at $c100. It doesn't show up in the .cfg file. I used to be able to map data to that segment at $c100 using older version of Intybasic. Small work around is to map at $c200. I'm not sure if I'm alone with the issue, I'm using the latest Intybasic version. EDIT: I may be over in segment $A000-$BFFF, so that's why it's not mapping at $C100. EDIT2: It been confirmed I was over that segment. It's now all fixed. Edited November 25, 2020 by Kiwi Running in circle. 2 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted November 27, 2020 Share Posted November 27, 2020 I am trying to make some math involving VARPTR and DATA but I get errors... Is there a way to define this DATA VARPTR #roomattr0(0)-8*20 DATA VARPTR #roomattr1(0)-8*20 DATA VARPTR #roomattr2(0)-6*20 The expression in normal expressions is valid. Only DATA does not accept it! Quote Link to comment Share on other sites More sharing options...
+nanochess Posted November 27, 2020 Author Share Posted November 27, 2020 22 minutes ago, artrag said: I am trying to make some math involving VARPTR and DATA but I get errors... Is there a way to define this DATA VARPTR #roomattr0(0)-8*20 DATA VARPTR #roomattr1(0)-8*20 DATA VARPTR #roomattr2(0)-6*20 The expression in normal expressions is valid. Only DATA does not accept it! Use this: DATA VARPTR #roomattr0(-8*20) DATA VARPTR #roomattr1(-8*20) DATA VARPTR #roomattr2(-6*20) 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted November 28, 2020 Share Posted November 28, 2020 I had just found the same right now Thanks! 1 Quote Link to comment Share on other sites More sharing options...
Kiwi Posted November 30, 2020 Share Posted November 30, 2020 I want to report a typo in the >>>>>>>>>>>>>> Real number of variables allowed It said, "Substract 26 if you use PLAY", but it takes 28 8-bit bytes. Leaving the total of 200 bytes for the users. 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted November 30, 2020 Author Share Posted November 30, 2020 14 hours ago, Kiwi said: I want to report a typo in the >>>>>>>>>>>>>> Real number of variables allowed It said, "Substract 26 if you use PLAY", but it takes 28 8-bit bytes. Leaving the total of 200 bytes for the users. I've updated the manual in the Git https://github.com/nanochess/IntyBASIC/blob/master/intybasic/manual.txt 1 Quote Link to comment Share on other sites More sharing options...
First Spear Posted December 17, 2020 Share Posted December 17, 2020 I am trying to put a music gosub inside of a for...next loop to play the same segment 3 times. Has anyone tried to do that? I cannot get it to work. Thanks. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted December 18, 2020 Author Share Posted December 18, 2020 3 hours ago, First Spear said: I am trying to put a music gosub inside of a for...next loop to play the same segment 3 times. Has anyone tried to do that? I cannot get it to work. Thanks. MUSIC GOSUB is only of use inside a MUSIC block, cannot be mixed with IntyBASIC statements. Quote Link to comment Share on other sites More sharing options...
First Spear Posted December 18, 2020 Share Posted December 18, 2020 1 hour ago, nanochess said: MUSIC GOSUB is only of use inside a MUSIC block, cannot be mixed with IntyBASIC statements. Maybe a MUSIC LOOP for the next version? 1 Quote Link to comment Share on other sites More sharing options...
carlsson Posted December 18, 2020 Share Posted December 18, 2020 You already have MUSIC JUMP, MUSIC GOSUB and MUSIC REPEAT. If you compose your music with a fixed number of repeats, you can unroll those. For added complexity, I can imagine MUSIC QUEUE that would tell the player that once it reaches MUSIC STOP, it should immediately tag onto the next song, but I would imagine it has a rather limited use. You can of course PEEK through the music variables for added features. Up till now, I still don't know anyone who has integrated Arnaud's tracker with IntyBASIC. I imagine me or DZ-Jay are most likely to do that, though the player uses a good amount of 16-bit variables so it could be a tight fit without CC3/JLP extension. 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted December 18, 2020 Share Posted December 18, 2020 (edited) Question: is there an efficient way to do a function doing this YEvent:procedure 'YEvent(ys,ya) ' input ys,ya if (ya and 1) then yr = #Interaction(ys*2 + ((ya/2) and 1))/256 else yr = #Interaction(ys*2 + ((ya/2) and 1))and 255 end if end I did this: DEF FN XEvent(s,a) = (#Interact(s*2 + ((a/2) and 1))/((a and 1)*255 + 1)) and 255 but it is way too slow for its purpose Edited December 18, 2020 by artrag Quote Link to comment Share on other sites More sharing options...
carlsson Posted December 18, 2020 Share Posted December 18, 2020 Is a/2 compiled into a single SLR/SAR instruction? I was trying to think if ((a/2) and 1) equals ((a and 2)-1) but shift is faster than decrease it seems. Quote Link to comment Share on other sites More sharing options...
First Spear Posted December 18, 2020 Share Posted December 18, 2020 4 hours ago, carlsson said: You already have MUSIC JUMP, MUSIC GOSUB and MUSIC REPEAT. If you compose your music with a fixed number of repeats, you can unroll those. For added complexity, I can imagine MUSIC QUEUE that would tell the player that once it reaches MUSIC STOP, it should immediately tag onto the next song, but I would imagine it has a rather limited use. You can of course PEEK through the music variables for added features. Up till now, I still don't know anyone who has integrated Arnaud's tracker with IntyBASIC. I imagine me or DZ-Jay are most likely to do that, though the player uses a good amount of 16-bit variables so it could be a tight fit without CC3/JLP extension. The number of folks that have the mental agility and Inty expertise to do this are fairly low. Maybe 4 of you? 5? Anyway, it would be fun to have the extra functionality from Arnauld's tracker, maybe call it MUSIC2 or MUSICA commands? Quote Link to comment Share on other sites More sharing options...
