lucifershalo Posted January 22, 2019 Share Posted January 22, 2019 Hello years ago someone modified my Astrocade and installed a svideo output th eother side of the cable is svideo too and is working on my small multistandard tv I would like to use on my flat screen that has as input composite, scart, hdmi, I have a modified Intellivision that plugs inside the console a svideo and has rca on the other side, it doesnt work with the AStrocade do you know what I could do to be able to, play the console on my flat screen? thanks I am not a big tech guy;) Quote Link to comment Share on other sites More sharing options...
ballyalley Posted January 22, 2019 Share Posted January 22, 2019 [...] modified my Astrocade and installed a svideo output [...] I would like to use on my flat screen that has as input composite, scart, hdmi, do you know what I could do to be able to, play the console on my flat screen? I live in the U.S., so I haven't done this before, but I would suggest an S-video to composite adapter, like this one: https://www.startech.com/Cables/Audio-Video/Legacy/6in-S-Video-to-Composite-Video-Adapter-Cable~SVID2COMP You can also get s-video to hdmi adapter quite cheaply too. Neither is an ideal fix, as your flatscreen will probably introduce some timing issues. That is, there will be a very-slight delay between when you press a joystick direction and when you get a response on the screen. For the price of one of these adapters (usually $10-$20), it's worth a try. Let us know how it goes. Adam Quote Link to comment Share on other sites More sharing options...
lucifershalo Posted January 23, 2019 Author Share Posted January 23, 2019 ok thanks I will try Quote Link to comment Share on other sites More sharing options...
carlsson Posted February 5, 2019 Share Posted February 5, 2019 If your TV has two SCART inputs, the second one might be configured or possible to reconfigure in menus to take S-Video instead of RGB. It would mean you need a passive S-Video to SCART adapter, but it will only work if the input is configured as such. TV's with only one SCART tend to only support RGB input, and since yours is so new it might only have one of those fairly legacy inputs. Quote Link to comment Share on other sites More sharing options...
+adamchevy Posted February 7, 2020 Share Posted February 7, 2020 Does anyone know if anyone offers an AV mod service for Svideo or RGB for the Astrocade? Quote Link to comment Share on other sites More sharing options...
drphilxr Posted September 11, 2021 Share Posted September 11, 2021 On 2/7/2020 at 12:20 AM, adamchevy said: Does anyone know if anyone offers an AV mod service for Svideo or RGB for the Astrocade? I would love this too...a few other posts here over the years, but i can't seem to find info on ballyally.com. RF works "ok" on new LCD TVs with that input. I wonder if its hard to do a sort of "rgb2hdmi" like the amiga line has now, as the video output has R-Y, B-Y, and a 2.5V "Resistor ladder" that outputs video to the modulator. Quote Link to comment Share on other sites More sharing options...
+GoldLeader Posted September 12, 2021 Share Posted September 12, 2021 (edited) On 1/22/2019 at 12:27 PM, lucifershalo said: Hello years ago someone modified my Astrocade and installed a svideo output th eother side of the cable is svideo too and is working on my small multistandard tv I would like to use on my flat screen that has as input composite, scart, hdmi, I have a modified Intellivision that plugs inside the console a svideo and has rca on the other side, it doesnt work with the AStrocade do you know what I could do to be able to, play the console on my flat screen? thanks I am not a big tech guy;) In case you're still looking for a solution; A Retro Tink 2X Mini or Retro Tink 2X Pro would probably look pretty good and it's a true line doubler...If you can spend the dough (Damn! I didn't realize how expensive these have gotten!)...Plus it will work with many other systems and set ups Like so: https://www.ebay.com/itm/313170047084?hash=item48ea63b06c:g:iGUAAOSwSGtfJ00K or https://www.ebay.com/itm/313348689243?hash=item48f5098d5b:g:5BIAAOSwfVhf3Hvu Or maybe... https://www.ebay.com/itm/174740559628?ssPageName=STRK%3AMEBIDX%3AIT&var=473919652655&_trksid=p2060353.m1438.l2649 Edited September 12, 2021 by GoldLeader Oh, I Totally misread the date on this post! Whoops! I'll still leave this here in case anyone else needs it :) Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted September 28, 2021 Share Posted September 28, 2021 On 9/12/2021 at 3:50 AM, GoldLeader said: In case you're still looking for a solution; A Retro Tink 2X Mini or Retro Tink 2X Pro would probably look pretty good and it's a true line doubler...If you can spend the dough (Damn! I didn't realize how expensive these have gotten!). Not as expensive if you just order them directly from Mike Chi himself. Tink2x Pro: https://www.retrotink.com/product-page/retrotink-2x-pro Tink2x Mini: https://www.retrotink.com/product-page/2x-mini Another reason to always shop around. However, I wouldn't wait on getting Tink2x devices. Word on the street is that Mike Chi doesn't plan to restock or have anymore of his Tink2x product lines made once they sell out. This is so he can focus on just the Tink5x product itself. Makes sense, but I do think the Tink2x is a better solution for the pre 16-bit era consoles from the testing I've done. So it will be sad to see the Tink2x line fade away. Quote Link to comment Share on other sites More sharing options...
